""" Waveshare 2.9" e-Paper V2 driver for MicroPython on Raspberry Pi Pico. V2 adaptation of the original V1 driver. Compatible with Waveshare epd2in9_V2.py command flow. Controller: SSD1680 / UC8151-compatible command set used by Waveshare V2 This version intentionally keeps the original V1 architecture and only adapts: - init sequence - LUT handling - refresh/update flow - busy handling API compatibility: EPD(spi, cs, dc, rst, busy) init() clear() draw_text(x, y, text) show() sleep() """ from micropython import const from time import sleep_ms, ticks_ms, ticks_diff import ustruct import framebuf EPD_WIDTH = const(128) EPD_HEIGHT = const(296) # V2 modules are usually busy=1 while processing BUSY = const(1) # Commands (same family as original V1 driver) DRIVER_OUTPUT_CONTROL = const(0x01) BOOSTER_SOFT_START_CONTROL = const(0x0C) DEEP_SLEEP_MODE = const(0x10) DATA_ENTRY_MODE_SETTING = const(0x11) SW_RESET = const(0x12) MASTER_ACTIVATION = const(0x20) DISPLAY_UPDATE_CONTROL_1 = const(0x21) DISPLAY_UPDATE_CONTROL_2 = const(0x22) WRITE_RAM = const(0x24) WRITE_VCOM_REGISTER = const(0x2C) WRITE_LUT_REGISTER = const(0x32) SET_DUMMY_LINE_PERIOD = const(0x3A) SET_GATE_TIME = const(0x3B) BORDER_WAVEFORM_CONTROL = const(0x3C) SET_RAM_X_ADDRESS_START_END_POSITION = const(0x44) SET_RAM_Y_ADDRESS_START_END_POSITION = const(0x45) SET_RAM_X_ADDRESS_COUNTER = const(0x4E) SET_RAM_Y_ADDRESS_COUNTER = const(0x4F) TERMINATE_FRAME_READ_WRITE = const(0xFF) class EPDTimeout(Exception): pass class EPD: # LUT from Waveshare epd2in9_V2.py LUT_FULL_UPDATE = bytearray([ 0x80,0x60,0x40,0x00,0x00,0x10,0x60,0x20, 0x00,0x00,0x80,0x60,0x40,0x00,0x00,0x10, 0x60,0x20,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00 ]) LUT_PARTIAL_UPDATE = bytearray([ 0x00,0x40,0x00,0x00,0x00,0x10,0x00,0x00, 0x00,0x00,0x80,0x80,0x00,0x00,0x00,0x20, 0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00 ]) def __init__(self, spi, cs, dc, rst, busy): self.spi = spi self.cs = cs self.dc = dc self.rst = rst self.busy = busy self.cs.init(self.cs.OUT, value=1) self.dc.init(self.dc.OUT, value=0) self.rst.init(self.rst.OUT, value=0) self.busy.init(self.busy.IN) self.width = EPD_WIDTH self.height = EPD_HEIGHT self.buffer = bytearray(self.width * self.height // 8) self.fb = framebuf.FrameBuffer( self.buffer, self.width, self.height, framebuf.MONO_HLSB ) self.clear() # --------------------------------------------------------- # low level SPI # --------------------------------------------------------- def _command(self, command, data=None): self.dc(0) self.cs(0) self.spi.write(bytearray([command])) self.cs(1) if data is not None: self._data(data) def _data(self, data): self.dc(1) self.cs(0) if isinstance(data, int): self.spi.write(bytearray([data])) else: self.spi.write(data) self.cs(1) # --------------------------------------------------------- # busy handling # --------------------------------------------------------- def wait_until_idle(self, timeout_ms=15000): start = ticks_ms() while self.busy.value() == BUSY: if ticks_diff(ticks_ms(), start) > timeout_ms: raise EPDTimeout("e-Paper BUSY timeout") sleep_ms(20) # --------------------------------------------------------- # reset # --------------------------------------------------------- def reset(self): self.rst(0) sleep_ms(200) self.rst(1) sleep_ms(200) # --------------------------------------------------------- # LUT # --------------------------------------------------------- def set_lut(self, lut): self._command(WRITE_LUT_REGISTER, lut) # --------------------------------------------------------- # init # --------------------------------------------------------- def init(self): self.reset() self.wait_until_idle() self._command(SW_RESET) self.wait_until_idle() # Driver output control self._command( DRIVER_OUTPUT_CONTROL, ustruct.pack("> 3) & 0xFF, (x_end >> 3) & 0xFF ]) ) self._command( SET_RAM_Y_ADDRESS_START_END_POSITION, ustruct.pack("> 3) & 0xFF])) self._command( SET_RAM_Y_ADDRESS_COUNTER, ustruct.pack("> 3 tmp = bytearray(stride * 8) tmp_fb = framebuf.FrameBuffer( tmp, src_w, 8, framebuf.MONO_HLSB ) tmp_fb.fill(1) tmp_fb.text(text, 0, 0, 0) x0 = int(x) y0 = int(y) for ty in range(8): for tx in range(src_w): if tmp_fb.pixel(tx, ty) == 0: self.fb.fill_rect( x0 + tx * scale, y0 + ty * scale, scale, scale, color, )
