Format: Log Type - Time(microsec) - Message - Optional Info Log Type: B - Since Boot(Power On Reset), D - Delta, S - Statistic S - QC_IMAGE_VERSION_STRING=AVM_BOOT.BF.3.1.1 S - IMAGE_VARIANT_STRING=DAABANAZA S - OEM_IMAGE_VERSION_STRING=1204 S - Boot Config, 0x00000025 S - Reset status Config, 0x00000000 S - Core 0 Frequency, 0 MHz B - 261 - PBL, Start B - 1339 - bootable_media_detect_entry, Start B - 2612 - bootable_media_detect_success, Start B - 2626 - elf_loader_entry, Start B - 4044 - auth_hash_seg_entry, Start B - 5977 - auth_hash_seg_exit, Start B - 110183 - elf_segs_hash_verify_entry, Start B - 301589 - PBL, End B - 0 - SBL1, Start B - 401988 - pm_device_init, Start D - 9 - pm_device_init, Delta B - 403119 - boot_flash_init, Start D - 80171 - boot_flash_init, Delta B - 487536 - boot_config_data_table_init, Start D - 13957 - boot_config_data_table_init, Delta - (419 Bytes) B - 503954 - clock_init, Start D - 7603 - clock_init, Delta B - 514530 - CDT version:2,Platform ID:8,Major B - 515835 - sbl1_ddr_set_params, Start B - 520544 - cpr_init, Start D - 4 - cpr_init, Delta B - 525621 - Pre_DDR_clock_init, Start D - 5 - Pre_DDR_clock_init, Delta D - 13022 - sbl1_ddr_set_params, Delta B - 539012 - pm_driver_init, Start D - 4 - pm_driver_init, Delta B - 574584 - sbl1_wait_for_ddr_training, Start D - 30 - sbl1_wait_for_ddr_training, Delta B - 590683 - Image Verify, Start 0:QSEE D - 284444 - QSEE Image Loaded, Delta - (293400 Bytes) B - 875441 - Image Verify, Start 0:QSEE_B D - 287223 - QSEE Image Loaded, Delta - (293400 Bytes) B - 1163023 - Selected TZ0: 15788 (0:QSEE) B - 1166083 - Image Load, Start D - 287118 - QSEE Image Loaded, Delta - (293400 Bytes) B - 1453515 - Image Load, Start D - 2028 - SEC Image Loaded, Delta - (2048 Bytes) B - 1467072 - Image Verify, Start 0:APPSBL D - 143148 - APPSBL Image Loaded, Delta - (137996 Bytes) B - 1610540 - Image Verify, Start 0:APPSBL_B D - 146465 - APPSBL Image Loaded, Delta - (137996 Bytes) B - 1757349 - Selected EVA0: 11581 (0:APPSBL) B - 1761195 - Image Load, Start D - 145424 - APPSBL Image Loaded, Delta - (137996 Bytes) B - 1906937 - QSEE Execution, Start D - 56 - QSEE Execution, Delta B - 1913116 - SBL1, End D - 1915250 - SBL1, Delta S - Flash Throughput, 2128 KB/s (1296655 Bytes, 609259 us) S - DDR Frequency, 672 MHz NAND corrected 1 @ page: 0x2BC800 (AVM) EVA Revision: 1.11581 (C) Copyright 2018 AVM Date: Jul 14 2021 Time: 11:47:51 (0) 3 0x0-0x46409 [NAND:] 128MB MACRONIX 2048 Pagesize 128k Blocksize 1024 Blocks HW [SYSTEM:] CortexA9 Eva_AVM >NAND corrected 1 @ page: 0xD77800 .......................................................................NAND corrected 1 @ page: 0x2BC800 [ 0.000000][ T0] Booting Linux on physical CPU 0x0 [ 0.000000][ T0] Linux version 4.4.271 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g162062dc) ) #1 SMP PREEMPT 2026-03-03 [ 0.000000][ T0] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000][ T0] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000][ T0] Machine model: AVM FRITZ!Box 7530 [ 0.000000][ T0] Memory policy: Data cache writealloc [ 0.000000][ T0] [fw-info] Version 08.25 buildnr=131719 buildtype=1 [ 0.000000][ T0] [module-mem] Use 0x81000000-0x81296fff (mapped at c1000000-c1296fff) for 8 modules [ 0.000000][ T0] [module-mem] Using whitelist, set default strict_mode=2 [ 0.000000][ T0] PERCPU: Embedded 11 pages/cpu @cfdb4000 s16012 r8192 d20852 u45056 [ 0.000000][ T0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 60928 [ 0.000000][ T0] Kernel command line: clk_ignore_unused audit=1 slub_debug=FL [ 0.000000][ T0] audit: enabled (after initialization) [ 0.000000][ T0] setup_slub_debug: slub_debug = DEBUG_FREE STORE_USER_LITE [ 0.000000][ T0] PID hash table entries: 1024 (order: 0, 4096 bytes) [ 0.000000][ T0] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000][ T0] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) [ 0.000000][ T0] Memory: 226920K/245760K available (6264K kernel code, 1396K rwdata, 2124K rodata, 248K init, 2685K bss, 18840K reserved, 0K cma-reserved, 0K highmem) [ 0.000000][ T0] Virtual kernel memory layout: [ 0.000000][ T0] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000][ T0] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000][ T0] vmalloc : 0xd0800000 - 0xff800000 ( 752 MB) [ 0.000000][ T0] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB) [ 0.000000][ T0] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000][ T0] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000][ T0] .text : 0xc0208000 - 0xc0a39350 (8389 kB) [ 0.000000][ T0] .init : 0xc0a3a000 - 0xc0a78000 ( 248 kB) [ 0.000000][ T0] .data : 0xc0a78000 - 0xc0bd5000 (1396 kB) [ 0.000000][ T0] .bss : 0xc0bd7000 - 0xc0e76748 (2686 kB) [ 0.000000][ T0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000][ T0] Preemptible hierarchical RCU implementation. [ 0.000000][ T0] Build-time adjustment of leaf fanout to 32. [ 0.000000][ T0] NR_IRQS:16 nr_irqs:16 16 [ 0.000000][ T0] Architected cp15 timer(s) running at 48.00MHz (virt). [ 0.000000][ T0] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xb11fd3bfb, max_idle_ns: 440795203732 ns [ 0.000000][ T0] sched_clock: 56 bits at 48MHz, resolution 20ns, wraps every 4398046511096ns [ 0.000000][ T0] Switching to timer-based delay loop, resolution 20ns [ 0.000419][ T0] Calibrating delay loop (skipped), value calculated using timer frequency.. 96.00 BogoMIPS (lpj=192000) [ 0.000459][ T0] pid_max: default: 32768 minimum: 301 [ 0.000610][ T0] Security Framework initialized [ 0.000656][ T0] AppArmor: AppArmor initialized [ 0.000747][ T0] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.000778][ T0] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.001592][ T0] CPU: Testing write buffer coherency: ok [ 0.002097][ T1] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.002205][ T1] Setting up static identity map for 0x802082c0 - 0x80208318 [ 0.040509][ T0] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.052555][ T0] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.064627][ T0] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.064744][ T1] Brought up 4 CPUs [ 0.064804][ T1] SMP: Total of 4 processors activated (384.00 BogoMIPS). [ 0.064827][ T1] CPU: All CPU(s) started in SVC mode. [ 0.066051][ T1] devtmpfs: initialized [ 0.080594][ T1] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 [ 0.080841][ T1] [rte_ipi] Available IPIs 6 [ 0.081271][ T1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.081326][ T1] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.081883][ T1] pinctrl core: initialized pinctrl subsystem [ 0.083847][ T1] NET: Registered protocol family 16 [ 0.085554][ T1] DMA: preallocated 2048 KiB pool for atomic coherent allocations [ 0.096544][ T1] cpuidle: using governor ladder [ 0.108566][ T1] cpuidle: using governor menu [ 0.108613][ T1] Creating Config Table [ 0.113100][ T1] [qcom:qtimer_probe] WARNING avm,clk-rate not set in dt, using built in default [ 0.117126][ T1] [qcom_wdt] wdt_ipq_probe ... [ 0.129351][ T1] hw-breakpoint: debug architecture 0x5 unsupported. [ 0.132339][ T1] CPU: IPQ8064, SoC Version: 4294967274.4294967274 [ 0.132547][ T1] glink_init: IPC Logging Disabled [ 0.133328][ T1] avm_alloc_page_extension node_extension_table[0] entries=65536 (size=262144) alloced [ 0.133560][ T1] Reboot Status is: Power-On [ 0.134380][ T1] IPC logging disabled [ 0.134408][ T1] IPC logging disabled [ 0.134430][ T1] IPC logging disabled [ 0.134450][ T1] IPC logging disabled [ 0.134471][ T1] IPC logging disabled [ 0.134924][ T1] sps:sps is ready. [ 0.135968][ T1] pstore: using zlib compression [ 0.151160][ T1] console [pstore0] enabled [ 0.151657][ T1] pstore: Registered ramoops as persistent store backend [ 0.151951][ T1] ramoops: attached 0x100000@0x86000000, ecc: 16/0 [ 0.176719][ T1] SCSI subsystem initialized [ 0.177422][ T1] usbcore: registered new interface driver usbfs [ 0.177764][ T1] usbcore: registered new interface driver hub [ 0.178129][ T1] usbcore: registered new device driver usb [ 0.180431][ T1] Advanced Linux Sound Architecture Driver Initialized. [ 0.181625][ T1] AVM PA for Linux version 4.4.271 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g162062dc) ) #1 SMP PREEMPT 2026-03-03 [ 0.181625][ T1] (early init) [ 0.182539][ T1] NET: Registered protocol family 8 [ 0.182715][ T1] NET: Registered protocol family 20 [ 0.183132][ T1] TZ-pin nr 15 reprioritized to 60 [ 0.183434][ T1] TZ-pin nr 36 reprioritized to 60 [ 0.183673][ T1] TZ-pin nr 206 reprioritized to 60 [ 0.183964][ T1] TZ-pin nr 213 reprioritized to 60 [ 0.184134][ T1] TZ-pin nr 225 reprioritized to 60 [ 0.184423][ T1] TZ-pin nr 226 reprioritized to 60 [ 0.184587][ T1] TZ-pin nr 227 reprioritized to 60 [ 0.184875][ T1] TZ-pin nr 228 reprioritized to 60 [ 0.185039][ T1] TZ-pin nr 229 reprioritized to 60 [ 0.185204][ T1] TZ-pin nr 230 reprioritized to 60 [ 0.185492][ T1] TZ-pin nr 231 reprioritized to 60 [ 0.185656][ T1] TZ-pin nr 232 reprioritized to 60 [ 0.185945][ T1] TZ-pin nr 233 reprioritized to 60 [ 0.186176][ T1] TZ-pin nr 269 reprioritized to 60 [ 0.186833][ C3] [AVM_FIQ] FIQ disabled on CPU3 to install new vector! [ 0.186840][ C2] [AVM_FIQ] FIQ disabled on CPU2 to install new vector! [ 0.186847][ C1] [AVM_FIQ] FIQ disabled on CPU1 to install new vector! [ 0.187426][ T1] [AVM_FIQ] FIQ disabled on CPU0 to install new vector! [ 0.187714][ T1] [AVM_FIQ] Vector installed! [ 0.187877][ T1] [avm_scm] Set FIQ handler address [ 0.188170][ C1] [AVM_FIQ] FIQ enabled again on CPU1! [ 0.188175][ C2] [AVM_FIQ] FIQ enabled again on CPU2! [ 0.188181][ C3] [AVM_FIQ] FIQ enabled again on CPU3! [ 0.188767][ T1] [AVM_FIQ] FIQ enabled again on CPU0! [ 0.189070][ T1] [AVM_FIQ] (Version 1.0)(TZ 15788) [ 0.189353][ T1] clocksource: Switched to clocksource arch_sys_counter [ 0.190373][ T1] AppArmor: AppArmor Filesystem Enabled [ 0.192905][ T1] NET: Registered protocol family 2 [ 0.205635][ T1] TCP established hash table entries: 2048 (order: 1, 8192 bytes) [ 0.205844][ T1] TCP bind hash table entries: 2048 (order: 2, 16384 bytes) [ 0.206170][ T1] TCP: Hash tables configured (established 2048 bind 2048) [ 0.206521][ T1] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 0.206710][ T1] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 0.207302][ T1] NET: Registered protocol family 1 [ 0.207965][ T1] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available [ 0.210886][ T1] audit: initializing netlink subsys (enabled) [ 0.211252][ T1] audit: type=2000 audit(0.203:1): initialized [ 0.239589][ T1] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.240531][ T1] ANTFS Module: Version 2.56 [ 0.240988][ T1] jffs2: version 2.2 (NAND) (SUMMARY) (ZLIB) (LZO) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc. [ 0.244287][ T1] fuse init (API version 7.23) [ 0.252122][ T1] Key type asymmetric registered [ 0.252316][ T1] Asymmetric key parser 'x509' registered [ 0.252661][ T1] io scheduler noop registered [ 0.252836][ T1] io scheduler deadline registered (default) [ 0.257177][ T1] 40000000.pci supply vdda not found, using dummy regulator [ 0.257694][ T1] 40000000.pci supply vdda_phy not found, using dummy regulator [ 0.258069][ T1] 40000000.pci supply vdda_refclk not found, using dummy regulator [ 0.258660][ T1] PCI host bridge /soc/pci@40000000 ranges: [ 0.258972][ T1] IO 0x40200000..0x402fffff -> 0x40200000 [ 0.259148][ T1] MEM 0x48000000..0x57ffffff -> 0x48000000 [ 0.323035][ T1] PCI change magic executed [ 0.526947][ T1] qcom-pcie 40000000.pci: link up [ 0.527557][ T1] qcom-pcie 40000000.pci: PCI host bridge to bus 0000:00 [ 0.527736][ T1] pci_bus 0000:00: root bus resource [bus 00-ff] [ 0.528034][ T1] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x40200000-0x402fffff]) [ 0.528326][ T1] pci_bus 0000:00: root bus resource [mem 0x48000000-0x57ffffff] [ 0.529211][ T1] PCI: bus0: Fast back to back transfers disabled [ 0.529440][ T1] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 0.531058][ T1] PCI: bus1: Fast back to back transfers disabled [ 0.531387][ T1] pci 0000:00:00.0: BAR 8: assigned [mem 0x48000000-0x487fffff] [ 0.531687][ T1] pci 0000:00:00.0: BAR 0: assigned [mem 0x48800000-0x48800fff 64bit] [ 0.531994][ T1] pci 0000:01:00.0: BAR 0: assigned [mem 0x48000000-0x487fffff] [ 0.532178][ T1] pci 0000:00:00.0: PCI bridge to [bus 01] [ 0.532473][ T1] pci 0000:00:00.0: bridge window [mem 0x48000000-0x487fffff] [ 0.532859][ T1] pcieport 0000:00:00.0: enabling device (0144 -> 0146) [ 0.533387][ T1] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt [ 0.533688][ T1] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt [ 0.534089][ T1] PCIe: RC0 enabled during bootup [ 0.539351][ T1] glink_loopback_server_init: IPC Logging disabled [ 0.541417][ T1] NET: Registered protocol family 27 [ 0.541599][ T1] IPC_RTR: ipc_router_create_log_ctx: IPC Logging disabled [ 0.541902][ T1] qmi_log_init: IPC Logging disabled [ 0.542063][ T1] qmi_log_init: IPC Logging disabled [ 0.542719][ T1] tcsr 194b000.tcsr: setting usb hs phy mode select = e700e7 [ 0.542978][ T1] tcsr 1953000.ess_tcsr: setting ess interface select = 0 [ 0.543341][ T1] tcsr 1949000.tcsr: setting wifi_glb_cfg = 41000000 [ 0.543589][ T1] tcsr 1957000.tcsr: setting wifi_noc_memtype_m0_m2 = 2222222 [ 0.544152][ T1] TZ Log : Will warn on Access Violation, as paniconaccessviolation is not set [ 0.545734][ T1] msm_serial 78af000.serial: msm_serial: detected port #0 [ 0.546051][ T1] msm_dectuart_probe: set dectuart_port to ttyMSM0 [ 0.546384][ T1] msm_serial 78af000.serial: uartclk = 1843200 [ 0.546592][ T1] 78af000.serial: ttyMSM0 at MMIO 0x78af000 (irq = 24, base_baud = 115200) is a MSM [ 0.546901][ T1] msm_serial: console setup on port #0 [ 1.636818][ T1] console [ttyMSM0] enabled [ 1.643001][ T1] msm_serial: driver initialized [ 1.647174][ T1] msm_serial_hsl_init: driver initialized [ 1.651701][ T1] [avm_power]avm_power_pm_qos_init [ 1.657249][ T1] [loadcontrol] set auto - scale=1 [ 1.661960][avm] configured: watchdog event debug [ 1.671848][ T1] Register push button event to receive the set_factory_kernel event [ 1.672805][ T1] AVM Simple Profiling enabled Version 3.0 [ 1.679546][ T1] [simple-profiling]:4 performance counters implemented [ 1.685213][ T1] [simple-profiling]all cpus:performance-mode: round-robin [ 1.692040][ T1] [simple-profiling]all cpus:performance-mode: round-robin [ 1.699022][ T1] [simple-profiling]all cpus:performance-mode: round-robin [ 1.706173][ T1] [simple-profiling]all cpus:performance-mode: round-robin [ 1.713277][ T1] AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0) [ 1.720318][ T1] [qcom_wdt] ar7wdt_hw_init... [ 1.727728][ T1] [avm_request_fiq_on] Virtual IRQ numbers are not supported. Use HWIRQ (35) for requested IRQ (25) [ 1.732249][ T1] [qcom_wdt] [register_wdt_bark_irq] watchdog as fastirq(35) on all cpus registered with its default prio [ 1.742708][ T1] [avm_request_fiq_on] Forcing HW-IRQ 36 instead [ 1.753546][ T1] [qcom_wdt] [register_wdt_bark_irq] watchdog as fastirq(36) on all cpus registered with highest prio [ 1.759929][ T1] [avm_request_fiq_on] Forcing HW-IRQ 213 instead [ 1.770601][ T1] [qcom_wdt] [register_secure_wdt_bark_irq] secure watchdog as fastirq(213) on all cpus registered with highest prio [ 1.785454][ T1] [qcom_wdt] [ar7wdt_hw_init] Wdt bark time: 320000, bite time: 640000 [ 1.788961][ T1] [qcom_wdt] [ar7wdt_hw_init] Secure watchdog: bark: 20s, bite time: 40s [ 1.798647][ T1] avm_net_trace: Up and running. [ 1.808574][ T1] loop: module loaded [ 1.811183][ T1] zram: Added device: zram0 [ 1.815579][ T1] QPIC controller hw version Major:1, Minor:4 [ 1.818800][ T1] nand: device found, Manufacturer ID: 0xc2, Chip ID: 0xf1 [ 1.824053][ T1] nand: ONFI 10-Compliant Macronix MX30LF1G18AC [ 1.831275][ T1] nand: 128 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64 [ 1.837385][ T1] [TFFS3_Register_Panic_CB] registering panic callback for mtd qcom_nand.0 [ 1.845557][ T1] 5 ofpart partitions found on MTD device qcom_nand.0 [ 1.853948][ T1] Creating 5 MTD partitions on "qcom_nand.0": [ 1.860408][ T1] 0x000000b00000-0x000000f00000 : "kernel" [ 1.872152][ T1] 0x000000000000-0x0000002c0000 : "urlader" [ 1.881115][ T1] 0x0000002c0000-0x000000b00000 : "nand-tffs" [ 1.891486][ T1] 0x000000f00000-0x000001300000 : "reserved-kernel" [ 1.897783][ T1] 0x000001300000-0x000008000000 : "ubi" [ 2.013623][ T1] libphy: Fixed MDIO Bus: probed [ 2.014676][ T1] qca-mdio 90000.mdio: Could not find phy-reset-gpio, idx 0 [ 2.017775][ T1] libphy: qca_mdio: probed [ 2.031654][ T1] qca-mdio 90000.mdio: qca-mdio driver was registered [ 2.032024][ T1] tun: Universal TUN/TAP device driver, 1.6 [ 2.037438][ T1] tun: (C) 1999-2004 Max Krasnyansky [ 2.350877][ T1] i2c /dev entries driver [ 2.353745][ T1] sdhci: Secure Digital Host Controller Interface driver [ 2.354028][ T1] sdhci: Copyright(c) Pierre Ossman [ 2.361144][ T1] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.399888][ T1] intf_tdm_probe: ena: dma-tx-channel=0 stereo-tx-port=0 ena: dma-rx-channel=7 stereo-rx-port=3 [ 2.400580][ T1] AVM PA 2.182.1.4-release_smart24p2-smart24p2 for Linux Linux version 4.4.271 (kbuild-team@core.avm.de) (gcc version 8.4.0 (Buildroot -g162062dc) ) #1 SMP PREEMPT 2026-03-03 [ 2.400580][ T1] (late init) [ 2.410566][ T1] gre: GRE over IPv4 demultiplexor driver [ 2.429825][ T1] Initializing XFRM netlink socket [ 2.435043][ T1] IPsec XFRM device driver [ 2.442151][ T1] NET: Registered protocol family 10 [ 2.446994][ T1] sit: IPv6 over IPv4 tunneling driver [ 2.450577][ T1] NET: Registered protocol family 17 [ 2.455394][ T1] Bridge broadcast ratelimiter registered [ 2.459843][ T1] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this. [ 2.465488][ T1] Bridge firewalling registered [ 2.478999][ T1] KOAM is loaded successfully. [ 2.483488][ T1] l2tp_core: L2TP core driver, V2.0 [ 2.488265][ T1] l2tp_ip: L2TP IP encapsulation support (L2TPv3) [ 2.493423][ T1] l2tp_netlink: L2TP netlink interface [ 2.499334][ T1] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3) [ 2.504728][ T1] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3) [ 2.511483][ T1] 8021q: 802.1Q VLAN Support v1.8 [ 2.518534][ T1] Registering SWP/SWPB emulation handler [ 2.523216][ T1] SBL Boot Info Version 1204 Boot TZ 0 Boot Eva 0 [ 2.528584]TZ0 Version 15788 [ 2.534861][ T1] TZ1 Version 15788 [ 2.537841][ T1] EVA0 Version 11581 [ 2.541504][ T1] EVA1 Version 11581 [ 2.545509][ T1] [rte_ipi] Requested ipi RTE monitor (nr=9, prio=00, flags=0x00800001) [ 2.549063][ T1] [rte_ipi] Requested ipi RTE linux (nr=10, prio=80, flags=0x00800000) [ 2.560486][ T1] Could not find Env 'kernel_args' in the device tree [ 2.565722][ T1] [TFFS3_Init] Called. [ 2.571785][ T1] [TFFS3_CACHE_Configure] Setting up caching for backend nand [ 2.576034][ T1] [TFFS3-CACHE] Caching module for TFFS 3.x [ 2.582839][ T1] [TFFS3-NAND] NAND storage backend for TFFS 3.x on mtd2 [ 2.953048][ C0] random: nonblocking pool is initialized [ 3.970846][ T1] [TFFS3-NAND] Initialisation successful, 66/66/66 NAND blocks active, fill rate 7% [ 3.971182][ T1] [TFFS_Cache] Allocate segement buffer cache (size=2024) [ 3.979595][ T1] TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 3.0) [ 3.987353][ T1] [TFFS3-NANDSTAT][tffs_erase_stat_init] Erase counts: (min/max/mean): 1/1/1 - 0 bad blocks [ 3.995482][ T1] ubi0: attaching mtd4 [ 4.595865][ T1] ubi0: scanning is finished [ 4.607139][ T1] ubi0: attached mtd4 (name "ubi", size 109 MiB) [ 4.607462][ T1] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes [ 4.612434][ T1] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048 [ 4.620079][ T1] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 4.627630][ T1] ubi0: good PEBs: 870, bad PEBs: 2, corrupted PEBs: 0 [ 4.634967][ T1] ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128 [ 4.642041][ T1] ubi0: max/mean erase counter: 4101/1946, WL threshold: 4096, image sequence number: 1077262412 [ 4.649765][ T1] ubi0: available PEBs: 0, total reserved PEBs: 870, PEBs reserved for bad PEB handling: 18 [ 4.660120][ T98] ubi0: background thread "ubi_bgt0d" started, PID 98 [ 4.661899][ T1] Could not find Env 'linux_fs_start' in the device tree [ 4.661950][ T1] mtd: device 5 (filesystem) set to be root filesystem [ 4.663681][ T1] Could not find Env 'linux_fs_start' in the device tree [ 4.669495][ T1] Could not find Env 'linux_fs_start' in the device tree [ 4.671251][ T1] Could not find Env 'linux_fs_start' in the device tree [ 4.671347][ T1] hctosys: unable to open rtc device (rtc0) [ 4.678253][ T1] clk: Not disabling unused clocks [ 4.678271][ T1] ALSA device list: [ 4.678280][ T1] No soundcards found. [ 4.729565][ T1] VFS: Mounted root (squashfs filesystem) readonly on device 31:5. [ 4.734276][ T1] devtmpfs: mounted [ 4.737172][ T1] Could not find Env 'linux_fs_start' in the device tree [ 4.740688][ T1] Could not find Env 'linux_fs_start' in the device tree [ 4.747242][ T1] Could not find Env 'linux_fs_start' in the device tree [ 4.754211][ T1] Could not find Env 'linux_fs_start' in the device tree [ 4.761515][ T1] Freeing unused kernel memory: 248K starting pid 107, tty '': '/etc/boot.d/1' [ 5.593080][ T121] hui: loading out-of-tree module taints kernel. [ 5.599271][ T121] [hui] Initialize hardware user interface [ 5.604422][ T121] [avm_connect][state_machine_init] starting event worker thread [Supervisor] Info: start svlogd.service [Supervisor] Info: svlogd.service notified: ready [Supervisor] Info: start dmesg-printk.service [Supervisor] Info: start ptest_env.service [Supervisor] Info: start tffs.service [ 5.832214][ T146] [avm_debug] redirecting kernel-messages [Supervisor] Info: ptest_env.service exit success Please press Enter to activate this console. Jan 1 1970 00:00:07 ar7cfgctl[262]: [ERROR] load_config(ar7): file empty - factory default loaded Jan 1 1970 00:00:07 ar7cfgctl[266]: [ERROR] load_config(ar7): file empty - factory default loaded Jan 1 1970 01:00:08 ar7cfgctl[314]: [ERROR] load_config(ar7): file empty - factory default loaded Jan 1 1970 01:00:08 ar7cfgctl[317]: [ERROR] load_config(ar7): file empty - factory default loaded P-Defaults: not configured - skip. [Supervisor] Info: tffs.service exit success [Supervisor] Info: start untrustedd.service 00000008.983094 01.01.70/00:00:08 trusted_api.c:1326 trustedd thread start OK [ 9.030976][ T0] [0]system-load 81% loadavg 0.16 0.3 0.1 - softirqs:4.08% (vchan_complete 61%) pgstat: sum=56792 free=49730 slab=1892 alloc=2108/s fault=1693/s (sleep 1) 00000009.177277 01.01.70/00:00:09 crypto.c:556 Failed to load provider 'legacy' 00000009.639213 01.01.70/00:00:09 watchdog.c:104 Keepalive watchdog init OK 00000009.642565 01.01.70/00:00:09 untrusted_api.c:233 Database is empty. 00000009.643550 01.01.70/00:00:09 trusted_api.c:284 Init result 0, DB-len=0 [Supervisor] Info: untrustedd.service notified: ready [Supervisor] Info: start rekey.service [ 9.809615][ T344] [1]system-load 71% loadavg 0.16 0.3 0.1 - task runtime:9% max:untrustedd 4% pgstat: sum=56792 free=49257 slab=1908 alloc=2190/s fault=1727/s (sleep 4) Jan 1 1970 01:00:10 firmwarecfg[344]: [ERROR] Warning: clogger_freeonly: default logger 'firmwareupdate' gone firmwarecfg config_rekey: nop [Supervisor] Info: rekey.service exit success [Supervisor] Info: start environment.service Jan 1 1970 01:00:10 ar7cfgctl[348]: [ERROR] load_config(ar7): file empty - factory default loaded [ 10.605644][ T0] [2]system-load 69% loadavg 0.31 0.7 0.2 - task runtime:1% max:rc.conf 0% pgstat: sum=56792 free=48774 slab=1949 alloc=2366/s fault=1881/s (sleep 1) [ 10.645680][ T0] [3]system-load 68% loadavg 0.31 0.7 0.2 - task runtime:2% max:rc.conf 2% pgstat: sum=56792 free=48758 slab=1949 alloc=2427/s fault=1958/s (sleep 2) Jan 1 1970 01:00:10 ar7cfgctl[388]: [ERROR] load_config(ar7): file empty - factory default loaded Jan 1 1970 01:00:11 ar7cfgctl[391]: [ERROR] load_config(ar7): file empty - factory default loaded [Supervisor] Info: environment.service exit success [Supervisor] Info: reached target environment.target [Supervisor] Info: start watchdog.service [Supervisor] Info: watchdog.service exit success [Supervisor] Info: start udev.service [Supervisor] Info: start udevadm.service [ 11.098452][ T399] AVM_WATCHDOG: System Init Ueberwachung 120 Sekunden [ 11.278874][ T400] udevd[400]: starting version 3.2.11 [ 11.323941][ T400] udevd[400]: specified group 'tty' unknown [ 11.324355][ T400] udevd[400]: specified group 'dialout' unknown [ 11.324597][ T400] udevd[400]: specified group 'kmem' unknown [ 11.324821][ T400] udevd[400]: specified group 'input' unknown [ 11.325074][ T400] udevd[400]: specified group 'video' unknown [ 11.325593][ T400] udevd[400]: specified group 'audio' unknown [ 11.326044][ T400] udevd[400]: specified group 'lp' unknown [ 11.326404][ T400] udevd[400]: specified group 'disk' unknown [ 11.326640][ T400] udevd[400]: specified group 'cdrom' unknown [ 11.327038][ T400] udevd[400]: specified group 'tape' unknown [ 11.327583][ T400] udevd[400]: specified group 'kvm' unknown [ 11.334400][ T400] udevd[400]: starting eudev-3.2.11 [ 11.509145][ T410] vrx518: Intel(R) SmartPHY DSL(VRX518) PCIe EP/ACA Driver - version 2.1.0-k [ 11.509187][ T410] vrx518: Copyright (c) 2016 Intel Corporation. [ 11.509452][ T410] vrx518 0000:01:00.0: enabling device (0140 -> 0142) [ 11.653418][ T74] avm_power: [avm_power_temperature] No cpu sensor registered [ 11.960841][ T413] ssdk_switch_device_num_init[1340]:INFO:ess-switch dts node number: 1 [ 11.960917][ T413] ssdk_dt_get_switch_node[1143]:INFO:ess-switch DT exist! [ 11.960952][ T413] ssdk_dt_parse_access_mode[1029]:INFO:switch_access_mode: local bus [ 11.960979][ T413] ssdk_dt_parse_access_mode[1042]:INFO:switchreg_base_addr: 0xc000000 [ 11.961003][ T413] ssdk_dt_parse_access_mode[1043]:INFO:switchreg_size: 0x80000 [ 11.961032][ T413] ssdk_dt_parse_mac_mode[361]:INFO:mac mode = 0x0 (PORT_WRAPPER_PSGMII) [ 11.961057][ T413] ssdk_dt_parse_mac_mode[367]:INFO:mac mode1 doesn't exit! [ 11.961082][ T413] ssdk_dt_parse_mac_mode[377]:INFO:mac mode2 doesn't exit! [ 11.961106][ T413] ssdk_dt_parse_phy_info[645]:INFO:qcom,port_phyinfo DT doesn't exist! [ 11.961139][ T413] ssdk_dt_parse_mdio[806]:INFO:mdio DT exist! [ 11.961200][ T413] ssdk_dt_parse_led[1116]:INFO:current dts led_source_num is 0 [ 11.961234][ T413] ssdk_dt_parse_psgmii[994]:INFO:ess-psgmii DT exist! [ 11.961275][ T413] ssdk_plat_init start [ 11.961545][ T413] ssdk_plat_init[1624]:INFO:Enable ess clk [ 12.143221][ T413] malibu_phy_api_ops_init[2869]:INFO:qca probe malibu phy driver succeeded! [ 12.146954][ T413] regi_init[4080]:INFO:Initializing DESS!! [ 13.833221][ T413] ssdk_switch_register[1965]:INFO:Chip version 0x1401 [ 13.833306][ T413] qca_link_polling_select[1556]:INFO:link-polling-required node does not exist [ 13.833373][ T413] ssdk_switch_register[1991]:INFO:polling is selected [ 13.833414][ T413] regi_init[4090]:INFO:Initializing DESS Done!! [ 13.850432][ T413] regi_init[4162]:INFO:qca-ssdk module init succeeded! [ 13.876802][ T413] [module-mem] give 0x11000 bytes at c1001000 to module 'essedma' (0x285000 bytes left) [ 13.879104][ T413] Using 4 netdevs [ 13.880156][ T413] EDMA Dev eth0 (0) --> phy mdio 0 [ 13.880197][ T413] EDMA Dev eth1 (1) --> phy mdio 1 [ 13.880229][ T413] EDMA Dev eth2 (2) --> phy mdio 2 [ 13.880259][ T413] EDMA Dev eth3 (3) --> phy mdio 3 [ 13.880530][ T413] [avm_request_fiq_on] Virtual IRQ numbers are not supported. Use HWIRQ (272) for requested IRQ (78) [Supervisor] Info: udevadm.service exit success [Supervisor] Info: start cortexa9.service SBL ACK done [TZ-Update] [tz-update] bound mibib block at page 524288. [tz-update] 2 trustzones found. update index 0 first. [tz-update] tz0 already up to date. version: 15788 [tz-update] tz1 already up to date. version: 15788 ... tz not updated [Supervisor] Info: cortexa9.service exit success [Supervisor] Info: reached target basic.target [Supervisor] Info: start capi-config.service [Supervisor] Info: start modules-load.service [Supervisor] Info: start piglet.service [ 14.236159][ T440] Piglet_noemif: module license 'Proprietary.Copyright 2008-2024 by AVM ' taints kernel. [ 14.236210][ T440] Disabling lock debugging due to kernel taint [ 14.239627][ T440] Could not find Env 'kernel_args' in the device tree [ 14.239689][ T440] use_hw_config_to_set_gpios: hw_config: gpio_avm_dect_reset 40 [ 14.239715][ T440] use_hw_config_to_set_gpios: hw_config: gpio_avm_dect_rd 16 [ 14.239740][ T440] [piglet]use default-settings (2 gpios from hw_config) [ 14.245728][ T443] cprocfs: loaded [ 14.247270][ T443] cchardevice: loaded [ 14.248906][ T443] cchardevice: device_create(b2b): 240,0 [ 14.249296][ T443] b2b: AVM B2B driver: init done [Supervisor] Info: capi-config.service exit success [ 14.286779][ T450] cchardevice: device_create(kskbtracepoint): 239,0 [ 14.287211][ T450] kskbtracepoint: l  [piglet]===== shared usage of UART (DECT and CONSOLE) - unusual characters shown: ==== gՠ5,lFFFFFFFFFFFFFFFFFFFFFFFFDFhFFFJEF`*P ݀H  T "     T ",$(       Ё    ! #  % '  ) +݂     ? hVPHPD @OhVPHPD @VVPHPD @48I@ 4s     wTJZrUv|Zq,K3qK3qK3qK3qK3qK3qK3qK36qK3qK3qK3y;  tU ` tU ` tU ` tU ` tU `tUr,tUr tUrUb`tUrU`&tUrU`(wYm |x*m^"m |"UUm |&fm\l Jl |,Dlll w24ւ|FUUll |Lll |RUU~l |Vnlfl \l |\LlDlp C|bBR|br ~ r~d~|z|p @~p|` Z f >r |B|t re~u re~d~||p @~|   > |B| r~ r~d~4}}p @~} I >!} I  B 0}I r~ r~d~~}X}p @~N} y>k}   B z} rL ~rL ~r ~ B p @~}}Uxd~}}}X  Ux p @~}}Uxd~}}}X  Ux p @~}}Uxd~}}}X  Ux DHDUTDt~ ~ Կ p @~~~Uxd~2~'~2~X  Ux DHDUTDt~E~ տ p @~R~T~Uxd~l~a~l~X  Ux DHDUTDt~~ ֿvh~pLOX~~?~pIpJ}pH ~~A~-{pH p"@v@OvpEp#pF`~~@{pF~pG`~~@{pG~pD`~~@{pDpE p UUzH~~p K~ <(}<pC`~<pDp~.pGp~.pFp~.@pH l}+P pFpG pFpG UhU pD y [Q[2R]B`X`[B0P[B[+"R`[*+Y:YHUg[s[C2RX8VZL а`r_/U@`UO``/?_㯿&,P|| p/"]XV P[ Y /_)0@!%zOy$l.p{(!0 #%8s`{(s( @@ %@OU`܋O`j  J@ %XPP P`!0$0P `t团Ui;O`R y"%Ur{"K;O`p"  Qy$0V PW Y /9(0@!%|$ A@%jOU`WO`PP P`!0$hP0 G@%|` p\ Y0p\X !$ p]_U0L aUa!$ `/?_㿿 T( UTUT#[322X5Vpr"`GZI 0` UX !P$ / ' 0@!% p[ [ !Jq[ %  X( `OUr`މO``O ]_Uar` 0( O`` ] _$U!THZrU܉X "pU` X'PPp iLaX ZyFwi"TZrUXwN$T*ZrUXXrYA0gPK|x$TxZUXXU@]_ LUL`aaP]_aX@0P@0PLT[Zrw$uTZrUXwtUSXX8`tUrfO` (rNO`Xs]_5LWU5LWa%LuaSa!Q P!Q0`PHXDPGZ0ZPBX(0@E! DPAZ0PBX(0AE%Y ZPBX(0AE%Y XZ Xpx$$]D_$LFULda@a]D_@aP@]03[00PIh 2[] YXZi]2fPZ%`';r^PXV"a`dTF [P0PCXPPP0@@bPU]XX`/O:YX@X**jt"UB`Άp"(!p"(!O`VPSYXV PV]2Z] S~X}Y@Y##px$]"_"L$ULBa aUp]_ U@aU:p]`2^aQSQ /"] PPQOYUPrp]_aP Y 10QF[12"St0gPG0* Dt"UB`O`PP  ]~PYuXY%XY%XY%XY%V/  V / Y`-Y >}U`U`-B$-B$YYU` O`P|U` ` ]_tU`"U`"  O`'X!Q t]_6LhU6Lha&LadaPD7 0Y QY'0aPCX'p"]"_2L$U2L$a"LBa a rPD0 r rPD0 'YU` PP:rY'` jZJ:rY5(/` PPrY#jZJ:rYe%zHy$XXrY$XXXrYXXrY'Y5 U`RRX `+Y y]dNUa|U`P'PUt\~pN$QUVj`UXpN$Q@0R$'C\~L$XY'\v`Rn"`X}U`\~P. |U`7<P0Y PYP Y]M< Xsz `#@[2Q QZZ`/?GUr"`LX`}U`8ryN$+U /O` `[ Y p$ P+PKPkP P2PPVP"PX' p}" ' Pws p~"' p"'X' "PX0PXp p~"p"XXIy P PXp}" p~"p" P PP%)} $Pt `+PO9y}1$ri" 0La$U`7rUJqri" p`>[ $ wk qO`+PG  P P P0P $ Yq9  iq pP^p0PX $P'X`p0P ZZ$PNyFP@ws)q4X)p"P"P 2P BPRPbPrPP`RT/UUpyqO`0z@y"t"Uo0)"Py"t" 0 XoUJU@K[I0)y"tI 0 y"lt"UroXs 0 P `@~@n@v/K 7X ]2Zm YP q?33]`/%%'%`3_3L5U3L5a#LSa1a ]_0La % ]_0LU0La L aa ``T `PTt{"U ZY PZ PP P` PP && &" Z Y PP PPPpP&PPBPRPbPrPPP PP &&P&P& P1P&&&P@&&&PPBPRPPP P P & &@& ""& @P P "P RPP P`&&&&P%P & ]_0LU0La L@a `PT `]Ux>:U a, U*SXm/.pG X&yZNUZ**N[IQOQXXNP]2]Sj]TfZ ;@S`@[2^U a ]Sp P,y|,q XXPQPU` ^Ua,@R 0 P0 0]Qf[2/-QK i*"] Sv!2^ a z qz P ]`  jMro`'p"]&_6LhU6Lha&LaUha(P ( P(P("]&_6LhU6Lha&La`a`0%$'P$4'$4'`o&Y=YLYY[z`]_0LU0La L a a-  tUYbYQ%PPP P [IYY@@P,PPPIY* %':7 R(_p]OD_L@a @ $%G @@0%lPXp$PU`9,z? X 8 P PP   %  O` Y;[r'Uay}U`P T$U]_0L U0L a LaaapPF40*`0 - y' SXi' U'"]"_2L$U2L$a"LBa aa `O,Y;[]V}U` { " л" 0 3ZY' " л"yU` PP  P0P@P PP`P pP P  @ ' Y~ "@& ''Y~ & (4 ' [Y{)~ " & y~ "} ~ WP t<`WP33 @ * #O`]_0LU0La L aBUa ]_0LU0La L aa Xw]0pPBXgP]fp a`Q ' a` c]rPF"]22S`Q pPF]20S0ePLePbY'0dPGX_2L U2L a"La )Y3wM@ Y*Y9YGUsUY[]3_3L5U3L5a#LSa0aG"0X# ` g6QSYC!`V!cQX`p"p~"K@cY %:Q) F@0"s@`pQ$F@6%7S!cQ72 $Q #Q'QX #Q`O+Y=YbY_]yU`  R^PPP `RQ|U`0PL~SU0PL~ 2 @RZd ?YsYO``@T p" 0p "ttzD(4!$ PrPjttzD(4!$ @r@jQ `/?]_|2 a P P,Y U,MU &]B'] 'Z&UZ;* SZ PRXT(ZrUXeXp)P"Pr7P?' Xr]&O``Y 00kPOP0"7 XtCUmO`uU4`U|dY 0O`0kPFP6ZX UZPCZFt~]_-U VZ , UUR`d(p!pp!pp!pU` O`PMU`c O`9{ p%pI{ p%pi{ p%p zcO` 1TZUR`cETZU`c PDZRX Uǂr"`r" VZ  м0"s ){ ,'s GU`UB`bTtUD``UbTtUD`]`UbO`p%pp" p0p앓(#!3 rd j^X!'7P?' P@ PP  2^-O`R P O}9MUU` O`R9U`Ox`OO`O`R`$U`U`O`RpZ)0PCZ!F(!p0X/ P X/ s 0 s  'sU` ~7sp~Wst(`LarUR`^a,O`PP}`T ]2^U@L aUarU`*a ]2^U@L aUa`!O`!trU`` O`PXU` pPY`Tt]_.arUR``U`,.R`O`R X/ X/@ U PL { `r`GsO`  G P/ `XATU//`Z&sUZ3*[I&'PPP>\`StbUO` UU/IX/S0 0Q$`|~]_U@L a a p[ U@L aaU2` t~ 2^U@L aBUa `TUrU `@Tt> `PTt~ 4EXYZLRX"P p"/"0p~"C@Y 0%Q/ Y Qp pQ$QY XYYrPY(p)p*pV$+pW$,VZU`(#XI>P|9:O+ " SfYJ3XYYYPyPoJ@PP8' UXN /2HT(ZUI>`  pN$@@ Y 5ZUZ[*[I Y XYO`0XG p$] p$sa32Q $ a` ' p$0XG p$pU$8PUP`/(O`` $']` Z'5ZG"r" QGyGiGqPGyYt@U ab]-_Ua`"R\YU`]*^a`"bXPXPY 9mp{XE0`{O{{ XLPFlQTY0%0p UCUa Ua`"P U`$ RS2 RCeQIGyGiGq?Y=Y|U`A Rr"0 PP "`Q`R~'MU @ @PDqXRU@]_aQ RJt D@@ P7@Z(A];C2Dq7qW@DG7 ZRXW0P(J 2 4` 04 O?Yg0   2 >Z{R2>RyyEXX6X2 iigk76y>yyEXXXg{7<Pg{{{=0=<0<PP`<PWy=]2Sry`~|yiXY'PX7y7iXY'PX y 0PO?YP{PiWy7PXYgqy'y77y72=]S}yD`Bv:b`2P ' 'XY!XY''πXXkPPJ` pN$@0R$7'0) 7 /`PpPTq7yi7P$XYw0P' 2  p~"B@0p" #%0 p"B@7 #%0' ' 2O?YoP"!P{P X{ǿ!P \X '` ]];^]_pU aU`"rU`"6B!]];SZ>A!Y9  9 !O` P P X YSXB$YX)'''!SXA 9 !0 0hPY PPP PP(Pp/ aPqPP PiP 0 ' 0 'O?Ym O(/2A/" r$ 0k9B O`Ly` yP0g{7(gk7gs7 SyiP 0 ' 0 '`  ?/`Z,>t iP!P APaPhP PyiqsU`,Y}4XYPh Y]R U`,YU 4XY[Di'B&6y.*`UY Y@P /̤UrU`*?O`|PPz]_ a UQO`@PZ`UUYXYP YUYXYiyqXd4XYPrYU@]_0LU0La LPaa`4XdXBYyFi>P6Yu`0y< , XYXYP 1PQPqP Pgy| OSZY {UXX4 wywiOSZY` @yEXXiqZ,>7P PXgyg{7;PX PF@PTX 2X"XX)7 @ pPSq'sU` ''?/ PP zU` Q MO`R"  X=uU` ?('d#0 O`?/΀Gq z` Py`U`UE`?YO`'yyZDXWUVZZ`F@t <@\^a`%`T@OB`< {Z&?'#Gy+ o`0RFGiY)/"?#%00Pxo`0 0P ]!];R|r"G PEPPfpZ0PCZF Y!PD' U ! 9X&yXN]2SZ: [Pf]Ss*YZdT(ZU;`]_<U`; 0 ]UB[2"^ a'7C@#%0 0 $2B^U a O`yrqYSXd;1 '!1!"$ y(ZNUZ[*[I NY OPr"XPyNiO?YwXYYoqo`SyBFi0rU`*PF*]B+]'X ,*]B+]'X YYiyFiTXYY7q@V Eg{7(gk7gs7w0y5ZZdXXYqyLGi`XXYIgy"DypXUX>gi'ygi'iy'q77&XX 6Xt,XpXYo`OZY !];RP' r/280 !P0!0O`Cwy0Dy@XEXwi'ywi'i'yi"XX7PS PKXgyg{7;PX PF@PTX 2X"Xv$7 P pPPqDXvXr P' UZp\U` P T(Ud`UZ7 /"$ O`yU`V PTUd`U`(7 O` `ZT7ZTt/`z P jj2!  R 0 0POr@r;PPr"pPI0pPT`0E֒Y<O`P WysU` ''TPy"P?q|PP P P Ps/{Ps@P?{ s0$PP {_T{?T`G"ВYO`@pXY`20y WG77 `P !tUa`" " & '=0'= XG[X W7GZBX Gq7 6ZU` q 0r"0[Y0 |Y [*@[I pN$  pU$ p$  ]=2|Y /"   UQ_aYr r"`@ pP `[[ `Z  p0$O`  p0$0X2 @ V @ @ `ZZ `ZZXXY 9`[IYW7GZBX tU` XY 0r"0[Y0 `CY z]Z.[b*a` ]_L UL a2La  0`ZZ ]_ a ]_ a 00Q ]_2L U2L a"LaU a ]_2L U2L a"LaU a`=] p]U LaL a ]_0LU0La L a _0LU0La L a a z]_0LU0La L aUa ]_0LU0La L aUa `0TtU` `PTO(U `PTt{" `oO?Y Z~XII04!P X Z Y ~1 0 BRZ ZXEUVZп` Tt"rU"`1pO`@P'Rt"rUR`1PTt"rU`r1ZZZZZ(O`RR[ [IYX Yp PCXDC ppB]"_ a (%!P B]"_ a R% RR[ [IYX Yp PCXDC p&p&B]"_ a (%!P Zs5U_7Lua"!S2R(CZ1U_5LQa"R2R(^'[:YHUp["RR(Pr_0LaZ PXVH PB#"G'r"HD]"']"01BA' H@ %B"HD]XU]BE'"'RsRKRXB#q["A'"2j"'r "@r"2"'Bs#X'UIY[Ym[ϫ]_Z/Zr`_0La"R"]@[0BSN]@30BSYY Y0 Q["Z  PCZF3"E'R Q YY0@ 9Yp @P[FCX(0DE%2CX(0D(E!P V{k2R(MY ]_pU@a@Xz P w ]_aT&ZrU.ZҗwFT Zr XY0yPKXpB]"_LU%aU%aX%0PDTfZrTfZr~00t.r-Xpp0앰X?p0T7ZrT7Zr&TPZr]T@ZrO`w|²ZRI`R$ZXX1XrYXrYrYXrYͿ`XXXSXrYy0/`gPE0|Z ,`ZT0,qT1"&1_,Zp`I2~RkRXfIvR YbXV PF@ P[\Z r;f]+2RsZR8cZ7 Yp"]$_L@a@~t{ 2QU0X  B " 0 2 0 ZXQUV Z#pN$@PrD]D_4LIU4LIa$LaBa"' Z_sUauLa2RDp$@PPXXW` p gsYCZXVZ ppP@P+TqZrB+ :+TZr X0IR `O(Uز|" pUP`ZX8RSRWRX RY R[R\ R^R R_ RiRjpRz( R|R*R R  R+|R,R- R0 R3pRD RERG4RPRQ RRR RRhR"|R$|R&sZXUV ZJt"`~)O`UD`8Y pPIU` TP4`r>$@)O`RDUrF$()pm"pJ$Zd Рm"O`z~]2^U@L a aRK`UR`O`R4`UR`(O`RGU`U(O`RKlU`r(O`R!Mh{U5`U`Y[REU`TU5`YR@ `Ur4(O`j Pz]2^U@L a a`TU4`U(O`R@2  & "P pP 8`UZXX? p$PP 0PCZFqY(!p$ {0PCZFqY%p pp"{ P$  {ppp({"p"EPp"QL ܱz"v"p"r"t"P  { Dj"j0jj z Jj p"p"0Q$p8 0Q$$$$Dr"r0rrp"Jr ""P)P /R@ (P"P  `RT/Ur{"(bPPf `RT/UJUr~]_U@L@aaU&q1Hp[PCZ@F0%|PTt3JUr~U@L@aaUO`Rp(p[PCZ F%p8{p(p[PCZ F%pH{q1Hp[PCZ@F0%h{ PCZFqY%pPCZFqY(!ppp  "0Q$(!A  " p" Pk p( "PC x{$p$p$ P pp$Zp$0$ PP  P è0 BP X_`m"@0p$P @Px Z$0$d p[X YyN @@$X$XUR`q0 /R CUTX]B]'eP $X(`UUe`H8(ӬrY$2R]`_U$`#0`TU$`x#Xpw$O`PA0"0w$P0p"YtpPPl8YQ YZ/X U VNT/ZUN#Z%   X`]_UatLa0PC`Tt 4ad`U`"TZp*"]"_L'UL'a2Lra a``U"O`PY] w]  ]_U a`r LULa0L@aaB`I ? XYP y* .LX  T &YYP(xP qY PXz]_1LU1La!L1aaqU]_LULa1L1aSUa vj{7\XLXnYcU`P@sY Y 7 @ pPS qz7{]B]'XZU#`]B]' ` 8 TX]B]' 0P 2jR(Tq]_L1aH{ZX{nX{X]B]'q{( Ph XU#`({6(48YPR\U`1P X  R\: U2`2 O` `T(` Uj`U{6XXRXZTZ]`h8Z/`RX`ZT8ZT8YᚐPP" X  B P |]<,a X  B2 `T(UD`j`UHT`,Ul`U j8Yݩ^YYCYPNz ]_0LU0La L0a aU`U`7x{jy P P--]M< X jijy P Plz PX PF@PTX 7X'XY]M< rY @ pPS qjqYYuP(PzrPPtp"]2Z$[4b@a("]B TYY9x Z`RG]B] 'RCP:z]h apY P 7 P [ PW*9 PN[`*9/`Q0 @PF ;` @PUq P @ A C D ;PA RrY M# *9[ #[ p%YPpY PsY/YP pU@]RUa U`PZ ;Z D qgyq jyP PF@PS?yq jy/P/YP**ZJsY /tpY PpY pPP q:7P 0Y P/P  //ZJ:7 Xji*9*z7 89 ;`[IYZ7YZBX{`XXYY YPw]*|U`7<P 0Y PzU`YP YY/ZJ< Xdgi**_Xp#]3_`0a0QU`7S heQ XSD 0bPUYYPq]_1a`2Џ`3L5U3L5a#LSa p*"]"_L$UL$a2LBa a` LULa0L a z]Z.[b*a _0LU0La L a _0LU0La L aa `U `PT `@T FY5Y$YZC2X'YPtYZ2XXX)rY$YZ2Xs)Y >TP> $[pDpX  <Pr[[ R3 @3 r[2[ r3 p33 B3 2"^"L%ULRa a )[2zY ignore [ 14.310456][ T440] [piglet]patch_dectfw: dectmode 5 [ 14.310801][ T440] [piglet]patch_dectfw: d1cf0000, totallen = 54119(d367) crc=0xab [ 14.323262][ T440] [piglet]slow: dect_loader-bootmode [ 15.562382][ T450] kdsld: init start (sizeof(struct sk_buff) = 464) [ 15.562426][ T450] kdsld[3]: Initialisation of debughandles ... [ 15.562493][ T450] kdsld[3]: Initialisation of debughandles [OK] [ 15.562521][ T450] kdsld[3]: Initialisation of cmemstack ... [ 15.562547][ T450] kdsld[3]: Initialisation of cmemstack [OK] [ 15.562573][ T450] kdsld[3]: Initialisation of global ... [ 15.563132][ T450] kdsld[3]: Initialisation of global [OK] [ 15.563160][ T450] kdsld[3]: Initialisation of procfs ... [ 15.563221][ T450] kdsld[3]: Initialisation of procfs [OK] [ 15.563251][ T450] kdsld[3]: Initialisation of ptype ... [ 15.563352][ T450] kdsld[3]: Initialisation of ptype [OK] [ 15.563382][ T450] kdsld[3]: Initialisation of kmod_debugctl ... [ 15.563431][ T450] kdsld[3]: Initialisation of kmod_debugctl [OK] [ 15.563459][ T450] kdsld[3]: Initialisation of cenv ... [ 15.563485][ T450] kdsld[3]: Initialisation of cenv [OK] [ 15.563511][ T450] kdsld[3]: Initialisation of ctimer ... [ 15.563966][ T450] kdsld[3]: Initialisation of ctimer [OK] [ 15.563998][ T450] kdsld[3]: Initialisation of prefixtab ... [ 15.564062][ T450] kdsld[3]: Initialisation of prefixtab [OK] [ 15.564091][ T450] kdsld[3]: Initialisation of avmsgc ... [ 15.564485][ T450] kdsld[3]: Initialisation of avmsgc [OK] [ 15.564517][ T450] kdsld[3]: Initialisation of avmcounter ... [ 15.565136][ T450] kdsld[3]: Initialisation of avmcounter [OK] [ 15.565171][ T450] kdsld[3]: Initialisation of dsld_setup ... [ 15.565210][ T450] kdsld[3]: Initialisation of dsld_setup [OK] [ 15.565239][ T450] kdsld[3]: Initialisation of adsl_net ... [ 15.569564][ T450] kdsld[3]: Initialisation of adsl_net [OK] [ 15.569607][ T450] kdsld[3]: Initialisation of ppptty_net ... [ 15.570786][ T450] kdsld[3]: Initialisation of ppptty_net [OK] [ 15.570825][ T450] kdsld[3]: Initialisation of ingress_shaping ... [ 15.572085][ T450] kdsld[3]: Initialisation of ingress_shaping [OK] [ 15.572126][ T450] kdsld[3]: Initialisation of pppdp ... [ 15.590685][ T450] kdsld[3]: Initialisation of pppdp [OK] [ 15.590728][ T450] kdsld[3]: Initialisation of kmodcmddev ... [ 15.590797][ T450] kdsld[3]: Initialisation of kmodcmddev [OK] [ 15.590825][ T450] kdsld[3]: Initialisation of kdsldev ... [ 15.590963][ T450] cchardevice: device_create(kdsld): 238,0 [ 15.591310][ T450] kdsld[3]: Initialisation of kdsldev [OK] [ 15.591347][ T450] kdsld[3]: Initialisation of kavmcounterddev ... [ 15.591433][ T450] cchardevice: device_create(kavmcounterd): 237,0 [ 15.591700][ T450] kdsld[3]: Initialisation of kavmcounterddev [OK] [ 15.591733][ T450] kdsld[3]: Initialisation of kvpnd ... [ 15.591823][ T450] cchardevice: device_create(kvpnd): 236,0 [ 15.592153][ T450] kdsld[3]: Initialisation of kvpnd [OK] [ 15.592189][ T450] kdsld[3]: Initialisation of klatd ... [ 15.592304][ T450] cchardevice: device_create(klatd%d): 235,0 [ 15.593759][ T450] cchardevice: device_create(klatd%d): 235,1 [ 15.595500][ T450] kdsld[0]: Initialisation of klatd [OK] [ 15.595540][ T450] kdsld[0]: Initialisation of kdsluserdev ... [ 15.595580][ T450] kdsld[0]: Initialisation of kdsluserdev [OK] [ 15.595607][ T450] kdsld[0]: Initialisation of kdslmiscdev ... [ 15.595642][ T450] kdsld[0]: Initialisation of kdslmiscdev [OK] [ 15.595670][ T450] kdsld[0]: Initialisation of packettrace ... [ 15.595770][ T450] cchardevice: device_create(kdsldptrace%d): 232,0 [ 15.596088][ T450] cchardevice: device_create(kdsldptrace%d): 232,1 [ 15.596395][ T450] cchardevice: device_create(kdsldptrace%d): 232,2 [ 15.596654][ T450] cchardevice: device_create(kdsldptrace%d): 232,3 [Supervisor] Info: modules-load.service exit success [Supervisor] Info: start devnodes.service [Supervisor] Info: start sysctl.service [ 15.596919][ T450] cchardevice: device_create(kdsldptrace%d): 232,4 [ 15.597212][ T450] cchardevice: device_create(kdsldptrace%d): 232,5 [ 15.598699][ T450] cchardevice: device_create(kdsldptrace%d): 232,6 [Supervisor] Info: devnodes.service exit success [Supervisor] Info: reached target kmod.target [Supervisor] Info: start apparmor.service [Supervisor] Info: start filesystem.service [ 15.599021][ T450] cchardevice: device_create(kdsldptrace%d): 232,7 [ 15.599316][ T450] cchardevice: device_create(kdsldptrace%d): 232,8 [ 15.599582][ T450] cchardevice: device_create(kdsldptrace%d): 232,9 [ 15.599878][ T450] cchardevice: device_create(kdsldptrace%d): 232,10 [ 15.600170][ T450] cchardevice: device_create(kdsldptrace%d): 232,11 [ 15.600433][ T450] cchardevice: device_create(kdsldptrace%d): 232,12 [ 15.600735][ T450] cchardevice: device_create(kdsldptrace%d): 232,13 [ 15.601047][ T450] cchardevice: device_create(kdsldptrace%d): 232,14 [ 15.601426][ T450] cchardevice: device_create(kdsldptrace%d): 232,15 [ 15.601732][ T450] cchardevice: device_create(kdsldptrace%d): 232,16 [ 15.602037][ T450] cchardevice: device_create(kdsldptrace%d): 232,17 [ 15.602307][ T450] cchardevice: device_create(kdsldptrace%d): 232,18 [ 15.602566][ T450] cchardevice: device_create(kdsldptrace%d): 232,19 [ 15.602861][ T450] cchardevice: device_create(kdsldptrace%d): 232,20 [ 15.603168][ T450] cchardevice: device_create(kdsldptrace%d): 232,21 [ 15.603435][ T450] cchardevice: device_create(kdsldptrace%d): 232,22 net.ipv4.tcp_min_snd_mss = 536 [ 15.603745][ T450] cchardevice: device_create(kdsldptrace%d): 232,23 [ 15.604019][ T450] cchardevice: device_create(kdsldptrace%d): 232,24 [ 15.604285][ T450] cchardevice: device_create(kdsldptrace%d): 232,25 [ 15.604580][ T450] cchardevice: device_create(kdsldptrace%d): 232,26 [ 15.604873][ T450] cchardevice: device_create(kdsldptrace%d): 232,27 [ 15.605142][ T450] cchardevice: device_create(kdsldptrace%d): 232,28 [ 15.605546][ T450] cchardevice: device_create(kdsldptrace%d): 232,29 [ 15.605867][ T450] cchardevice: device_create(kdsldptrace%d): 232,30 [ 15.606170][ T450] cchardevice: device_create(kdsldptrace%d): 232,31 [ 15.606454][ T450] cchardevice: device_create(kdsldptrace%d): 232,32 [ 15.610541][ T450] kdsld[0]: Initialisation of packettrace [OK] [ 15.610581][ T450] kdsld[0]: Initialisation of nqos ... [ 15.610711][ T450] cchardevice: device_create(knqos): 231,0 [ 15.612517][ T450] cchardevice: device_create(avmtrackd): 230,0 [ 15.612893][ T450] cchardevice: device_create(avmtrackdquery): 229,0 [ 15.613431][ T450] kdsld[0]: Initialisation of nqos [OK] [ 15.613467][ T450] kdsld[0]: Initialisation of http_filter ... [ 15.613589][ T450] cchardevice: device_create(userman_url): 228,0 [ 15.613912][ T450] url_dev_register device userman_url registered [ 15.613948][ T450] kdsld[0]: Initialisation of http_filter [OK] [ 15.613975][ T450] kdsld[0]: Initialisation of atmvcchook ... [ 15.614003][ T450] kdsld[0]: Initialisation of atmvcchook [OK] [ 15.614029][ T450] kdsld[0]: Initialisation of timer ... [ 15.614090][ T450] kdsld[0]: Initialisation of timer [OK] [ 15.614117][ T450] kdsld[0]: Initialisation of netdevice_notifier ... [ 15.614187][ T450] kdsld[0]: Initialisation of netdevice_notifier [OK] [ 15.614216][ T450] kdsld[0]: Initialisation of ttychannel_ldisc ... [ 15.614245][ T450] kdsld[0]: ttychannel: ldisc 8 registered [ 15.614271][ T450] kdsld[0]: Initialisation of ttychannel_ldisc [OK] [ 15.614297][ T450] kdsld[0]: Initialisation of guestflt ... [ 15.614512][ T450] cchardevice: device_create(guestflt): 227,0 [ 15.614816][ T450] kdsld[0]: Initialisation of guestflt [OK] [ 15.614850][ T450] kdsld[0]: Initialisation of bridgeflt ... [ 15.614940][ T450] cchardevice: device_create(bridgeflt): 226,0 [ 15.615275][ T450] kdsld[0]: Initialisation of bridgeflt [OK] [ 15.615308][ T450] kdsld[0]: Initialisation of krextd ... [ 15.615337][ T450] kdsld[0]: Initialisation of krextd:debughandles ... [ 15.615415][ T450] kdsld[0]: Initialisation of krextd:debughandles [OK] [ 15.615443][ T450] kdsld[0]: Initialisation of krextd:global ... [ 15.615473][ T450] kdsld[0]: Initialisation of krextd:global [OK] [ 15.615500][ T450] kdsld[0]: Initialisation of krextd:memcache ... [ 15.617010][ T450] kdsld[0]: Initialisation of krextd:memcache [OK] [ 15.617046][ T450] kdsld[0]: Initialisation of krextd:igmpcompr ... [ 15.617083][ T450] kdsld[0]: Initialisation of krextd:igmpcompr [OK] [ 15.617110][ T450] kdsld[0]: Initialisation of krextd:krextdev ... [ 15.617206][ T450] cchardevice: device_create(krextd): 225,0 [ 15.617594][ T450] kdsld[0]: Initialisation of krextd:krextdev [OK] [ 15.617629][ T450] kdsld[0]: Initialisation of krextd:krextdev_wland ... [ 15.617787][ T450] cchardevice: device_create(krextd_wlan): 224,0 [ 15.618106][ T450] kdsld[0]: Initialisation of krextd:krextdev_wland [OK] [ 15.618140][ T450] kdsld[0]: Initialisation of krextd:netdevice_notifier ... [ 15.618208][ T450] kdsld[0]: Initialisation of krextd:netdevice_notifier [OK] [ 15.618237][ T450] kdsld[0]: Initialisation of krextd:krextdprocfs ... [ 15.618348][ T450] kdsld[0]: Initialisation of krextd:krextdprocfs [OK] [ 15.618377][ T450] kdsld[0]: Initialisation of krextd:krextdtimer ... [ 15.618413][ T450] kdsld[0]: Initialisation of krextd:krextdtimer [OK] [ 15.618441][ T450] kdsld[0]: Initialisation of krextd [OK] [ 15.618470][ T450] kdsld[0]: Initialisation of kdsldprocfs ... [ 15.618560][ T450] kdsld[0]: Initialisation of kdsldprocfs [OK] [ 15.618589][ T450] kdsld[0]: Initialisation of pcp ... [ 15.619323][ T450] kdsld[0]: Initialisation of pcp [OK] [ 15.619358][ T450] kdsld[0]: Initialisation [OK] 0+[INFO] /dev/ubi0_3 mounted at /var/media/ftp 1 records in 0+1 records out [ 15.653780][ T454] kspeedtest: kspeedtest_init: second timer started [ 15.653896][ T454] kspeedtest: Starting default task on discard port 9 [Supervisor] Info: apparmor.service exit success [ 15.653984][ T454] kspeedtest: listening on port 9 [ 15.654009][ T454] kspeedtest: kspeedtest_init done [ 15.683948][ T457] cchardevice: device_create(net_us): 223,0 [ 15.684309][ T457] net_upstream: AVM net_upstream driver: init done [ 15.724070][ T440] * [ 15.770968][ T463] QCE50: __qce_get_device_tree_data: BAM Apps EE is not defined, setting to default 1 [ 15.771453][ T463] QCE50: __qce_init_clk: Unable to get CE core src clk, set to NULL [ 15.771554][ T463] qcrypto 8e20000.qcrypto: Qualcomm Crypto 5.3.1 device found @0x8e20000 [ 15.771591][ T463] qcrypto 8e20000.qcrypto: CE device = 0x0 IO base, CE = 0xd1fc0000 Consumer (IN) PIPE 2, Producer (OUT) PIPE 3 IO base BAM = 0x00000000 BAM IRQ 23 Engines Availability = 0x2010453 [ 15.771643][ T463] sps_register_bam_device : unable to create IPC Logging 0 for bam 0x08e04000 [ 15.771667][ T463] sps_register_bam_device : unable to create IPC Logging 1 for bam 0x08e04000 [ 15.771694][ T463] sps_register_bam_device : unable to create IPC Logging 2 for bam 0x08e04000 [ 15.771714][ T463] sps_register_bam_device : unable to create IPC Logging 3 for bam 0x08e04000 [ 15.771740][ T463] sps_register_bam_device : unable to create IPC Logging 4 for bam 0x08e04000 [ 15.771761][ T463] sps:BAM 0x08e04000 is registered. [ 15.771985][ T463] sps:BAM 0x08e04000 (va:0xd2040000) enabled: ver:0x27, number of pipes:4 [ 15.772244][ T463] QCE50: qce_sps_init: Qualcomm MSM CE-BAM at 0x0000000008e04000 irq 23 [ 15.774544][ T463] bus_scale_table is NULL [ 15.774830][ T463] qcrypto 8e20000.qcrypto: qcrypto-ecb-aes [ 15.775023][ T463] qcrypto 8e20000.qcrypto: qcrypto-cbc-aes [ 15.775204][ T463] qcrypto 8e20000.qcrypto: qcrypto-ctr-aes [ 15.775386][ T463] qcrypto 8e20000.qcrypto: qcrypto-ecb-des [ 15.775564][ T463] qcrypto 8e20000.qcrypto: qcrypto-cbc-des [ 15.775741][ T463] qcrypto 8e20000.qcrypto: qcrypto-ecb-3des [ 15.775967][ T463] qcrypto 8e20000.qcrypto: qcrypto-cbc-3des [ 15.776144][ T463] qcrypto 8e20000.qcrypto: qcrypto-xts-aes [ 15.776321][ T463] qcrypto 8e20000.qcrypto: qcrypto-sha1 [ 15.776527][ T463] qcrypto 8e20000.qcrypto: qcrypto-sha256 [ 15.776710][ T463] qcrypto 8e20000.qcrypto: qcrypto-aead-hmac-sha1-cbc-aes [ 15.776886][ T463] qcrypto 8e20000.qcrypto: qcrypto-aead-hmac-sha1-cbc-des [ 15.777080][ T463] qcrypto 8e20000.qcrypto: qcrypto-aead-hmac-sha1-cbc-3des [ 15.777272][ T463] qcrypto 8e20000.qcrypto: qcrypto-aead-hmac-sha256-cbc-aes [ 15.777503][ T463] qcrypto 8e20000.qcrypto: qcrypto-aead-hmac-sha256-cbc-des [ 15.777679][ T463] qcrypto 8e20000.qcrypto: qcrypto-aead-hmac-sha256-cbc-3des [ 15.777850][ T463] qcrypto 8e20000.qcrypto: qcrypto-hmac-sha1 [ 15.778032][ T463] qcrypto 8e20000.qcrypto: qcrypto-hmac-sha256 [ 15.778225][ T463] qcrypto 8e20000.qcrypto: qcrypto-aes-ccm [ 15.778390][ T463] qcrypto 8e20000.qcrypto: qcrypto-rfc4309-aes-ccm [ 15.901846][ T440] * [ 15.908424][ T504] audit: type=1400 audit(15.899:2): apparmor="STATUS" operation="profile_load" name="/sbin/nqcs" pid=504 comm="dd" [ 15.925251][ T506] UBIFS (ubi0:3): background thread "ubifs_bgt0_3" started, PID 506 [ 15.960288][ T505] UBIFS (ubi0:3): recovery needed [ 16.072340][ T505] UBIFS (ubi0:3): recovery completed [ 16.072527][ T505] UBIFS (ubi0:3): UBIFS: mounted UBI device 0, volume 3, name "avm_userdata" [ 16.072559][ T505] UBIFS (ubi0:3): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes [ 16.072588][ T505] UBIFS (ubi0:3): FS size: 11808768 bytes (11 MiB, 93 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs) [ 16.072615][ T505] UBIFS (ubi0:3): reserved for root: 557756 bytes (544 KiB) [ 16.072646][ T505] UBIFS (ubi0:3): media format: w4/r0 (latest is w4/r0), UUID 0BBC755E-2D92-43F3-8F31-196AEE42F75E, small LPT model [ 16.079621][ T440] *********************** [ 20.065692][ T440] [1]system-load 65% loadavg 0.57 0.13 0.4 - task runtime:17% max:modprobe 15% pgstat: sum=56792 free=43075 slab=4432 alloc=1708/s fault=1151/s (sleep 6) [ 20.170505][ T440] * [ 20.273376][ T440] [piglet]dect_file_process: upload of 'dectfw_secondlevel_441.hex' successfull [ 20.279520][ T440] msm_serial_dectuart_exit [ 20.633651][ T0] [2]system-load 30% loadavg 0.57 0.13 0.4 - task runtime:9% max:modprobe 8% pgstat: sum=56792 free=43190 slab=4432 alloc=1539/s fault=1005/s (sleep 0) vm.laptop_mode = 2 [Supervisor] Info: filesystem.service exit success TAM: create directory /data/tam vm.dirty_expire_centisecs = 100 [Supervisor] Info: start default-files.service vm.dirty_writeback_centisecs = 100 net.ipv4.ip_forward = 0 net.ipv6.conf.all.forwarding = 0 net.ipv4.conf.all.rp_filter = 1 net.ipv4.conf.default.rp_filter = 1 net.ipv6.conf.default.disable_ipv6 = 1 net.ipv6.conf.all.autoconf = 0 net.ipv6.conf.default.autoconf = 0 net.ipv4.tcp_min_tso_segs = 100 net.core.rmem_max = 10000000 kernel.panic_on_oops = 1 vm.panic_on_oom = 2 [Supervisor] Info: sysctl.service exit success [ 21.332689][ T524] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_analog: norm_power_rate=100 act_rate=0 mul=141 div=10 offset=100 NormP=1510 mW -> SumNormP=1510 mW [ 21.332806][ T524] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_wlan: norm_power_rate=100 act_rate=0 mul=130 div=10 offset=100 NormP=1400 mW -> SumNormP=2910 mW [ 21.332876][ T524] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_cpuclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=2910 mW [Supervisor] Info: default-files.service exit success [Supervisor] Info: reached target local-fs.target Jan 1 1970 01:00:21 ar7cfgctl[528]: [ERROR] load_config(ar7): file empty - factory default loaded [ 21.332937][ T524] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_loadrate: norm_power_rate=100 act_rate=22 mul=29 div=10 offset=-17 NormP=273 mW -> SumNormP=3183 mW [Supervisor] Info: start config.service [ 21.332998][ T524] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_dspclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=1500 NormP=1500 mW -> SumNormP=4683 mW [ 21.333058][ T524] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_systemclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=2500 NormP=2500 mW -> SumNormP=7183 mW [ 21.333119][ T524] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_dect: norm_power_rate=100 act_rate=0 mul=200 div=78 offset=150 NormP=406 mW -> SumNormP=7589 mW [ 21.333179][ T524] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_usb_host: norm_power_rate=900 act_rate=0 mul=5 div=1 offset=0 NormP=4500 mW -> SumNormP=12089 mW [ 21.333239][ T524] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_dsl: norm_power_rate=100 act_rate=0 mul=15 div=1 offset=0 NormP=1500 mW -> SumNormP=13589 mW [ 21.333301][ T524] [avm_power]pm_ressourceinfo_scriptparse: powerdevice_ethernet: norm_power_rate=2267 act_rate=134217728 mul=1 div=1 offset=50 NormP=2317 mW -> SumNormP=15906 mW [Supervisor] Info: config.service exit success [ 22.482835][ T440] avm_set_reset_status: Soft-Reboot(PANIC) - PANIC(1)UP(22)UTC(22)FW(08.25)HW(236)HWS(2)BV(1.11581)BN(131719)FS(08.25)BT(1)BD(0) [ 22.483377][ F0] [qcom_wdt] FIQ watchdog handling, master: CPU#0, retry counter=0, caught slaves: 3 [ 22.483387][ F0] [qcom_wdt] Non secure ISFR=0x7, DSFR=0x80f, IFAR=0xb6ea60e4, DFAR=0x19c83dc [ 22.483398][ F0] [qcom_wdt] [collect_pregs] set crashed_cpu to handling_master #1 ... [ 22.483406][ F0] [qcom_wdt] [collect_pregs] ... and switch handling_master to CPU#0 [ 22.483419][ F0] [qcom_wdt] [collect_pregs] PANIC-HANDLING CRASHED CPU: PC=0xc020f508, LR=0xc020f4e0, SP=0xcdae3d88 on CPU#1 [ 22.483426][ F0] [qcom_wdt] let slaves go awaiting the backtrace trigger [ 22.483432][ F0] [qcom_wdt] die with mode change [ 22.483437][ F1] [qcom_wdt] setting CPU NR 1 offline! [ 22.483445][ F3] [qcom_wdt] setting CPU NR 3 offline! [ 22.483452][ F2] [qcom_wdt] setting CPU NR 2 offline! [ 22.483458][ F0] [qcom_wdt] [avm_rte_die]: crashed_cpu is CPU#1, continuing in SVC [ 22.483472][ T0] Internal error: [piglet]bye bye - can't detect TDM-FS or TDM-CLK! [ 22.483472][ T0] : 0 [#1] PREEMPT SMP ARM [ 22.576337][ T0] FIQ watchdog handling, master CPU calls die notifier ... [ 22.588069][ T0] Following notifiers will be called for chain (check System.map): 0xc0bfcb3c: [ 22.595400][ T0] - hw_breakpoint_exceptions_notify: [ 22.604031][ T0] - die_notifier: [ 22.609445][ T0] - die_notifier: [ 22.612880][ T0] [notifier] hw_breakpoint_exceptions_notify: [ 22.616651][ T0] [notifier] die_notifier: [ 22.622351]Modules linked in: qcrypto qce50 net_upstream_drv(O) kspeedtest(O) kdsldmod(PO) kskbtrace(O) b2b_drv(O) cchardev(O) cprocfsmod(O) Piglet_noemif(PO+) essedma(O) sch_tbf qca_ssdk(O) vrx518(O) hui(O) [ 22.644817][ T0] Process modprobe (pid: 440, stack limit = 0xcdae0210) [ 22.645101][ F1] [monitor_ipi_firq_context] MONITOR_BT fiq_regs, regs=0xc0c44c20 [ 22.645108][ F1] [monitor_ipi_firq_context] slave cpu is crashed cpu! [ 22.645115][ F1] [monitor_ipi_firq_context] just memcpy pregs! [ 22.645125][ T0] [ 22.672249][ T0] CPU: 1 Pid: 440, comm: modprobe [ 22.674641][ T0] Tainted: P O (4.4.271 #1) [ 22.680161][ T0] PC is at panic+0x224/0x2bc [ 22.686530][ T0] LR is at panic+0x1fc/0x2bc [ 22.690838][ T0] pc :[] lr :[] psr: 60000013 [ 22.690838][ T0] sp : cdae3d88 ip : 28008000 fp : bf1260cc [ 22.695396][ T0] r10: 00000000 r9 : c0a91748 r8 : c0a91748 [ 22.707803][ T0] r7 : c0a7c408 r6 : bf12556e r5 : cdae3da4 r4 : 00000008 [ 22.713929][ T0] r3 : 00000000 r2 : 00000008 r1 : 00000204 r0 : 28008000 [ 22.721691][ T0] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user [ 22.729156][ T0] Control: 10c5387d Table: 8dad006a DAC: 00000051 [ 22.737002][ T0] Classified pointer on registers: [ 22.743301][ T0] r5 : cdae3da4 [stack(modprobe): cdae0000+0x3da4] [ 22.748302][ T0] Backtrace: [ 22.754688][ T0] 3dac: [] (0xc020f508 panic+0x224/0x2bc) [ 22.757465][ T0] 3dbc: [] (0xbf1221a4 piglet_loader_thread+0x58/0x360 [Piglet_noemif]) [ 22.764084][ T0] 3dec: [] (0xbf129190 init_module+0x190/0x1000 [Piglet_noemif]) [ 22.772918][ T0] 3e64: [] (0xc021f4a0 do_one_initcall+0x1bc/0x200) [ 22.781473][ T0] 3e7c: [] (0xc02a2bd8 do_init_module+0x54/0x1c4) [ 22.788625][ T0] 3f3c: [] (0xc02a43a8 load_module+0xb98/0xef0) [ 22.795919][ T0] 3fa4: [] (0xc02a4958 SyS_finit_module+0x98/0xc0) [ 22.802566][ T0] Code: e1a0000c e1a01003 e1a02004 e1600070 (eafffffe) [ 22.809971][ T0] Stack: (0xcdae3d88 to 0xcdae4000) [ 22.816710][ T0] 3d80: cdae3da4 dc8ba6ff dc8ba6ff c0a7c408 bf1260cc bf1221a4 [ 22.821875][ T0] 3da0: bf12556e 0f34b000 dc8ba6ff c020f2e4 bf1262d8 00000000 cdb27380 bf129190 [ 22.830730][ T0] 3dc0: c0a91748 00000000 00000080 00000000 00000000 dc8ba6ff c0a7c408 bf129000 [ 22.839582][ T0] 3de0: c0a7c408 cdb27380 00000000 c021f4a0 c0976824 00000000 8020001e c02ef5e0 [ 22.848314][ T0] 3e00: 8020001f cffca8e0 c0a7c408 c02f64d8 ce9c7a00 c02a43a0 8020001e cffca8e0 [ 22.857291][ T0] 3e20: c0a7c408 c02f64d8 c02ef5e0 dc8ba6ff cf801e40 cdb27300 024000c0 c02a2b9c [ 22.866143][ T0] 3e40: 00011641 dc8ba6ff bf1260c0 bf1260c0 cdae3f48 cdb27300 00000003 cdae3ed8 [ 22.874998][ T0] 3e60: 00000000 c02a2bd8 bf1260c0 00000000 bf1260c0 cdae3f48 00000000 c02a43a8 [ 22.883855][ T0] 3e80: ffff8000 00007fff bf1260c0 c02a1c0c c0a7c484 d1c84744 bf12a000 dc8ba6ff [ 22.892582][ T0] 3ea0: c0970380 01cac1d8 00000000 c02a0cec d1c78000 0000c7bc 00000000 c023030c [ 22.901562][ T0] 3ec0: 00000000 00000000 00000000 00000000 00000000 00000000 6e72656b 00006c65 [ 22.910414][ T0] 3ee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 22.919266][ T0] 3f00: 00000000 00000000 00000000 00000000 00000000 dc8ba6ff 01cac1d8 c0a7c408 [ 22.928124][ T0] 3f20: 00000000 01cac1d8 00000003 c0209fa4 cdae0000 0000017b 01cac140 c02a4958 [ 22.936855][ T0] 3f40: 0000c7bc c02d8ee4 d1c78000 0000c7bc d1c840dc d1c83f10 d1c81010 00009000 [ 22.945832][ T0] 3f60: 00009880 bf126070 00000001 00000000 000039e0 00000029 0000002a 0000001e [ 22.954687][ T0] 3f80: 00000000 00000016 00000000 dc8ba6ff 00000003 00040000 01cac1d8 00000000 [ 22.963537][ T0] 3fa0: 0000017b c0209dc0 00040000 01cac1d8 00000003 01cac1d8 00000000 01cac140 [ 22.972273][ T0] 3fc0: 00040000 01cac1d8 00000000 0000017b 01cab4d0 00000000 01cac140 01cac140 [ 22.981126][ T0] 3fe0: bef22568 bef22558 004248e0 b6e52db0 60000010 00000003 00000000 00000000 [ 22.990131][ T0] Classified pointer on stack: [ 22.998818][ T0] cdae3da4 [stack(modprobe): cdae0000+0x3da4] [ 23.003698][ T0] bf1221a4 piglet_loader_thread+0x58/0x360 [Piglet_noemif] [ 23.009335][ T0] c020f2e4 panic+0x0/0x2bc [ 23.016533][ T0] cdb27380 [slab: type:kmalloc-64 size:128 start:0xcdb27380+0x0 freed by:0xc0447c68 security_file_free+0x24/0x30] [ 23.020861][ T0] bf129190 init_module+0x190/0x1000 [Piglet_noemif] [ 23.032486][ T0] bf129000 init_module+0x0/0x1000 [Piglet_noemif] [ 23.038872][ T0] c021f4a0 do_one_initcall+0x1bc/0x200 [ 23.045045][ T0] c0976824 sysfs_bin_kfops_ro+0x0/0x24 [ 23.050526][ T0] c02ef5e0 __vunmap+0xac/0xbc [ 23.055937][ T0] cffca8e0 [page: type:reserved] [ 23.060025][ T0] c02f64d8 free_debug_processing_fast+0xf8/0x130 [ 23.064949][ T0] ce9c7a00 [slab: type:kmalloc-64 size:128 start:0xce9c7a00+0x0 freed by:0xbf121a7c log_piglet_exit+0xc4/0xe8 [Piglet_noemif]] [ 23.071310][ T0] c02a43a0 load_module+0xb90/0xef0 [ 23.084201][ T0] cffca8e0 [page: type:reserved] [ 23.089230][ T0] c02f64d8 free_debug_processing_fast+0xf8/0x130 [ 23.093704][ T0] c02ef5e0 __vunmap+0xac/0xbc [ 23.099907][ T0] cf801e40 [slab: type:kmem_cache size:192 start:0xcf801e40+0x0 allocated by:0xc0a46e04 create_kmalloc_cache+0x20/0x80] [ 23.104589][ T0] cdb27300 [slab: type:kmalloc-64 size:128 start:0xcdb27300+0x0 allocated by:0xc02a2b9c do_init_module+0x18/0x1c4] [ 23.116952][ T0] c02a2b9c do_init_module+0x18/0x1c4 [ 23.128861][ T0] cdae3f48 [stack(modprobe): cdae0000+0x3f48] [ 23.133879][ T0] cdb27300 [slab: type:kmalloc-64 size:128 start:0xcdb27300+0x0 allocated by:0xc02a2b9c do_init_module+0x18/0x1c4] [ 23.139691][ T0] cdae3ed8 [stack(modprobe): cdae0000+0x3ed8] [ 23.151714][ T0] c02a2bd8 do_init_module+0x54/0x1c4 [ 23.157547][ T0] cdae3f48 [stack(modprobe): cdae0000+0x3f48] [ 23.162563][ T0] c02a43a8 load_module+0xb98/0xef0 [ 23.168550][ T0] c02a1c0c unknown_module_param_cb+0x0/0x64 [ 23.173595][ T0] c0970380 modinfo_attrs+0x0/0x24 [ 23.179381][ T0] Code: Code(0xc020f500): 0xe1a02004 0xe1600070 <0xeafffffe> 0xeb02780d 0xe1550007 [ 23.183893] Backtrace of all other CPU's: [ 23.193387][ T0] [monitor_ipi_direct_context] MONITOR_BT exception_regs, regs=0xc0c44bd8 [ 23.197411][ T0] [monitor_ipi_direct_context] master cpu is not crashed cpu! [ 23.205629][ T0] [monitor_ipi_direct_context] just memcpy pregs! [ 23.212918][ T0] [monitor_ipi_direct_context] BT register set valid! [ 23.219047][ T0] [ 23.225636][ T0] CPU: 0 Pid: 0, comm: swapper/0 [ 23.228197][ T0] Tainted: P O (4.4.271 #1) [ 23.233723][ T0] PC is at cpu_ca15_do_idle+0x8/0xc [ 23.239917][ T0] LR is at arch_cpu_idle+0x34/0x58 [ 23.244916][ T0] pc :[] lr :[] psr: 60000093 [ 23.244916][ T0] sp : c0a7bfa0 ip : 00000000 fp : c0bd801c [ 23.250084][ T0] r10: c0a6a8c0 r9 : c0bd8020 r8 : c0a7c400 [ 23.262312][ T0] r7 : c0a7c4c8 r6 : ffffc000 r5 : 00000000 r4 : 00000000 [ 23.268563][ T0] r3 : c020b5e0 r2 : 00000000 r1 : 00000000 r0 : 00000000 [ 23.276081][ T0] Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel [ 23.283669][ T0] Control: 10c5387d Table: 8e85806a DAC: 00000051 [ 23.291549][ T0] Classified pointer on registers: [ 23.297951][ T0] r3 : c020b5e0 cpu_ca15_do_idle+0x0/0xc [ 23.303198][ T0] Backtrace: [ 23.308291][ T0] 3f9c: [] (0xc020b5e8 cpu_ca15_do_idle+0x8/0xc) [ 23.311336][ T0] 3fa4: [] (0xc0224f88 arch_cpu_idle+0x34/0x58) [ 23.318665][ T0] 3fac: [] (0xc0271cc0 cpu_startup_entry+0x160/0x228) [ 23.325346][ T0] Code: ee010f10 e12fff1e f57ff04f e320f003 (e12fff1e) [ 23.332850][ T0] Stack: (0xc0a7bfa0 to 0xc0a7c000) [ 23.339750][ T0] bfa0: 00000000 c0271cc0 c0a7c408 c0a3ac20 ffffffff ffffffff 00000000 c0a3a590 [ 23.344791][ T0] bfc0: 00000000 cfffc180 c0a6a8c0 00000000 00000000 c0bd8118 c0a7c464 c0a6a8bc [ 23.353521][ T0] bfe0: c0a7fa14 8020406a 410fc075 00000000 00000000 80208088 00000000 00000000 [ 23.362524][ T0] Classified pointer on stack: [ 23.371336][ T0] c0271cc0 cpu_startup_entry+0x160/0x228 [ 23.375911][ T0] c0a3ac20 start_kernel+0x348/0x3d0 [ 23.381252][ T0] c0a3a590 unknown_bootoption+0x0/0x1b8 [ 23.386488][ T0] cfffc180 [page: type:reserved] [ 23.391904][ F2] [monitor_ipi_firq_context] MONITOR_BT fiq_regs, regs=0xc0c44c68 [ 23.391911][ F2] [monitor_ipi_firq_context] slave cpu is not crashed cpu! [ 23.391917][ F2] [monitor_ipi_firq_context] just memcpy pregs! [ 23.391927][ T0] [ 23.417217][ T0] CPU: 2 Pid: 0, comm: swapper/2 [ 23.419604][ T0] Tainted: P O (4.4.271 #1) [ 23.425126][ T0] PC is at cpu_ca15_do_idle+0x8/0xc [ 23.431325][ T0] LR is at arch_cpu_idle+0x34/0x58 [ 23.436322][ T0] pc :[] lr :[] psr: 60000093 [ 23.436322][ T0] sp : cf8a3fe8 ip : 00000000 fp : 00000000 [ 23.441488][ T0] r10: 00000000 r9 : 410fc075 r8 : 8020406a [ 23.453720][ T0] r7 : c0a7c4c8 r6 : ffffc000 r5 : 00000000 r4 : 00000000 [ 23.459970][ T0] r3 : c020b5e0 r2 : 00000000 r1 : 00000000 r0 : 00000000 [ 23.467487][ T0] Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel [ 23.475077][ T0] Control: 10c5387d Table: 8ef5c06a DAC: 00000051 [ 23.482963][ T0] Classified pointer on registers: [ 23.489359][ T0] r3 : c020b5e0 cpu_ca15_do_idle+0x0/0xc [ 23.494684][ T0] Backtrace: [ 23.499694][ T0] 3fe4: [] (0xc020b5e8 cpu_ca15_do_idle+0x8/0xc) [ 23.502739][ T0] 3fec: [] (0xc0224f88 arch_cpu_idle+0x34/0x58) [ 23.510068][ T0] 3ff4: [] (0xc0271cc0 cpu_startup_entry+0x160/0x228) [ 23.516748][ T0] Code: ee010f10 e12fff1e f57ff04f e320f003 (e12fff1e) [ 23.524255][ T0] Stack: (0xcf8a3fe8 to 0xcf8a4000) [ 23.531152][ T0] 3fe0: 00000000 c0271cc0 c0bd82a8 8020966c 00000000 00000000 [ 23.536220][ T0] Classified pointer on stack: [ 23.544913][ T0] c0271cc0 cpu_startup_entry+0x160/0x228 [ 23.549677][ F3] [monitor_ipi_firq_context] MONITOR_BT fiq_regs, regs=0xc0c44cb0 [ 23.549684][ F3] [monitor_ipi_firq_context] slave cpu is not crashed cpu! [ 23.549690][ F3] [monitor_ipi_firq_context] just memcpy pregs! [ 23.549701][ T0] [ 23.575722][ T0] CPU: 3 Pid: 0, comm: swapper/3 [ 23.578110][ T0] Tainted: P O (4.4.271 #1) [ 23.583759][ T0] PC is at cpu_ca15_do_idle+0x8/0xc [ 23.589708][ T0] LR is at arch_cpu_idle+0x34/0x58 [ 23.594830][ T0] pc :[] lr :[] psr: 60000093 [ 23.594830][ T0] sp : cf8a7fe8 ip : 00000000 fp : 00000000 [ 23.600118][ T0] r10: 00000000 r9 : 410fc075 r8 : 8020406a [ 23.612102][ T0] r7 : c0a7c4c8 r6 : ffffc000 r5 : 00000000 r4 : 00000000 [ 23.618480][ T0] r3 : c020b5e0 r2 : 00000000 r1 : 00000000 r0 : 00000000 [ 23.625995][ T0] Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel [ 23.633581][ T0] Control: 10c5387d Table: 8dbe006a DAC: 00000051 [ 23.641469][ T0] Classified pointer on registers: [ 23.647864][ T0] r3 : c020b5e0 cpu_ca15_do_idle+0x0/0xc [ 23.653191][ T0] Backtrace: [ 23.658202][ T0] 3fe4: [] (0xc020b5e8 cpu_ca15_do_idle+0x8/0xc) [ 23.661244][ T0] 3fec: [] (0xc0224f88 arch_cpu_idle+0x34/0x58) [ 23.668574][ T0] 3ff4: [] (0xc0271cc0 cpu_startup_entry+0x160/0x228) [ 23.675256][ T0] Code: ee010f10 e12fff1e f57ff04f e320f003 (e12fff1e) [ 23.682761][ T0] Stack: (0xcf8a7fe8 to 0xcf8a8000) [ 23.689659][ T0] 7fe0: 00000000 c0271cc0 c0bd82a8 8020966c 00000000 00000000 [ 23.694724][ T0] Classified pointer on stack: [ 23.703416][ T0] c0271cc0 cpu_startup_entry+0x160/0x228 [ 23.708174][ T0] [ 23.708174][ T0] Backtrace of all other CPU's done [ 23.708174][ T0] [ 23.713406][ T0] FASTIRQ-Status: [ 23.722819][ T0] CPU0 CPU1 CPU2 CPU3 [ 23.726204][ T0] 35: 1 1 1 1 watchdog_bark * [ 23.733244][ T0] 36: 0 0 0 0 watchdog_bite [ 23.741811][ T0] 213: 1 1 1 1 secure-watchdog [ 23.750013][ T0] 272: 1 0 0 0 edma_eth_rx_0_fiq [ 23.758513][ T0] IPI9: 0 RTE monitor [ 23.767003][ T0] preempts: 0 0 0 0 [ 23.772089][ T0] spurious: 53506 0 1 1 [ 23.778986][ T0] consum: 0.0 0.0 0.0 0.0 [ 23.785839][ T0] ---[ end trace 8cdb39072fb1c248 ]--- [ 23.792569][ T0] [qcom_wdt] FIQ watchdog handling, master CPU calls nmi notifier ... [ 23.798171][ T0] Following notifiers will be called for chain (check System.map): 0xc0c44bc4: [ 23.805774][ T0] - nmi_timer_notify: [ 23.814915][ T0] [notifier] nmi_timer_notify: [ 23.818719][ T0] CPU0: active_timers: 15 [ 23.818719][ T0] last: 0xc0289aac process_timeout+0x0/0x4 before 0 ms [ 23.818719][ T0] running: (null) [ 23.818719][ T0] next: 0xc0289aac process_timeout+0x0/0x4 in 16 ms [ 23.824402][ T0] [qcom_wdt] FIQ watchdog handling, master CPU calls panic notifier chain ... [ 23.846519][ T0] Following notifiers will be called for chain (check System.map): 0xc0bfc560: [ 23.854942][ T0] - ssr_panic_handler: [ 23.863837][ T0] - panic_handler: [ 23.867861][ T0] - rcu_panic: [ 23.871476][ T0] - arch_ipq_panic_notifier: [ 23.874861][ T0] - hung_task_panic: [ 23.879760][ T0] - thermal_panic_notify: [ 23.883541][ T0] [notifier] ssr_panic_handler: [ 23.887798][ T0] [notifier] panic_handler: [ 23.892673][ T0] [notifier] rcu_panic: [ 23.896822][ T0] [notifier] arch_ipq_panic_notifier: [ 23.900939][ T0] [notifier] hung_task_panic: [ 23.905852][ T0] [notifier] thermal_panic_notify: [ 23.958033][ T0] [qcom_wdt] FIQ watchdog handling, master CPU with kmsg_dump() done ... [ 23.958355][ T0] Following notifiers will be called for chain (check System.map): 0xc0bfcb64: [ 23.965471][ T0] - qcom_wdt_restart: [ 23.974281][ T0] [notifier] qcom_wdt_restart: [ 23.978306][ T0] [qcom_wdt] [qcom_wdt_restart] ... Format: Log Type - Time(microsec) - Message - Optional Info Log Type: B - Since Boot(Power On Reset), D - Delta, S - Statistic S - QC_IMAGE_VERSION_STRING=AVM_BOOT.BF.3.1.1 S - IMAGE_VARIANT_STRING=DAABANAZA S - OEM_IMAGE_VERSION_STRING=1204 S - Boot Config, 0x00000025 S - Reset status Config, 0x00000033 S - Core 0 Frequency, 0 MHz B - 261 - PBL, Start B - 1339 - bootable_media_detect_entry, Start B - 2612 - bootable_media_detect_success, Start B - 2626 - elf_loader_entry, Start B - 4044 - auth_hash_seg_entry, Start B - 5977 - auth_hash_seg_exit, Start B - 110183 - elf_segs_hash_verify_entry, Start B - 301589 - PBL, End B - 0 - SBL1, Start B - 401886 - pm_device_init, Start D - 9 - pm_device_init, Delta B - 403016 - boot_flash_init, Start D - 80160 - boot_flash_init, Delta B - 487527 - boot_config_data_table_init, Start D - 13968 - boot_config_data_table_init, Delta - (419 Bytes) B - 503951 - clock_init, Start D - 7609 - clock_init, Delta B - 514533 - CDT version:2,Platform ID:8,Major B - 515837 - sbl1_ddr_set_params, Start B - 520546 - cpr_init, Start D - 4 - cpr_init, Delta B - 525624 - Pre_DDR_clock_init, Start D - 5 - Pre_DDR_clock_init, Delta D - 13022 - sbl1_ddr_set_params, Delta B - 539016 - pm_driver_init, Start D - 4 - pm_driver_init, Delta B - 574492 - sbl1_wait_for_ddr_training, Start D - 30 - sbl1_wait_for_ddr_training, Delta B - 590610 - Image Verify, Start 0:QSEE D - 284430 - QSEE Image Loaded, Delta - (293400 Bytes) B - 875355 - Image Verify, Start 0:QSEE_B D - 287187 - QSEE Image Loaded, Delta - (293400 Bytes) B - 1162988 - Selected TZ0: 15788 (0:QSEE) B - 1165940 - Image Load, Start D - 287096 - QSEE Image Loaded, Delta - (293400 Bytes) B - 1453349 - Image Load, Start D - 2030 - SEC Image Loaded, Delta - (2048 Bytes) B - 1466905 - Image Verify, Start 0:APPSBL D - 143142 - APPSBL Image Loaded, Delta - (137996 Bytes) B - 1610367 - Image Verify, Start 0:APPSBL_B D - 146500 - APPSBL Image Loaded, Delta - (137996 Bytes) B - 1757296 - Selected EVA0: 11581 (0:APPSBL) B - 1761035 - Image Load, Start D - 145554 - APPSBL Image Loaded, Delta - (137996 Bytes) B - 1906904 - QSEE Execution, Start D - 56 - QSEE Execution, Delta B - 1913083 - SBL1, End D - 1915218 - SBL1, Delta S - Flash Throughput, 2128 KB/s (1296655 Bytes, 609230 us) S - DDR Frequency, 672 MHz NAND corrected 1 @ page: 0x2BC800
