| CPU-Z | |
| Binaries | |
| CPU-Z version | 2.15.0.x64 |
| Processors | |
| CPU Groups | 1 |
| CPU Group 0 | 12 threads, mask=0xFFF |
| Number of sockets | 1 |
| Number of threads | 12 |
| APICs | |
| Socket 0 | |
| -- Core 0 (ID 0) | |
| -- Thread 0 | 0 |
| -- Thread 1 | 1 |
| -- Core 1 (ID 1) | |
| -- Thread 2 | 2 |
| -- Thread 3 | 3 |
| -- Core 2 (ID 2) | |
| -- Thread 4 | 4 |
| -- Thread 5 | 5 |
| -- Core 3 (ID 3) | |
| -- Thread 6 | 6 |
| -- Thread 7 | 7 |
| -- Core 4 (ID 4) | |
| -- Thread 8 | 8 |
| -- Thread 9 | 9 |
| -- Core 5 (ID 5) | |
| -- Thread 10 | 10 |
| -- Thread 11 | 11 |
| Timers | |
| ACPI timer | 3.580 MHz |
| Perf timer | 10.000 MHz |
| Sys timer | 1.000 KHz |
| Processors Information | |
| Socket 1 | ID = 0 |
| Number of cores | 6 (max 6) |
| Number of threads | 12 (max 12) |
| Manufacturer | GenuineIntel |
| Name | Intel Core i7 9850H |
| Codename | Coffee Lake |
| Specification | Intel(R) Core(TM) i7-9850H CPU @ 2.60GHz |
| Package (platform ID) | Socket 1440 FCBGA (0x5) |
| CPUID | 6.E.D |
| Extended CPUID | 6.9E |
| Core Stepping | R0 |
| Technology | 14 nm |
| TDP Limit | 45.0 Watts |
| Tjmax | 100.0 °C |
| Core Speed | 2195.4 MHz |
| Multiplier x Bus Speed | 22.0 x 99.8 MHz |
| Base frequency (cores) | 99.8 MHz |
| Stock frequency | 2600 MHz |
| Instructions sets | MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, AES, AVX, AVX2, FMA3 |
| Microcode Revision | 0xDE |
| L1 Data cache | 6 x 32 KB (8-way, 64-byte line) |
| L1 Instruction cache | 6 x 32 KB (8-way, 64-byte line) |
| L2 cache | 6 x 256 KB (4-way, 64-byte line) |
| L3 cache | 12 MB (16-way, 64-byte line) |
| Max CPUID level | 00000016h |
| Max CPUID ext. level | 80000008h |
| FID/VID Control | yes |
| Turbo Mode | supported, enabled |
| Max non-turbo ratio | 26x |
| Max turbo ratio | 46x |
| Max efficiency ratio | 8x |
| Min operating ratio | 8x |
| Speedshift | Autonomous |
| O/C bins | +4 |
| Power Max (PL1) | 55.00 W |
| PL1 Time Window | 28.00 s |
| Short Power Max (PL2) | 90.00 W |
| Max Peak Power (PL4) | 130.00 W |
| Ratio 1 core | 46x |
| Ratio 2 cores | 45x |
| Ratio 3 cores | 44x |
| Ratio 4 cores | 43x |
| Ratio 5 cores | 42x |
| Ratio 6 cores | 41x |
| Ratio 7 cores | 41x |
| Ratio 8 cores | 41x |
| TDP Level | 45.0 W @ 26x |
| TDP Level | 35.0 W @ 23x |
| Temperature 0 | 77 degC (170 degF) (Package) |
| Temperature 1 | 55 degC (131 degF) (Cores (Max)) |
| Temperature 2 | 68 degC (154 degF) (Core #0) |
| Temperature 3 | 70 degC (158 degF) (Core #1) |
| Temperature 4 | 77 degC (170 degF) (Core #2) |
| Temperature 5 | 52 degC (125 degF) (Core #3) |
| Temperature 6 | 52 degC (125 degF) (Core #4) |
| Temperature 7 | 52 degC (125 degF) (Core #5) |
| Voltage 0 | 1.20 Volts (VID) |
| Power 00 | 6.92 W (Package) |
| Power 01 | 5.74 W (IA Cores) |
| Power 02 | n.a. (GT) |
| Power 03 | 1.32 W (DRAM) |
| Power 04 | 55.00 W (Power Max (PL1)) |
| Power 05 | 90.00 W (Short Power Max (PL2)) |
| Power 06 | 130.00 W (Max Peak Power (PL4)) |
| Clock Speed 0 | 2195.38 MHz (Core #0) |
| Clock Speed 1 | 2195.38 MHz (Core #1) |
| Clock Speed 2 | 2195.38 MHz (Core #2) |
| Clock Speed 3 | 1097.69 MHz (Core #3) |
| Clock Speed 4 | 2594.54 MHz (Core #4) |
| Clock Speed 5 | 1097.69 MHz (Core #5) |
| Clock Speed 6 | 99.79 MHz (CPU BCLK) |
| Clock Speed 7 | n.a. (SOC BCLK) |
| Core 0 max ratio | 46.00 (effective 43.00) |
| Core 1 max ratio | 46.00 (effective 43.00) |
| Core 2 max ratio | 46.00 (effective 43.00) |
| Core 3 max ratio | 46.00 (effective 44.00) |
| Core 4 max ratio | 46.00 (effective 43.00) |
| Core 5 max ratio | 46.00 (effective 43.00) |
| Chipset | |
| Northbridge | Intel Coffee Lake rev. 0D |
| Southbridge | Intel CM246 rev. 10 |
| Bus Specification | PCI-Express 3.0 (8.0 GT/s) |
| Graphic Interface | PCI-Express 3.0 |
| PCI-E Link Width | x16 (max 16x) |
| PCI-E Link Speed | 2.5 GT/s (max 8.0 GT/s) |
| Memory Type | DDR4 |
| Memory Size | 32 GBytes |
| Channels | Dual |
| Memory Frequency | 1197.1 MHz (3:36) |
| CAS# latency (CL) | 17.0 |
| RAS# to CAS# delay (tRCD) | 17 |
| RAS# Precharge (tRP) | 17 |
| Cycle Time (tRAS) | 39 |
| Row Refresh Cycle Time (tRFC) | 420 |
| Command Rate (CR) | 2T |
| Uncore Frequency | 3891.8 MHz |
| Host Bridge | 0x3EC4 |
| Memory SPD | |
| DIMM # | 1 |
| SMBus address | 0x51 |
| Memory type | DDR4 |
| Module format | SO-DIMM |
| Module Manufacturer(ID) | Samsung (CE000000000000000000000000000000) |
| SDRAM Manufacturer (ID) | Samsung (CE000000000000000000000000000000) |
| Size | 16384 MBytes |
| Max bandwidth | DDR4-2666 (1333 MHz) |
| Part number | M471A2K43CB1-CTD |
| Serial number | 37589399 |
| Manufacturing date | Week 19/Year 20 |
| Nominal Voltage | 1.20 Volts |
| EPP | no |
| XMP | no |
| AMP | no |
| EXPO | no |
| JEDEC timings table | CL-tRCD-tRP-tRAS-tRC @ frequency |
| JEDEC #1 | 10.0-11-11-24-34 @ 733 MHz |
| JEDEC #2 | 11.0-11-11-26-37 @ 800 MHz |
| JEDEC #3 | 12.0-12-12-28-40 @ 866 MHz |
| JEDEC #4 | 13.0-13-13-30-43 @ 933 MHz |
| JEDEC #5 | 14.0-15-15-34-48 @ 1033 MHz |
| JEDEC #6 | 15.0-16-16-36-51 @ 1100 MHz |
| JEDEC #7 | 16.0-17-17-38-54 @ 1166 MHz |
| JEDEC #8 | 17.0-17-17-40-57 @ 1233 MHz |
| JEDEC #9 | 18.0-18-18-42-60 @ 1300 MHz |
| JEDEC #10 | 19.0-19-19-43-61 @ 1333 MHz |
| JEDEC #11 | 20.0-19-19-43-61 @ 1333 MHz |
| DIMM # | 2 |
| SMBus address | 0x53 |
| Serial number | 37589451 |
| EPP | no |
| XMP | no |
| AMP | no |
| EXPO | no |
| Monitoring | |
| Mainboard Model | 860F (0x000000E4 - 0x000023B0) |
| LPCIO | |
| Hardware Monitors | |
| Hardware monitor | NVIDIA NVML |
| Power 01 | 2.03 W (GPU) |
| Clock Speed 0 | 300.00 MHz [0x12C] (Graphics) |
| Clock Speed 1 | 405.00 MHz [0x195] (Memory) |
| Clock Speed 2 | n.a. (Processor) |
| Hardware monitor | NVIDIA NVAPI |
| Power 01 | 2.12 W (GPU) |
| Hardware monitor | D3D |
| Hardware monitor | NVIDIA I/O |
| PCI Devices | |
| Description | Host Bridge |
| Location | bus 0 (0x00), device 0 (0x00), function 0 (0x00) |
| Common header | |
| Vendor ID | 0x8086 (Intel) |
| Model ID | 0x3EC4 |
| Revision ID | 0x0D |
| PCI header | |
| Subvendor ID | 0x103C (Hewlett-Packard) |
| Subsystem ID | 0x860F |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| PCI capability | |
| Caps class | Vendor Dependant |
| Caps offset | 0xE0 |
| Description | PCI to PCI Bridge |
| Location | bus 0 (0x00), device 1 (0x01), function 0 (0x00) |
| Common header | |
| Model ID | 0x1901 |
| PCI header | |
| Primary bus | 0x00 |
| Secondary bus | 0x01 |
| Int. Line | 0x00 |
| Int. Pin | 0x01 |
| PCI capability | |
| Caps class | Subsystem Vendor |
| Caps offset | 0x88 |
| SubVendor ID | 0x103C (Hewlett-Packard) |
| SubSystem ID | 0x860F |
| PCI capability | |
| Caps class | Power Management |
| Caps offset | 0x80 |
| Caps version | 1.2 |
| PCI capability | |
| Caps class | Message Signalled Interrupts |
| Caps offset | 0x90 |
| PCI capability | |
| Caps class | PCI Express |
| Caps offset | 0xA0 |
| Device type | Root Port of PCI-E Root Complex |
| Port | 2 |
| Caps version | 2.0 |
| Physical slot | #0 |
| Presence detect | yes |
| Link width | 16x (max 16x) |
| Link speed | 2.5 GT/s (max 8.0 GT/s) |
| Description | Data Aquisition and Signal Processing Device |
| Location | bus 0 (0x00), device 4 (0x04), function 0 (0x00) |
| Common header | |
| Model ID | 0x1903 |
| PCI header | |
| Address 0 (memory) | 0x0000007FFFEF0004 |
| Int. Line | 0x10 |
| Int. Pin | 0x01 |
| PCI capability | |
| PCI capability | |
| Caps offset | 0xD0 |
| PCI capability | |
| Location | bus 0 (0x00), device 18 (0x12), function 0 (0x00) |
| Common header | |
| Model ID | 0xA379 |
| Revision ID | 0x10 |
| PCI header | |
| Address 0 (memory) | 0x000000404A111004 |
| Int. Line | 0xFF |
| Int. Pin | 0x01 |
| PCI capability | |
| Caps offset | 0x50 |
| PCI capability | |
| Description | USB Controller (xHCI) |
| Location | bus 0 (0x00), device 20 (0x14), function 0 (0x00) |
| Common header | |
| Model ID | 0xA36D |
| PCI header | |
| Address 0 (memory) | 0x00000000ED320004 |
| Int. Line | 0x00 |
| Int. Pin | 0x01 |
| PCI capability | |
| Caps offset | 0x70 |
| Caps version | 1.1 |
| PCI capability | |
| PCI capability | |
| Description | RAM Memory Controller |
| Location | bus 0 (0x00), device 20 (0x14), function 2 (0x02) |
| Common header | |
| Model ID | 0xA36F |
| PCI header | |
| Address 0 (memory) | 0x00000000ED332004 |
| Address 2 (memory) | 0x000000404A110004 |
| Int. Line | 0xFF |
| Int. Pin | 0x00 |
| PCI capability | |
| Description | Serial Bus Controller |
| Location | bus 0 (0x00), device 21 (0x15), function 0 (0x00) |
| Common header | |
| Model ID | 0xA368 |
| PCI header | |
| Int. Line | 0x10 |
| Int. Pin | 0x01 |
| PCI capability | |
| PCI capability | |
| Location | bus 0 (0x00), device 21 (0x15), function 1 (0x01) |
| Common header | |
| Model ID | 0xA369 |
| PCI header | |
| Address 0 (memory) | 0x0000007FFFEFA004 |
| Int. Line | 0x11 |
| Int. Pin | 0x02 |
| PCI capability | |
| PCI capability | |
| Description | Communication Device |
| Location | bus 0 (0x00), device 22 (0x16), function 0 (0x00) |
| Common header | |
| Model ID | 0xA360 |
| PCI header | |
| Address 0 (memory) | 0x0000007FFFEF9004 |
| Int. Line | 0x00 |
| Int. Pin | 0x01 |
| PCI capability | |
| PCI capability | |
| Caps offset | 0x8C |
| PCI capability | |
| Caps offset | 0xA4 |
| Description | Serial 16550 Controller |
| Location | bus 0 (0x00), device 22 (0x16), function 3 (0x03) |
| Common header | |
| Model ID | 0xA363 |
| PCI header | |
| Address 0 (port) | 0x0000FFF8 |
| Address 1 (memory) | 0xFE1FF000 |
| Int. Line | 0x13 |
| Int. Pin | 0x04 |
| PCI capability | |
| Caps offset | 0x40 |
| PCI capability | |
| Description | Serial ATA Controller - AHCI |
| Location | bus 0 (0x00), device 23 (0x17), function 0 (0x00) |
| Common header | |
| Model ID | 0xA353 |
| PCI header | |
| Address 0 (memory) | 0xED330000 |
| Address 1 (memory) | 0xED336000 |
| Address 2 (port) | 0x00005040 |
| Address 3 (port) | 0x00005050 |
| Address 4 (port) | 0x00005020 |
| Address 5 (memory) | 0xED335000 |
| Int. Line | 0x00 |
| Int. Pin | 0x01 |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Caps class | Serial ATA Configuration |
| Caps offset | 0xA8 |
| Location | bus 0 (0x00), device 28 (0x1C), function 0 (0x00) |
| Common header | |
| Model ID | 0xA33A |
| Revision ID | 0xF0 |
| PCI header | |
| Secondary bus | 0x02 |
| Int. Line | 0x00 |
| Int. Pin | 0x03 |
| PCI capability | |
| Port | 3 |
| Presence detect | no |
| Link width | 1x (max 1x) |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Location | bus 0 (0x00), device 28 (0x1C), function 4 (0x04) |
| Common header | |
| Model ID | 0xA33C |
| PCI header | |
| Secondary bus | 0x04 |
| Int. Line | 0x00 |
| Int. Pin | 0x01 |
| PCI capability | |
| Port | 5 |
| Link width | 4x (max 4x) |
| Link speed | 8.0 GT/s (max 8.0 GT/s) |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Location | bus 0 (0x00), device 29 (0x1D), function 0 (0x00) |
| Common header | |
| Model ID | 0xA330 |
| PCI header | |
| Secondary bus | 0x6F |
| Int. Line | 0x00 |
| Int. Pin | 0x01 |
| PCI capability | |
| Port | 9 |
| Physical slot | #1 |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Location | bus 0 (0x00), device 29 (0x1D), function 5 (0x05) |
| Common header | |
| Model ID | 0xA335 |
| PCI header | |
| Secondary bus | 0x70 |
| Int. Line | 0x00 |
| Int. Pin | 0x02 |
| PCI capability | |
| Port | 14 |
| Link speed | 5.0 GT/s (max 8.0 GT/s) |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Description | PCI to ISA Bridge |
| Location | bus 0 (0x00), device 31 (0x1F), function 0 (0x00) |
| Common header | |
| Model ID | 0xA30E |
| PCI header | |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| Description | Audio device |
| Location | bus 0 (0x00), device 31 (0x1F), function 3 (0x03) |
| Common header | |
| Model ID | 0xA348 |
| PCI header | |
| Address 0 (memory) | 0x0000007FFFEFC004 |
| Address 4 (memory) | 0x0000007FFFF00004 |
| Int. Line | 0x00 |
| Int. Pin | 0x01 |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Caps offset | 0x60 |
| Description | SMBus Controller |
| Location | bus 0 (0x00), device 31 (0x1F), function 4 (0x04) |
| Common header | |
| Model ID | 0xA323 |
| PCI header | |
| Address 0 (memory) | 0x000000404A10C004 |
| Address 4 (port) | 0x0000EFA0 |
| Int. Line | 0x0B |
| Int. Pin | 0x01 |
| Location | bus 0 (0x00), device 31 (0x1F), function 5 (0x05) |
| Common header | |
| Model ID | 0xA324 |
| PCI header | |
| Address 0 (memory) | 0xFE010000 |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| Description | Ethernet Controller |
| Location | bus 0 (0x00), device 31 (0x1F), function 6 (0x06) |
| Common header | |
| Model ID | 0x15BB |
| PCI header | |
| Address 0 (memory) | 0xED300000 |
| Int. Line | 0x00 |
| Int. Pin | 0x01 |
| PCI capability | |
| Caps offset | 0xC8 |
| PCI capability | |
| Description | VGA Controller |
| Location | bus 1 (0x01), device 0 (0x00), function 0 (0x00) |
| Common header | |
| Vendor ID | 0x10DE (NVIDIA) |
| Model ID | 0x1FB9 |
| Revision ID | 0xA1 |
| PCI header | |
| Address 0 (memory) | 0xE8000000 |
| Address 1 (memory) | 0x00000000A000000C |
| Address 3 (memory) | 0x00000000B000000C |
| Address 5 (port) | 0x00004000 |
| Subsystem ID | 0x8611 |
| Int. Line | 0x00 |
| Int. Pin | 0x01 |
| PCI capability | |
| PCI capability | |
| Caps offset | 0x68 |
| PCI capability | |
| Caps offset | 0x78 |
| Device type | Legacy PCI-E Endpoint Device |
| Port | 0 |
| Description | High Definition Audio (HDA) |
| Location | bus 1 (0x01), device 0 (0x00), function 1 (0x01) |
| Common header | |
| Model ID | 0x10FA |
| PCI header | |
| Address 0 (memory) | 0xE90FC000 |
| Int. Line | 0x11 |
| Int. Pin | 0x02 |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Device type | PCI-E Endpoint Device |
| Port | 0 |
| Description | NVM Express (NVMe) Controller |
| Location | bus 111 (0x6F), device 0 (0x00), function 0 (0x00) |
| Common header | |
| Vendor ID | 0x1C5C (SK hynix) |
| Model ID | 0x174A |
| Revision ID | 0x00 |
| PCI header | |
| Address 0 (memory) | 0x00000000ED200004 |
| Address 2 (memory) | 0xED205000 |
| Address 3 (memory) | 0xED204000 |
| Subvendor ID | 0x1C5C (SK hynix) |
| Subsystem ID | 0x174A |
| Int. Line | 0x00 |
| Int. Pin | 0x01 |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Caps class | MSI-X |
| Caps offset | 0xB0 |
| PCI capability | |
| Caps offset | 0xC0 |
| Port | 0 |
| Description | Network Controller |
| Location | bus 112 (0x70), device 0 (0x00), function 0 (0x00) |
| Common header | |
| Model ID | 0x2723 |
| Revision ID | 0x1A |
| PCI header | |
| Address 0 (memory) | 0x00000000ED1FC004 |
| Subvendor ID | 0x8086 (Intel) |
| Subsystem ID | 0x0088 |
| Int. Line | 0x00 |
| Int. Pin | 0x01 |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Port | 0 |
| Link speed | 5.0 GT/s (max 5.0 GT/s) |
| PCI capability | |
| DMI | |
| SMBIOS Version | 3.1 |
| DMI BIOS | |
| vendor | HP |
| version | R92 Ver. 01.06.00 |
| date | 08/03/2020 |
| ROM size | 16384 KB |
| DMI System Information | |
| manufacturer | HP |
| product | HP ZBook 15 G6 |
| version | unknown |
| serial | 5CD026GTKV |
| UUID | {9D5FA155-97A7-9A28-1126-59C114080EA9} |
| SKU | 6CJ05AV |
| family | 103C_5336AN HP ZBook |
| DMI Baseboard | |
| vendor | HP |
| model | 860F |
| revision | KBC Version 65.2D.00 |
| serial | PJJUL018JDW00N |
| DMI System Enclosure | |
| manufacturer | HP |
| chassis type | Notebook |
| chassis serial | 5CD026GTKV |
| DMI Physical Memory Array | |
| location | Motherboard |
| usage | System Memory |
| correction | None |
| max capacity | 64 GB |
| max# of devices | 4 |
| DMI Processor | |
| manufacturer | Intel(R) Corporation |
| model | Intel(R) Core(TM) i7-9850H CPU @ 2.60GHz |
| clock speed | 2475.0 MHz |
| FSB speed | 100.0 MHz |
| multiplier | 25.0x |
| max clock speed | 4600.0 MHz |
| DMI Port Connector | |
| designation | Ctrl0Port0 (internal) |
| designation | SSD1 (external) |
| designation | Ctrl0Port1 (internal) |
| designation | HDD1 (external) |
| designation | Ctrl0Port4 (internal) |
| designation | SSD2 (external) |
| DMI Extension Slot | |
| designation | M2 WLAN/BT |
| type | PCI Express Gen 3 |
| populated | no |
| designation | M2 SSD |
| populated | yes |
| DMI Memory Device | |
| designation | Top-Slot 1(left) |
| format | SODIMM |
| type | DDR4 |
| total width | 64 bits |
| data width | 64 bits |
| size | 16 GB |
| speed | 2400 MHz |
| manufacturer | Samsung |
| part number | M471A2K43CB1-CTD |
| serial number | 37589399 |
| voltage | 1.200000 |
| designation | Top-Slot 2(right) |
| format | SODIMM |
| type | DDR4 |
| size | 16 GB |
| speed | 2400 MHz |
| serial number | 37589451 |
| designation | Bottom-Slot 1(left) |
| format | unknown |
| type | unknown |
| designation | Bottom-Slot 2(right) |
| format | unknown |
| type | unknown |
| DMI OEM Strings | |
| string[0] | FBYTE#3X476J6S6b7B7M7Q7U7W7maBaEapaqauawbhcAdUdpdqfPhKjhk8.FD; |
| string[1] | BUILDID#19WWAVCT601#SABD#DABD; |
| string[2] | EDK2_1 |
| string[3] | Buff=2 |
| string[4] | HRDWFEATS=VMCSSHAD:1;VTX:1;VTD:1;SGX:0;NONHPBATDET:1; |
| string[5] | MEFWRec |
| Graphics | |
| Number of adapters | 1 |
| Graphic APIs | |
| API | D3D |
| API | NVIDIA I/O |
| API | NVIDIA NVML |
| API | NVIDIA NVAPI |
| pwrMask | 0x0008014B |
| pwrTable | [F5 F6 00 F1 00 00 FE 00 E8 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 ] |
| Display Adapters | |
| Display adapter 0 (primary) | |
| ID | 0x1000000 |
| Name | NVIDIA Quadro T1000 |
| Board Manufacturer | Hewlett-Packard |
| Revision | A1 |
| Core family | 0x167 (TU117GL-A) |
| Power Limit | 50.0 W (default) |
| Thermal Limit | 102.0 °C (max), 92.0 °C (slowdown), 97.0 °C (shutdown) |
| Cores | 896 |
| ROP Units | 32 |
| Memory type | GDDR5 |
| Memory vendor | Hynix |
| Memory size | 4 GB |
| Memory bus width | 128 bits |
| Current Link Width | x16 |
| Current Link Speed | 2.5 GT/s |
| PCI device | bus 1 (0x1), device 0 (0x0), function 0 (0x0) |
| Vendor ID | 0x10DE (0x103C) |
| Model ID | 0x1FB9 (0x8611) |
| Root device | bus 0 (0x0), device 1 (0x1), function 0 (0x0) |
| Performance Level | Base |
| Core clock | 1395.0 MHz |
| Shader clock | 1395.0 MHz |
| Memory clock | 4001.0 MHz |
| Performance Level | Boost |
| Core clock | 1455.0 MHz |
| Shader clock | 1455.0 MHz |
| Performance Level | Current |
| Core clock | 300.0 MHz |
| Memory clock | 405.0 MHz |
| Driver version | 32.0.15.9595 |
| WDDM Model | 3.2 |
| Win32_VideoController | AdapterRAM = 0xFFF00000 (4293918720) |
| Win32_VideoController | DriverVersion = 32.0.15.9595 |
| Win32_VideoController | DriverDate = 03/15/2026 |
| Monitor 0 | |
| Model | () |
| ID | BOE0852 |
| Serial | |
| Manufacturing Date | Week 47, Year 2018 |
| Size | 15.3 inches |
| Max Resolution | 1920 x 1080 @ 60 Hz |
| Horizontal Freq. Range | 0-0 kHz |
| Vertical Freq. Range | 0-0 Hz |
| Max Pixel Clock | 0 MHz |
| Gamma Factor | 2.2 |
| Video Input | Display Port |
| Software | |
| Windows Version | Microsoft Windows 11 Professional (x64) Build 26200.8737 |
| Windows Installation Date | 2/28/2024 |
| DirectX Version | 12.0 |
