--  Boundary Scan Descriptor Language (BSDL) for:
--  IBM39STBx25xxPBA05CA
--  Copyright 2002, IBM. All Rights Reserved
--  This information is for modeling purposes only, and is not guaranteed.
--  THIS INFORMATION IS PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND,
--  EITHER EXPRESS OR IMPLIED, INCLUDING WITHOUT LIMITATION, THE IMPLIED
--  WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, AND
--  NON-INFRINGEMENT.  SOME JURISDICTIONS DO NOT ALLOW THE EXCLUSION OF
--  IMPLIED WARRANTIES, SO THE ABOVE EXCLUSION MAY NOT APPLY TO YOU.
--  This Information may contain technical inaccuracies or typographical
--  errors.  IBM reserves the right to modify or withdraw this information
--  at any time without notice.
--  IN NO EVENT WILL IBM BE LIABLE TO ANY PARTY FOR ANY DIRECT, INDIRECT,
--  SPECIAL OR CONSEQUENTIAL DAMAGES FOR ANY USE OF THIS INFORMATION,
--  INCLUDING, WITHOUT LIMITATION, ANY LOST PROFITS, BUSINESS INTERRUPTION,
--  LOSS OF PROGRAMS OR OTHER DATA ON YOUR INFORMATION HANDLING SYSTEM OR
--  OTHERWISE, EVEN IF WE ARE EXPRESSLY ADVISED OF THE POSSIBILITY OF SUCH
--  DAMAGES.
--  BSDL Syntax checker location:
--  The informational Web Site is: www.agilent.com/see/bsdl_service
--           The EMail address is: BSDL_Server@lvld.agilent.com
entity vulcan is
    -- Entity declaration
generic (PHYSICAL_PIN_MAP : string := "YI0665NC1_304EPBGA_31SCk_Vulcan");
port (
     RW_TDI : in bit;
     RW_TMS : in bit;
     RW_TRST : in bit;
     RW_TCK : in bit;
     RW_TDO : out bit;
     SD0_ADDRESS0 : out bit;
     SD0_ADDRESS1 : out bit;
     SD0_ADDRESS2 : out bit;
     SD0_ADDRESS3 : out bit;
     SD0_ADDRESS4 : out bit;
     SD0_ADDRESS5 : out bit;
     SD0_ADDRESS6 : out bit;
     SD0_ADDRESS7 : out bit;
     SD0_ADDRESS8 : out bit;
     SD0_ADDRESS9 : out bit;
     SD0_ADDRESS10 : out bit;
     SD0_ADDRESS11 : out bit;
     SD0_ADDRESS12 : out bit;
     SD0_ADDRESS13 : out bit;
     SD0_ADDRESS14 : out bit;
     SD0_DATA0 : inout bit;
     SD0_DATA1 : inout bit;
     SD0_DATA2 : inout bit;
     SD0_DATA3 : inout bit;
     SD0_DATA4 : inout bit;
     SD0_DATA5 : inout bit;
     SD0_DATA6 : inout bit;
     SD0_DATA7 : inout bit;
     SD0_DATA8 : inout bit;
     SD0_DATA9 : inout bit;
     SD0_DATA10 : inout bit;
     SD0_DATA11 : inout bit;
     SD0_DATA12 : inout bit;
     SD0_DATA13 : inout bit;
     SD0_DATA14 : inout bit;
     SD0_DATA15 : inout bit;
     SD0_CS0 : out bit;
     SD0_RAS : out bit;
     SD0_CAS : out bit;
     SD0_WE : out bit;
     SD0_DQMH : out bit;
     SD0_DQML : out bit;
     SD0_CLK : inout bit;
     SD1_ADDRESS0 : out bit;
     SD1_ADDRESS1 : out bit;
     SD1_ADDRESS2 : out bit;
     SD1_ADDRESS3 : out bit;
     SD1_ADDRESS4 : out bit;
     SD1_ADDRESS5 : out bit;
     SD1_ADDRESS6 : out bit;
     SD1_ADDRESS7 : out bit;
     SD1_ADDRESS8 : out bit;
     SD1_ADDRESS9 : out bit;
     SD1_ADDRESS10 : out bit;
     SD1_ADDRESS11 : out bit;
     SD1_ADDRESS12 : out bit;
     SD1_ADDRESS13 : out bit;
     SD1_ADDRESS14 : out bit;
     SD1_DATA0 : inout bit;
     SD1_DATA1 : inout bit;
     SD1_DATA2 : inout bit;
     SD1_DATA3 : inout bit;
     SD1_DATA4 : inout bit;
     SD1_DATA5 : inout bit;
     SD1_DATA6 : inout bit;
     SD1_DATA7 : inout bit;
     SD1_DATA8 : inout bit;
     SD1_DATA9 : inout bit;
     SD1_DATA10 : inout bit;
     SD1_DATA11 : inout bit;
     SD1_DATA12 : inout bit;
     SD1_DATA13 : inout bit;
     SD1_DATA14 : inout bit;
     SD1_DATA15 : inout bit;
     SD1_CS0 : out bit;
     SD1_RAS : out bit;
     SD1_CAS : out bit;
     SD1_WE : out bit;
     SD1_DQMH : out bit;
     SD1_DQML : out bit;
     SD1_CLK : inout bit;
     BI_ADDRESS11 : out bit;
     BI_ADDRESS12 : out bit;
     BI_ADDRESS13 : out bit;
     BI_ADDRESS14 : out bit;
     BI_ADDRESS15 : out bit;
     BI_ADDRESS16 : out bit;
     BI_ADDRESS17 : out bit;
     BI_ADDRESS18 : out bit;
     BI_ADDRESS19 : out bit;
     BI_ADDRESS20 : out bit;
     BI_ADDRESS21 : out bit;
     BI_ADDRESS22 : out bit;
     BI_ADDRESS23 : out bit;
     BI_ADDRESS24 : out bit;
     BI_ADDRESS25 : out bit;
     BI_ADDRESS26 : out bit;
     BI_ADDRESS27 : out bit;
     BI_ADDRESS28 : out bit;
     BI_ADDRESS29 : out bit;
     BI_ADDRESS30 : out bit;
     BI_ADDRESS31_WBE1 : out bit;
     BI_DATA0 : inout bit;
     BI_DATA1 : inout bit;
     BI_DATA2 : inout bit;
     BI_DATA3 : inout bit;
     BI_DATA4 : inout bit;
     BI_DATA5 : inout bit;
     BI_DATA6 : inout bit;
     BI_DATA7 : inout bit;
     BI_DATA8 : inout bit;
     BI_DATA9 : inout bit;
     BI_DATA10 : inout bit;
     BI_DATA11 : inout bit;
     BI_DATA12 : inout bit;
     BI_DATA13 : inout bit;
     BI_DATA14 : inout bit;
     BI_DATA15 : inout bit;
     BI_RW : out bit;
     BI_READY : in bit;
     BI_OE : out bit;
     BI_WBE0 : out bit;
     BI_CS0 : out bit;
     BI_CS1 : out bit;
     BI_CS2 : out bit;
     BI_CS3 : out bit;
     INT0 : in bit;
     INT1 : in bit;
     INT2 : in bit;
     EDMAC3_REQ : in bit;
     EDMAC3_ACK : out bit;
     I2C0_SDA : inout bit;
     I2C0_SCL : inout bit;
     CI_DATA0 : in bit;
     CI_DATA1 : in bit;
     CI_DATA2 : in bit;
     CI_DATA3 : in bit;
     CI_DATA4 : in bit;
     CI_DATA5 : in bit;
     CI_DATA6 : in bit;
     CI_DATA7 : in bit;
     CI_CLOCK : in bit;
     CI_DATA_ENABLE : in bit;
     G_SYSTEM_RESET : inout bit;
     TEST_MODE : in bit;
     RW_HALT : in bit;
     DA_SERIAL_DATA : out bit;
     DA_BIT_CLOCK : out bit;
     DA_LR_CLOCK : out bit;
     DA_OS_CLOCK : inout bit;
     DA_IEC_958 : out bit;
     SC0_IO : inout bit;
     SC0_CLK : out bit;
     SC0_DETECT : in bit;
     SC0_RESET : out bit;
     SC0_VCC : out bit;
     SC1_IO : inout bit;
     SC1_CLK : out bit;
     SC1_DETECT : in bit;
     SC1_RESET : out bit;
     SC1_VCC : out bit;
     GPIO0 : inout bit;
     GPIO1 : inout bit;
     GPIO2 : inout bit;
     GPIO3 : inout bit;
     GPIO4 : inout bit;
     GPIO5 : inout bit;
     GPIO6 : inout bit;
     GPIO7 : inout bit;
     GPIO8 : inout bit;
     GPIO9 : inout bit;
     GPIO10 : inout bit;
     GPIO11 : inout bit;
     GPIO12 : inout bit;
     GPIO13 : inout bit;
     GPIO14 : inout bit;
     GPIO15 : inout bit;
     GPIO16 : inout bit;
     GPIO17 : inout bit;
     GPIO18 : inout bit;
     GPIO19 : inout bit;
     GPIO20 : inout bit;
     GPIO21 : inout bit;
     GPIO22 : inout bit;
     GPIO23 : inout bit;
     GPIO24 : inout bit;
     GPIO25 : inout bit;
     GPIO26 : inout bit;
     GPIO27 : inout bit;
     GPIO28 : inout bit;
     GPIO29 : inout bit;
     GPIO30 : inout bit;
     GPIO31 : inout bit;
     DAC1_AGND0 : linkage bit;
     DAC1_AGND1 : linkage bit;
     DAC1_AGND2 : linkage bit;
     DAC1_AVDD0 : linkage bit;
     DAC1_AVDD1 : linkage bit;
     DAC1_AVDD2 : linkage bit;
     DAC1_AVDD3 : linkage bit;
     DAC2_AGND0 : linkage bit;
     DAC2_AGND1 : linkage bit;
     DAC2_AGND2 : linkage bit;
     DAC2_AVDD0 : linkage bit;
     DAC2_AVDD1 : linkage bit;
     DAC2_AVDD2 : linkage bit;
     DAC2_AVDD3 : linkage bit;
     DAC1_RREF_OUT : linkage bit;
     DAC1_GREF_OUT : linkage bit;
     DAC1_CREF_OUT : linkage bit;
     DAC2_RREF_OUT : linkage bit;
     DAC2_GREF_OUT : linkage bit;
     DAC2_CREF_OUT : linkage bit;
     DAC1_VREF_IN : linkage bit;
     DAC2_VREF_IN : linkage bit;
     DAC1_ROUT : linkage bit;
     DAC1_GOUT : linkage bit;
     DAC1_BOUT : linkage bit;
     DAC2_ROUT : linkage bit;
     DAC2_GOUT : linkage bit;
     DAC2_BOUT : linkage bit;
     AUD_VDDA0 : linkage bit;
     AUD_VDDA1 : linkage bit;
     AUD_GNDA0 : linkage bit;
     AUD_GNDA1 : linkage bit;
     CLK_VDDA : linkage bit;
     CLK_GNDA : linkage bit;
     G_SYSTEM_CLOCK : in bit;
     PACKAGE_SELECT0 : linkage bit;
     PACKAGE_SELECT1 : linkage bit;
     P_GND : linkage bit_vector(0 to 43);
     P_VDD : linkage bit_vector(0 to 15);
     P_VDD2 : linkage bit_vector(0 to 3);
     P_VDD3 : linkage bit_vector(0 to 3);
     P_VDD4 : linkage bit_vector(0 to 3);
     P_VDD5 : linkage bit_vector(0 to 3)
use STD_1149_1_1994.all ;
use IBMDFT_1149_1_1998_V5.all ;
attribute COMPONENT_CONFORMANCE of vulcan: entity is "STD_1149_1_1993";
attribute PIN_MAP of vulcan : entity is PHYSICAL_PIN_MAP;
constant YI0665NC1_304EPBGA_31SCk_Vulcan : PIN_MAP_STRING :=
				"AUD_GNDA0:AA8, " &
				"AUD_GNDA1:AC3, " &
				"AUD_VDDA0:AC7, " &
				"AUD_VDDA1:AA5, " &
				"BI_ADDRESS11:W21, " &
				"BI_ADDRESS12:Y23, " &
				"BI_ADDRESS13:V20, " &
				"BI_ADDRESS14:W22, " &
				"BI_ADDRESS15:W23, " &
				"BI_ADDRESS16:V21, " &
				"BI_ADDRESS17:V22, " &
				"BI_ADDRESS18:U21, " &
				"BI_ADDRESS19:U22, " &
				"BI_ADDRESS20:U23, " &
				"BI_ADDRESS21:T21, " &
				"BI_ADDRESS22:P20, " &
				"BI_ADDRESS23:R23, " &
				"BI_ADDRESS24:P21, " &
				"BI_ADDRESS25:P22, " &
				"BI_ADDRESS26:N21, " &
				"BI_ADDRESS27:N22, " &
				"BI_ADDRESS28:N23, " &
				"BI_ADDRESS29:M21, " &
				"BI_ADDRESS30:M22, " &
				"BI_ADDRESS31_WBE1:M23, " &
				"BI_CS0:D21, " &
				"BI_CS1:C22, " &
				"BI_CS2:B23, " &
				"BI_CS3:A22, " &
				"BI_DATA0:L23, " &
				"BI_DATA1:L22, " &
				"BI_DATA10:G23, " &
				"BI_DATA11:G22, " &
				"BI_DATA12:G21, " &
				"BI_DATA13:F22, " &
				"BI_DATA14:E23, " &
				"BI_DATA15:E22, " &
				"BI_DATA2:L21, " &
				"BI_DATA3:K21, " &
				"BI_DATA4:K20, " &
				"BI_DATA5:J23, " &
				"BI_DATA6:J22, " &
				"BI_DATA7:J21, " &
				"BI_DATA8:H23, " &
				"BI_DATA9:H22, " &
				"BI_OE:B20, " &
				"BI_READY:D23, " &
				"BI_RW:E21, " &
				"BI_WBE0:C23, " &
				"CI_CLOCK:B5, " &
				"CI_DATA0:B19, " &
				"CI_DATA1:B18, " &
				"CI_DATA2:C16, " &
				"CI_DATA3:A16, " &
				"CI_DATA4:A12, " &
				"CI_DATA5:D14, " &
				"CI_DATA6:B14, " &
				"CI_DATA7:B12, " &
				"CI_DATA_ENABLE:C6, " &
				"CLK_GNDA:AC9, " &
				"CLK_VDDA:AA11, " &
				"DAC1_AGND0:B7, " &
				"DAC1_AGND1:A8, " &
				"DAC1_AGND2:C10, " &
				"DAC1_AVDD0:B6, " &
				"DAC1_AVDD1:C8, " &
				"DAC1_AVDD2:A9, " &
				"DAC1_AVDD3:B11, " &
				"DAC1_BOUT:C7, " &
				"DAC1_CREF_OUT:A5, " &
				"DAC1_GOUT:B8, " &
				"DAC1_GREF_OUT:A11, " &
				"DAC1_ROUT:C11, " &
				"DAC1_RREF_OUT:A7, " &
				"DAC1_VREF_IN:C9, " &
				"DAC2_AGND0:B17, " &
				"DAC2_AGND1:B15, " &
				"DAC2_AGND2:C13, " &
				"DAC2_AVDD0:C18, " &
				"DAC2_AVDD1:B16, " &
				"DAC2_AVDD2:C14, " &
				"DAC2_AVDD3:A13, " &
				"DAC2_BOUT:C17, " &
				"DAC2_CREF_OUT:A19, " &
				"DAC2_GOUT:C15, " &
				"DAC2_GREF_OUT:C12, " &
				"DAC2_ROUT:B13, " &
				"DAC2_RREF_OUT:A17, " &
				"DAC2_VREF_IN:A15, " &
				"DA_BIT_CLOCK:AA1, " &
				"DA_IEC_958:F20, " &
				"DA_LR_CLOCK:AA2, " &
				"DA_OS_CLOCK:AB1, " &
				"DA_SERIAL_DATA:Y2, " &
				"EDMAC3_ACK:V3, " &
				"EDMAC3_REQ:E3, " &
				"GPIO0:AC2, " &
				"GPIO1:Y6, " &
				"GPIO10:R2, " &
				"GPIO11:V4, " &
				"GPIO12:W3, " &
				"GPIO13:B10, " &
				"GPIO14:D10, " &
				"GPIO15:B9, " &
				"GPIO16:D6, " &
				"GPIO17:C5, " &
				"GPIO18:A4, " &
				"GPIO19:B4, " &
				"GPIO2:AB5, " &
				"GPIO20:A3, " &
				"GPIO21:C4, " &
				"GPIO22:B3, " &
				"GPIO23:A2, " &
				"GPIO24:K22, " &
				"GPIO25:Y22, " &
				"GPIO26:Y21, " &
				"GPIO27:AA6, " &
				"GPIO28:F21, " &
				"GPIO29:R22, " &
				"GPIO3:AC5, " &
				"GPIO30:K4, " &
				"GPIO31:AB15, " &
				"GPIO4:C19, " &
				"GPIO5:B21, " &
				"GPIO6:A20, " &
				"GPIO7:D18, " &
				"GPIO8:M1, " &
				"GPIO9:N3, " &
				"G_SYSTEM_CLOCK:AA12, " &
				"G_SYSTEM_RESET:AA4, " &
				"I2C0_SCL:T3, " &
				"I2C0_SDA:U3, " &
				"INT0:C1, " &
				"INT1:D2, " &
				"INT2:H21, " &
				"RW_HALT:W2, " &
				"RW_TCK:AB6, " &
				"RW_TDI:AC4, " &
				"RW_TDO:Y1, " &
				"RW_TMS:AB3, " &
				"RW_TRST:Y3, " &
				"SC0_CLK:AA9, " &
				"SC0_DETECT:AB4, " &
				"SC0_IO:AB8, " &
				"SC0_RESET:AC8, " &
				"SC0_VCC:C20, " &
				"SC1_CLK:R21, " &
				"SC1_DETECT:T22, " &
				"SC1_IO:D22, " &
				"SC1_RESET:T23, " &
				"SC1_VCC:A21, " &
				"SD0_ADDRESS0:M3, " &
				"SD0_ADDRESS1:M2, " &
				"SD0_ADDRESS10:T2, " &
				"SD0_ADDRESS11:U1, " &
				"SD0_ADDRESS12:U2, " &
				"SD0_ADDRESS13:V2, " &
				"SD0_ADDRESS14:W1, " &
				"SD0_ADDRESS2:N1, " &
				"SD0_ADDRESS3:N2, " &
				"SD0_ADDRESS4:P2, " &
				"SD0_ADDRESS5:P3, " &
				"SD0_ADDRESS6:P4, " &
				"SD0_ADDRESS7:R1, " &
				"SD0_ADDRESS8:R3, " &
				"SD0_ADDRESS9:T1, " &
				"SD0_CAS:L3, " &
				"SD0_CLK:J1, " &
				"SD0_CS0:J2, " &
				"SD0_DATA0:B1, " &
				"SD0_DATA1:C2, " &
				"SD0_DATA10:G2, " &
				"SD0_DATA11:G1, " &
				"SD0_DATA12:H3, " &
				"SD0_DATA13:H2, " &
				"SD0_DATA14:H1, " &
				"SD0_DATA15:J3, " &
				"SD0_DATA2:D3, " &
				"SD0_DATA3:D1, " &
				"SD0_DATA4:F4, " &
				"SD0_DATA5:E2, " &
				"SD0_DATA6:E1, " &
				"SD0_DATA7:F3, " &
				"SD0_DATA8:F2, " &
				"SD0_DATA9:G3, " &
				"SD0_DQMH:L2, " &
				"SD0_DQML:L1, " &
				"SD0_RAS:K2, " &
				"SD0_WE:K3, " &
				"SD1_ADDRESS0:AA17, " &
				"SD1_ADDRESS1:AB18, " &
				"SD1_ADDRESS10:AA20, " &
				"SD1_ADDRESS11:AB21, " &
				"SD1_ADDRESS12:AC22, " &
				"SD1_ADDRESS13:AB23, " &
				"SD1_ADDRESS14:AA22, " &
				"SD1_ADDRESS2:AA18, " &
				"SD1_ADDRESS3:AC19, " &
				"SD1_ADDRESS4:AB19, " &
				"SD1_ADDRESS5:Y18, " &
				"SD1_ADDRESS6:AA19, " &
				"SD1_ADDRESS7:AC20, " &
				"SD1_ADDRESS8:AB20, " &
				"SD1_ADDRESS9:AC21, " &
				"SD1_CAS:AA16, " &
				"SD1_CLK:AA15, " &
				"SD1_CS0:AC15, " &
				"SD1_DATA0:AA7, " &
				"SD1_DATA1:AB7, " &
				"SD1_DATA10:AC13, " &
				"SD1_DATA11:AB13, " &
				"SD1_DATA12:AA13, " &
				"SD1_DATA13:AB14, " &
				"SD1_DATA14:AA14, " &
				"SD1_DATA15:Y14, " &
				"SD1_DATA2:AB9, " &
				"SD1_DATA3:Y10, " &
				"SD1_DATA4:AA10, " &
				"SD1_DATA5:AB10, " &
				"SD1_DATA6:AB11, " &
				"SD1_DATA7:AC11, " &
				"SD1_DATA8:AB12, " &
				"SD1_DATA9:AC12, " &
				"SD1_DQMH:AC17, " &
				"SD1_DQML:AB17, " &
				"SD1_RAS:AB16, " &
				"SD1_WE:AC16, " &
				"TEST_MODE:AA23, " &
				"P_GND:(A1, " &
				"A6, " &
				"A10, " &
				"A14, " &
				"A18, " &
				"A23, " &
				"B2, " &
				"B22, " &
				"C3, " &
				"C21, " &
				"D4, " &
				"D8, " &
				"D12, " &
				"D16, " &
				"D20, " &
				"F1, " &
				"F23, " &
				"H4, " &
				"H20, " &
				"K1, " &
				"K23, " &
				"M4, " &
				"M20, " &
				"P1, " &
				"P23, " &
				"T4, " &
				"T20, " &
				"V1, " &
				"V23, " &
				"Y4, " &
				"Y8, " &
				"Y12, " &
				"Y16, " &
				"Y20, " &
				"AA3, " &
				"AA21, " &
				"AB2, " &
				"AB22, " &
				"AC1, " &
				"AC6, " &
				"AC10, " &
				"AC14, " &
				"AC18, " &
				"AC23 ), " &
				"P_VDD:(D9, " &
				"D11, " &
				"D13, " &
				"D15, " &
				"J4, " &
				"J20, " &
				"L4, " &
				"L20, " &
				"N4, " &
				"N20, " &
				"R4, " &
				"R20, " &
				"Y9, " &
				"Y11, " &
				"Y13, " &
				"Y15 ), " &
				"P_VDD2:(Y5, " &
				"Y7, " &
				"Y17, " &
				"Y19 ), " &
				"P_VDD3:(E20, " &
				"G20, " &
				"U20, " &
				"W20 ), " &
				"P_VDD4:(D5, " &
				"D7, " &
				"D17, " &
				"D19 ), " &
				"P_VDD5:(E4, " &
				"G4, " &
				"U4, " &
				"W4 )";
--Scan Port Identification
attribute TAP_SCAN_IN of RW_TDI: signal is true;
attribute TAP_SCAN_MODE of RW_TMS: signal is true;
attribute TAP_SCAN_OUT of RW_TDO: signal is true;
attribute TAP_SCAN_RESET of RW_TRST: signal is true;
attribute TAP_SCAN_CLOCK of RW_TCK: signal is (20.0e6, BOTH);
attribute COMPLIANCE_PATTERNS of vulcan: entity is
 "(TEST_MODE) (0)";
-- TAP Description
attribute INSTRUCTION_LENGTH of vulcan: entity is 7;
attribute INSTRUCTION_OPCODE of vulcan: entity is
"EXTEST (0000000)," &
"SAMPLE (1111010)," &
"IDCODE (1111011)," &
"HIGHZ (1111101)," &
"CLAMP (1111110)," &
"BYPASS (1111111)";
attribute INSTRUCTION_CAPTURE of vulcan: entity is "0000001";
attribute IDCODE_REGISTER of vulcan: entity is
 "00010010100101010101000001001001";
attribute BOUNDARY_LENGTH of vulcan: entity is 251;
attribute BOUNDARY_REGISTER of vulcan: entity is
 "0 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "1 (BSR_OUT_NT, SD0_ADDRESS0, OUTPUT3, X, 0, 0, Z)," &
 "2 (BSR_OUT_NT, SD0_ADDRESS1, OUTPUT3, X, 0, 0, Z)," &
 "3 (BSR_OUT_NT, SD0_ADDRESS2, OUTPUT3, X, 0, 0, Z)," &
 "4 (BSR_OUT_NT, SD0_ADDRESS3, OUTPUT3, X, 0, 0, Z)," &
 "5 (BSR_OUT_NT, SD0_ADDRESS4, OUTPUT3, X, 0, 0, Z)," &
 "6 (BSR_OUT_NT, SD0_ADDRESS5, OUTPUT3, X, 0, 0, Z)," &
 "7 (BSR_OUT_NT, SD0_ADDRESS6, OUTPUT3, X, 0, 0, Z)," &
 "8 (BSR_OUT_NT, SD0_ADDRESS7, OUTPUT3, X, 0, 0, Z)," &
 "9 (BSR_OUT_TI, SD0_ADDRESS8, OUTPUT3, X, 0, 0, Z)," &
 "10 (BSR_OUT_NT, SD0_ADDRESS9, OUTPUT3, X, 0, 0, Z)," &
 "11 (BSR_OUT_NT, SD0_ADDRESS10, OUTPUT3, X, 0, 0, Z)," &
 "12 (BSR_OUT_NT, SD0_ADDRESS11, OUTPUT3, X, 0, 0, Z)," &
 "13 (BSR_OUT_NT, SD0_ADDRESS12, OUTPUT3, X, 0, 0, Z)," &
 "14 (BSR_OUT_TO_OO, SD0_ADDRESS13, OUTPUT3, X, 0, 0, Z)," &
 "15 (BSR_OUT_TI, SD0_ADDRESS14, OUTPUT3, X, 0, 0, Z)," &
 "16 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "17 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "18 (BSR_BIDIR, SD0_DATA0, BIDIR, X, 16, 0, Z)," &
 "19 (BSR_BIDIR, SD0_DATA1, BIDIR, X, 16, 0, Z)," &
 "20 (BSR_BIDIR, SD0_DATA2, BIDIR, X, 16, 0, Z)," &
 "21 (BSR_BIDIR, SD0_DATA3, BIDIR, X, 16, 0, Z)," &
 "22 (BSR_BIDIR, SD0_DATA4, BIDIR, X, 16, 0, Z)," &
 "23 (BSR_BIDIR, SD0_DATA5, BIDIR, X, 16, 0, Z)," &
 "24 (BSR_BIDIR, SD0_DATA6, BIDIR, X, 16, 0, Z)," &
 "25 (BSR_BIDIR, SD0_DATA7, BIDIR, X, 16, 0, Z)," &
 "26 (BSR_BIDIR_TO, SD0_DATA8, BIDIR, X, 17, 0, Z)," &
 "27 (BSR_BIDIR, SD0_DATA9, BIDIR, X, 17, 0, Z)," &
 "28 (BSR_BIDIR, SD0_DATA10, BIDIR, X, 17, 0, Z)," &
 "29 (BSR_BIDIR, SD0_DATA11, BIDIR, X, 17, 0, Z)," &
 "30 (BSR_BIDIR, SD0_DATA12, BIDIR, X, 17, 0, Z)," &
 "31 (BSR_BIDIR_TI, SD0_DATA13, BIDIR, X, 17, 0, Z)," &
 "32 (BSR_BIDIR_TI, SD0_DATA14, BIDIR, X, 17, 0, Z)," &
 "33 (BSR_BIDIR, SD0_DATA15, BIDIR, X, 17, 0, Z)," &
 "34 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "35 (BSR_OUT_NT, SD0_CS0, OUTPUT3, X, 34, 0, Z)," &
 "36 (BSR_OUT_NT, SD0_RAS, OUTPUT3, X, 34, 0, Z)," &
 "37 (BSR_OUT_NT, SD0_CAS, OUTPUT3, X, 34, 0, Z)," &
 "38 (BSR_OUT_NT, SD0_WE, OUTPUT3, X, 34, 0, Z)," &
 "39 (BSR_OUT_NT, SD0_DQMH, OUTPUT3, X, 34, 0, Z)," &
 "40 (BSR_OUT_TI, SD0_DQML, OUTPUT3, X, 34, 0, Z)," &
 "41 (BSR_BIDIR, SD0_CLK, BIDIR, X, 34, 0, Z)," &
 "42 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "43 (BSR_OUT_TI, SD1_ADDRESS0, OUTPUT3, X, 42, 0, Z)," &
 "44 (BSR_OUT_TI, SD1_ADDRESS1, OUTPUT3, X, 42, 0, Z)," &
 "45 (BSR_OUT_TI, SD1_ADDRESS2, OUTPUT3, X, 42, 0, Z)," &
 "46 (BSR_OUT_TI, SD1_ADDRESS3, OUTPUT3, X, 42, 0, Z)," &
 "47 (BSR_OUT_TI, SD1_ADDRESS4, OUTPUT3, X, 42, 0, Z)," &
 "48 (BSR_OUT_NT, SD1_ADDRESS5, OUTPUT3, X, 42, 0, Z)," &
 "49 (BSR_OUT_NT, SD1_ADDRESS6, OUTPUT3, X, 42, 0, Z)," &
 "50 (BSR_OUT_NT, SD1_ADDRESS7, OUTPUT3, X, 42, 0, Z)," &
 "51 (BSR_OUT_NT, SD1_ADDRESS8, OUTPUT3, X, 42, 0, Z)," &
 "52 (BSR_OUT_NT, SD1_ADDRESS9, OUTPUT3, X, 42, 0, Z)," &
 "53 (BSR_OUT_NT, SD1_ADDRESS10, OUTPUT3, X, 42, 0, Z)," &
 "54 (BSR_OUT_NT, SD1_ADDRESS11, OUTPUT3, X, 42, 0, Z)," &
 "55 (BSR_OUT_NT, SD1_ADDRESS12, OUTPUT3, X, 42, 0, Z)," &
 "56 (BSR_OUT_NT, SD1_ADDRESS13, OUTPUT3, X, 42, 0, Z)," &
 "57 (BSR_OUT_NT, SD1_ADDRESS14, OUTPUT3, X, 42, 0, Z)," &
 "58 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "59 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "60 (BSR_BIDIR, SD1_DATA0, BIDIR, X, 58, 0, Z)," &
 "61 (BSR_BIDIR, SD1_DATA1, BIDIR, X, 58, 0, Z)," &
 "62 (BSR_BIDIR, SD1_DATA2, BIDIR, X, 58, 0, Z)," &
 "63 (BSR_BIDIR, SD1_DATA3, BIDIR, X, 58, 0, Z)," &
 "64 (BSR_BIDIR, SD1_DATA4, BIDIR, X, 58, 0, Z)," &
 "65 (BSR_BIDIR, SD1_DATA5, BIDIR, X, 58, 0, Z)," &
 "66 (BSR_BIDIR, SD1_DATA6, BIDIR, X, 58, 0, Z)," &
 "67 (BSR_BIDIR, SD1_DATA7, BIDIR, X, 58, 0, Z)," &
 "68 (BSR_BIDIR, SD1_DATA8, BIDIR, X, 59, 0, Z)," &
 "69 (BSR_BIDIR, SD1_DATA9, BIDIR, X, 59, 0, Z)," &
 "70 (BSR_BIDIR, SD1_DATA10, BIDIR, X, 59, 0, Z)," &
 "71 (BSR_BIDIR, SD1_DATA11, BIDIR, X, 59, 0, Z)," &
 "72 (BSR_BIDIR, SD1_DATA12, BIDIR, X, 59, 0, Z)," &
 "73 (BSR_BIDIR, SD1_DATA13, BIDIR, X, 59, 0, Z)," &
 "74 (BSR_BIDIR, SD1_DATA14, BIDIR, X, 59, 0, Z)," &
 "75 (BSR_BIDIR, SD1_DATA15, BIDIR, X, 59, 0, Z)," &
 "76 (BSR_OUT_NT, SD1_CS0, OUTPUT3, X, 34, 0, Z)," &
 "77 (BSR_OUT_NT, SD1_RAS, OUTPUT3, X, 34, 0, Z)," &
 "78 (BSR_OUT_TI, SD1_CAS, OUTPUT3, X, 34, 0, Z)," &
 "79 (BSR_OUT_NT, SD1_WE, OUTPUT3, X, 34, 0, Z)," &
 "80 (BSR_OUT_NT, SD1_DQMH, OUTPUT3, X, 34, 0, Z)," &
 "81 (BSR_OUT_NT, SD1_DQML, OUTPUT3, X, 34, 0, Z)," &
 "82 (BSR_BIDIR_TO_OO, SD1_CLK, BIDIR, X, 34, 0, Z)," &
 "83 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "84 (BSR_OUT_TI, BI_ADDRESS11, OUTPUT3, X, 83, 0, Z)," &
 "85 (BSR_OUT_NT, BI_ADDRESS12, OUTPUT3, X, 83, 0, Z)," &
 "86 (BSR_OUT_NT, BI_ADDRESS13, OUTPUT3, X, 83, 0, Z)," &
 "87 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "88 (BSR_OUT_NT, BI_ADDRESS14, OUTPUT3, X, 87, 0, Z)," &
 "89 (BSR_OUT_NT, BI_ADDRESS15, OUTPUT3, X, 87, 0, Z)," &
 "90 (BSR_OUT_NT, BI_ADDRESS16, OUTPUT3, X, 83, 0, Z)," &
 "91 (BSR_OUT_TI, BI_ADDRESS17, OUTPUT3, X, 83, 0, Z)," &
 "92 (BSR_OUT_NT, BI_ADDRESS18, OUTPUT3, X, 83, 0, Z)," &
 "93 (BSR_OUT_NT, BI_ADDRESS19, OUTPUT3, X, 83, 0, Z)," &
 "94 (BSR_OUT_NT, BI_ADDRESS20, OUTPUT3, X, 83, 0, Z)," &
 "95 (BSR_OUT_NT, BI_ADDRESS21, OUTPUT3, X, 83, 0, Z)," &
 "96 (BSR_OUT_NT, BI_ADDRESS22, OUTPUT3, X, 83, 0, Z)," &
 "97 (BSR_OUT_NT, BI_ADDRESS23, OUTPUT3, X, 83, 0, Z)," &
 "98 (BSR_OUT_NT, BI_ADDRESS24, OUTPUT3, X, 83, 0, Z)," &
 "99 (BSR_OUT_NT, BI_ADDRESS25, OUTPUT3, X, 83, 0, Z)," &
 "100 (BSR_OUT_NT, BI_ADDRESS26, OUTPUT3, X, 83, 0, Z)," &
 "101 (BSR_OUT_NT, BI_ADDRESS27, OUTPUT3, X, 83, 0, Z)," &
 "102 (BSR_OUT_TI, BI_ADDRESS28, OUTPUT3, X, 83, 0, Z)," &
 "103 (BSR_OUT_NT, BI_ADDRESS29, OUTPUT3, X, 83, 0, Z)," &
 "104 (BSR_OUT_NT, BI_ADDRESS30, OUTPUT3, X, 83, 0, Z)," &
 "105 (BSR_OUT_NT, BI_ADDRESS31_WBE1, OUTPUT3, X, 83, 0, Z)," &
 "106 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "107 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "108 (BSR_BIDIR, BI_DATA0, BIDIR, X, 106, 0, Z)," &
 "109 (BSR_BIDIR, BI_DATA1, BIDIR, X, 106, 0, Z)," &
 "110 (BSR_BIDIR, BI_DATA2, BIDIR, X, 106, 0, Z)," &
 "111 (BSR_BIDIR, BI_DATA3, BIDIR, X, 106, 0, Z)," &
 "112 (BSR_BIDIR, BI_DATA4, BIDIR, X, 106, 0, Z)," &
 "113 (BSR_BIDIR, BI_DATA5, BIDIR, X, 106, 0, Z)," &
 "114 (BSR_BIDIR, BI_DATA6, BIDIR, X, 106, 0, Z)," &
 "115 (BSR_BIDIR, BI_DATA7, BIDIR, X, 106, 0, Z)," &
 "116 (BSR_BIDIR, BI_DATA8, BIDIR, X, 107, 0, Z)," &
 "117 (BSR_BIDIR, BI_DATA9, BIDIR, X, 107, 0, Z)," &
 "118 (BSR_BIDIR, BI_DATA10, BIDIR, X, 107, 0, Z)," &
 "119 (BSR_BIDIR, BI_DATA11, BIDIR, X, 107, 0, Z)," &
 "120 (BSR_BIDIR, BI_DATA12, BIDIR, X, 107, 0, Z)," &
 "121 (BSR_BIDIR, BI_DATA13, BIDIR, X, 107, 0, Z)," &
 "122 (BSR_BIDIR_TO_OO, BI_DATA14, BIDIR, X, 107, 0, Z)," &
 "123 (BSR_BIDIR_TO_OO, BI_DATA15, BIDIR, X, 107, 0, Z)," &
 "124 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "125 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "126 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "127 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "128 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "129 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "130 (BSR_OUT_NT, BI_RW, OUTPUT3, X, 124, 0, Z)," &
 "131 (BSR_IN_NT, BI_READY, INPUT, X)," &
 "132 (BSR_OUT_TO_OO, BI_OE, OUTPUT3, X, 125, 0, Z)," &
 "133 (BSR_OUT_NT, BI_WBE0, OUTPUT3, X, 83, 0, Z)," &
 "134 (BSR_OUT_NT, BI_CS0, OUTPUT3, X, 126, 0, Z)," &
 "135 (BSR_OUT_NT, BI_CS1, OUTPUT3, X, 127, 0, Z)," &
 "136 (BSR_OUT_NT, BI_CS2, OUTPUT3, X, 128, 0, Z)," &
 "137 (BSR_OUT_NT, BI_CS3, OUTPUT3, X, 129, 0, Z)," &
 "138 (BSR_IN_NT, INT0, INPUT, X)," &
 "139 (BSR_IN_NT, INT1, INPUT, X)," &
 "140 (BSR_IN_SIO, INT2, INPUT, X)," &
 "141 (BSR_IN_NT, EDMAC3_REQ, INPUT, X)," &
 "142 (BSR_OUT_TI, EDMAC3_ACK, OUTPUT3, X, 34, 0, Z)," &
 "143 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "144 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "145 (BSR_BIDIR_TI, I2C0_SDA, BIDIR, X, 143, 0, Z)," &
 "146 (BSR_BIDIR_TO_OO, I2C0_SCL, BIDIR, X, 144, 0, Z)," &
 "147 (BSR_IN_SIO, CI_DATA0, INPUT, X)," &
 "148 (BSR_IN_SIO, CI_DATA1, INPUT, X)," &
 "149 (BSR_IN_SIO, CI_DATA2, INPUT, X)," &
 "150 (BSR_IN_SIO, CI_DATA3, INPUT, X)," &
 "151 (BSR_IN_SIO, CI_DATA4, INPUT, X)," &
 "152 (BSR_IN_SIO, CI_DATA5, INPUT, X)," &
 "153 (BSR_IN_NT, CI_DATA6, INPUT, X)," &
 "154 (BSR_IN_SIO, CI_DATA7, INPUT, X)," &
 "155 (BSR_IN_SIO, CI_CLOCK, INPUT, X)," &
 "156 (BSR_IN_SIO, CI_DATA_ENABLE, INPUT, X)," &
 "157 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "158 (BSR_BIDIR, G_SYSTEM_RESET, BIDIR, X, 157, 0, Z)," &
 "159 (BSR_IN_SIO, RW_HALT, INPUT, X)," &
 "160 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "161 (BSR_OUT_NT, DA_SERIAL_DATA, OUTPUT3, X, 34, 0, Z)," &
 "162 (BSR_OUT_NT, DA_BIT_CLOCK, OUTPUT3, X, 34, 0, Z)," &
 "163 (BSR_OUT_NT, DA_LR_CLOCK, OUTPUT3, X, 34, 0, Z)," &
 "164 (BSR_BIDIR, DA_OS_CLOCK, BIDIR, X, 160, 0, Z)," &
 "165 (BSR_OUT_NT, DA_IEC_958, OUTPUT3, X, 34, 0, Z)," &
 "166 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "167 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "168 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "169 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "170 (BSR_BIDIR_TI, SC0_IO, BIDIR, X, 166, 0, Z)," &
 "171 (BSR_OUT_TI, SC0_CLK, OUTPUT3, X, 167, 0, Z)," &
 "172 (BSR_IN_SIO, SC0_DETECT, INPUT, X)," &
 "173 (BSR_OUT_TO_OO, SC0_RESET, OUTPUT3, X, 168, 0, Z)," &
 "174 (BSR_OUT_NT, SC0_VCC, OUTPUT3, X, 169, 0, Z)," &
 "175 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "176 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "177 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "178 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "179 (BSR_BIDIR, SC1_IO, BIDIR, X, 175, 0, Z)," &
 "180 (BSR_OUT_TO_OO, SC1_CLK, OUTPUT3, X, 176, 0, Z)," &
 "181 (BSR_IN_SIO, SC1_DETECT, INPUT, X)," &
 "182 (BSR_OUT_TO_OO, SC1_RESET, OUTPUT3, X, 177, 0, Z)," &
 "183 (BSR_OUT_TI, SC1_VCC, OUTPUT3, X, 178, 0, Z)," &
 "184 (BSR_BIDIR, GPIO0, BIDIR, X, 216, 0, Z)," &
 "185 (BSR_BIDIR, GPIO1, BIDIR, X, 217, 0, Z)," &
 "186 (BSR_BIDIR, GPIO2, BIDIR, X, 218, 0, Z)," &
 "187 (BSR_BIDIR_TO_OO, GPIO3, BIDIR, X, 219, 0, Z)," &
 "188 (BSR_BIDIR_TO_OO, GPIO4, BIDIR, X, 220, 0, Z)," &
 "189 (BSR_BIDIR, GPIO5, BIDIR, X, 221, 0, Z)," &
 "190 (BSR_BIDIR, GPIO6, BIDIR, X, 222, 0, Z)," &
 "191 (BSR_BIDIR, GPIO7, BIDIR, X, 223, 0, Z)," &
 "192 (BSR_BIDIR, GPIO8, BIDIR, X, 224, 0, Z)," &
 "193 (BSR_BIDIR, GPIO9, BIDIR, X, 225, 0, Z)," &
 "194 (BSR_BIDIR_TO, GPIO10, BIDIR, X, 226, 0, Z)," &
 "195 (BSR_BIDIR, GPIO11, BIDIR, X, 227, 0, Z)," &
 "196 (BSR_BIDIR, GPIO12, BIDIR, X, 228, 0, Z)," &
 "197 (BSR_BIDIR, GPIO13, BIDIR, X, 229, 0, Z)," &
 "198 (BSR_BIDIR, GPIO14, BIDIR, X, 230, 0, Z)," &
 "199 (BSR_BIDIR_TO_OO, GPIO15, BIDIR, X, 231, 0, Z)," &
 "200 (BSR_BIDIR_TO_OO, GPIO16, BIDIR, X, 232, 0, Z)," &
 "201 (BSR_BIDIR_TO_OO, GPIO17, BIDIR, X, 233, 0, Z)," &
 "202 (BSR_BIDIR_TO_OO, GPIO18, BIDIR, X, 234, 0, Z)," &
 "203 (BSR_BIDIR, GPIO19, BIDIR, X, 235, 0, Z)," &
 "204 (BSR_BIDIR, GPIO20, BIDIR, X, 236, 0, Z)," &
 "205 (BSR_BIDIR, GPIO21, BIDIR, X, 237, 0, Z)," &
 "206 (BSR_BIDIR, GPIO22, BIDIR, X, 238, 0, Z)," &
 "207 (BSR_BIDIR, GPIO23, BIDIR, X, 239, 0, Z)," &
 "208 (BSR_BIDIR, GPIO24, BIDIR, X, 240, 0, Z)," &
 "209 (BSR_BIDIR, GPIO25, BIDIR, X, 241, 0, Z)," &
 "210 (BSR_BIDIR, GPIO26, BIDIR, X, 242, 0, Z)," &
 "211 (BSR_BIDIR, GPIO27, BIDIR, X, 243, 0, Z)," &
 "212 (BSR_BIDIR_TI, GPIO28, BIDIR, X, 244, 0, Z)," &
 "213 (BSR_BIDIR, GPIO29, BIDIR, X, 245, 0, Z)," &
 "214 (BSR_BIDIR, GPIO30, BIDIR, X, 246, 0, Z)," &
 "215 (BSR_BIDIR_TO_OO, GPIO31, BIDIR, X, 247, 0, Z)," &
 "216 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "217 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "218 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "219 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "220 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "221 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "222 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "223 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "224 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "225 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "226 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "227 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "228 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "229 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "230 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "231 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "232 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "233 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "234 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "235 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "236 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "237 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "238 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "239 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "240 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "241 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "242 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "243 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "244 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "245 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "246 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "247 (BSR_ENAB_NT, *, CONTROL, 0)," &
 "248 (BSR_CLKIN, G_SYSTEM_CLOCK, CLOCK, X)," &
 "249 (BSR_IN_NT, *, INTERNAL, X)," &
 "250 (BSR_IN_NT, *, INTERNAL, X)" ;
attribute BOUNDARY_SCAN_DESIGN_TYPE: BSDL_EXTENSION;
attribute BOUNDARY_SCAN_DESIGN_TYPE of vulcan: entity is "IEEE_11491_LSSD";
end vulcan ;
