#include #include // Erforderlich fuer getch() #include #include // Entfernen oder ersetzen, falls die Kompilierung unter Linux #include "ftd2xx.h" // Offizielle Header-Datei FTDI #include #define FT232H_INDEX 0 // Geraeteindex (0 - erster angeschlossener Chip FTDI) // Funktion zum Senden von Befehlen an den Puffer MPSSE FT_STATUS Send_Commands(FT_HANDLE ftHandle, BYTE* buffer, DWORD size) { DWORD bytesWritten = 0; FT_STATUS status = FT_Write(ftHandle, buffer, size, &bytesWritten); if (status != FT_OK || bytesWritten != size) { printf("[!] MPSSE Aktivierung fehlgeschlagen.\n"); return FT_OTHER_ERROR; } return FT_OK; } int main() { FT_HANDLE ftHandle; FT_STATUS ftStatus; BYTE txBuffer[64]; BYTE rxBuffer[4]; DWORD dwBytesRead = 0; DWORD idx = 0; DWORD driverVersion = 0; FT_DEVICE_LIST_INFO_NODE* devInfo; DWORD numDevs; printf("=== Reading JTAG IDCODE via FT232H (MPSSE) ===\n\n"); // 1. oeffnen des Geraets FT232H ftStatus = FT_Open(FT232H_INDEX, &ftHandle); if (ftStatus != FT_OK) { printf("[!] Fehler: FT232H konnte nicht geoeffnet werden. (Status: %d)\n", (int)ftStatus); return 1; } assert(ftHandle != NULL); ftStatus = FT_GetDriverVersion(ftHandle, &driverVersion); if (ftStatus != FT_OK) { printf("Failure. FT_GetDriverVersion returned %d.\n", (int)ftStatus); //goto exit; return 1; } printf("D2XX version : %x.%x.%x\n", (unsigned int)((driverVersion & 0x00FF0000) >> 16), (unsigned int)((driverVersion & 0x0000FF00) >> 8), (unsigned int)(driverVersion & 0x000000FF) ); // create the device information list ftStatus = FT_CreateDeviceInfoList(&numDevs); if (ftStatus == FT_OK) { printf("Number of devices is %d\n", numDevs); } if (numDevs > 0) { // allocate storage for list based on numDevs devInfo = (FT_DEVICE_LIST_INFO_NODE*)malloc(sizeof(FT_DEVICE_LIST_INFO_NODE) * numDevs); // get the device information list ftStatus = FT_GetDeviceInfoList(devInfo, &numDevs); if (ftStatus == FT_OK) { for (int i = 0; i < numDevs; i++) { printf("Dev %d:\n", i); printf(" Flags=0x%x\n", devInfo[i].Flags); printf(" Type=0x%x\n", devInfo[i].Type); printf(" ID=0x%x\n", devInfo[i].ID); printf(" LocId=0x%x\n", devInfo[i].LocId); printf(" SerialNumber=%s\n", devInfo[i].SerialNumber); printf(" Description=%s\n\n", devInfo[i].Description); } } } // 2. USB-Reset und Basiskonfiguration FT_ResetDevice(ftHandle); FT_SetUSBParameters(ftHandle, 65536, 65536); // Puffergroeße 64КБ FT_SetChars(ftHandle, 0, 0, 0, 0); // Deaktivieren von Sonderzeichen FT_SetTimeouts(ftHandle, 1000, 1000); // Lese-/Schreib-Timeouts: 1 Sek. FT_SetLatencyTimer(ftHandle, 1); // Minimale Latenz: 1 ms // 3. Modusaktivierung MPSSE FT_SetBitMode(ftHandle, 0x00, 0x00); // Pin-Controller-Reset Sleep(50); ftStatus = FT_SetBitMode(ftHandle, 0x00, 0x02); // Aktivieren des Modus MPSSE (0x02) if (ftStatus != FT_OK) { printf("[!] MPSSE Aktivierung fehlgeschlagen.\n"); FT_Close(ftHandle); return 1; } Sleep(50); // Warten auf Stabilisierung MPSSE // 4. Echotest zur Motorsynchronisation MPSSE idx = 0; txBuffer[idx++] = 0xAB; // Senden eines ungueltigen Befehls MPSSE if (Send_Commands(ftHandle, txBuffer, idx) != FT_OK) goto cleanup; Sleep(10); FT_GetQueueStatus(ftHandle, &dwBytesRead); if (dwBytesRead > 0) { FT_Read(ftHandle, rxBuffer, dwBytesRead, &dwBytesRead); // Wir ueberprüfen, ob das MPSSE den Fehler 0xFA sowie unser Befehlsbyte 0xAB zurückgegeben hat. if (rxBuffer[0] != 0xFA || rxBuffer[1] != 0xAB) { printf("[!] MPSSE Echo Test Synchronization Error.\n"); goto cleanup; } } else { printf("[!] The MPSSE engine is unresponsive. Check the device driver.\n"); goto cleanup; } // 5. Konfiguration der Pin-Richtung JTAG // AD0(TCK)=Output(1), AD1(TDI)=Output(1), AD2(TDO)=Input(0), AD3(TMS)=Output(1) // Richtung: 0x0B (00001011in binaerer Form) idx = 0; txBuffer[idx++] = 0x80; // Befehl: Downstream-Port konfigurieren (ADBUS) txBuffer[idx++] = 0x00; // Anfaengliche Pin-Werte (alle in 0) txBuffer[idx++] = 0x0B; // Pin-Richtung // Taktfrequenzkonfiguration TCK (Installation eines 6-MHz-Teilers zur Stabilisierung) txBuffer[idx++] = 0x8A; // Deaktivieren Sie den internen ÷5-Teiler (Basisfrequenz: 60 MHz). txBuffer[idx++] = 0x86; // Befehl: TCK-Frequenzteiler setzen txBuffer[idx++] = 0x04; // Teiler fuer das untere Byte: Frequenz = 60МГц / ((1 + 4) * 2) = 6 МГц txBuffer[idx++] = 0x00; // Teiler High Byte if (Send_Commands(ftHandle, txBuffer, idx) != FT_OK) goto cleanup; // 6. JTAG-TAP-Controller-Reset (Übergang in den Zustand „Test-Logic-Reset“) // Gemaeß dem JTAG-Standard wird der Schutzschalter zurueckgesetzt, wenn TMS=1 für 5 TCK-Zyklen gehalten wird. // und der Zielchip wird seinen IDCODE automatisch in das Datenregister (DR) übernehmen. idx = 0; txBuffer[idx++] = 0x4B; // MPSSE-Befehl: Bits auf der TMS-Leitung uebertragen (ohne Auslesen) txBuffer[idx++] = 0x04; // Anzahl der Bits minus 1 (0x04 bedeutet 5 Bits) txBuffer[idx++] = 0xFF; // Bitwerte (TMS = 1,1,1,1,1) if (Send_Commands(ftHandle, txBuffer, idx) != FT_OK) goto cleanup; // 7. Übergang des endlichen Automaten in den Zustand Shift-DR zum Auslesen des Datenregisters. // Bitsequenz TMS: 0 (in Run-Test/Idle), 1 (in Select-DR-Scan), 0 (in Capture-DR), 0 (in Shift-DR) // TMS-Binaersequenz (vom Ende her): 0010 -> 0x02 (Uebertragung von 4 Bits) idx = 0; txBuffer[idx++] = 0x4B; txBuffer[idx++] = 0x03; // Количество бит минус 1 (4 бита) txBuffer[idx++] = 0x02; // Значение бит TMS if (Send_Commands(ftHandle, txBuffer, idx) != FT_OK) goto cleanup; // 8. Auslesen des 32-Bit- (4-Byte-) IDCODE aus dem Datenregister (TDO) // Wir verwenden den Befehl fuer gleichzeitiges Takten und Byte-Lesen. idx = 0; txBuffer[idx++] = 0x24; // MPSSE-Befehl: Bytes an der fallenden Flanke von TCK lesen (MSB/LSB haengt vom Chip ab; typischerweise LSB zuerst). txBuffer[idx++] = 0x03; // Anzahl der Bytes minus 1 (0x03 bedeutet 4 Bytes) txBuffer[idx++] = 0x00; if (Send_Commands(ftHandle, txBuffer, idx) != FT_OK) goto cleanup; // Warten auf den Puffer vom PC und Auslesen des Puffers dwBytesRead = 0; int timeout = 100; while (dwBytesRead < 4 && timeout-- > 0) { FT_GetQueueStatus(ftHandle, &dwBytesRead); Sleep(5); } if (dwBytesRead >= 4) { FT_Read(ftHandle, rxBuffer, 4, &dwBytesRead); // Wandle die Bytes in eine 32-Bit-Zahl um. unsigned int idcode = (rxBuffer[3] << 24) | (rxBuffer[2] << 16) | (rxBuffer[1] << 8) | rxBuffer[0]; if (idcode == 0x00000000 || idcode == 0xFFFFFFFF) { printf("[!] Error: Invalid value read. IDCODE: 0x%08X\n", idcode); printf("Check the quality of the connections, the wire lengths, and the power supply to the target board.\n"); } else { printf("========================================\n"); printf("SUCCESS! Device responded via JTAG.\n"); printf("========================================\n"); printf("Read IDCODE: 0x%08X\n", idcode); printf("----------------------------------------\n"); printf("Die Revision (Version): 0x%X\n", (idcode >> 28) & 0xF); printf("Device Code (Part ID): 0x%04X\n", (idcode >> 12) & 0xFFFF); printf("ID manufacturer (MFG ID): 0x%03X\n", (idcode >> 1) & 0x7FF); printf("========================================\n"); } } else { printf("[!] Failed to read 4 bytes of IDCODE from the device. (Таймаут).\n"); } cleanup: // Eine Sitzung beenden mit FTDI FT_SetBitMode(ftHandle, 0x00, 0x00); // Zuruecksetzen des MPSSE-Modus auf Standard-UART FT_Close(ftHandle); printf("\nThe program has finished. Press any key to exit..."); getch(); // Warte auf Tastendruck... return 0; }
