#include #include #include #include #include // ----------------------------- // Pin-Zuordnung MegaCore AT90CAN64 // ----------------------------- #define CJ125_CS_PIN 8 // PB0 #define HEATER_OUTPUT_PIN 12 // PB4, Low-Side MOSFET #define LED_ONOFF_PIN 15 // PB7 #define LED_STATUS_POWER 7 // PE7 #define LED_STATUS_HEATER 6 // PE6 #define UB_ANALOG_INPUT_PIN 48 // PF3 -> UBatt #define UR_ANALOG_INPUT_PIN 49 // PF4 -> UR #define UA_ANALOG_INPUT_PIN 50 // PF5 -> UA // ----------------------------- // CJ125 Register / Konstanten // ----------------------------- #define CJ125_IDENT_REG_REQUEST 0x4800 #define CJ125_DIAG_REG_REQUEST 0x7800 #define CJ125_INIT_REG1_REQUEST 0x6C00 #define CJ125_INIT_REG2_REQUEST 0x7E00 #define CJ125_INIT_REG1_MODE_CALIBRATE 0x569D #define CJ125_INIT_REG1_MODE_NORMAL_V8 0x5688 #define CJ125_INIT_REG1_MODE_NORMAL_V17 0x5689 #define CJ125_DIAG_REG_STATUS_OK 0x28FF #define CJ125_DIAG_REG_STATUS_NOPOWER 0x2855 #define CJ125_DIAG_REG_STATUS_NOSENSOR 0x287F #define CJ125_INIT_REG1_STATUS_0 0x2888 #define CJ125_INIT_REG1_STATUS_1 0x2889 // ----------------------------- // Einstellbare Parameter // ----------------------------- #define SERIAL_RATE_HZ 5 // Ausgabe-Rate in Hz #define UBAT_MIN_VOLT 10.5 // minimale Bordspannung in Volt #define UBAT_DIV_FACTOR 11.0 // 100k / 10k Teiler #define ADC_REF_VOLT 5.0 // UBAT_MIN als ADC-Schwelle (ca.) #define UBAT_MIN_ADC (uint16_t)((UBAT_MIN_VOLT / (ADC_REF_VOLT * UBAT_DIV_FACTOR)) * 1023.0) // ----------------------------- // Globale Variablen // ----------------------------- int adcValue_UA = 0; int adcValue_UR = 0; int adcValue_UB = 0; int adcValue_UA_Optimal = 0; int adcValue_UR_Optimal = 0; int HeaterOutput = 0; int serial_counter = 0; uint16_t CJ125_Status = 0; // PID int dState = 0; int iState = 0; const int iMax = 250; const int iMin = -250; const float pGain = 120.0; const float iGain = 0.8; const float dGain = 10.0; // ----------------------------- // Lambda- und O2-Tabellen (Platzhalter) // ----------------------------- // Füge hier deine Tabellen ein: const PROGMEM float Lambda_Conversion[753] { 0.750, 0.751, 0.752, 0.752, 0.753, 0.754, 0.755, 0.755, 0.756, 0.757, 0.758, 0.758, 0.759, 0.760, 0.761, 0.761, 0.762, 0.763, 0.764, 0.764, 0.765, 0.766, 0.766, 0.767, 0.768, 0.769, 0.769, 0.770, 0.771, 0.772, 0.772, 0.773, 0.774, 0.774, 0.775, 0.776, 0.777, 0.777, 0.778, 0.779, 0.780, 0.780, 0.781, 0.782, 0.782, 0.783, 0.784, 0.785, 0.785, 0.786, 0.787, 0.787, 0.788, 0.789, 0.790, 0.790, 0.791, 0.792, 0.793, 0.793, 0.794, 0.795, 0.796, 0.796, 0.797, 0.798, 0.799, 0.799, 0.800, 0.801, 0.802, 0.802, 0.803, 0.804, 0.805, 0.805, 0.806, 0.807, 0.808, 0.808, 0.809, 0.810, 0.811, 0.811, 0.812, 0.813, 0.814, 0.815, 0.815, 0.816, 0.817, 0.818, 0.819, 0.820, 0.820, 0.821, 0.822, 0.823, 0.824, 0.825, 0.825, 0.826, 0.827, 0.828, 0.829, 0.830, 0.830, 0.831, 0.832, 0.833, 0.834, 0.835, 0.836, 0.837, 0.837, 0.838, 0.839, 0.840, 0.841, 0.842, 0.843, 0.844, 0.845, 0.846, 0.846, 0.847, 0.848, 0.849, 0.850, 0.851, 0.852, 0.853, 0.854, 0.855, 0.855, 0.856, 0.857, 0.858, 0.859, 0.860, 0.861, 0.862, 0.863, 0.864, 0.865, 0.865, 0.866, 0.867, 0.868, 0.869, 0.870, 0.871, 0.872, 0.873, 0.874, 0.875, 0.876, 0.877, 0.878, 0.878, 0.879, 0.880, 0.881, 0.882, 0.883, 0.884, 0.885, 0.886, 0.887, 0.888, 0.889, 0.890, 0.891, 0.892, 0.893, 0.894, 0.895, 0.896, 0.897, 0.898, 0.899, 0.900, 0.901, 0.902, 0.903, 0.904, 0.905, 0.906, 0.907, 0.908, 0.909, 0.910, 0.911, 0.912, 0.913, 0.915, 0.916, 0.917, 0.918, 0.919, 0.920, 0.921, 0.922, 0.923, 0.924, 0.925, 0.926, 0.927, 0.928, 0.929, 0.931, 0.932, 0.933, 0.934, 0.935, 0.936, 0.937, 0.938, 0.939, 0.940, 0.941, 0.942, 0.944, 0.945, 0.946, 0.947, 0.948, 0.949, 0.950, 0.951, 0.952, 0.953, 0.954, 0.955, 0.957, 0.958, 0.959, 0.960, 0.961, 0.962, 0.963, 0.965, 0.966, 0.967, 0.969, 0.970, 0.971, 0.973, 0.974, 0.976, 0.977, 0.979, 0.980, 0.982, 0.983, 0.985, 0.986, 0.987, 0.989, 0.990, 0.991, 0.992, 0.994, 0.995, 0.996, 0.998, 0.999, 1.001, 1.003, 1.005, 1.008, 1.010, 1.012, 1.015, 1.017, 1.019, 1.022, 1.024, 1.026, 1.028, 1.030, 1.032, 1.035, 1.037, 1.039, 1.041, 1.043, 1.045, 1.048, 1.050, 1.052, 1.055, 1.057, 1.060, 1.062, 1.064, 1.067, 1.069, 1.072, 1.075, 1.077, 1.080, 1.082, 1.085, 1.087, 1.090, 1.092, 1.095, 1.098, 1.100, 1.102, 1.105, 1.107, 1.110, 1.112, 1.115, 1.117, 1.120, 1.122, 1.124, 1.127, 1.129, 1.132, 1.135, 1.137, 1.140, 1.142, 1.145, 1.148, 1.151, 1.153, 1.156, 1.159, 1.162, 1.165, 1.167, 1.170, 1.173, 1.176, 1.179, 1.182, 1.185, 1.188, 1.191, 1.194, 1.197, 1.200, 1.203, 1.206, 1.209, 1.212, 1.215, 1.218, 1.221, 1.224, 1.227, 1.230, 1.234, 1.237, 1.240, 1.243, 1.246, 1.250, 1.253, 1.256, 1.259, 1.262, 1.266, 1.269, 1.272, 1.276, 1.279, 1.282, 1.286, 1.289, 1.292, 1.296, 1.299, 1.303, 1.306, 1.310, 1.313, 1.317, 1.320, 1.324, 1.327, 1.331, 1.334, 1.338, 1.342, 1.345, 1.349, 1.352, 1.356, 1.360, 1.364, 1.367, 1.371, 1.375, 1.379, 1.382, 1.386, 1.390, 1.394, 1.398, 1.401, 1.405, 1.409, 1.413, 1.417, 1.421, 1.425, 1.429, 1.433, 1.437, 1.441, 1.445, 1.449, 1.453, 1.457, 1.462, 1.466, 1.470, 1.474, 1.478, 1.483, 1.487, 1.491, 1.495, 1.500, 1.504, 1.508, 1.513, 1.517, 1.522, 1.526, 1.531, 1.535, 1.540, 1.544, 1.549, 1.554, 1.558, 1.563, 1.568, 1.572, 1.577, 1.582, 1.587, 1.592, 1.597, 1.601, 1.606, 1.611, 1.616, 1.621, 1.627, 1.632, 1.637, 1.642, 1.647, 1.652, 1.658, 1.663, 1.668, 1.674, 1.679, 1.684, 1.690, 1.695, 1.701, 1.707, 1.712, 1.718, 1.724, 1.729, 1.735, 1.741, 1.747, 1.753, 1.759, 1.764, 1.770, 1.776, 1.783, 1.789, 1.795, 1.801, 1.807, 1.813, 1.820, 1.826, 1.832, 1.839, 1.845, 1.852, 1.858, 1.865, 1.872, 1.878, 1.885, 1.892, 1.898, 1.905, 1.912, 1.919, 1.926, 1.933, 1.940, 1.947, 1.954, 1.961, 1.968, 1.975, 1.983, 1.990, 1.997, 2.005, 2.012, 2.020, 2.027, 2.035, 2.042, 2.050, 2.058, 2.065, 2.073, 2.081, 2.089, 2.097, 2.105, 2.113, 2.121, 2.129, 2.137, 2.145, 2.154, 2.162, 2.171, 2.179, 2.188, 2.196, 2.205, 2.214, 2.222, 2.231, 2.240, 2.249, 2.258, 2.268, 2.277, 2.286, 2.295, 2.305, 2.314, 2.324, 2.333, 2.343, 2.353, 2.363, 2.373, 2.383, 2.393, 2.403, 2.413, 2.424, 2.434, 2.444, 2.455, 2.466, 2.476, 2.487, 2.498, 2.509, 2.520, 2.532, 2.543, 2.554, 2.566, 2.577, 2.589, 2.601, 2.613, 2.625, 2.637, 2.649, 2.662, 2.674, 2.687, 2.699, 2.712, 2.725, 2.738, 2.751, 2.764, 2.778, 2.791, 2.805, 2.819, 2.833, 2.847, 2.861, 2.875, 2.890, 2.904, 2.919, 2.934, 2.949, 2.964, 2.979, 2.995, 3.010, 3.026, 3.042, 3.058, 3.074, 3.091, 3.107, 3.124, 3.141, 3.158, 3.175, 3.192, 3.209, 3.227, 3.245, 3.263, 3.281, 3.299, 3.318, 3.337, 3.355, 3.374, 3.394, 3.413, 3.433, 3.452, 3.472, 3.492, 3.513, 3.533, 3.554, 3.575, 3.597, 3.618, 3.640, 3.662, 3.684, 3.707, 3.730, 3.753, 3.776, 3.800, 3.824, 3.849, 3.873, 3.898, 3.924, 3.950, 3.976, 4.002, 4.029, 4.056, 4.084, 4.112, 4.140, 4.169, 4.198, 4.228, 4.258, 4.288, 4.319, 4.350, 4.382, 4.414, 4.447, 4.480, 4.514, 4.548, 4.583, 4.618, 4.654, 4.690, 4.726, 4.764, 4.801, 4.840, 4.879, 4.918, 4.958, 4.999, 5.040, 5.082, 5.124, 5.167, 5.211, 5.255, 5.299, 5.345, 5.391, 5.438, 5.485, 5.533, 5.582, 5.632, 5.683 ,5.735, 5.788, 5.841, 5.896, 5.953, 6.010, 6.069, 6.129, 6.190, 6.253, 6.318, 6.384, 6.452, 6.521, 6.592, 6.665, 6.740, 6.817, 6.896, 6.976, 7.059, 7.144, 7.231, 7.320, 7.412, 7.506, 7.602, 7.701, 7.803, 7.906, 8.013, 8.122, 8.234, 8.349, 8.466, 8.587, 8.710, 8.837, 8.966, 9.099, 9.235, 9.374, 9.516, 9.662, 9.811, 9.963, 10.119 }; const PROGMEM float Oxygen_Conversion[548] { 00.00, 00.04, 00.08, 00.13, 00.17, 00.21, 00.25, 00.30, 00.34, 00.38, 00.42, 00.47, 00.51, 00.55, 00.59, 00.64, 00.68, 00.72, 00.76, 00.81, 00.85, 00.89, 00.93, 00.98, 01.02, 01.06, 01.10, 01.15, 01.19, 01.23, 01.27, 01.31, 01.36, 01.40, 01.44, 01.48, 01.53, 01.57, 01.61, 01.65, 01.70, 01.74, 01.78, 01.82, 01.86, 01.91, 01.95, 01.99, 02.03, 02.08, 02.12, 02.16, 02.20, 02.24, 02.29, 02.33, 02.37, 02.41, 02.45, 02.50, 02.54, 02.58, 02.62, 02.66, 02.71, 02.75, 02.79, 02.83, 02.87, 02.92, 02.96, 03.00, 03.04, 03.08, 03.13, 03.17, 03.21, 03.25, 03.29, 03.33, 03.38, 03.42, 03.46, 03.50, 03.54, 03.58, 03.63, 03.67, 03.71, 03.75, 03.79, 03.83, 03.88, 03.92, 03.96, 04.00, 04.04, 04.08, 04.12, 04.17, 04.21, 04.25, 04.29, 04.33, 04.37, 04.41, 04.45, 04.50, 04.54, 04.58, 04.62, 04.66, 04.70, 04.74, 04.78, 04.82, 04.86, 04.91, 04.95, 04.99, 05.03, 05.07, 05.11, 05.15, 05.19, 05.23, 05.27, 05.31, 05.35, 05.39, 05.44, 05.48, 05.52, 05.56, 05.60, 05.64, 05.68, 05.72, 05.76, 05.80, 05.84, 05.88, 05.92, 05.96, 06.00, 06.04, 06.08, 06.12, 06.16, 06.20, 06.24, 06.28, 06.32, 06.36, 06.40, 06.44, 06.48, 06.52, 06.56, 06.60, 06.64, 06.68, 06.72, 06.76, 06.80, 06.84, 06.88, 06.92, 06.96, 07.00, 07.03, 07.07, 07.11, 07.15, 07.19, 07.23, 07.27, 07.31, 07.35, 07.39, 07.43, 07.47, 07.51, 07.55, 07.59, 07.62, 07.66, 07.70, 07.74, 07.78, 07.82, 07.86, 07.90, 07.94, 07.98, 08.02, 08.06, 08.09, 08.13, 08.17, 08.21, 08.25, 08.29, 08.33, 08.37, 08.41, 08.45, 08.49, 08.52, 08.56, 08.60, 08.64, 08.68, 08.72, 08.76, 08.80, 08.84, 08.88, 08.91, 08.95, 08.99, 09.03, 09.07, 09.11, 09.15, 09.19, 09.23, 09.26, 09.30, 09.34, 09.38, 09.42, 09.46, 09.50, 09.54, 09.57, 09.61, 09.65, 09.69, 09.73, 09.77, 09.81, 09.85, 09.89, 09.92, 09.96, 10.00, 10.04, 10.08, 10.12, 10.16, 10.19, 10.23, 10.27, 10.31, 10.35, 10.39, 10.43, 10.47, 10.50, 10.54, 10.58, 10.62, 10.66, 10.70, 10.73, 10.77, 10.81, 10.85, 10.89, 10.93, 10.97, 11.00, 11.04, 11.08, 11.12, 11.16, 11.20, 11.23, 11.27, 11.31, 11.35, 11.39, 11.43, 11.46, 11.50, 11.54, 11.58, 11.62, 11.66, 11.69, 11.73, 11.77, 11.81, 11.85, 11.89, 11.92, 11.96, 12.00, 12.04, 12.08, 12.11, 12.15, 12.19, 12.23, 12.27, 12.30, 12.34, 12.38, 12.42, 12.46, 12.49, 12.53, 12.57, 12.61, 12.65, 12.68, 12.72, 12.76, 12.80, 12.84, 12.87, 12.91, 12.95, 12.99, 13.03, 13.06, 13.10, 13.14, 13.18, 13.21, 13.25, 13.29, 13.33, 13.36, 13.40, 13.44, 13.48, 13.51, 13.55, 13.59, 13.63, 13.67, 13.70, 13.74, 13.78, 13.82, 13.85, 13.89, 13.93, 13.96, 14.00, 14.04, 14.08, 14.11, 14.15, 14.19, 14.23, 14.26, 14.30, 14.34, 14.38, 14.41, 14.45, 14.49, 14.52, 14.56, 14.60, 14.64, 14.67, 14.71, 14.75, 14.78, 14.82, 14.86, 14.90, 14.93, 14.97, 15.01, 15.04, 15.08, 15.12, 15.15, 15.19, 15.23, 15.26, 15.30, 15.34, 15.37, 15.41, 15.45, 15.48, 15.52, 15.56, 15.59, 15.63, 15.67, 15.70, 15.74, 15.78, 15.81, 15.85, 15.89, 15.92, 15.96, 16.00, 16.03, 16.07, 16.11, 16.14, 16.18, 16.22, 16.25, 16.29, 16.32, 16.36, 16.40, 16.43, 16.47, 16.51, 16.54, 16.58, 16.61, 16.65, 16.69, 16.72, 16.76, 16.79, 16.83, 16.87, 16.90, 16.94, 16.97, 17.01, 17.05, 17.08, 17.12, 17.15, 17.19, 17.22, 17.26, 17.30, 17.33, 17.37, 17.40, 17.44, 17.47, 17.51, 17.55, 17.58, 17.62, 17.65, 17.69, 17.72, 17.76, 17.79, 17.83, 17.86, 17.90, 17.94, 17.97, 18.01, 18.04, 18.08, 18.11, 18.15, 18.18, 18.22, 18.25, 18.29, 18.32, 18.36, 18.39, 18.43, 18.46, 18.50, 18.53, 18.57, 18.60, 18.64, 18.67, 18.71, 18.74, 18.78, 18.81, 18.85, 18.88, 18.92, 18.95, 18.98, 19.02, 19.05, 19.09, 19.12, 19.16, 19.19, 19.23, 19.26, 19.30, 19.33, 19.36, 19.40, 19.43, 19.47, 19.50, 19.54, 19.57, 19.60, 19.64, 19.67, 19.71, 19.74, 19.77, 19.81, 19.84, 19.88, 19.91, 19.94, 19.98, 20.01, 20.05, 20.08, 20.11, 20.15, 20.18, 20.22, 20.25, 20.28, 20.32, 20.35, 20.38, 20.42, 20.45, 20.48, 20.52, 20.55, 20.58, 20.62, 20.65, 20.68, 20.72, 20.75, 20.78, 20.82, 20.85, 20.88, 20.92, 20.95 }; // ----------------------------- // SPI zum CJ125 // ----------------------------- uint16_t COM_SPI(uint16_t TX_data) { SPI.beginTransaction(SPISettings(500000, MSBFIRST, SPI_MODE1)); digitalWrite(CJ125_CS_PIN, LOW); uint16_t Response = SPI.transfer16(TX_data); digitalWrite(CJ125_CS_PIN, HIGH); SPI.endTransaction(); return Response; } // ----------------------------- // Lambda-Lookup // ----------------------------- float Lookup_Lambda(int Input_ADC) { float LAMBDA_VALUE = 0.0; if (Input_ADC >= 39 && Input_ADC <= 791) { LAMBDA_VALUE = pgm_read_float_near(Lambda_Conversion + (Input_ADC - 39)); } else if (Input_ADC > 791) { LAMBDA_VALUE = 10.119; } else { LAMBDA_VALUE = 0.750; } return LAMBDA_VALUE; } // ----------------------------- // O2-Lookup // ----------------------------- float Lookup_Oxygen(int Input_ADC) { float OXYGEN_CONTENT = 0.0; if (Input_ADC > 854) Input_ADC = 854; if (Input_ADC >= 307 && Input_ADC <= 854) { OXYGEN_CONTENT = pgm_read_float_near(Oxygen_Conversion + (Input_ADC - 307)); } return OXYGEN_CONTENT; } // ----------------------------- // PID-Regler Heizung // ----------------------------- int Heater_PID_Control(int input) { int error = adcValue_UR_Optimal - input; int position = input; float pTerm = -pGain * error; iState += error; if (iState > iMax) iState = iMax; if (iState < iMin) iState = iMin; float iTerm = -iGain * iState; float dTerm = -dGain * (dState - position); dState = position; int RegulationOutput = (int)(pTerm + iTerm + dTerm); if (RegulationOutput > 255) RegulationOutput = 255; if (RegulationOutput < 0) RegulationOutput = 0; return RegulationOutput; } // ----------------------------- // CAN-Initialisierung 500 kbit/s // ----------------------------- void can_init_500k() { CANGCON = (1 << SWRES); _delay_ms(5); CANGCON = (1 << ENASTB); _delay_ms(5); // 500 kbit/s @ 16 MHz CANBT1 = 0x02; CANBT2 = 0x0C; CANBT3 = 0x37; for (uint8_t mob = 0; mob < 15; mob++) { CANPAGE = mob << 4; CANCDMOB = 0x00; CANSTMOB = 0x00; } } // ----------------------------- // CAN-Frame senden // ID 0x300 // Byte0-1: UA (ADC) // Byte2-3: UR (ADC) // Byte4: Heater PWM // Byte5: UBatt * 10 (V*10, uint8_t, 0–255) // Byte6-7: Lambda * 1000 (uint16) // ----------------------------- void can_send_lambdaframe(uint16_t ua, uint16_t ur, uint8_t heaterPWM, float UBatt_V, float lambda) { CANPAGE = 0x00; CANSTMOB = 0x00; uint16_t id = 0x300; CANIDT1 = (uint8_t)(id >> 3); CANIDT2 = (uint8_t)(id << 5); CANCDMOB = 8; // DLC setzen, Datenzeiger reset uint16_t lambda_scaled = (uint16_t)(lambda * 1000.0); uint8_t ubatt_scaled = (uint8_t)(constrain(UBatt_V, 0.0, 25.5) * 10.0); CANMSG = (uint8_t)(ua >> 8); CANMSG = (uint8_t)(ua & 0xFF); CANMSG = (uint8_t)(ur >> 8); CANMSG = (uint8_t)(ur & 0xFF); CANMSG = heaterPWM; CANMSG = ubatt_scaled; CANMSG = (uint8_t)(lambda_scaled >> 8); CANMSG = (uint8_t)(lambda_scaled & 0xFF); CANCDMOB = (1 << CONMOB0) | 8; // jetzt erst senden // Mit Timeout warten statt für immer zu blockieren unsigned long t0 = millis(); while (!(CANSTMOB & (1 << TXOK))) { if (millis() - t0 > 20) { // 20ms reichen für 500kbit/s locker CANCDMOB = 0; // MOb abbrechen/freigeben break; } } CANSTMOB &= ~(1 << TXOK); } // ----------------------------- // Start-Sequenz (wie Bylund start()) // ----------------------------- void start_controller() { // Warten bis UBatt ok und CJ125 ok adcValue_UB = 0; CJ125_Status = 0; while (adcValue_UB < UBAT_MIN_ADC || CJ125_Status != CJ125_DIAG_REG_STATUS_OK) { CJ125_Status = COM_SPI(CJ125_DIAG_REG_REQUEST); if (CJ125_Status != CJ125_DIAG_REG_STATUS_OK) { Serial.print("Error, CJ125: 0x"); Serial.println(CJ125_Status, HEX); } adcValue_UB = analogRead(UB_ANALOG_INPUT_PIN); delay(500); } Serial.println("Device ready."); digitalWrite(LED_STATUS_POWER, HIGH); Serial.println("Reading calibration data..."); // CJ125 in Kalibriermodus COM_SPI(CJ125_INIT_REG1_MODE_CALIBRATE); delay(500); adcValue_UA_Optimal = analogRead(UA_ANALOG_INPUT_PIN); adcValue_UR_Optimal = analogRead(UR_ANALOG_INPUT_PIN); // CJ125 in Normalbetrieb V=17 COM_SPI(CJ125_INIT_REG1_MODE_NORMAL_V17); Serial.print("UA_Optimal (lambda ~1.0): "); Serial.print(adcValue_UA_Optimal); Serial.print(" (lambda = "); Serial.print(Lookup_Lambda(adcValue_UA_Optimal), 2); Serial.println(")"); Serial.print("UR_Optimal: "); Serial.println(adcValue_UR_Optimal); // Heiz-Ramp-Up Serial.println("Heating sensor (ramp-up)..."); float UBatt_V = (analogRead(UB_ANALOG_INPUT_PIN) / 1023.0) * ADC_REF_VOLT * UBAT_DIV_FACTOR; // Kondensationsphase: 2V eff für 5s int CondensationPWM = (int)((2.0 / UBatt_V) * 255.0); if (CondensationPWM > 255) CondensationPWM = 255; if (CondensationPWM < 0) CondensationPWM = 0; analogWrite(HEATER_OUTPUT_PIN, CondensationPWM); HeaterOutput = CondensationPWM; int t = 0; while (t < 5 && analogRead(UB_ANALOG_INPUT_PIN) > UBAT_MIN_ADC) { // ADC aktualisieren adcValue_UA = analogRead(UA_ANALOG_INPUT_PIN); adcValue_UR = analogRead(UR_ANALOG_INPUT_PIN); adcValue_UB = analogRead(UB_ANALOG_INPUT_PIN); float UBatt_V = (adcValue_UB / 1023.0) * ADC_REF_VOLT * UBAT_DIV_FACTOR; float lambda = Lookup_Lambda(adcValue_UA); // CAN senden can_send_lambdaframe(adcValue_UA, adcValue_UR, HeaterOutput, UBatt_V, lambda); digitalWrite(LED_STATUS_HEATER, HIGH); delay(250); digitalWrite(LED_STATUS_HEATER, LOW); delay(250); t++; } // Ramp-Up: +0.4V/s von 8.5V bis 13V float UHeater = 8.5; while (UHeater < 13.0 && analogRead(UB_ANALOG_INPUT_PIN) > UBAT_MIN_ADC) { adcValue_UA = analogRead(UA_ANALOG_INPUT_PIN); adcValue_UR = analogRead(UR_ANALOG_INPUT_PIN); adcValue_UB = analogRead(UB_ANALOG_INPUT_PIN); float UBatt_V = (adcValue_UB / 1023.0) * ADC_REF_VOLT * UBAT_DIV_FACTOR; float lambda = Lookup_Lambda(adcValue_UA); can_send_lambdaframe(adcValue_UA, adcValue_UR, HeaterOutput, UBatt_V, lambda); UBatt_V = (analogRead(UB_ANALOG_INPUT_PIN) / 1023.0) * ADC_REF_VOLT * UBAT_DIV_FACTOR; CondensationPWM = (int)((UHeater / UBatt_V) * 255.0); if (CondensationPWM > 255) CondensationPWM = 255; if (CondensationPWM < 0) CondensationPWM = 0; analogWrite(HEATER_OUTPUT_PIN, CondensationPWM); HeaterOutput = CondensationPWM; digitalWrite(LED_STATUS_HEATER, HIGH); delay(500); digitalWrite(LED_STATUS_HEATER, LOW); delay(500); UHeater += 0.4; } // Heizen bis UR <= UR_Optimal (Sensor warm) while (analogRead(UR_ANALOG_INPUT_PIN) > adcValue_UR_Optimal && analogRead(UB_ANALOG_INPUT_PIN) > UBAT_MIN_ADC) { adcValue_UA = analogRead(UA_ANALOG_INPUT_PIN); adcValue_UR = analogRead(UR_ANALOG_INPUT_PIN); adcValue_UB = analogRead(UB_ANALOG_INPUT_PIN); float UBatt_V = (adcValue_UB / 1023.0) * ADC_REF_VOLT * UBAT_DIV_FACTOR; float lambda = Lookup_Lambda(adcValue_UA); can_send_lambdaframe(adcValue_UA, adcValue_UR, HeaterOutput, UBatt_V, lambda); digitalWrite(LED_STATUS_HEATER, HIGH); delay(500); digitalWrite(LED_STATUS_HEATER, LOW); delay(500); } // Übergabe an PID digitalWrite(LED_STATUS_HEATER, HIGH); analogWrite(HEATER_OUTPUT_PIN, 0); HeaterOutput = CondensationPWM; // oder 0, wenn du willst } // ----------------------------- // SETUP // ----------------------------- void setup() { Serial.begin(115200); delay(200); Serial.println("Lambdacontroller (Bylund-Style, AT90CAN64 + MCP2551)"); SPI.begin(); pinMode(CJ125_CS_PIN, OUTPUT); pinMode(LED_ONOFF_PIN, OUTPUT); pinMode(LED_STATUS_POWER, OUTPUT); pinMode(LED_STATUS_HEATER, OUTPUT); pinMode(HEATER_OUTPUT_PIN, OUTPUT); digitalWrite(CJ125_CS_PIN, HIGH); digitalWrite(LED_ONOFF_PIN, HIGH); // LED sofort an bei Strom digitalWrite(LED_STATUS_POWER, LOW); digitalWrite(LED_STATUS_HEATER, LOW); analogWrite(HEATER_OUTPUT_PIN, 0); can_init_500k(); // Erste Diagnose CJ125_Status = COM_SPI(CJ125_DIAG_REG_REQUEST); Serial.print("CJ125 DIAG: 0x"); Serial.println(CJ125_Status, HEX); start_controller(); } // ----------------------------- // LOOP // ----------------------------- void loop() { // CJ125 Status CJ125_Status = COM_SPI(CJ125_DIAG_REG_REQUEST); // ADC einlesen adcValue_UA = analogRead(UA_ANALOG_INPUT_PIN); adcValue_UR = analogRead(UR_ANALOG_INPUT_PIN); adcValue_UB = analogRead(UB_ANALOG_INPUT_PIN); // UBatt in Volt float UBatt_V = (adcValue_UB / 1023.0) * ADC_REF_VOLT * UBAT_DIV_FACTOR; // PID-Heizregelung if (adcValue_UR_Optimal != 0 && adcValue_UB > UBAT_MIN_ADC) { HeaterOutput = Heater_PID_Control(adcValue_UR); analogWrite(HEATER_OUTPUT_PIN, HeaterOutput); } else { HeaterOutput = 0; analogWrite(HEATER_OUTPUT_PIN, 0); } // Bei Unterspannung neu starten if (adcValue_UB < UBAT_MIN_ADC) { Serial.println("Low power, restarting..."); digitalWrite(LED_STATUS_POWER, LOW); digitalWrite(LED_STATUS_HEATER, LOW); start_controller(); } // Lambda & O2 float lambda = Lookup_Lambda(adcValue_UA); float oxygen = Lookup_Oxygen(adcValue_UA); // CAN-Frame senden can_send_lambdaframe((uint16_t)adcValue_UA, (uint16_t)adcValue_UR, (uint8_t)HeaterOutput, UBatt_V, lambda); // Serielle Ausgabe mit SERIAL_RATE_HZ if (serial_counter >= (100 / SERIAL_RATE_HZ)) { serial_counter = 0; Serial.print("CJ125: 0x"); Serial.print(CJ125_Status, HEX); Serial.print(" UA_ADC: "); Serial.print(adcValue_UA); Serial.print(" UR_ADC: "); Serial.print(adcValue_UR); Serial.print(" UB_ADC: "); Serial.print(adcValue_UB); Serial.print(" UBatt: "); Serial.print(UBatt_V, 2); Serial.print(" V"); Serial.print(" HeaterPWM: "); Serial.print(HeaterOutput); Serial.print(" Lambda: "); if (adcValue_UA >= 39 && adcValue_UA <= 791) { Serial.print(lambda, 2); } else { Serial.print("-"); } Serial.print(" O2: "); if (adcValue_UA >= 307) { Serial.print(oxygen, 2); Serial.print(" %"); } else { Serial.print("-"); } Serial.println(); } serial_counter++; delay(10); }
