  "board": {
    "3dviewports": [],
    "design_settings": {
      "defaults": {
        "apply_defaults_to_fp_barcodes": false,
        "apply_defaults_to_fp_dimensions": false,
        "apply_defaults_to_fp_fields": false,
        "apply_defaults_to_fp_shapes": false,
        "apply_defaults_to_fp_text": false,
        "board_outline_line_width": 0.05,
        "copper_line_width": 0.2,
        "copper_text_italic": false,
        "copper_text_size_h": 1.5,
        "copper_text_size_v": 1.5,
        "copper_text_thickness": 0.3,
        "copper_text_upright": false,
        "courtyard_line_width": 0.05,
        "dimension_precision": 4,
        "dimension_units": 3,
        "dimensions": {
          "arrow_length": 1270000,
          "extension_offset": 500000,
          "keep_text_aligned": true,
          "suppress_zeroes": true,
          "text_position": 0,
          "units_format": 0
        "fab_line_width": 0.1,
        "fab_text_italic": false,
        "fab_text_size_h": 1.0,
        "fab_text_size_v": 1.0,
        "fab_text_thickness": 0.15,
        "fab_text_upright": false,
        "other_line_width": 0.1,
        "other_text_italic": false,
        "other_text_size_h": 1.0,
        "other_text_size_v": 1.0,
        "other_text_thickness": 0.15,
        "other_text_upright": false,
        "pads": {
          "drill": 0.0,
          "height": 1.0,
          "width": 1.0
        "silk_line_width": 0.1,
        "silk_text_italic": false,
        "silk_text_size_h": 1.0,
        "silk_text_size_v": 1.0,
        "silk_text_thickness": 0.1,
        "silk_text_upright": false,
        "zones": {
          "border_display_style": 2,
          "border_hatch_pitch": 0.5,
          "corner_radius": 0.0,
          "corner_smoothing": 0,
          "fill_mode": 0,
          "hatch_gap": 1.5,
          "hatch_orientation": 0.0,
          "hatch_smoothing_level": 0,
          "hatch_smoothing_value": 0.1,
          "hatch_thickness": 1.0,
          "min_clearance": 0.5,
          "min_island_area": 10.0,
          "min_thickness": 0.25,
          "pad_connection": 1,
          "remove_islands": 0,
          "thermal_relief_gap": 0.5,
          "thermal_relief_spoke_width": 0.5
      "diff_pair_dimensions": [
          "gap": 0.0,
          "via_gap": 0.0,
          "width": 0.0
      "drc_exclusions": [],
      "meta": {
        "version": 2
      "rule_severities": {
        "annular_width": "error",
        "clearance": "error",
        "connection_width": "warning",
        "copper_edge_clearance": "error",
        "copper_sliver": "warning",
        "courtyards_overlap": "error",
        "creepage": "error",
        "diff_pair_gap_out_of_range": "error",
        "diff_pair_uncoupled_length_too_long": "error",
        "drill_out_of_range": "error",
        "duplicate_footprints": "warning",
        "extra_footprint": "warning",
        "footprint": "error",
        "footprint_filters_mismatch": "ignore",
        "footprint_symbol_field_mismatch": "warning",
        "footprint_symbol_mismatch": "warning",
        "footprint_type_mismatch": "ignore",
        "hole_clearance": "error",
        "hole_to_hole": "warning",
        "holes_co_located": "warning",
        "invalid_outline": "error",
        "isolated_copper": "warning",
        "item_on_disabled_layer": "error",
        "items_not_allowed": "error",
        "length_out_of_range": "error",
        "lib_footprint_issues": "warning",
        "lib_footprint_mismatch": "warning",
        "malformed_courtyard": "error",
        "microvia_drill_out_of_range": "error",
        "mirrored_text_on_front_layer": "warning",
        "missing_courtyard": "ignore",
        "missing_footprint": "warning",
        "missing_tuning_profile": "warning",
        "net_conflict": "warning",
        "nonmirrored_text_on_back_layer": "warning",
        "npth_inside_courtyard": "error",
        "padstack": "warning",
        "pth_inside_courtyard": "error",
        "shorting_items": "error",
        "silk_edge_clearance": "warning",
        "silk_over_copper": "warning",
        "silk_overlap": "warning",
        "skew_out_of_range": "error",
        "solder_mask_bridge": "error",
        "starved_thermal": "error",
        "text_height": "warning",
        "text_on_edge_cuts": "error",
        "text_thickness": "warning",
        "through_hole_pad_without_hole": "error",
        "too_many_vias": "error",
        "track_angle": "error",
        "track_dangling": "warning",
        "track_not_centered_on_via": "ignore",
        "track_on_post_machined_layer": "error",
        "track_segment_length": "error",
        "track_width": "error",
        "tracks_crossing": "error",
        "tuning_profile_track_geometries": "ignore",
        "unconnected_items": "error",
        "unresolved_variable": "error",
        "via_dangling": "warning",
        "zones_intersect": "error"
      "rules": {
        "max_error": 0.005,
        "min_clearance": 0.0,
        "min_connection": 0.0,
        "min_copper_edge_clearance": 0.5,
        "min_groove_width": 0.0,
        "min_hole_clearance": 0.25,
        "min_hole_to_hole": 0.25,
        "min_microvia_diameter": 0.2,
        "min_microvia_drill": 0.1,
        "min_resolved_spokes": 2,
        "min_silk_clearance": 0.0,
        "min_text_height": 0.8,
        "min_text_thickness": 0.08,
        "min_through_hole_diameter": 0.3,
        "min_track_width": 0.2,
        "min_via_annular_width": 0.1,
        "min_via_diameter": 0.5,
        "solder_mask_to_copper_clearance": 0.0,
        "use_height_for_length_calcs": true
      "teardrop_options": [
          "td_onpthpad": true,
          "td_onroundshapesonly": false,
          "td_onsmdpad": true,
          "td_ontrackend": false,
          "td_onvia": true
      "teardrop_parameters": [
          "td_allow_use_two_tracks": true,
          "td_curve_segcount": 0,
          "td_height_ratio": 1.0,
          "td_length_ratio": 0.5,
          "td_maxheight": 2.0,
          "td_maxlen": 1.0,
          "td_on_pad_in_zone": false,
          "td_target_name": "td_round_shape",
          "td_width_to_size_filter_ratio": 0.9
          "td_maxlen": 1.0,
          "td_target_name": "td_rect_shape",
          "td_maxlen": 1.0,
          "td_target_name": "td_track_end",
      "track_widths": [
        0.0,
        0.3,
        1.0
      "tuning_pattern_settings": {
        "diff_pair_defaults": {
          "corner_radius_percentage": 80,
          "corner_style": 1,
          "max_amplitude": 1.0,
          "min_amplitude": 0.2,
          "single_sided": false,
          "spacing": 1.0
        "diff_pair_skew_defaults": {
          "corner_style": 1,
          "spacing": 0.6
        "single_track_defaults": {
          "corner_style": 1,
          "spacing": 0.6
      "via_dimensions": [
          "diameter": 0.0,
          "drill": 0.0
      "zones_allow_external_fillets": false
    "ipc2581": {
      "bom_rev": "",
      "dist": "",
      "distpn": "",
      "internal_id": "",
      "mfg": "",
      "mpn": "",
      "sch_revision": "0.1"
    "layer_pairs": [],
    "layer_presets": [],
    "viewports": []
  "boards": [],
  "component_class_settings": {
    "assignments": [],
    "meta": {
      "version": 0
    "sheet_component_classes": {
      "enabled": false
  "cvpcb": {
    "equivalence_files": []
  "erc": {
    "erc_exclusions": [],
    "meta": {
      "version": 0
    "pin_map": [
        0,
        0,
        0,
        0,
        0,
        0,
        1,
        0,
        0,
        0,
        0,
        2,
        0,
        1,
        0,
        0,
        1,
        0,
        2,
        2,
        2,
        0,
        0,
        0,
        0,
        0,
        1,
        0,
        1,
        0,
        1,
        1,
        0,
        0,
        0,
        0,
        1,
        1,
        2,
        1,
        1,
        0,
        0,
        0,
        0,
        0,
        1,
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        1,
        1,
        1,
        1,
        0,
        1,
        1,
        1,
        1,
        1,
        0,
        0,
        1,
        0,
        0,
        1,
        0,
        0,
        0,
        0,
        2,
        1,
        2,
        0,
        0,
        1,
        0,
        2,
        2,
        2,
        2,
        0,
        1,
        0,
        0,
        1,
        0,
        2,
        0,
        0,
        2,
        1,
        1,
        0,
        0,
        1,
        0,
        2,
        0,
        0,
        2,
        2,
        2,
        2,
        2,
        2,
        2,
        2,
        2,
        2,
      "bus_definition_conflict": "error",
      "bus_entry_needed": "error",
      "bus_to_bus_conflict": "error",
      "bus_to_net_conflict": "error",
      "conflicting_netclasses": "error",
      "different_unit_footprint": "error",
      "different_unit_net": "error",
      "duplicate_reference": "error",
      "duplicate_sheet_names": "error",
      "endpoint_off_grid": "warning",
      "extra_units": "error",
      "field_name_whitespace": "warning",
      "footprint_filter": "ignore",
      "footprint_link_issues": "warning",
      "four_way_junction": "ignore",
      "global_label_dangling": "warning",
      "ground_pin_not_ground": "warning",
      "hier_label_mismatch": "error",
      "isolated_pin_label": "warning",
      "label_dangling": "error",
      "label_multiple_wires": "warning",
      "lib_symbol_issues": "warning",
      "lib_symbol_mismatch": "warning",
      "missing_bidi_pin": "warning",
      "missing_input_pin": "warning",
      "missing_power_pin": "error",
      "missing_unit": "warning",
      "multiple_net_names": "warning",
      "net_not_bus_member": "warning",
      "no_connect_connected": "warning",
      "no_connect_dangling": "warning",
      "pin_not_connected": "error",
      "pin_not_driven": "error",
      "pin_to_pin": "warning",
      "power_pin_not_driven": "error",
      "same_local_global_label": "warning",
      "similar_label_and_power": "warning",
      "similar_labels": "warning",
      "similar_power": "warning",
      "simulation_model_issue": "ignore",
      "single_global_label": "ignore",
      "stacked_pin_name": "warning",
      "unannotated": "error",
      "unconnected_wire_endpoint": "warning",
      "undefined_netclass": "error",
      "unit_value_mismatch": "error",
      "wire_dangling": "error"
  "libraries": {
    "pinned_footprint_libs": [],
    "pinned_symbol_libs": []
  "meta": {
    "filename": "CamperESP.kicad_pro",
    "version": 3
  "net_settings": {
    "classes": [
        "bus_width": 12,
        "clearance": 0.2,
        "diff_pair_gap": 0.25,
        "diff_pair_via_gap": 0.25,
        "diff_pair_width": 0.2,
        "line_style": 0,
        "microvia_diameter": 0.3,
        "microvia_drill": 0.1,
        "name": "Default",
        "pcb_color": "rgba(0, 0, 0, 0.000)",
        "priority": 2147483647,
        "schematic_color": "rgba(0, 0, 0, 0.000)",
        "track_width": 0.2,
        "tuning_profile": "",
        "via_diameter": 0.6,
        "via_drill": 0.3,
        "wire_width": 6
    "meta": {
      "version": 5
    "net_colors": null,
    "netclass_assignments": null,
    "netclass_patterns": []
  "pcbnew": {
    "last_paths": {
      "gencad": "",
      "idf": "",
      "netlist": "",
      "plot": "",
      "specctra_dsn": "exports/CamperESP.dsn",
      "step": "",
      "vrml": ""
    "page_layout_descr_file": ""
  "schematic": {
    "annotate_start_num": 0,
    "annotation": {
      "method": 0,
      "sort_order": 0
    "bom_export_filename": "${PROJECTNAME}.csv",
    "bom_fmt_presets": [],
    "bom_fmt_settings": {
      "field_delimiter": ",",
      "keep_line_breaks": false,
      "keep_tabs": false,
      "name": "CSV",
      "ref_delimiter": ",",
      "ref_range_delimiter": "",
      "string_delimiter": "\""
    "bom_presets": [],
    "bom_settings": {
      "exclude_dnp": false,
      "fields_ordered": [
          "group_by": false,
          "label": "Reference",
          "name": "Reference",
          "show": true
          "group_by": false,
          "label": "Qty",
          "name": "${QUANTITY}",
          "show": true
          "group_by": true,
          "label": "Value",
          "name": "Value",
          "show": true
          "group_by": true,
          "label": "DNP",
          "name": "${DNP}",
          "show": true
          "group_by": true,
          "label": "Exclude from BOM",
          "name": "${EXCLUDE_FROM_BOM}",
          "show": true
          "group_by": true,
          "label": "Exclude from Board",
          "name": "${EXCLUDE_FROM_BOARD}",
          "show": true
          "group_by": true,
          "label": "Footprint",
          "name": "Footprint",
          "show": true
          "group_by": false,
          "label": "Datasheet",
          "name": "Datasheet",
          "show": true
      "filter_string": "",
      "group_symbols": true,
      "include_excluded_from_bom": true,
      "name": "Default Editing",
      "sort_asc": true,
      "sort_field": "Referenz"
    "bus_aliases": {},
    "connection_grid_size": 50.0,
    "drawing": {
      "dashed_lines_dash_length_ratio": 12.0,
      "dashed_lines_gap_length_ratio": 3.0,
      "default_line_thickness": 6.0,
      "default_text_size": 50.0,
      "field_names": [],
      "hop_over_size_choice": 0,
      "intersheets_ref_own_page": false,
      "intersheets_ref_prefix": "",
      "intersheets_ref_short": false,
      "intersheets_ref_show": false,
      "intersheets_ref_suffix": "",
      "junction_size_choice": 3,
      "label_size_ratio": 0.375,
      "operating_point_overlay_i_precision": 3,
      "operating_point_overlay_i_range": "~A",
      "operating_point_overlay_v_precision": 3,
      "operating_point_overlay_v_range": "~V",
      "overbar_offset_ratio": 1.23,
      "pin_symbol_size": 25.0,
      "text_offset_ratio": 0.15
    "legacy_lib_dir": "",
    "legacy_lib_list": [],
    "meta": {
      "version": 1
    "net_format_name": "",
    "page_layout_descr_file": "",
    "plot_directory": "",
    "reuse_designators": true,
    "spice_current_sheet_as_root": false,
    "spice_external_command": "spice \"%I\"",
    "spice_model_current_sheet_as_root": true,
    "spice_save_all_currents": false,
    "spice_save_all_voltages": false,
    "subpart_first_id": 65,
    "subpart_id_separator": 0,
    "top_level_sheets": [
        "filename": "CamperESP.kicad_sch",
        "name": "CamperESP",
        "uuid": "d608fe2d-042e-49d6-b1e8-363eadf19542"
    "used_designators": "J2-4,TP1",
    "variants": []
  "sheets": [
      "d608fe2d-042e-49d6-b1e8-363eadf19542",
      "CamperESP"
  "text_variables": {},
  "tuning_profiles": {
    "meta": {
      "version": 0
    "tuning_profiles_impedance_geometric": []
