(kicad_sch
	(version 20250114)
	(generator "eeschema")
	(generator_version "9.0")
	(uuid "682c6d69-8613-4e5a-9d14-c681b224ad94")
	(paper "A5")
	(title_block
		(date "2025-12-16")
		(rev "3")
	(lib_symbols
		(symbol "Amplifier_Operational:TLV9061xDBV"
			(pin_names
				(offset 0.127)
			(exclude_from_sim no)
			(in_bom yes)
			(on_board yes)
			(property "Reference" "U"
				(at -1.27 6.35 0)
				(effects
					(font
						(size 1.27 1.27)
					(justify left)
			(property "Value" "TLV9061xDBV"
				(at -1.27 3.81 0)
				(effects
					(font
						(size 1.27 1.27)
					(justify left)
			(property "Footprint" "Package_TO_SOT_SMD:SOT-23-5"
				(at -15.24 -19.05 0)
				(effects
					(font
						(size 1.27 1.27)
					(justify left)
					(hide yes)
			(property "Datasheet" "https://www.ti.com/lit/ds/symlink/tlv9061.pdf"
				(at 0 20.32 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Description" "10-MHz, RRIO, CMOS Operational Amplifiers for Cost-Sensitive Systems, SOT-23-5"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "ki_keywords" "single opamp rail to rail input output"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "ki_fp_filters" "SOT?23*"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(symbol "TLV9061xDBV_0_1"
				(polyline
					(pts
						(xy -5.08 5.08) (xy 5.08 0) (xy -5.08 -5.08) (xy -5.08 5.08)
					(stroke
						(width 0.254)
						(type default)
					(fill
						(type background)
				(pin power_in line
					(at -2.54 7.62 270)
					(length 3.81)
					(name "V+"
						(effects
							(font
								(size 1.27 1.27)
					(number "5"
						(effects
							(font
								(size 1.27 1.27)
				(pin power_in line
					(at -2.54 -7.62 90)
					(length 3.81)
					(name "V-"
						(effects
							(font
								(size 1.27 1.27)
					(number "2"
						(effects
							(font
								(size 1.27 1.27)
			(symbol "TLV9061xDBV_1_1"
				(pin input line
					(at -7.62 2.54 0)
					(length 2.54)
					(name "+"
						(effects
							(font
								(size 1.27 1.27)
					(number "3"
						(effects
							(font
								(size 1.27 1.27)
				(pin input line
					(at -7.62 -2.54 0)
					(length 2.54)
					(name "-"
						(effects
							(font
								(size 1.27 1.27)
					(number "4"
						(effects
							(font
								(size 1.27 1.27)
				(pin output line
					(at 7.62 0 180)
					(length 2.54)
					(name "~"
						(effects
							(font
								(size 1.27 1.27)
					(number "1"
						(effects
							(font
								(size 1.27 1.27)
			(embedded_fonts no)
		(symbol "Connector:TestPoint_Small"
			(pin_numbers
				(hide yes)
			(pin_names
				(offset 0.762)
				(hide yes)
			(in_bom yes)
			(on_board yes)
			(property "Reference" "TP"
				(at 0 3.81 0)
				(effects
					(font
						(size 1.27 1.27)
			(property "Value" "TestPoint_Small"
				(at 0 2.032 0)
				(effects
					(font
						(size 1.27 1.27)
			(property "Footprint" ""
				(at 5.08 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Datasheet" "~"
				(at 5.08 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Description" "test point"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "ki_keywords" "test point tp"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "ki_fp_filters" "Pin* Test*"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(symbol "TestPoint_Small_0_1"
				(circle
					(center 0 0)
					(radius 0.508)
					(stroke
						(width 0)
						(type default)
					(fill
						(type none)
			(symbol "TestPoint_Small_1_1"
				(pin passive line
					(at 0 0 90)
					(length 0)
					(name "1"
						(effects
							(font
								(size 1.27 1.27)
					(number "1"
						(effects
							(font
								(size 1.27 1.27)
			(embedded_fonts no)
		(symbol "Connector_Generic:Conn_01x01"
			(pin_names
				(offset 1.016)
				(hide yes)
			(in_bom yes)
			(on_board yes)
			(property "Reference" "J"
				(at 0 2.54 0)
				(effects
					(font
						(size 1.27 1.27)
			(property "Value" "Conn_01x01"
				(at 0 -2.54 0)
				(effects
					(font
						(size 1.27 1.27)
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Description" "Generic connector, single row, 01x01, script generated (kicad-library-utils/schlib/autogen/connector/)"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "ki_keywords" "connector"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "ki_fp_filters" "Connector*:*_1x??_*"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(symbol "Conn_01x01_1_1"
				(rectangle
					(start -1.27 1.27)
					(end 1.27 -1.27)
					(stroke
						(width 0.254)
						(type default)
					(fill
						(type background)
				(rectangle
					(start -1.27 0.127)
					(end 0 -0.127)
					(stroke
						(width 0.1524)
						(type default)
					(fill
						(type none)
				(pin passive line
					(at -5.08 0 0)
					(length 3.81)
					(name "Pin_1"
						(effects
							(font
								(size 1.27 1.27)
					(number "1"
						(effects
							(font
								(size 1.27 1.27)
			(embedded_fonts no)
		(symbol "Device:C"
			(pin_numbers
				(hide yes)
			(pin_names
				(offset 0.254)
			(in_bom yes)
			(on_board yes)
			(property "Reference" "C"
				(at 0.635 2.54 0)
				(effects
					(font
						(size 1.27 1.27)
					(justify left)
			(property "Value" "C"
				(at 0.635 -2.54 0)
				(effects
					(font
						(size 1.27 1.27)
					(justify left)
				(at 0.9652 -3.81 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Description" "Unpolarized capacitor"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "ki_keywords" "cap capacitor"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "ki_fp_filters" "C_*"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(symbol "C_0_1"
				(polyline
					(pts
						(xy -2.032 0.762) (xy 2.032 0.762)
					(stroke
						(width 0.508)
						(type default)
					(fill
						(type none)
				(polyline
					(pts
						(xy -2.032 -0.762) (xy 2.032 -0.762)
					(stroke
						(width 0.508)
						(type default)
					(fill
						(type none)
			(symbol "C_1_1"
				(pin passive line
					(at 0 3.81 270)
					(length 2.794)
					(name "~"
						(effects
							(font
								(size 1.27 1.27)
					(number "1"
						(effects
							(font
								(size 1.27 1.27)
				(pin passive line
					(at 0 -3.81 90)
					(length 2.794)
					(name "~"
						(effects
							(font
								(size 1.27 1.27)
					(number "2"
						(effects
							(font
								(size 1.27 1.27)
			(embedded_fonts no)
		(symbol "Device:LED_Pad"
			(pin_names
				(offset 1.016)
				(hide yes)
			(in_bom yes)
			(on_board yes)
			(property "Reference" "D"
				(at 0 5.715 0)
				(effects
					(font
						(size 1.27 1.27)
			(property "Value" "LED_Pad"
				(at 0 3.81 0)
				(effects
					(font
						(size 1.27 1.27)
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Description" "Light emitting diode with pad"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "ki_keywords" "LED diode pad"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "ki_fp_filters" "LED* LED_SMD:* LED_THT:*"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(symbol "LED_Pad_0_1"
				(polyline
					(pts
						(xy -2.032 -0.508) (xy -2.032 -2.032) (xy 2.032 -2.032) (xy 2.032 -0.508)
					(stroke
						(width 0)
						(type default)
					(fill
						(type none)
				(polyline
					(pts
						(xy -1.27 0) (xy 1.27 0)
					(stroke
						(width 0)
						(type default)
					(fill
						(type none)
				(polyline
					(pts
						(xy -1.27 -1.27) (xy -1.27 1.27)
					(stroke
						(width 0.254)
						(type default)
					(fill
						(type none)
				(polyline
					(pts
						(xy -0.889 1.397) (xy 0.635 2.921) (xy -0.127 2.921) (xy 0.635 2.921) (xy 0.635 2.159)
					(stroke
						(width 0)
						(type default)
					(fill
						(type none)
				(polyline
					(pts
						(xy 0 -2.54) (xy 0 -2.032)
					(stroke
						(width 0)
						(type default)
					(fill
						(type none)
				(polyline
					(pts
						(xy 0.381 1.397) (xy 1.905 2.921) (xy 1.143 2.921) (xy 1.905 2.921) (xy 1.905 2.159)
					(stroke
						(width 0)
						(type default)
					(fill
						(type none)
				(polyline
					(pts
						(xy 1.27 -1.27) (xy 1.27 1.27) (xy -1.27 0) (xy 1.27 -1.27)
					(stroke
						(width 0.254)
						(type default)
					(fill
						(type none)
			(symbol "LED_Pad_1_1"
				(pin passive line
					(at -3.81 0 0)
					(length 2.54)
					(name "K"
						(effects
							(font
								(size 1.27 1.27)
					(number "1"
						(effects
							(font
								(size 1.27 1.27)
				(pin passive line
					(at 0 -5.08 90)
					(length 2.54)
					(name "PAD"
						(effects
							(font
								(size 1.27 1.27)
					(number "3"
						(effects
							(font
								(size 1.27 1.27)
				(pin passive line
					(at 3.81 0 180)
					(length 2.54)
					(name "A"
						(effects
							(font
								(size 1.27 1.27)
					(number "2"
						(effects
							(font
								(size 1.27 1.27)
			(embedded_fonts no)
		(symbol "Device:R"
			(pin_numbers
				(hide yes)
			(pin_names
				(offset 0)
			(in_bom yes)
			(on_board yes)
			(property "Reference" "R"
				(at 2.032 0 90)
				(effects
					(font
						(size 1.27 1.27)
			(property "Value" "R"
				(at 0 0 90)
				(effects
					(font
						(size 1.27 1.27)
				(at -1.778 0 90)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Description" "Resistor"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "ki_keywords" "R res resistor"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "ki_fp_filters" "R_*"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(symbol "R_0_1"
				(rectangle
					(start -1.016 -2.54)
					(end 1.016 2.54)
					(stroke
						(width 0.254)
						(type default)
					(fill
						(type none)
			(symbol "R_1_1"
				(pin passive line
					(at 0 3.81 270)
					(length 1.27)
					(name "~"
						(effects
							(font
								(size 1.27 1.27)
					(number "1"
						(effects
							(font
								(size 1.27 1.27)
				(pin passive line
					(at 0 -3.81 90)
					(length 1.27)
					(name "~"
						(effects
							(font
								(size 1.27 1.27)
					(number "2"
						(effects
							(font
								(size 1.27 1.27)
			(embedded_fonts no)
		(symbol "Diode:1N4148WS"
			(pin_numbers
				(hide yes)
			(pin_names
				(hide yes)
			(in_bom yes)
			(on_board yes)
				(at 0 2.54 0)
				(effects
					(font
						(size 1.27 1.27)
			(property "Value" "1N4148WS"
				(at 0 -2.54 0)
				(effects
					(font
						(size 1.27 1.27)
			(property "Footprint" "Diode_SMD:D_SOD-323"
				(at 0 -4.445 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Datasheet" "https://www.vishay.com/docs/85751/1n4148ws.pdf"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Description" "75V 0.15A Fast switching Diode, SOD-323"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Sim.Device" "D"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Sim.Pins" "1=K 2=A"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "ki_keywords" "diode"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "ki_fp_filters" "D*SOD?323*"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(symbol "1N4148WS_0_1"
				(polyline
					(pts
						(xy -1.27 1.27) (xy -1.27 -1.27)
					(stroke
						(width 0.254)
						(type default)
					(fill
						(type none)
				(polyline
					(pts
						(xy 1.27 1.27) (xy 1.27 -1.27) (xy -1.27 0) (xy 1.27 1.27)
					(stroke
						(width 0.254)
						(type default)
					(fill
						(type none)
				(polyline
					(pts
						(xy 1.27 0) (xy -1.27 0)
					(stroke
						(width 0)
						(type default)
					(fill
						(type none)
			(symbol "1N4148WS_1_1"
				(pin passive line
					(at -3.81 0 0)
					(length 2.54)
					(name "K"
						(effects
							(font
								(size 1.27 1.27)
					(number "1"
						(effects
							(font
								(size 1.27 1.27)
				(pin passive line
					(at 3.81 0 180)
					(length 2.54)
					(name "A"
						(effects
							(font
								(size 1.27 1.27)
					(number "2"
						(effects
							(font
								(size 1.27 1.27)
			(embedded_fonts no)
		(symbol "Diode:MBR0520LT"
			(pin_numbers
				(hide yes)
			(pin_names
				(offset 1.016)
				(hide yes)
			(in_bom yes)
			(on_board yes)
				(at 0 2.54 0)
				(effects
					(font
						(size 1.27 1.27)
			(property "Value" "MBR0520LT"
				(at 0 -2.54 0)
				(effects
					(font
						(size 1.27 1.27)
			(property "Footprint" "Diode_SMD:D_SOD-123"
				(at 0 -4.445 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Datasheet" "http://www.onsemi.com/pub_link/Collateral/MBR0520LT1-D.PDF"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Description" "20V 0.5A Schottky Power Rectifier Diode, SOD-123"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "ki_keywords" "diode Schottky"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "ki_fp_filters" "D*SOD?123*"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(symbol "MBR0520LT_0_1"
				(polyline
					(pts
						(xy -1.905 0.635) (xy -1.905 1.27) (xy -1.27 1.27) (xy -1.27 -1.27) (xy -0.635 -1.27) (xy -0.635 -0.635)
					(stroke
						(width 0.254)
						(type default)
					(fill
						(type none)
				(polyline
					(pts
					(stroke
						(width 0.254)
						(type default)
					(fill
						(type none)
				(polyline
					(pts
					(stroke
						(width 0)
						(type default)
					(fill
						(type none)
			(symbol "MBR0520LT_1_1"
				(pin passive line
					(at -3.81 0 0)
					(length 2.54)
					(name "K"
						(effects
							(font
								(size 1.27 1.27)
					(number "1"
						(effects
							(font
								(size 1.27 1.27)
				(pin passive line
					(at 3.81 0 180)
					(length 2.54)
					(name "A"
						(effects
							(font
								(size 1.27 1.27)
					(number "2"
						(effects
							(font
								(size 1.27 1.27)
			(embedded_fonts no)
		(symbol "Transistor_BJT:BC847"
			(pin_names
				(offset 0)
				(hide yes)
			(in_bom yes)
			(on_board yes)
			(property "Reference" "Q"
				(at 5.08 1.905 0)
				(effects
					(font
						(size 1.27 1.27)
					(justify left)
			(property "Value" "BC847"
				(at 5.08 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(justify left)
			(property "Footprint" "Package_TO_SOT_SMD:SOT-23"
				(at 5.08 -1.905 0)
				(effects
					(font
						(size 1.27 1.27)
						(italic yes)
					(justify left)
					(hide yes)
			(property "Datasheet" "http://www.infineon.com/dgdl/Infineon-BC847SERIES_BC848SERIES_BC849SERIES_BC850SERIES-DS-v01_01-en.pdf?fileId=db3a304314dca389011541d4630a1657"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(justify left)
					(hide yes)
			(property "Description" "0.1A Ic, 45V Vce, NPN Transistor, SOT-23"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Sim.Device" "NPN"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Sim.Pins" "1=B 2=E 3=C"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "ki_keywords" "NPN Small Signal Transistor"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(symbol "BC847_0_1"
				(polyline
					(pts
						(xy -2.54 0) (xy 0.635 0)
					(stroke
						(width 0)
						(type default)
					(fill
						(type none)
				(polyline
					(pts
						(xy 0.635 1.905) (xy 0.635 -1.905)
					(stroke
						(width 0.508)
						(type default)
					(fill
						(type none)
				(circle
					(center 1.27 0)
					(radius 2.8194)
					(stroke
						(width 0.254)
						(type default)
					(fill
						(type none)
			(symbol "BC847_1_1"
				(polyline
					(pts
						(xy 0.635 0.635) (xy 2.54 2.54)
					(stroke
						(width 0)
						(type default)
					(fill
						(type none)
				(polyline
					(pts
						(xy 0.635 -0.635) (xy 2.54 -2.54)
					(stroke
						(width 0)
						(type default)
					(fill
						(type none)
				(polyline
					(pts
						(xy 1.27 -1.778) (xy 1.778 -1.27) (xy 2.286 -2.286) (xy 1.27 -1.778)
					(stroke
						(width 0)
						(type default)
					(fill
						(type outline)
				(pin input line
					(at -5.08 0 0)
					(length 2.54)
					(name "B"
						(effects
							(font
								(size 1.27 1.27)
					(number "1"
						(effects
							(font
								(size 1.27 1.27)
				(pin passive line
					(at 2.54 5.08 270)
					(length 2.54)
					(name "C"
						(effects
							(font
								(size 1.27 1.27)
					(number "3"
						(effects
							(font
								(size 1.27 1.27)
				(pin passive line
					(at 2.54 -5.08 90)
					(length 2.54)
					(name "E"
						(effects
							(font
								(size 1.27 1.27)
					(number "2"
						(effects
							(font
								(size 1.27 1.27)
			(embedded_fonts no)
		(symbol "Transistor_BJT:BC857"
			(pin_names
				(offset 0)
				(hide yes)
			(in_bom yes)
			(on_board yes)
				(at 5.08 1.905 0)
				(effects
					(font
						(size 1.27 1.27)
					(justify left)
			(property "Value" "BC857"
				(at 5.08 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(justify left)
				(at 5.08 -1.905 0)
				(effects
					(font
						(size 1.27 1.27)
						(italic yes)
					(justify left)
					(hide yes)
			(property "Datasheet" "https://www.onsemi.com/pub/Collateral/BC860-D.pdf"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(justify left)
					(hide yes)
			(property "Description" "0.1A Ic, 45V Vce, PNP Transistor, SOT-23"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Sim.Device" "PNP"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "ki_keywords" "PNP transistor"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(symbol "BC857_0_1"
				(polyline
					(pts
					(stroke
						(width 0)
						(type default)
					(fill
						(type none)
				(polyline
					(pts
					(stroke
						(width 0.508)
						(type default)
					(fill
						(type none)
				(polyline
					(pts
					(stroke
						(width 0)
						(type default)
					(fill
						(type none)
				(polyline
					(pts
					(stroke
						(width 0)
						(type default)
					(fill
						(type none)
				(circle
					(center 1.27 0)
					(radius 2.8194)
					(stroke
						(width 0.254)
						(type default)
					(fill
						(type none)
				(polyline
					(pts
						(xy 2.286 -1.778) (xy 1.778 -2.286) (xy 1.27 -1.27) (xy 2.286 -1.778)
					(stroke
						(width 0)
						(type default)
					(fill
						(type outline)
			(symbol "BC857_1_1"
				(pin input line
					(at -5.08 0 0)
					(length 2.54)
					(name "B"
						(effects
							(font
								(size 1.27 1.27)
					(number "1"
						(effects
							(font
								(size 1.27 1.27)
				(pin passive line
					(at 2.54 5.08 270)
					(length 2.54)
					(name "C"
						(effects
							(font
								(size 1.27 1.27)
					(number "3"
						(effects
							(font
								(size 1.27 1.27)
				(pin passive line
					(at 2.54 -5.08 90)
					(length 2.54)
					(name "E"
						(effects
							(font
								(size 1.27 1.27)
					(number "2"
						(effects
							(font
								(size 1.27 1.27)
			(embedded_fonts no)
		(symbol "power:+5V"
			(power)
			(pin_numbers
				(hide yes)
			(pin_names
				(offset 0)
				(hide yes)
			(in_bom yes)
			(on_board yes)
			(property "Reference" "#PWR"
				(at 0 -3.81 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Value" "+5V"
				(at 0 3.556 0)
				(effects
					(font
						(size 1.27 1.27)
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Datasheet" ""
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Description" "Power symbol creates a global label with name \"+5V\""
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "ki_keywords" "global power"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(symbol "+5V_0_1"
				(polyline
					(pts
						(xy -0.762 1.27) (xy 0 2.54)
					(stroke
						(width 0)
						(type default)
					(fill
						(type none)
				(polyline
					(pts
						(xy 0 2.54) (xy 0.762 1.27)
					(stroke
						(width 0)
						(type default)
					(fill
						(type none)
				(polyline
					(pts
						(xy 0 0) (xy 0 2.54)
					(stroke
						(width 0)
						(type default)
					(fill
						(type none)
			(symbol "+5V_1_1"
				(pin power_in line
					(at 0 0 90)
					(length 0)
					(name "~"
						(effects
							(font
								(size 1.27 1.27)
					(number "1"
						(effects
							(font
								(size 1.27 1.27)
			(embedded_fonts no)
		(symbol "power:GND"
			(power)
			(pin_numbers
				(hide yes)
			(pin_names
				(offset 0)
				(hide yes)
			(in_bom yes)
			(on_board yes)
				(at 0 -6.35 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Value" "GND"
				(at 0 -3.81 0)
				(effects
					(font
						(size 1.27 1.27)
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(property "Description" "Power symbol creates a global label with name \"GND\" , ground"
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
				(at 0 0 0)
				(effects
					(font
						(size 1.27 1.27)
					(hide yes)
			(symbol "GND_0_1"
				(polyline
					(pts
						(xy 0 0) (xy 0 -1.27) (xy 1.27 -1.27) (xy 0 -2.54) (xy -1.27 -1.27) (xy 0 -1.27)
					(stroke
						(width 0)
						(type default)
					(fill
						(type none)
			(symbol "GND_1_1"
				(pin power_in line
					(at 0 0 270)
					(length 0)
					(name "~"
						(effects
							(font
								(size 1.27 1.27)
					(number "1"
						(effects
							(font
								(size 1.27 1.27)
			(embedded_fonts no)
	(junction
		(at 96.52 43.18)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "022b9f76-2ac4-461b-86b9-95ff93c1d4b0")
	(junction
		(at 27.94 38.1)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "062021b3-be37-405c-b56e-164192ad08de")
	(junction
		(at 27.94 124.46)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "09396b76-6c30-44dc-806a-b2c3136e3640")
	(junction
		(at 27.94 22.86)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "0c20a9a2-ecfc-4f99-9320-ac39fb725329")
	(junction
		(at 58.42 99.06)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "13109953-d6c0-4789-bbc6-7d39df2fc7ea")
	(junction
		(at 149.86 43.18)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "13d84077-a912-486c-9760-df498437a5f0")
	(junction
		(at 160.02 91.44)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "1465796b-74bd-40dc-8086-364cacf43ac1")
	(junction
		(at 127 63.5)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "1e1565d6-c272-4f6b-9296-37487f7c0fde")
	(junction
		(at 160.02 73.66)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "3609534c-d505-4455-a452-4d57c8eba516")
	(junction
		(at 160.02 39.37)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "3639b4cf-feae-4ab5-aa86-837ba0410761")
	(junction
		(at 119.38 58.42)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "36c244d3-924e-477c-ae3e-44eb503ff915")
	(junction
		(at 53.34 55.88)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "37f22aa9-9a1d-48f9-9b25-5fd4698efc35")
	(junction
		(at 99.06 43.18)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "398f730d-46ba-4eb7-85cc-964e4d108e46")
	(junction
		(at 142.24 58.42)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "3f3e7bda-2439-43f1-b880-63b7b5b9c8b6")
	(junction
		(at 27.94 60.96)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "3fb9bbb1-da51-40d9-926d-61c37bde4e16")
	(junction
		(at 99.06 68.58)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "59178304-e138-4989-a4e5-c190944ad17a")
	(junction
		(at 149.86 81.28)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "673a9ada-64e4-452f-a1ea-1e662d2f6608")
	(junction
		(at 149.86 78.74)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "69413087-8567-4a97-8789-c2356ca434d4")
	(junction
		(at 60.96 111.76)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "6b39adcd-6e11-4c02-9ba9-a2e587e462a0")
	(junction
		(at 68.58 111.76)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "75aa9ac0-a796-468c-a294-ae305124ebf0")
	(junction
		(at 27.94 76.2)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "76c69ab8-404c-4e87-8370-dc2595aeef75")
	(junction
		(at 119.38 53.34)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "771b55bd-3107-4692-aa41-2b54fab0a51e")
	(junction
		(at 170.18 52.07)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "82971d36-f179-43d7-9dcb-495d8d94bd05")
	(junction
		(at 160.02 58.42)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "9a48e014-e062-4ea3-9d70-237af00196b8")
	(junction
		(at 99.06 55.88)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "a298fdf5-1063-4d7a-b102-80cf26e9e48f")
	(junction
		(at 45.72 55.88)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "a45c1bbe-8f06-4837-a68f-d2084f5a6626")
	(junction
		(at 111.76 27.94)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "aeb83418-1acb-4256-919c-48f3a4267bcc")
	(junction
		(at 88.9 55.88)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "b1699dc6-cd93-4c40-92c9-a72b0fa0aab7")
	(junction
		(at 76.2 48.26)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "b17f091d-e855-4657-a04a-eadaacd61ff3")
	(junction
		(at 78.74 99.06)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "c5d770a4-7655-4189-992f-8670c68dec09")
	(junction
		(at 149.86 33.02)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "c5ff3ac5-396a-4e09-ae75-416731957e95")
	(junction
		(at 172.72 39.37)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "cbd57104-1fa0-429b-bb19-91dfaa258f3e")
	(junction
		(at 35.56 38.1)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "d290bad4-38e6-4c66-864a-6d08c64c5e8f")
	(junction
		(at 45.72 38.1)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "d6825f41-4224-4831-bb87-47404b49c319")
	(junction
		(at 170.18 39.37)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "f155400f-822d-4b38-97d1-c794e8539f42")
	(junction
		(at 68.58 27.94)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "f6566fba-5921-4cc6-b6c9-d9afb51794a5")
	(junction
		(at 127 78.74)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "f8393659-7397-4af5-8630-00783018324f")
	(junction
		(at 91.44 55.88)
		(diameter 0)
		(color 0 0 0 0)
		(uuid "fa18e63f-13fd-44e8-9bf6-ad3b1f1c303b")
	(wire
		(pts
			(xy 160.02 50.8) (xy 160.02 39.37)
		(stroke
			(width 0)
			(type default)
		(uuid "00a1f311-17ce-4490-acce-20959e59dd5f")
	(wire
		(pts
			(xy 45.72 95.25) (xy 45.72 99.06)
		(stroke
			(width 0)
			(type default)
		(uuid "02b6fa3d-34e4-4d5c-922b-870498045d96")
	(wire
		(pts
			(xy 58.42 111.76) (xy 60.96 111.76)
		(stroke
			(width 0)
			(type default)
		(uuid "031e1f79-7d29-41b0-aafc-b0fbc075683f")
	(wire
		(pts
			(xy 127 63.5) (xy 137.16 63.5)
		(stroke
			(width 0)
			(type default)
		(uuid "04dfe66a-c8c3-4e20-810b-52de1236da01")
	(wire
		(pts
			(xy 53.34 55.88) (xy 45.72 55.88)
		(stroke
			(width 0)
			(type default)
		(uuid "0e002f68-0df3-483d-b958-a3c07d18bc51")
	(wire
		(pts
			(xy 27.94 76.2) (xy 27.94 82.55)
		(stroke
			(width 0)
			(type default)
		(uuid "0f08eca9-521d-4451-9d0f-010021751121")
	(wire
		(pts
			(xy 149.86 81.28) (xy 152.4 81.28)
		(stroke
			(width 0)
			(type default)
		(uuid "125c9244-9a70-4e20-9092-9174dcdc488a")
	(polyline
		(pts
			(xy 176.53 43.18) (xy 191.77 43.18)
		(stroke
			(width 0)
			(type dash)
		(uuid "13a762dc-320f-4521-9320-379633b2181c")
	(wire
		(pts
			(xy 114.3 27.94) (xy 111.76 27.94)
		(stroke
			(width 0)
			(type default)
		(uuid "197a8b7a-f666-486f-9346-41bda4c8ef6c")
	(wire
		(pts
			(xy 45.72 99.06) (xy 58.42 99.06)
		(stroke
			(width 0)
			(type default)
		(uuid "20af0f16-82ed-474c-afda-fd2f9088c7d2")
	(wire
		(pts
			(xy 99.06 68.58) (xy 119.38 68.58)
		(stroke
			(width 0)
			(type default)
		(uuid "23926309-bedb-4966-b83c-67e2bbc14cf3")
	(wire
		(pts
			(xy 88.9 55.88) (xy 91.44 55.88)
		(stroke
			(width 0)
			(type default)
		(uuid "2403688d-c102-4141-9e94-6483a89e243a")
	(wire
		(pts
			(xy 35.56 91.44) (xy 35.56 114.3)
		(stroke
			(width 0)
			(type default)
		(uuid "28c2fe98-48d5-4677-b8b2-c340b6580bd8")
	(polyline
		(pts
			(xy 191.77 72.39) (xy 176.53 72.39)
		(stroke
			(width 0)
			(type dash)
		(uuid "292a428a-bef3-4b94-b86b-49d562c05de8")
	(wire
		(pts
			(xy 99.06 55.88) (xy 101.6 55.88)
		(stroke
			(width 0)
			(type default)
		(uuid "2a17107e-9882-4b71-a819-96404e2a844b")
	(wire
		(pts
			(xy 160.02 71.12) (xy 160.02 73.66)
		(stroke
			(width 0)
			(type default)
		(uuid "2b83e016-a072-474b-a669-6f3a00954d63")
	(wire
		(pts
			(xy 99.06 43.18) (xy 119.38 43.18)
		(stroke
			(width 0)
			(type default)
		(uuid "2f4813f3-20fa-4d4a-bd79-0aa066d782ec")
	(wire
		(pts
			(xy 96.52 43.18) (xy 96.52 38.1)
		(stroke
			(width 0)
			(type default)
		(uuid "2f8bfb9f-668f-4a8b-b6e1-98f1abeed20b")
	(wire
		(pts
			(xy 149.86 91.44) (xy 149.86 93.98)
		(stroke
			(width 0)
			(type default)
		(uuid "2feda4c8-b185-4eac-b070-e0ac0eb004bc")
	(wire
		(pts
			(xy 149.86 20.32) (xy 149.86 21.59)
		(stroke
			(width 0)
			(type default)
		(uuid "305fc6a9-6363-49a5-9aab-bc438c5cd6b4")
	(wire
		(pts
			(xy 149.86 33.02) (xy 152.4 33.02)
		(stroke
			(width 0)
			(type default)
		(uuid "309261ec-9400-418c-aa04-d6da722d0291")
	(wire
		(pts
			(xy 149.86 83.82) (xy 149.86 81.28)
		(stroke
			(width 0)
			(type default)
		(uuid "31c0f9d2-34b6-40ba-9988-b6cbe1075b8c")
	(wire
		(pts
			(xy 160.02 39.37) (xy 170.18 39.37)
		(stroke
			(width 0)
			(type default)
		(uuid "36c178b9-4bb6-4778-bb64-05ee1a868474")
	(wire
		(pts
			(xy 68.58 121.92) (xy 68.58 124.46)
		(stroke
			(width 0)
			(type default)
		(uuid "36c49b07-abea-4d8c-90ab-9e924522a4b0")
	(wire
		(pts
			(xy 78.74 99.06) (xy 78.74 106.68)
		(stroke
			(width 0)
			(type default)
		(uuid "39fbd09c-4b06-4140-9bc7-7a488383e089")
	(wire
		(pts
			(xy 160.02 86.36) (xy 160.02 91.44)
		(stroke
			(width 0)
			(type default)
		(uuid "3a293483-a459-4d70-a24b-be98aa5c6586")
	(wire
		(pts
			(xy 116.84 53.34) (xy 119.38 53.34)
		(stroke
			(width 0)
			(type default)
		(uuid "3cc05e52-5cb3-4dcf-afb1-ec3c182972f4")
	(wire
		(pts
			(xy 45.72 76.2) (xy 40.64 76.2)
		(stroke
			(width 0)
			(type default)
		(uuid "3f04484e-4277-43ec-95ae-698f86f4b869")
	(wire
		(pts
			(xy 119.38 58.42) (xy 119.38 68.58)
		(stroke
			(width 0)
			(type default)
		(uuid "41af847d-45fc-4e12-b933-8e9bf07ff8e2")
	(wire
		(pts
			(xy 172.72 39.37) (xy 182.88 39.37)
		(stroke
			(width 0)
			(type default)
		(uuid "42532d37-99f6-4f58-af95-67dc4dd2aad1")
	(wire
		(pts
			(xy 170.18 39.37) (xy 170.18 41.91)
		(stroke
			(width 0)
			(type default)
		(uuid "45466f66-838e-4701-9ddf-bf9424ab5b96")
	(wire
		(pts
			(xy 27.94 22.86) (xy 129.54 22.86)
		(stroke
			(width 0)
			(type default)
		(uuid "46439fa8-d362-490b-b662-2738ef30c57f")
	(wire
		(pts
			(xy 45.72 38.1) (xy 53.34 38.1)
		(stroke
			(width 0)
			(type default)
		(uuid "47daf60e-b0ad-4c81-85dd-ea33f42d1950")
	(wire
		(pts
			(xy 35.56 38.1) (xy 35.56 43.18)
		(stroke
			(width 0)
			(type default)
		(uuid "4bbd299f-e26c-41a2-ba11-ba19c464dfad")
	(wire
		(pts
			(xy 35.56 38.1) (xy 45.72 38.1)
		(stroke
			(width 0)
			(type default)
		(uuid "4bfc04c6-161e-4b7d-b152-caaa70c8d10d")
	(wire
		(pts
			(xy 27.94 38.1) (xy 35.56 38.1)
		(stroke
			(width 0)
			(type default)
		(uuid "4cdb096d-26dd-40af-bcd7-6b41dfc57568")
	(wire
		(pts
			(xy 25.4 22.86) (xy 27.94 22.86)
		(stroke
			(width 0)
			(type default)
		(uuid "4d0f5535-474c-49a2-8db6-f05dd14db5cd")
	(wire
		(pts
			(xy 182.88 55.88) (xy 182.88 58.42)
		(stroke
			(width 0)
			(type default)
		(uuid "4f5c13a9-dd9e-4879-8d8a-0c3f4e05a91c")
	(wire
		(pts
			(xy 50.8 78.74) (xy 127 78.74)
		(stroke
			(width 0)
			(type default)
		(uuid "50fdfffc-ca64-4006-b7a4-f6709145b799")
	(wire
		(pts
			(xy 27.94 60.96) (xy 50.8 60.96)
		(stroke
			(width 0)
			(type default)
		(uuid "516f308f-4bd9-472d-a5d7-f65f81b335e2")
	(polyline
		(pts
			(xy 176.53 43.18) (xy 176.53 72.39)
		(stroke
			(width 0)
			(type dash)
		(uuid "526d7e7d-e8ad-480b-9a28-4a2f44c80483")
	(wire
		(pts
			(xy 45.72 50.8) (xy 45.72 55.88)
		(stroke
			(width 0)
			(type default)
		(uuid "567ebf65-807e-42dd-8908-90f7289a19d4")
	(wire
		(pts
			(xy 160.02 73.66) (xy 160.02 76.2)
		(stroke
			(width 0)
			(type default)
		(uuid "5d93f675-5bc4-452c-b77b-c408743d48cf")
	(polyline
		(pts
			(xy 38.1 82.55) (xy 54.61 82.55)
		(stroke
			(width 0)
			(type dash)
		(uuid "5fcb66f6-2b41-4126-bf4a-be730e88d21f")
	(wire
		(pts
			(xy 68.58 53.34) (xy 68.58 58.42)
		(stroke
			(width 0)
			(type default)
		(uuid "6186b041-e38f-463e-bbef-9a793b9ebc2a")
	(wire
		(pts
			(xy 160.02 27.94) (xy 160.02 20.32)
		(stroke
			(width 0)
			(type default)
		(uuid "62eb4039-6644-4b60-994c-6ceca55c4dfc")
	(wire
		(pts
			(xy 129.54 22.86) (xy 129.54 45.72)
		(stroke
			(width 0)
			(type default)
		(uuid "6843567b-373b-4c83-8ef0-38118ac53615")
	(wire
		(pts
			(xy 60.96 111.76) (xy 68.58 111.76)
		(stroke
			(width 0)
			(type default)
		(uuid "68941a4b-ac8c-481c-90bc-9a03b53a31e7")
	(wire
		(pts
			(xy 160.02 58.42) (xy 182.88 58.42)
		(stroke
			(width 0)
			(type default)
		(uuid "693ea809-047c-4ad9-9b3b-1bfc67c47c08")
	(wire
		(pts
			(xy 27.94 124.46) (xy 58.42 124.46)
		(stroke
			(width 0)
			(type default)
		(uuid "6b597311-1181-49a5-8839-57d1040ddb58")
	(wire
		(pts
			(xy 68.58 20.32) (xy 68.58 27.94)
		(stroke
			(width 0)
			(type default)
		(uuid "6c406b61-1c1f-4882-8160-361db3524034")
	(polyline
		(pts
			(xy 38.1 82.55) (xy 38.1 111.76)
		(stroke
			(width 0)
			(type dash)
		(uuid "713e6360-0bf1-45ba-8c3e-e44a117e7100")
	(wire
		(pts
			(xy 119.38 43.18) (xy 119.38 53.34)
		(stroke
			(width 0)
			(type default)
		(uuid "71919fb4-396e-4c32-a602-e2d994b97802")
	(wire
		(pts
			(xy 58.42 121.92) (xy 58.42 124.46)
		(stroke
			(width 0)
			(type default)
		(uuid "7246d606-2942-402b-856f-9c639541b728")
	(wire
		(pts
			(xy 160.02 58.42) (xy 160.02 63.5)
		(stroke
			(width 0)
			(type default)
		(uuid "754f74c6-c9ec-4b36-b6ef-264d4f2fe940")
	(wire
		(pts
			(xy 25.4 60.96) (xy 27.94 60.96)
		(stroke
			(width 0)
			(type default)
		(uuid "75955426-f443-4c4c-b6c4-aa99d9111ddb")
	(wire
		(pts
			(xy 119.38 53.34) (xy 127 53.34)
		(stroke
			(width 0)
			(type default)
		(uuid "77a20a75-f8a1-4b5b-8c95-7256efae8db7")
	(wire
		(pts
			(xy 182.88 69.85) (xy 182.88 74.93)
		(stroke
			(width 0)
			(type default)
		(uuid "79b583f6-65a0-4700-8564-ce1440600f6b")
	(wire
		(pts
			(xy 116.84 58.42) (xy 119.38 58.42)
		(stroke
			(width 0)
			(type default)
		(uuid "7c192e16-f0a8-49f4-9bed-292449c612fa")
	(wire
		(pts
			(xy 137.16 91.44) (xy 137.16 93.98)
		(stroke
			(width 0)
			(type default)
		(uuid "7cae6a4b-180c-4164-920d-11065050c4cb")
	(wire
		(pts
			(xy 119.38 58.42) (xy 142.24 58.42)
		(stroke
			(width 0)
			(type default)
		(uuid "7d85133a-6445-4265-9e19-fcb86a6ef061")
	(wire
		(pts
			(xy 88.9 48.26) (xy 88.9 55.88)
		(stroke
			(width 0)
			(type default)
		(uuid "7d96af26-a1e5-4efa-aea9-524761d0bebb")
	(wire
		(pts
			(xy 160.02 91.44) (xy 160.02 93.98)
		(stroke
			(width 0)
			(type default)
		(uuid "7dd57a2a-e6c0-49ec-8829-83b861bf2cb0")
	(wire
		(pts
			(xy 73.66 48.26) (xy 76.2 48.26)
		(stroke
			(width 0)
			(type default)
		(uuid "7f52a04c-495f-4559-a787-577d8c3a47d8")
	(wire
		(pts
			(xy 88.9 68.58) (xy 99.06 68.58)
		(stroke
			(width 0)
			(type default)
		(uuid "82d04285-012a-41b5-84a0-26aea5ade464")
	(wire
		(pts
			(xy 149.86 29.21) (xy 149.86 33.02)
		(stroke
			(width 0)
			(type default)
		(uuid "83195fe9-8bde-49ba-9030-a67ab5946fe4")
	(wire
		(pts
			(xy 40.64 91.44) (xy 35.56 91.44)
		(stroke
			(width 0)
			(type default)
		(uuid "84c75c19-8726-418c-9eb3-aa1d5e8498da")
	(wire
		(pts
			(xy 73.66 43.18) (xy 96.52 43.18)
		(stroke
			(width 0)
			(type default)
		(uuid "87a3af6d-997d-4bdd-bcd0-13d67a1e4cd1")
	(wire
		(pts
			(xy 121.92 27.94) (xy 124.46 27.94)
		(stroke
			(width 0)
			(type default)
		(uuid "8938962c-ed17-4409-a39c-81978a1912a3")
	(wire
		(pts
			(xy 71.12 99.06) (xy 78.74 99.06)
		(stroke
			(width 0)
			(type default)
		(uuid "895c6c82-4ba2-4831-ac3e-fb009f066f55")
	(wire
		(pts
			(xy 124.46 27.94) (xy 124.46 30.48)
		(stroke
			(width 0)
			(type default)
		(uuid "89b86ee2-af68-49c8-a5ad-6bab6d879262")
	(wire
		(pts
			(xy 127 53.34) (xy 127 63.5)
		(stroke
			(width 0)
			(type default)
		(uuid "8a4b80b3-81c4-49db-9a11-a35fadd7dbf1")
	(wire
		(pts
			(xy 139.7 27.94) (xy 139.7 30.48)
		(stroke
			(width 0)
			(type default)
		(uuid "8a804461-9876-47df-9f62-76878d49e772")
	(wire
		(pts
			(xy 27.94 73.66) (xy 27.94 76.2)
		(stroke
			(width 0)
			(type default)
		(uuid "8cb4a406-0d3e-40ee-aeee-4ec6ca89110d")
	(wire
		(pts
			(xy 45.72 109.22) (xy 45.72 114.3)
		(stroke
			(width 0)
			(type default)
		(uuid "8cebd780-18aa-4061-9718-615aa5d158ce")
	(wire
		(pts
			(xy 88.9 55.88) (xy 88.9 58.42)
		(stroke
			(width 0)
			(type default)
		(uuid "8dcaedae-96b8-48d8-8911-1d0305e4105d")
	(wire
		(pts
			(xy 127 78.74) (xy 127 83.82)
		(stroke
			(width 0)
			(type default)
		(uuid "8df764d9-e621-4249-b9f2-1d3f46aa7e63")
	(wire
		(pts
			(xy 86.36 48.26) (xy 88.9 48.26)
		(stroke
			(width 0)
			(type default)
		(uuid "90bafaef-5dc3-486e-bccd-8a62d31b58ed")
	(wire
		(pts
			(xy 127 91.44) (xy 127 93.98)
		(stroke
			(width 0)
			(type default)
		(uuid "9254d29e-31b9-4736-b34f-3f987467f78d")
	(wire
		(pts
			(xy 170.18 49.53) (xy 170.18 52.07)
		(stroke
			(width 0)
			(type default)
		(uuid "9b089894-9d7e-4a04-9179-9cb53bf54dc5")
	(wire
		(pts
			(xy 96.52 30.48) (xy 96.52 20.32)
		(stroke
			(width 0)
			(type default)
		(uuid "9b9b185f-0f0f-4ade-804e-ff788fab7ab0")
	(wire
		(pts
			(xy 45.72 55.88) (xy 35.56 55.88)
		(stroke
			(width 0)
			(type default)
		(uuid "9c572982-0a3a-41e6-9984-8aa8577bbb57")
	(wire
		(pts
			(xy 53.34 45.72) (xy 53.34 38.1)
		(stroke
			(width 0)
			(type default)
		(uuid "9dcbac5d-aaba-4827-9233-6bb0faaa6070")
	(wire
		(pts
			(xy 182.88 39.37) (xy 182.88 48.26)
		(stroke
			(width 0)
			(type default)
		(uuid "9e53ffd5-c551-4943-a827-37d22635d1ef")
	(wire
		(pts
			(xy 127 73.66) (xy 127 78.74)
		(stroke
			(width 0)
			(type default)
		(uuid "9f63ffb2-3266-4553-aab7-968c814497d8")
	(wire
		(pts
			(xy 142.24 45.72) (xy 149.86 45.72)
		(stroke
			(width 0)
			(type default)
		(uuid "9f974079-0eb3-4669-8090-13a5f488a559")
	(wire
		(pts
			(xy 58.42 114.3) (xy 58.42 111.76)
		(stroke
			(width 0)
			(type default)
		(uuid "a437f7f3-e663-475d-b721-da6d6cebf942")
	(wire
		(pts
			(xy 58.42 45.72) (xy 53.34 45.72)
		(stroke
			(width 0)
			(type default)
		(uuid "a716188f-e37f-4975-8956-b2e1f8f0e442")
	(wire
		(pts
			(xy 149.86 63.5) (xy 149.86 50.8)
		(stroke
			(width 0)
			(type default)
		(uuid "a777f61e-2889-474a-b89a-6c5a928c8509")
	(wire
		(pts
			(xy 81.28 27.94) (xy 81.28 30.48)
		(stroke
			(width 0)
			(type default)
		(uuid "a875f546-3b67-4f1e-a82b-ef8df2bf4e10")
	(wire
		(pts
			(xy 88.9 68.58) (xy 88.9 66.04)
		(stroke
			(width 0)
			(type default)
		(uuid "a8f68497-9219-4709-84ac-1d40ec0e6d55")
	(wire
		(pts
			(xy 170.18 39.37) (xy 172.72 39.37)
		(stroke
			(width 0)
			(type default)
		(uuid "a97aa6cd-19ad-47f6-ae7a-59902b6418e4")
	(wire
		(pts
			(xy 45.72 38.1) (xy 45.72 43.18)
		(stroke
			(width 0)
			(type default)
		(uuid "a9dc3074-7b55-4910-b31c-17a7c757a902")
	(wire
		(pts
			(xy 50.8 60.96) (xy 50.8 78.74)
		(stroke
			(width 0)
			(type default)
		(uuid "ab349168-b299-4d7a-9ee0-af530c1d326c")
	(wire
		(pts
			(xy 149.86 78.74) (xy 149.86 81.28)
		(stroke
			(width 0)
			(type default)
		(uuid "ae56e541-7b8d-47ee-a60d-023623e68212")
	(wire
		(pts
			(xy 68.58 111.76) (xy 68.58 114.3)
		(stroke
			(width 0)
			(type default)
		(uuid "af5b4993-007b-478b-8b7b-026f205b88d4")
	(wire
		(pts
			(xy 78.74 27.94) (xy 81.28 27.94)
		(stroke
			(width 0)
			(type default)
		(uuid "afbfb852-9a55-43dd-893a-2ca40a998d81")
	(wire
		(pts
			(xy 78.74 116.84) (xy 78.74 124.46)
		(stroke
			(width 0)
			(type default)
		(uuid "b48c0cf6-a0fc-4e57-b035-6ed558e4fb8e")
	(wire
		(pts
			(xy 45.72 76.2) (xy 45.72 87.63)
		(stroke
			(width 0)
			(type default)
		(uuid "b5a59bef-ae40-43aa-82be-730d57f068b5")
	(wire
		(pts
			(xy 76.2 48.26) (xy 76.2 55.88)
		(stroke
			(width 0)
			(type default)
		(uuid "b600d070-8604-4bf1-8e6c-381e6e12322a")
	(wire
		(pts
			(xy 111.76 63.5) (xy 111.76 71.12)
		(stroke
			(width 0)
			(type default)
		(uuid "b7025f6e-71b2-4c53-9859-8cec2c33a57f")
	(wire
		(pts
			(xy 170.18 52.07) (xy 170.18 74.93)
		(stroke
			(width 0)
			(type default)
		(uuid "b8611d41-81af-481c-959b-6f576e54a333")
	(wire
		(pts
			(xy 68.58 27.94) (xy 68.58 38.1)
		(stroke
			(width 0)
			(type default)
		(uuid "ba579ffd-43b0-467d-9035-47b585a638a2")
	(wire
		(pts
			(xy 25.4 38.1) (xy 27.94 38.1)
		(stroke
			(width 0)
			(type default)
		(uuid "bc2313c6-2917-43c9-ae66-1e61b8b83f18")
	(wire
		(pts
			(xy 99.06 66.04) (xy 99.06 68.58)
		(stroke
			(width 0)
			(type default)
		(uuid "bd0c8507-dd97-4dd7-8195-1705f8404eae")
	(wire
		(pts
			(xy 27.94 90.17) (xy 27.94 114.3)
		(stroke
			(width 0)
			(type default)
		(uuid "c15d4010-1dbf-4541-b9f8-03f4e3ec5334")
	(polyline
		(pts
			(xy 191.77 43.18) (xy 191.77 72.39)
		(stroke
			(width 0)
			(type dash)
		(uuid "c631a041-fc8c-4506-8341-b3991f5b36c0")
	(wire
		(pts
			(xy 96.52 43.18) (xy 99.06 43.18)
		(stroke
			(width 0)
			(type default)
		(uuid "c7716ec0-43d1-4c21-8526-5f9eb55a1c4c")
	(wire
		(pts
			(xy 35.56 55.88) (xy 35.56 50.8)
		(stroke
			(width 0)
			(type default)
		(uuid "c8c61745-aeef-4330-95cf-aef50b87f441")
	(wire
		(pts
			(xy 111.76 20.32) (xy 111.76 27.94)
		(stroke
			(width 0)
			(type default)
		(uuid "cc001f97-2e99-4a2c-ba19-c68e47789cbb")
	(wire
		(pts
			(xy 149.86 43.18) (xy 149.86 45.72)
		(stroke
			(width 0)
			(type default)
		(uuid "cd864c91-0ddc-472c-9729-4ce5c207ee22")
	(wire
		(pts
			(xy 149.86 33.02) (xy 149.86 43.18)
		(stroke
			(width 0)
			(type default)
		(uuid "d3b3c922-039a-4164-bf1c-d9e177ec1d0f")
	(wire
		(pts
			(xy 149.86 50.8) (xy 160.02 50.8)
		(stroke
			(width 0)
			(type default)
		(uuid "d4d34a94-392b-459b-93dc-0bded2a91cb3")
	(wire
		(pts
			(xy 149.86 71.12) (xy 149.86 78.74)
		(stroke
			(width 0)
			(type default)
		(uuid "d7b61955-7854-4469-baa8-57191c37c2ba")
	(wire
		(pts
			(xy 58.42 99.06) (xy 63.5 99.06)
		(stroke
			(width 0)
			(type default)
		(uuid "d897e58d-e386-407c-b9d4-b1971f2dd6e7")
	(wire
		(pts
			(xy 111.76 27.94) (xy 111.76 48.26)
		(stroke
			(width 0)
			(type default)
		(uuid "da76688b-a2eb-4171-acf0-417ab26e447d")
	(wire
		(pts
			(xy 76.2 55.88) (xy 53.34 55.88)
		(stroke
			(width 0)
			(type default)
		(uuid "db598bd4-bac6-4bd1-b8f6-ae2ecd636a4a")
	(wire
		(pts
			(xy 25.4 124.46) (xy 27.94 124.46)
		(stroke
			(width 0)
			(type default)
		(uuid "de2f1910-03eb-4a73-b688-c49c8bcdbb58")
	(wire
		(pts
			(xy 71.12 111.76) (xy 68.58 111.76)
		(stroke
			(width 0)
			(type default)
		(uuid "e2aa406c-aa4a-4d08-9403-675241b65c0c")
	(wire
		(pts
			(xy 71.12 27.94) (xy 68.58 27.94)
		(stroke
			(width 0)
			(type default)
		(uuid "e3b88a7a-83d2-4bdd-b05e-ff4540a0f0b8")
	(wire
		(pts
			(xy 160.02 58.42) (xy 142.24 58.42)
		(stroke
			(width 0)
			(type default)
		(uuid "e710fef1-c051-402d-abff-bbc4011f4d1b")
	(wire
		(pts
			(xy 91.44 55.88) (xy 99.06 55.88)
		(stroke
			(width 0)
			(type default)
		(uuid "ea77d151-ae54-4652-8c2f-25418cee63b8")
	(wire
		(pts
			(xy 137.16 83.82) (xy 137.16 63.5)
		(stroke
			(width 0)
			(type default)
		(uuid "ed621521-9f59-4af4-865f-f6a91cbde5ec")
	(polyline
		(pts
			(xy 54.61 111.76) (xy 38.1 111.76)
		(stroke
			(width 0)
			(type dash)
		(uuid "ed719e8d-61a6-46c2-8520-ec19ca88e50d")
	(wire
		(pts
			(xy 76.2 48.26) (xy 78.74 48.26)
		(stroke
			(width 0)
			(type default)
		(uuid "f042990d-885b-4416-bf56-350d08d73842")
	(wire
		(pts
			(xy 127 63.5) (xy 127 66.04)
		(stroke
			(width 0)
			(type default)
		(uuid "f38d93d8-d133-466b-afa6-8d2fcc8da0a9")
	(wire
		(pts
			(xy 129.54 45.72) (xy 134.62 45.72)
		(stroke
			(width 0)
			(type default)
		(uuid "f5748563-44e9-4c60-9aa6-b9b9e80873c3")
	(wire
		(pts
			(xy 99.06 55.88) (xy 99.06 58.42)
		(stroke
			(width 0)
			(type default)
		(uuid "f5ae97be-081c-440d-a07c-af61e533af5d")
	(wire
		(pts
			(xy 33.02 76.2) (xy 27.94 76.2)
		(stroke
			(width 0)
			(type default)
		(uuid "f7ff6161-d398-4b70-8e3d-337cbb1bc1f1")
	(wire
		(pts
			(xy 170.18 52.07) (xy 177.8 52.07)
		(stroke
			(width 0)
			(type default)
		(uuid "fb2d014f-6bd0-4a63-8e30-a8fb2c1b7ec5")
	(wire
		(pts
			(xy 160.02 38.1) (xy 160.02 39.37)
		(stroke
			(width 0)
			(type default)
		(uuid "fbeaedb1-8b43-455e-bb38-088b1ed38f07")
	(polyline
		(pts
			(xy 54.61 82.55) (xy 54.61 111.76)
		(stroke
			(width 0)
			(type dash)
		(uuid "fef4749b-7129-4cf3-938c-1ee0d5a24061")
	(label "VP"
		(at 91.44 43.18 0)
		(effects
			(font
				(size 1.27 1.27)
			(justify left bottom)
		(uuid "29310c42-16a1-44dd-827a-b9a5e9872dda")
	(label "VK"
		(at 132.08 58.42 0)
		(effects
			(font
				(size 1.27 1.27)
		(uuid "afe62358-4be3-40aa-a69f-28a30f74455d")
	(label "VO"
		(at 88.9 53.34 90)
		(effects
			(font
				(size 1.27 1.27)
		(uuid "d69359a0-3888-474c-a46b-71d446f9d970")
	(label "VA"
		(at 165.1 39.37 0)
		(effects
			(font
				(size 1.27 1.27)
		(uuid "dd905137-e966-440c-91d3-ba13fcb612a5")
	(label "VM"
		(at 71.12 55.88 0)
		(effects
			(font
				(size 1.27 1.27)
		(uuid "f4b3edd8-172f-4f16-82c2-3e745790389c")
	(hierarchical_label "OF-TXH"
		(shape input)
		(at 25.4 22.86 180)
		(effects
			(font
				(size 1.27 1.27)
			(justify right)
		(uuid "1bd7167f-a46f-458b-b8da-dd07e93077fd")
	(hierarchical_label "~{OF-TXF}"
		(shape input)
		(at 25.4 124.46 180)
		(effects
			(font
				(size 1.27 1.27)
			(justify right)
		(uuid "42db849d-6e0e-4376-83da-2eae1266e0be")
	(hierarchical_label "OF-SIG"
		(shape output)
		(at 25.4 38.1 180)
		(effects
			(font
				(size 1.27 1.27)
			(justify right)
		(uuid "58393404-fa26-4565-948e-0ff3d0aabab4")
	(hierarchical_label "OF-REF"
		(shape output)
		(at 25.4 60.96 180)
		(effects
			(font
				(size 1.27 1.27)
			(justify right)
		(uuid "878fde88-689f-48e3-8248-8cb6d42014f7")
	(symbol
		(lib_id "Connector:TestPoint_Small")
		(at 99.06 43.18 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(fields_autoplaced yes)
		(uuid "06db4e76-4756-4bcd-8c8a-0f420d09a865")
		(property "Reference" "TP17"
			(at 100.33 41.91 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 100.33 44.45 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
		(property "Footprint" "New:TestPoint_THTPad_D0.8mm_Drill0.5mm"
			(at 104.14 43.18 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 104.14 43.18 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Description" ""
			(at 99.06 43.18 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Ignore" ""
			(at 99.06 43.18 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Variant" "NoBOM"
			(at 99.06 43.18 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "475e6886-85a1-4c6a-ade9-04ab8db021d3")
		(instances
			(project "Demo-4CH-V2"
				(path "/aee667b5-809f-4a10-81df-de3a390f42f8/111d42ce-d577-415d-8e3b-126d83c32aa4/58bde598-8a7d-4cd8-8c21-309c78c076db"
					(reference "TP706")
					(unit 1)
				(path "/aee667b5-809f-4a10-81df-de3a390f42f8/111d42ce-d577-415d-8e3b-126d83c32aa4/67f1149e-872b-459f-b4af-432bdf1d3d64"
					(reference "TP506")
					(unit 1)
				(path "/aee667b5-809f-4a10-81df-de3a390f42f8/111d42ce-d577-415d-8e3b-126d83c32aa4/759545e9-36df-47e8-8bdf-3f0170ef12a1"
					(reference "TP806")
					(unit 1)
				(path "/aee667b5-809f-4a10-81df-de3a390f42f8/111d42ce-d577-415d-8e3b-126d83c32aa4/d2262164-5eaa-4586-b0fb-5aa7b161d239"
					(reference "TP606")
					(unit 1)
			(project "USB2LWL_AVRDU_V2"
				(path "/c0ba576d-1ca3-4631-af83-78872d5f0327/b6452d3a-0130-49eb-9475-73afca07cc5b"
					(reference "TP17")
					(unit 1)
	(symbol
		(lib_id "Device:R")
		(at 160.02 67.31 0)
		(mirror x)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "08d1e1d0-c57d-4a5b-9f02-c927460d2317")
		(property "Reference" "R19"
			(at 157.48 67.31 90)
			(effects
				(font
					(size 1.27 1.27)
		(property "Value" "24R"
			(at 162.56 67.31 90)
			(effects
				(font
					(size 1.27 1.27)
		(property "Footprint" "Resistor_SMD:R_1206_3216Metric"
			(at 158.242 67.31 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Datasheet" "${KIPRJMOD}/Datasheets/YAGEO_PYu-RC_Group_51_RoHS_L_12.pdf"
			(at 160.02 67.31 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 160.02 67.31 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Characteristics" "1% 0.25W"
			(at 160.02 67.31 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Variant" "Always"
			(at 160.02 67.31 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Part-ID" "R-82"
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "2a3b1482-0ea1-49ba-8781-f3647900f403")
		(pin "2"
			(uuid "30b6175e-15ea-45ec-873d-ba7007aadbd3")
		(instances
					(reference "R711")
					(unit 1)
					(reference "R511")
					(unit 1)
					(reference "R811")
					(unit 1)
					(reference "R611")
					(unit 1)
					(reference "R19")
					(unit 1)
	(symbol
		(lib_id "power:+5V")
		(at 27.94 73.66 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "175c2dff-7c4b-4224-814d-3405016f6749")
		(property "Reference" "#PWR020"
			(at 27.94 77.47 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 68.58 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 27.94 73.66 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 73.66 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 73.66 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "34761e45-a0e9-4306-9d82-586eb8ddd9c6")
		(instances
					(reference "#PWR020")
					(unit 1)
	(symbol
		(at 111.76 20.32 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "18422897-79b6-48ee-a1b4-6445c36fcf10")
		(property "Reference" "#PWR030"
			(at 111.76 24.13 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 111.76 15.24 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 111.76 20.32 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 111.76 20.32 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 111.76 20.32 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "0e417c16-bc9d-4d23-8c1a-6140a8019c85")
		(instances
					(reference "#PWR030")
					(unit 1)
	(symbol
		(at 149.86 43.18 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "1a0eb740-89bf-420d-b38c-52e477e77c48")
		(property "Reference" "TP19"
			(at 148.59 41.91 90)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 151.13 44.45 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
			(at 154.94 43.18 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 154.94 43.18 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 149.86 43.18 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 149.86 43.18 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 149.86 43.18 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "364a6f17-0762-4a32-a432-fc26543446b8")
		(instances
					(reference "TP708")
					(unit 1)
					(reference "TP508")
					(unit 1)
					(reference "TP808")
					(unit 1)
					(reference "TP608")
					(unit 1)
					(reference "TP19")
					(unit 1)
	(symbol
		(at 149.86 78.74 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "1cec16c1-9c13-40ea-aa59-bf01be3107c9")
		(property "Reference" "TP20"
			(at 148.59 77.47 90)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 151.13 80.01 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
			(at 154.94 78.74 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 154.94 78.74 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 149.86 78.74 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 149.86 78.74 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 149.86 78.74 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "a099c9c9-be0b-42bd-8a9b-4b8111666856")
		(instances
					(reference "TP709")
					(unit 1)
					(reference "TP509")
					(unit 1)
					(reference "TP809")
					(unit 1)
					(reference "TP609")
					(unit 1)
					(reference "TP20")
					(unit 1)
	(symbol
		(lib_id "power:GND")
		(at 81.28 30.48 0)
		(mirror y)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "20d19583-da70-4c37-83eb-b83c31e34355")
		(property "Reference" "#PWR028"
			(at 81.28 36.83 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 81.28 35.56 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 81.28 30.48 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 81.28 30.48 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 81.28 30.48 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "a19d1aec-ca63-4832-b620-841fccf9fc80")
		(instances
					(reference "#PWR028")
					(unit 1)
	(symbol
		(at 170.18 74.93 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "25582334-eaa4-454e-bbe2-028b728b9aa1")
		(property "Reference" "#PWR041"
			(at 170.18 81.28 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 170.18 80.01 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 170.18 74.93 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 170.18 74.93 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 170.18 74.93 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "868e569e-efa8-4d81-9855-6c62949122b2")
		(instances
					(reference "#PWR0708")
					(unit 1)
					(reference "#PWR0508")
					(unit 1)
					(reference "#PWR0808")
					(unit 1)
					(reference "#PWR0608")
					(unit 1)
					(reference "#PWR041")
					(unit 1)
	(symbol
		(at 172.72 39.37 270)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "25d13862-3fc3-499d-b640-0dc41fe28da2")
		(property "Reference" "TP23"
			(at 173.99 38.1 90)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 171.45 40.64 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
			(at 172.72 44.45 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 172.72 44.45 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 172.72 39.37 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 172.72 39.37 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 172.72 39.37 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "1eb72595-de44-4f9a-892b-e02ae15ffaab")
		(instances
					(reference "TP711")
					(unit 1)
					(reference "TP511")
					(unit 1)
					(reference "TP811")
					(unit 1)
					(reference "TP611")
					(unit 1)
					(reference "TP23")
					(unit 1)
	(symbol
		(lib_id "Amplifier_Operational:TLV9061xDBV")
		(at 109.22 55.88 0)
		(mirror y)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "283e17ce-d56b-4bdd-a6e9-8ba581050436")
		(property "Reference" "U4"
			(at 107.95 49.53 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
		(property "Value" "SL9061A"
			(at 107.95 52.07 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 124.46 74.93 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
		(property "Datasheet" "${KIPRJMOD}/Datasheets/Slkor_SL9061.pdf"
			(at 109.22 35.56 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 109.22 55.88 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 109.22 55.88 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Part-ID" "U-60"
			(at 109.22 55.88 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "3"
			(uuid "87b363a6-9e9e-4bef-95d2-dda3103b8758")
		(pin "4"
			(uuid "305b6334-c751-485b-8aad-671bbbca5694")
		(pin "1"
			(uuid "35e37a5b-7e53-4416-bfa7-ef7f294de344")
		(pin "2"
			(uuid "bc2cf9c7-23c5-41de-a33e-e8b000798ac2")
		(pin "5"
			(uuid "9f9ded45-4fbf-41b2-8cbe-0b4f12b4e561")
		(instances
			(project ""
					(reference "U701")
					(unit 1)
					(reference "U501")
					(unit 1)
					(reference "U801")
					(unit 1)
					(reference "U601")
					(unit 1)
					(reference "U4")
					(unit 1)
	(symbol
		(at 68.58 124.46 0)
		(mirror y)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "2dbb4cb0-87a1-4f72-8092-e0d21072f73b")
		(property "Reference" "#PWR026"
			(at 68.58 130.81 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 68.58 129.54 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 68.58 124.46 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 68.58 124.46 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 68.58 124.46 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "211b4fab-6fdb-4296-ad77-0e8226687d16")
		(instances
					(reference "#PWR026")
					(unit 1)
	(symbol
		(lib_id "Device:R")
		(at 127 87.63 0)
		(mirror x)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "33d19166-2da3-474d-a3d4-282081b15fc6")
		(property "Reference" "R14"
			(at 124.46 87.63 90)
			(effects
				(font
					(size 1.27 1.27)
		(property "Value" "680R"
			(at 129.54 87.63 90)
			(effects
				(font
					(size 1.27 1.27)
		(property "Footprint" "Resistor_SMD:R_0603_1608Metric"
			(at 125.222 87.63 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 127 87.63 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 127 87.63 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Characteristics" "1% 0.1W"
			(at 127 87.63 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 127 87.63 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Part-ID" "RB-70"
			(at 127 87.63 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "8f4f0fd2-bc48-40dc-8f56-726577b71c65")
		(pin "2"
			(uuid "237d9d74-1059-4b3a-8abf-e3c3e551696d")
		(instances
					(reference "R706")
					(unit 1)
					(reference "R506")
					(unit 1)
					(reference "R806")
					(unit 1)
					(reference "R606")
					(unit 1)
					(reference "R14")
					(unit 1)
	(symbol
		(lib_id "Diode:MBR0520LT")
		(at 36.83 76.2 0)
		(mirror y)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "36381826-e88b-475b-a150-81fcc47a1314")
		(property "Reference" "D3"
			(at 37.1475 69.85 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 37.1475 72.39 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 36.83 80.645 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Datasheet" "${KIPRJMOD}/Datasheets/onsemi_MBR0520LT1_D-2315148.pdf"
			(at 36.83 76.2 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 36.83 76.2 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 36.83 76.2 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Part-ID" "D-4"
			(at 36.83 76.2 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Characteristics" "10V 20% NP0"
			(at 36.83 76.2 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "2"
			(uuid "11d88845-06e7-4533-a243-21fb99a0e8c7")
		(pin "1"
			(uuid "b5a3af3f-035b-4a66-9b59-4ba64f3a81c5")
		(instances
					(reference "D3")
					(unit 1)
	(symbol
		(lib_id "Device:R")
		(at 149.86 25.4 0)
		(mirror x)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "365954ee-bd5e-4425-93cc-d100aa6aa864")
		(property "Reference" "R16"
			(at 147.32 25.4 90)
			(effects
				(font
					(size 1.27 1.27)
		(property "Value" "100K"
			(at 152.4 25.4 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 148.082 25.4 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Datasheet" "${KIPRJMOD}/Datasheets/Stackpole_sei-rmcf_rmcp.pdf"
			(at 149.86 25.4 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 149.86 25.4 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 149.86 25.4 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 154.432 25.4 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Part-ID" "R-23"
			(at 149.86 25.4 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "79ab9f2e-d2fc-42d1-a394-57b554c965ad")
		(pin "2"
			(uuid "66dad69c-2082-427c-8591-22cd3cc9e0cc")
		(instances
					(reference "R709")
					(unit 1)
					(reference "R509")
					(unit 1)
					(reference "R809")
					(unit 1)
					(reference "R609")
					(unit 1)
					(reference "R16")
					(unit 1)
	(symbol
		(at 35.56 114.3 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "3f3f347a-4f78-4f75-8a4e-35fa915cccf6")
		(property "Reference" "#PWR022"
			(at 35.56 120.65 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 35.56 119.38 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 35.56 114.3 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 35.56 114.3 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 35.56 114.3 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "ad6d461a-042b-46d3-98aa-3cf6cac8da08")
		(instances
					(reference "#PWR022")
					(unit 1)
	(symbol
		(lib_id "Device:C")
		(at 27.94 86.36 0)
		(mirror y)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "444d85ab-6531-491d-80a1-3af5b114abde")
		(property "Reference" "C9"
			(at 27.305 83.82 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
		(property "Value" "4u7"
			(at 27.305 88.9 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
		(property "Footprint" "Capacitor_SMD:C_0805_2012Metric"
			(at 26.9748 90.17 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Datasheet" "${KIPRJMOD}/Datasheets/Samsung_CL_Series_MLCC_ds.pdf"
			(at 27.94 86.36 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 86.36 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Characteristics" "10V 20% Y5V"
			(at 27.94 86.36 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 86.36 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Part-ID" "C-15"
			(at 27.94 86.36 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "41cdebc8-b35a-4867-820c-2060d6d5cd14")
		(pin "2"
			(uuid "3338aeef-6d92-4d03-93e9-0e1adce64909")
		(instances
					(reference "C9")
					(unit 1)
	(symbol
		(at 27.94 114.3 0)
		(mirror y)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "523af8bd-4c24-4f00-b42e-bf12d90fa3b3")
		(property "Reference" "#PWR021"
			(at 27.94 120.65 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 119.38 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 27.94 114.3 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 114.3 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 114.3 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "4ad145fe-8dd6-437f-bedd-4394f995e9a9")
		(instances
					(reference "#PWR021")
					(unit 1)
	(symbol
		(at 160.02 93.98 0)
		(mirror y)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "55303f4c-a889-485c-bd9d-ae444a708f80")
		(property "Reference" "#PWR040"
			(at 160.02 100.33 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 160.02 99.06 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 160.02 93.98 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 160.02 93.98 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 160.02 93.98 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "3268f619-a9fe-4955-8a36-f27cd90e6fea")
		(instances
					(reference "#PWR0707")
					(unit 1)
					(reference "#PWR0507")
					(unit 1)
					(reference "#PWR0807")
					(unit 1)
					(reference "#PWR0607")
					(unit 1)
					(reference "#PWR040")
					(unit 1)
	(symbol
		(at 45.72 114.3 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "5e8e272f-0b20-40fe-b687-cf903dece854")
		(property "Reference" "#PWR023"
			(at 45.72 120.65 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 45.72 119.38 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 45.72 114.3 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 45.72 114.3 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 45.72 114.3 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "4462b9a8-0791-4385-a900-3ea053dd6683")
		(instances
					(reference "#PWR023")
					(unit 1)
	(symbol
		(lib_id "Device:R")
		(at 88.9 62.23 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "616d5a30-7358-4b44-b1ff-8a8a227184f7")
		(property "Reference" "R11"
			(at 86.36 62.23 90)
			(effects
				(font
					(size 1.27 1.27)
		(property "Value" "5K1"
			(at 91.44 62.23 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 87.122 62.23 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 88.9 62.23 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 88.9 62.23 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 88.9 62.23 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 88.9 62.23 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Part-ID" "RB-91"
			(at 88.9 62.23 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "31f1d708-184e-4b95-80f9-a418d1793b0e")
		(pin "2"
			(uuid "b4fbc780-c8ad-4e4c-a298-9bcf0d4a97d9")
		(instances
					(reference "R705")
					(unit 1)
					(reference "R505")
					(unit 1)
					(reference "R805")
					(unit 1)
					(reference "R605")
					(unit 1)
					(reference "R11")
					(unit 1)
	(symbol
		(lib_id "Device:R")
		(at 138.43 45.72 270)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "62cee327-ba17-4fae-bf03-a2d3a52d36ec")
		(property "Reference" "R15"
			(at 138.43 43.18 90)
			(effects
				(font
					(size 1.27 1.27)
		(property "Value" "1K"
			(at 138.43 48.26 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 138.43 43.942 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 138.43 45.72 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 138.43 45.72 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 138.43 45.72 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 138.43 50.546 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Part-ID" "R-7"
			(at 138.43 45.72 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "9b105043-3049-4012-b103-204d22f2cb86")
		(pin "2"
			(uuid "bb10dd75-cd37-4eb0-8220-3250a2e50584")
		(instances
					(reference "R707")
					(unit 1)
					(reference "R507")
					(unit 1)
					(reference "R807")
					(unit 1)
					(reference "R607")
					(unit 1)
					(reference "R15")
					(unit 1)
	(symbol
		(lib_id "Device:C")
		(at 74.93 27.94 90)
		(mirror x)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "69e886a8-c44b-4eb4-8f3a-2a5c6c4b055e")
		(property "Reference" "C10"
			(at 72.39 28.575 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
		(property "Value" "100n"
			(at 77.47 28.575 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
		(property "Footprint" "Capacitor_SMD:C_0603_1608Metric"
			(at 78.74 28.9052 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 74.93 27.94 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 74.93 27.94 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 74.93 27.94 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 74.93 27.94 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 74.93 27.94 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Part-ID" "C-1"
			(at 74.93 27.94 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "d84ba95b-bd33-4580-8c82-4879132ea731")
		(pin "2"
			(uuid "9573608a-1222-42af-93c1-266d6245772a")
		(instances
					(reference "C10")
					(unit 1)
	(symbol
		(at 142.24 58.42 270)
		(mirror x)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "6a78ffed-da9c-491c-9bf3-5a44ec7f70f9")
		(property "Reference" "TP18"
			(at 143.51 57.15 90)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 140.97 57.15 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
			(at 142.24 53.34 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 142.24 53.34 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 142.24 58.42 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 142.24 58.42 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 142.24 58.42 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "ecf66c73-5363-4894-af53-40d7596ca4de")
		(instances
					(reference "TP707")
					(unit 1)
					(reference "TP507")
					(unit 1)
					(reference "TP807")
					(unit 1)
					(reference "TP607")
					(unit 1)
					(reference "TP18")
					(unit 1)
	(symbol
		(at 60.96 111.76 270)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "6aeb6466-42fc-40b4-8dd6-ffc0bb00d72e")
		(property "Reference" "TP14"
			(at 62.23 110.49 90)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 59.69 113.03 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
			(at 60.96 116.84 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 60.96 116.84 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 60.96 111.76 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 60.96 111.76 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 60.96 111.76 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "5ad99109-29d8-4ede-a1f3-2f7f38098213")
		(instances
					(reference "TP14")
					(unit 1)
	(symbol
		(lib_id "Device:C")
		(at 99.06 62.23 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "6e136e5e-0e2b-4243-8a24-44af52bf934e")
		(property "Reference" "C11"
			(at 99.695 59.69 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
		(property "Value" "1p"
			(at 99.695 64.77 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 100.0252 66.04 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Datasheet" "${KIPRJMOD}/Datasheets/YAGEO_UPY-GP_NP0_16V-to-50V_18.pdf"
			(at 99.06 62.23 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 99.06 62.23 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 99.06 62.23 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 99.06 62.23 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 99.06 62.23 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Part-ID" "CB-3"
			(at 99.06 62.23 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "03ebcc3d-b665-4e4e-b33f-bda4d86b5576")
		(pin "2"
			(uuid "b2ad5a51-e41f-470e-9ae4-43d054b5c092")
		(instances
					(reference "C701")
					(unit 1)
					(reference "C501")
					(unit 1)
					(reference "C801")
					(unit 1)
					(reference "C601")
					(unit 1)
					(reference "C11")
					(unit 1)
	(symbol
		(lib_id "Device:R")
		(at 149.86 87.63 0)
		(mirror x)
		(unit 1)
		(exclude_from_sim no)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "729a6cd8-4283-4209-be0e-0f753e0af732")
		(property "Reference" "R18"
			(at 147.32 87.63 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 152.4 87.63 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 148.082 87.63 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 149.86 87.63 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 149.86 87.63 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 149.86 87.63 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 149.86 87.63 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "0462440a-de6f-4053-a3bb-acf5adfba77d")
		(pin "2"
			(uuid "d6416bbb-a286-4168-a317-934614f456ed")
		(instances
					(reference "R710")
					(unit 1)
					(reference "R510")
					(unit 1)
					(reference "R810")
					(unit 1)
					(reference "R610")
					(unit 1)
					(reference "R18")
					(unit 1)
	(symbol
		(at 53.34 55.88 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "785e2491-d0d5-4575-b9ae-530d0492b6d2")
		(property "Reference" "TP12"
			(at 54.61 54.61 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 54.61 57.15 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
			(at 58.42 55.88 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 58.42 55.88 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 53.34 55.88 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 53.34 55.88 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 53.34 55.88 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "6d8e451e-25ae-4cab-95a8-3229646300d1")
		(instances
					(reference "TP12")
					(unit 1)
	(symbol
		(lib_id "Diode:1N4148WS")
		(at 35.56 46.99 270)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp yes)
		(uuid "78f32f85-0eaf-46f0-bcb8-17283165676e")
		(property "Reference" "D2"
			(at 33.02 44.45 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 38.1 41.91 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
		(property "Footprint" "Diode_SMD:D_SOD-323_HandSoldering"
			(at 31.115 46.99 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Datasheet" "${KIPRJMOD}/Datasheets/AnbonSemi_DS_4530_1N4148WS.pdf"
			(at 35.56 46.99 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 35.56 46.99 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 35.56 46.99 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Characteristics" "2pF"
			(at 35.56 46.99 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Part-ID" "D-23"
			(at 35.56 46.99 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "14e51aef-a20c-4c3d-ace3-0678bf7dd54d")
		(pin "2"
			(uuid "adcdc8a8-6878-486c-ad0d-e24c168b0d45")
		(instances
					(reference "D701")
					(unit 1)
					(reference "D501")
					(unit 1)
					(reference "D801")
					(unit 1)
					(reference "D601")
					(unit 1)
					(reference "D2")
					(unit 1)
	(symbol
		(at 160.02 73.66 270)
		(mirror x)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "7ad505b0-1e95-4573-8fd9-cff0aa988e31")
		(property "Reference" "TP21"
			(at 161.29 73.66 90)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
		(property "Value" "TestPoint_Small"
			(at 158.75 72.39 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
			(at 160.02 68.58 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 160.02 68.58 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 160.02 73.66 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 160.02 73.66 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 160.02 73.66 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "b466770f-9548-4ede-bbb6-8e01ce1a766b")
		(instances
					(reference "TP710")
					(unit 1)
					(reference "TP510")
					(unit 1)
					(reference "TP810")
					(unit 1)
					(reference "TP610")
					(unit 1)
					(reference "TP21")
					(unit 1)
	(symbol
		(lib_id "Device:LED_Pad")
		(at 182.88 52.07 270)
		(mirror x)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "7b72ae96-8f44-48c2-9cc4-3b30604b9702")
		(property "Reference" "D5"
			(at 187.96 55.626 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 187.96 47.498 0)
			(effects
				(font
					(size 1.27 1.27)
		(property "Footprint" "New:Amphenol_FLTS12WR00+3W-LED-3535"
			(at 182.88 52.07 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Datasheet" "${KIPRJMOD}/Datasheets/Cree_LED_XLamp-XPE.pdf"
			(at 182.88 52.07 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 182.88 52.07 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 182.88 52.07 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Part-ID" "D-43"
			(at 182.88 52.07 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "2"
			(uuid "8030b453-6a68-4cc2-bcf6-fbbd61280489")
		(pin "3"
			(uuid "03fb371b-b78d-43c7-bbcb-a2d360bfbe8a")
		(pin "1"
			(uuid "371f9193-1178-41e4-97f4-41bf19085b08")
		(instances
					(reference "D702")
					(unit 1)
					(reference "D502")
					(unit 1)
					(reference "D802")
					(unit 1)
					(reference "D602")
					(unit 1)
					(reference "D5")
					(unit 1)
	(symbol
		(at 149.86 93.98 0)
		(mirror y)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "7f41771e-d517-47c9-bdca-c8a19cdcf883")
		(property "Reference" "#PWR038"
			(at 149.86 100.33 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 149.86 99.06 0)
			(effects
				(font
					(size 1.27 1.27)
		(property "Footprint" ""
			(at 149.86 93.98 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 149.86 93.98 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 149.86 93.98 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "c25da904-058a-48fe-a766-dbc742d4d355")
		(instances
					(reference "#PWR0706")
					(unit 1)
					(reference "#PWR0506")
					(unit 1)
					(reference "#PWR0806")
					(unit 1)
					(reference "#PWR0606")
					(unit 1)
					(reference "#PWR038")
					(unit 1)
	(symbol
		(at 91.44 55.88 270)
		(mirror x)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "80fc7333-3427-49c4-b93b-d3175177b249")
		(property "Reference" "TP16"
			(at 92.71 54.61 90)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 90.17 54.61 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
			(at 91.44 50.8 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 91.44 50.8 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 91.44 55.88 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 91.44 55.88 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 91.44 55.88 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "bbae9112-1e7f-437a-8ba4-40289b93fac5")
		(instances
					(reference "TP16")
					(unit 1)
	(symbol
		(at 78.74 99.06 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "84456675-ede3-4eaa-9a3e-5e8f02cbe0fc")
		(property "Reference" "TP15"
			(at 77.47 97.79 90)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 80.01 100.33 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
			(at 83.82 99.06 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 83.82 99.06 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 78.74 99.06 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 78.74 99.06 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 78.74 99.06 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "8b741d87-c15b-497e-83d8-25208ecd1b0c")
		(instances
					(reference "TP15")
					(unit 1)
	(symbol
		(at 139.7 30.48 0)
		(mirror y)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "849db62a-08b3-4de9-8220-172848c8466b")
		(property "Reference" "#PWR036"
			(at 139.7 36.83 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 139.7 35.56 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 139.7 30.48 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 139.7 30.48 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 139.7 30.48 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "b713389b-6b36-41fb-8563-d9cfd57fecc1")
		(instances
					(reference "#PWR0705")
					(unit 1)
					(reference "#PWR0505")
					(unit 1)
					(reference "#PWR0805")
					(unit 1)
					(reference "#PWR0605")
					(unit 1)
					(reference "#PWR036")
					(unit 1)
	(symbol
		(lib_id "Device:C")
		(at 139.7 24.13 0)
		(mirror y)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "87bc4fe5-b067-4399-baee-0c89f39407d0")
		(property "Reference" "C14"
			(at 139.065 21.59 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 137.922 26.924 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 138.7348 27.94 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 139.7 24.13 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 139.7 24.13 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 139.7 24.13 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 139.7 24.13 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 139.7 24.13 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "4616b594-ea73-47ef-9e54-099d2ae60462")
		(pin "2"
			(uuid "75b46384-0b9b-458f-a3ba-1e03861830db")
		(instances
					(reference "C704")
					(unit 1)
					(reference "C504")
					(unit 1)
					(reference "C804")
					(unit 1)
					(reference "C604")
					(unit 1)
					(reference "C14")
					(unit 1)
	(symbol
		(at 78.74 124.46 0)
		(mirror y)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "8a1f9f7d-f9fd-4363-aa71-6d54301f6755")
		(property "Reference" "#PWR027"
			(at 78.74 130.81 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 78.74 129.54 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 78.74 124.46 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 78.74 124.46 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 78.74 124.46 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "493e8c41-95ea-40c1-983b-81f99e15bb98")
		(instances
					(reference "#PWR027")
					(unit 1)
	(symbol
		(at 127 93.98 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "8f34fba3-950d-4a53-946b-f808f4ab940f")
		(property "Reference" "#PWR033"
			(at 127 100.33 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 127 99.06 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 127 93.98 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 127 93.98 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 127 93.98 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "01593ddd-b98b-4842-83be-6477fc3812bf")
		(instances
					(reference "#PWR0703")
					(unit 1)
					(reference "#PWR0503")
					(unit 1)
					(reference "#PWR0803")
					(unit 1)
					(reference "#PWR0603")
					(unit 1)
					(reference "#PWR033")
					(unit 1)
	(symbol
		(at 96.52 20.32 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "913b3857-7356-4348-9b82-0856763ad5fe")
		(property "Reference" "#PWR029"
			(at 96.52 24.13 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 96.52 15.24 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 96.52 20.32 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 96.52 20.32 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 96.52 20.32 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "94ebb3b0-fd65-410d-867d-7cbfc3bf6289")
		(instances
					(reference "#PWR029")
					(unit 1)
	(symbol
		(lib_id "Transistor_BJT:BC847")
		(at 76.2 111.76 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "95a88eb0-2f86-49d4-a453-5a75cc0ae460")
		(property "Reference" "Q1"
			(at 81.28 111.76 90)
			(effects
				(font
					(size 1.27 1.27)
		(property "Value" "BC847C"
			(at 83.82 111.76 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 81.28 113.665 0)
			(effects
				(font
					(size 1.27 1.27)
					(italic yes)
				(justify left)
				(hide yes)
		(property "Datasheet" "Datasheets/Nexperia_BC847_SER.pdf"
			(at 76.2 111.76 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
			(at 76.2 111.76 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 76.2 111.76 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Part-ID" "Q-4"
			(at 76.2 111.76 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 76.2 111.76 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 76.2 111.76 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "3"
			(uuid "00381038-3ab3-4a82-9dd9-23d597260a0d")
		(pin "2"
			(uuid "6e6be615-d5a5-42c6-a28e-07486e02c361")
		(pin "1"
			(uuid "0dcd342e-397d-46a6-9c49-d7e5e54547a1")
		(instances
					(reference "Q1")
					(unit 1)
	(symbol
		(at 160.02 91.44 270)
		(mirror x)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "96ee464d-17bd-4685-836b-1ae6ba194598")
		(property "Reference" "TP22"
			(at 161.29 91.44 90)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 158.75 90.17 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
			(at 160.02 86.36 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 160.02 86.36 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 160.02 91.44 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 160.02 91.44 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 160.02 91.44 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "474cc15b-5bb2-463d-8f04-bac28804d3fb")
		(instances
					(reference "TP22")
					(unit 1)
	(symbol
		(lib_id "Device:R")
		(at 45.72 46.99 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "97b27898-dec5-4194-a053-cca3a2177937")
		(property "Reference" "R6"
			(at 43.18 46.99 90)
			(effects
				(font
					(size 1.27 1.27)
		(property "Value" "51K"
			(at 48.26 46.99 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 43.942 46.99 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 45.72 46.99 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 45.72 46.99 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 45.72 46.99 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 45.72 46.99 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Part-ID" "RB-115"
			(at 45.72 46.99 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "bd3383ce-dd03-4e1b-9775-89de278da8be")
		(pin "2"
			(uuid "a78c7777-9ec7-4a23-b38e-d84172fc049b")
		(instances
					(reference "R6")
					(unit 1)
	(symbol
		(at 27.94 124.46 270)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "9912eadc-34a6-4c30-8656-3d635bb8faa6")
		(property "Reference" "TP11"
			(at 29.21 123.19 90)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 26.67 125.73 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
			(at 27.94 129.54 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 129.54 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 124.46 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 124.46 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 124.46 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "abb79e46-e5cc-4f38-810e-958f1d2d65e8")
		(instances
					(reference "TP11")
					(unit 1)
	(symbol
		(lib_id "Device:R")
		(at 127 69.85 0)
		(mirror x)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "9cb3d098-4721-4e34-b0a5-4bd670c0e05c")
		(property "Reference" "R13"
			(at 124.46 69.85 90)
			(effects
				(font
					(size 1.27 1.27)
		(property "Value" "68R"
			(at 129.54 69.85 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 125.222 69.85 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 127 69.85 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 127 69.85 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 127 69.85 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 127 69.85 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Part-ID" "RB-46"
			(at 127 69.85 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "fd8bddb6-f4d0-4468-9955-b5b35612be8d")
		(pin "2"
			(uuid "1dc6cb29-f5aa-4ef1-9e8d-3951b8132a89")
		(instances
					(reference "R702")
					(unit 1)
					(reference "R502")
					(unit 1)
					(reference "R802")
					(unit 1)
					(reference "R602")
					(unit 1)
					(reference "R13")
					(unit 1)
	(symbol
		(lib_id "Device:C")
		(at 137.16 87.63 0)
		(mirror y)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "a206cfd1-7ff1-469a-bb76-4b0c3a510b73")
		(property "Reference" "C13"
			(at 136.525 85.09 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 136.525 90.17 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 136.1948 91.44 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 137.16 87.63 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 137.16 87.63 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 137.16 87.63 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 137.16 87.63 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 137.16 87.63 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "663f8941-d7a6-4e63-9657-4e4d76b22f05")
		(pin "2"
			(uuid "3deb7318-84b0-4461-961d-bdb15206ed9d")
		(instances
					(reference "C703")
					(unit 1)
					(reference "C503")
					(unit 1)
					(reference "C803")
					(unit 1)
					(reference "C603")
					(unit 1)
					(reference "C13")
					(unit 1)
	(symbol
		(at 45.72 91.44 270)
		(mirror x)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "a2d975d8-727c-4437-a6a8-6ff2368c5f49")
		(property "Reference" "D4"
			(at 52.832 91.186 0)
			(effects
				(font
					(size 1.27 1.27)
		(property "Value" "LED_Pad"
			(at 50.546 91.44 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 45.72 91.44 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 45.72 91.44 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Description" "Light emitting diode with pad"
			(at 45.72 91.44 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 45.72 91.44 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 45.72 91.44 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "2"
			(uuid "d39902e5-b115-42ac-bf80-95b0c3d31754")
		(pin "3"
			(uuid "fda6c8ab-1d7d-459d-82e4-a79f6ace5b6d")
		(pin "1"
			(uuid "ed42d017-ee55-4718-b378-a95f7dc34a9e")
		(instances
					(reference "D4")
					(unit 1)
	(symbol
		(at 58.42 99.06 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "a3921e91-324f-4c71-98c7-09d36af22cf9")
		(property "Reference" "TP13"
			(at 57.15 97.79 90)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 59.69 100.33 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
			(at 63.5 99.06 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Datasheet" ""
			(at 63.5 99.06 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 58.42 99.06 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 58.42 99.06 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 58.42 99.06 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "d600b876-533c-46ed-8b98-93628fd01699")
		(instances
					(reference "TP13")
					(unit 1)
	(symbol
		(at 149.86 20.32 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "a959def2-9bf1-49c6-8452-05be4c6660c8")
		(property "Reference" "#PWR037"
			(at 149.86 24.13 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Value" "+5V"
			(at 149.86 15.24 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 149.86 20.32 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 149.86 20.32 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Description" "Power symbol creates a global label with name \"+5V\""
			(at 149.86 20.32 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "2ea0051d-4c36-42b4-8235-51bf8d78be4a")
		(instances
					(reference "#PWR037")
					(unit 1)
	(symbol
		(at 68.58 20.32 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "ac68a589-8f89-4a06-9044-645b80e0be07")
		(property "Reference" "#PWR024"
			(at 68.58 24.13 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 68.58 15.24 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 68.58 20.32 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 68.58 20.32 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 68.58 20.32 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "f5256fe2-2a12-490f-87c2-b792df0a0522")
		(instances
					(reference "#PWR024")
					(unit 1)
	(symbol
		(at 27.94 22.86 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "b2bce463-93e3-40f3-a25b-a104c5040513")
		(property "Reference" "TP8"
			(at 29.21 21.59 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 29.21 24.13 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
			(at 33.02 22.86 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 33.02 22.86 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 22.86 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 22.86 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 22.86 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "d1186ed3-9972-48b2-a6da-4f8e152ca59b")
		(instances
					(reference "TP701")
					(unit 1)
					(reference "TP501")
					(unit 1)
					(reference "TP801")
					(unit 1)
					(reference "TP601")
					(unit 1)
					(reference "TP8")
					(unit 1)
	(symbol
		(lib_id "Connector_Generic:Conn_01x01")
		(at 182.88 64.77 90)
		(unit 1)
		(in_bom yes)
		(on_board no)
		(dnp no)
		(uuid "b4cb60c7-7b58-4359-9e7d-060436bece4b")
		(property "Reference" "J4"
			(at 179.832 64.77 0)
			(effects
				(font
					(size 1.27 1.27)
		(property "Value" "FLT-S12WR-00"
			(at 185.42 64.77 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 182.88 64.77 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Datasheet" "${KIPRJMOD}/Datasheets/Amphenol_P-FLT-S12WR-00.pdf"
			(at 182.88 64.77 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Description" "Generic connector, single row, 01x01, script generated (kicad-library-utils/schlib/autogen/connector/)"
			(at 182.88 64.77 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 182.88 64.77 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Part-ID" "J-24"
			(at 182.88 64.77 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "4665a2e4-0e30-4b8c-9d9d-d872bcea1899")
		(instances
					(reference "J701")
					(unit 1)
					(reference "J501")
					(unit 1)
					(reference "J801")
					(unit 1)
					(reference "J601")
					(unit 1)
					(reference "J4")
					(unit 1)
	(symbol
		(at 66.04 45.72 0)
		(mirror y)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "b7154272-a9c4-4416-970e-d212f9d14f06")
		(property "Reference" "U3"
			(at 64.77 39.37 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 64.77 41.91 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
		(property "Footprint" "Package_TO_SOT_SMD:SOT-23-5"
			(at 81.28 64.77 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
			(at 66.04 25.4 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Description" "10-MHz, RRIO, CMOS Operational Amplifiers for Cost-Sensitive Systems, SOT-23-5"
			(at 66.04 45.72 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 66.04 45.72 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 66.04 45.72 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "3"
			(uuid "b13b701f-04e3-40fb-9c0f-efcdaee2d4e4")
		(pin "4"
			(uuid "88034049-7061-41aa-adca-748169239ecc")
		(pin "1"
			(uuid "bc21a937-3fff-40bc-b864-1c35fef2176e")
		(pin "2"
			(uuid "1a048b0c-25ae-4b97-afec-247cda170854")
		(pin "5"
			(uuid "6e4d2761-b82d-49a8-9793-d259ad5a5f13")
		(instances
					(reference "U3")
					(unit 1)
	(symbol
		(lib_id "Transistor_BJT:BC857")
		(at 157.48 33.02 0)
		(mirror x)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "b7f8c18f-e61a-4baf-8da9-49532764f975")
		(property "Reference" "Q2"
			(at 162.814 33.02 90)
			(effects
				(font
					(size 1.27 1.27)
		(property "Value" "BC857C"
			(at 165.1 33.02 90)
			(effects
				(font
					(size 1.27 1.27)
		(property "Footprint" "Package_TO_SOT_SMD:SOT-23"
			(at 162.56 31.115 0)
			(effects
				(font
					(size 1.27 1.27)
					(italic yes)
				(justify left)
				(hide yes)
		(property "Datasheet" "Datasheets/Nexperia_BC856_BC857_BC858.pdf"
			(at 157.48 33.02 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
		(property "Description" "0.1A Ic, 45V Vce, PNP Transistor, SOT-23"
			(at 157.48 33.02 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 157.48 33.02 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Part-ID" "Q-6"
			(at 157.48 33.02 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Sim.Device" "PNP"
			(at 157.48 33.02 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Sim.Pins" "1=B 2=E 3=C"
			(at 157.48 33.02 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "3"
			(uuid "78926538-db2a-432f-8973-105578a2bbba")
		(pin "1"
			(uuid "85257bba-f660-490a-958b-3f71fba3a0ed")
		(pin "2"
			(uuid "4a68b457-9c18-4a09-9d4a-64d5f398cb5e")
		(instances
					(reference "Q701")
					(unit 1)
					(reference "Q501")
					(unit 1)
					(reference "Q801")
					(unit 1)
					(reference "Q601")
					(unit 1)
					(reference "Q2")
					(unit 1)
	(symbol
		(at 45.72 104.14 270)
		(mirror x)
		(unit 1)
		(in_bom yes)
		(on_board no)
		(dnp no)
		(uuid "bb8cda3d-fe49-4fb7-9aa1-394845d05adf")
		(property "Reference" "J3"
			(at 48.768 104.14 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 43.18 104.14 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 45.72 104.14 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 45.72 104.14 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 45.72 104.14 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 45.72 104.14 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 45.72 104.14 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "1a65f146-ff45-4165-bb8f-b6938aeec5c7")
		(instances
					(reference "J3")
					(unit 1)
	(symbol
		(lib_id "Device:R")
		(at 67.31 99.06 90)
		(mirror x)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "bcdf15ab-3c47-4ed7-8fa4-645d0d15c822")
		(property "Reference" "R8"
			(at 67.31 96.52 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 67.31 101.6 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 67.31 97.282 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 67.31 99.06 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 67.31 99.06 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 67.31 99.06 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 67.31 99.06 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 67.31 99.06 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "e88eaf38-e370-46e1-9e7a-beed4133cdb1")
		(pin "2"
			(uuid "77223c12-fbb5-451a-8f97-cb7a340d70f6")
		(instances
					(reference "R8")
					(unit 1)
	(symbol
		(at 27.94 38.1 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "bedbc6fb-37f5-4de3-8b48-9f744fea71e5")
		(property "Reference" "TP9"
			(at 29.21 36.83 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 29.21 39.37 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
			(at 33.02 38.1 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 33.02 38.1 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 38.1 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 38.1 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 38.1 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "68d1e253-feba-43e7-9222-77f0b548ac3a")
		(instances
					(reference "TP703")
					(unit 1)
					(reference "TP503")
					(unit 1)
					(reference "TP803")
					(unit 1)
					(reference "TP603")
					(unit 1)
					(reference "TP9")
					(unit 1)
	(symbol
		(lib_id "Device:R")
		(at 96.52 34.29 0)
		(mirror x)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "c33d20e4-790c-4fba-8077-2487f8c4ef6f")
		(property "Reference" "R12"
			(at 93.98 34.29 90)
			(effects
				(font
					(size 1.27 1.27)
		(property "Value" "3K"
			(at 99.06 34.29 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 94.742 34.29 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 96.52 34.29 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 96.52 34.29 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 96.52 34.29 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 96.52 34.29 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Part-ID" "R-85"
			(at 96.52 34.29 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "d4f9390e-c0b7-4d04-89d0-5e4e192aea0c")
		(pin "2"
			(uuid "9a1ec6b2-fc65-4272-b02c-1177dab7528e")
		(instances
					(reference "R701")
					(unit 1)
					(reference "R501")
					(unit 1)
					(reference "R801")
					(unit 1)
					(reference "R601")
					(unit 1)
					(reference "R12")
					(unit 1)
	(symbol
		(lib_id "Device:R")
		(at 170.18 45.72 0)
		(mirror y)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "d05bd88d-1cd7-41b6-9214-2854cb790fc7")
		(property "Reference" "R20"
			(at 172.72 45.72 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 167.64 45.72 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 171.958 45.72 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 170.18 45.72 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 170.18 45.72 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 170.18 45.72 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 170.18 45.72 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "b0f2ca16-a246-44ec-8e71-386fe8ae897e")
		(pin "2"
			(uuid "b044bcd4-06e1-4d81-b4fb-4ca87a222f1a")
		(instances
					(reference "R712")
					(unit 1)
					(reference "R512")
					(unit 1)
					(reference "R812")
					(unit 1)
					(reference "R612")
					(unit 1)
					(reference "R20")
					(unit 1)
	(symbol
		(lib_id "Device:R")
		(at 58.42 118.11 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "d0fab83c-8ad2-4e51-b021-51bafd8c60cf")
		(property "Reference" "R7"
			(at 55.88 118.11 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 61.468 118.11 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 56.642 118.11 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 58.42 118.11 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 58.42 118.11 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 58.42 118.11 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 58.42 118.11 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "6e3d67f2-8901-4eb1-90c2-975d7eff49c6")
		(pin "2"
			(uuid "a70bf50d-8def-43fb-8f21-b14bace624cd")
		(instances
					(reference "R7")
					(unit 1)
	(symbol
		(at 137.16 93.98 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "d7199104-9ba8-4ec7-82cf-d421827b004a")
		(property "Reference" "#PWR034"
			(at 137.16 100.33 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Value" "GND"
			(at 137.16 99.06 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 137.16 93.98 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 137.16 93.98 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Description" "Power symbol creates a global label with name \"GND\" , ground"
			(at 137.16 93.98 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "329f9b3c-b70e-4171-9377-cfa78a3514d8")
		(instances
					(reference "#PWR0704")
					(unit 1)
					(reference "#PWR0504")
					(unit 1)
					(reference "#PWR0804")
					(unit 1)
					(reference "#PWR0604")
					(unit 1)
					(reference "#PWR034")
					(unit 1)
	(symbol
		(at 124.46 30.48 0)
		(mirror y)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "d86bf7cd-d670-4706-aaf1-bf4ad5129d1b")
		(property "Reference" "#PWR032"
			(at 124.46 36.83 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 124.46 35.56 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 124.46 30.48 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 124.46 30.48 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 124.46 30.48 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "71e70844-ba76-4aa3-a630-abd4e3e7e26c")
		(instances
					(reference "#PWR0702")
					(unit 1)
					(reference "#PWR0502")
					(unit 1)
					(reference "#PWR0802")
					(unit 1)
					(reference "#PWR0602")
					(unit 1)
					(reference "#PWR032")
					(unit 1)
	(symbol
		(at 139.7 20.32 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "db6a52d2-2627-432a-bc3e-c6bb9ab2d3ba")
		(property "Reference" "#PWR035"
			(at 139.7 24.13 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 139.7 15.24 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 139.7 20.32 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 139.7 20.32 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 139.7 20.32 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "9c86151a-4902-4318-ae41-31f7984a4dcf")
		(instances
					(reference "#PWR035")
					(unit 1)
	(symbol
		(at 160.02 20.32 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "e227e78b-4745-489d-9107-594969a0d1d6")
		(property "Reference" "#PWR039"
			(at 160.02 24.13 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 160.02 15.24 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 160.02 20.32 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 160.02 20.32 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 160.02 20.32 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "ef21eae0-9b19-42ad-b0f2-c2d3f26c4880")
		(instances
					(reference "#PWR039")
					(unit 1)
	(symbol
		(lib_id "Device:R")
		(at 82.55 48.26 270)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "e2da81bb-967b-4cd4-8a04-f210ec68e74f")
		(property "Reference" "R10"
			(at 82.55 45.72 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 82.55 50.8 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 82.55 46.482 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 82.55 48.26 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 82.55 48.26 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 82.55 48.26 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 82.55 53.086 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 82.55 48.26 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "9f79012e-1c69-48df-8234-5c9703d047e7")
		(pin "2"
			(uuid "77c6bfdc-e62e-4036-a993-813e4a9d9aa4")
		(instances
					(reference "R10")
					(unit 1)
	(symbol
		(at 27.94 60.96 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "e57d91e3-dd72-45c8-97b0-71c9112b1176")
		(property "Reference" "TP10"
			(at 29.21 59.69 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 29.21 62.23 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
			(at 33.02 60.96 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 33.02 60.96 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 60.96 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 60.96 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 27.94 60.96 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "3f3e253c-085c-49ed-ac3a-d842e69ccef0")
		(instances
					(reference "TP702")
					(unit 1)
					(reference "TP502")
					(unit 1)
					(reference "TP802")
					(unit 1)
					(reference "TP602")
					(unit 1)
					(reference "TP10")
					(unit 1)
	(symbol
		(lib_id "Device:R")
		(at 149.86 67.31 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "e68d86cc-ba57-422d-964e-87f174f20af4")
		(property "Reference" "R17"
			(at 147.32 67.31 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 152.908 67.31 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 148.082 67.31 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 149.86 67.31 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 149.86 67.31 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 149.86 67.31 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 149.86 67.31 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "ad1e02e2-c5b7-492a-9c33-52546c0239aa")
		(pin "2"
			(uuid "9d1d3c3a-ce30-4c30-a2e0-1975c2e89702")
		(instances
					(reference "R708")
					(unit 1)
					(reference "R508")
					(unit 1)
					(reference "R808")
					(unit 1)
					(reference "R608")
					(unit 1)
					(reference "R17")
					(unit 1)
	(symbol
		(at 111.76 71.12 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "ea5fe1cb-347d-4032-8111-8634ffc5c102")
		(property "Reference" "#PWR031"
			(at 111.76 77.47 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 111.76 76.2 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 111.76 71.12 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 111.76 71.12 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 111.76 71.12 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "3374c383-6674-4c95-90e3-3c722263fcfc")
		(instances
					(reference "#PWR0701")
					(unit 1)
					(reference "#PWR0501")
					(unit 1)
					(reference "#PWR0801")
					(unit 1)
					(reference "#PWR0601")
					(unit 1)
					(reference "#PWR031")
					(unit 1)
	(symbol
		(at 68.58 58.42 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "f06ddd14-6cc6-404b-9a90-79805cc7874d")
		(property "Reference" "#PWR025"
			(at 68.58 64.77 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 68.58 63.5 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 68.58 58.42 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 68.58 58.42 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 68.58 58.42 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "657204fa-fe9f-4c15-aebe-6bd2474c7523")
		(instances
					(reference "#PWR025")
					(unit 1)
	(symbol
		(lib_id "Device:R")
		(at 68.58 118.11 0)
		(mirror x)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "f2d16d50-81af-4e05-a53c-97ada37b6645")
		(property "Reference" "R9"
			(at 66.04 118.11 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 71.12 118.11 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 66.802 118.11 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 68.58 118.11 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 68.58 118.11 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 68.58 118.11 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 68.58 118.11 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "f9246d14-0244-4614-bccf-8631bbc19516")
		(pin "2"
			(uuid "ed7da65a-9389-4bcf-b302-be1d47865700")
		(instances
					(reference "R9")
					(unit 1)
	(symbol
		(at 182.88 74.93 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "f6413566-e210-4a2c-bf67-2fc52305e332")
		(property "Reference" "#PWR042"
			(at 182.88 81.28 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 182.88 80.01 0)
			(effects
				(font
					(size 1.27 1.27)
			(at 182.88 74.93 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 182.88 74.93 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 182.88 74.93 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "0230b85c-f1a9-43bb-9db2-29516dbf805f")
		(instances
					(reference "#PWR0709")
					(unit 1)
					(reference "#PWR0509")
					(unit 1)
					(reference "#PWR0809")
					(unit 1)
					(reference "#PWR0609")
					(unit 1)
					(reference "#PWR042")
					(unit 1)
	(symbol
		(lib_id "Device:C")
		(at 118.11 27.94 90)
		(mirror x)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "f72b88a3-286f-4564-ae60-1d01da6366c7")
		(property "Reference" "C12"
			(at 115.57 28.575 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 120.65 28.575 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
			(at 121.92 28.9052 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 118.11 27.94 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 118.11 27.94 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 118.11 27.94 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 118.11 27.94 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 118.11 27.94 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 118.11 27.94 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "1"
			(uuid "ec5aeb3f-fc30-4c9b-9de0-0216af41e60f")
		(pin "2"
			(uuid "77521881-5e6e-4ad6-bc14-e4eed3e247fb")
		(instances
					(reference "C702")
					(unit 1)
					(reference "C502")
					(unit 1)
					(reference "C802")
					(unit 1)
					(reference "C602")
					(unit 1)
					(reference "C12")
					(unit 1)
	(symbol
		(at 157.48 81.28 0)
		(unit 1)
		(in_bom yes)
		(on_board yes)
		(dnp no)
		(uuid "fecc889c-efd0-4e6d-af48-a25d0bcbe8cc")
		(property "Reference" "Q3"
			(at 162.814 81.28 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 165.1 81.28 90)
			(effects
				(font
					(size 1.27 1.27)
			(at 162.56 83.185 0)
			(effects
				(font
					(size 1.27 1.27)
					(italic yes)
				(justify left)
				(hide yes)
			(at 157.48 81.28 0)
			(effects
				(font
					(size 1.27 1.27)
				(justify left)
				(hide yes)
		(property "Description" "0.1A Ic, 45V Vce, NPN Transistor, SOT-23"
			(at 157.48 81.28 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 157.48 81.28 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 157.48 81.28 90)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(property "Sim.Device" "NPN"
			(at 157.48 81.28 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
			(at 157.48 81.28 0)
			(effects
				(font
					(size 1.27 1.27)
				(hide yes)
		(pin "3"
			(uuid "c9225020-e206-4a05-a250-e0910a33ee55")
		(pin "2"
			(uuid "6fe8b088-381b-4a90-8c5f-1a307db1b3bc")
		(pin "1"
			(uuid "22ac7729-236e-484a-956c-3f7cb0099845")
		(instances
					(reference "Q702")
					(unit 1)
					(reference "Q502")
					(unit 1)
					(reference "Q802")
					(unit 1)
					(reference "Q602")
					(unit 1)
					(reference "Q3")
					(unit 1)
