[...] ICNova registering isp176x_hal [...] # cd /lib/modules/2.6.28.4/kernel/drivers/usb/pehcd/ # modprobe hal/hal_avr32.ko # modprobe host/pehci.ko usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb hal_avr32isp1761_register_driver(drv=c0929c20) ++ pehci_hcd_probe: Entered ++ pehci_hcd_probe: Entered isp176x_hal isp176x_hal.0: ST-ERICSSOON ISP1761 isp176x_hal isp176x_hal.0: new USB bus registered, assigned bus number 1 isp176x_hal isp176x_hal.0: irq 64, io mem 0x000000 ++ pehci_hcd_start: Entered ++ pehci_hcd_init_reg: Entered -- pehci_hcd_init_reg: Exit ++ pehci_hcd_start_controller: Entered -- pehci_hcd_start_controller: Exit ++ pehci_hcd_init_map_buffers: Entered phci_init_map_buffers(phci = 0x9310c800) -- pehci_hcd_init_map_buffers: Exit -- pehci_hcd_start: Exit usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: ST-ERICSSOON ISP1761 usb usb1: Manufacturer: Linux 2.6.28.4 ISP1761HCD usb usb1: SerialNumber: ISP1761 usb usb1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found pehci_rh_control : Enterd pehci_rh_control: number of ports 17 ++ pehci_hub_descriptor: Entered pehci_hub_descriptor: number of ports 1 -- pehci_hub_descriptor: Exit pehci_rh_control : Exit hub 1-0:1.0: 1 port detected pehci_rh_control : Enterd pehci_rh_control: number of ports 17 pehci_rh_control : Exit pehci_rh_control : Enterd pehci_rh_control: number of ports 17 pehci_rh_control: SetPortFeature SetPortFeature: USB_PORT_FEAT_POWER pehci_rh_control : Exit -- pehci_hcd_probe: Exit drivers/usb/pehcd/hal/hal_avr32.c: Registered Driver ISP1761HCD pehciHost Driver has been Registeredpehci_rh_control : Enterd pehci_rh_control: number of ports 17 pehci_rh_control: GetPortStatus feature CSC 0x00001803 and status 0x00010000 pehci_rh_control : Exit pehci_rh_control : Enterd pehci_rh_control: number of ports 17 pehci_rh_control: ClearPortFeature connect change, status is 0x00001803 pehci_rh_control : Exit # lsmod Module Size Used by Not tainted pehci 33572 0 usbcore 92300 1 pehci hal_avr32 7104 1 pehci
