#include #include "xmc_ccu4.h" #include "xmc_gpio.h" #include "xmc_scu.h" // fCPU=144MHz; Prescaler set to 4096 #define CALCULATE_PERIOD(interval_in_ms) ((35155 * interval_in_ms) / 1000) // Globale Variable für Timer-Interrupt volatile bool timerInterruptOccurred = false; // Globale Variable für die Timer-Periode uint32_t timer_interval = 1000; // Deklaration des Interrupt-Handlers für CCU43-Slice 1 extern "C" void CCU43_1_IRQHandler(void); extern "C" void UserIRQHandler(void); int main(void) { bool button_edge = true; /* // INITIALIZE CCU43 FOR TOGGLING OF LED XMC_CCU4_Init(CCU43, XMC_CCU4_SLICE_MCMS_ACTION_TRANSFER_PR_CR); */ // Enable the clock for selected timer XMC_CCU4_EnableClock(CCU43, 3); /* // Prepare configuration XMC_CCU4_SLICE_COMPARE_CONFIG_t slice_config = { // .tc = 0, // set pre-scaler to 4096 // .prescaler_initval = 12, // .float_limit = 0, // .dither_limit = 0, //.passive_level = 0, // .timer_concatenation = 0 }; // Configure the timer XMC_CCU4_SLICE_CompareInit(CCU43_CC43, &slice_config); // programs the timer period register according to time interval value XMC_CCU4_SLICE_SetTimerPeriodMatch(CCU43_CC43, CALCULATE_PERIOD(timer_interval)); // Transfers value from shadow timer registers to actual timer registers XMC_CCU4_EnableShadowTransfer(CCU43, XMC_CCU4_SHADOW_TRANSFER_SLICE_3 | XMC_CCU4_SHADOW_TRANSFER_PRESCALER_SLICE_3); // Bind period match event to an NVIC node CCU43_1_IRQn XMC_CCU4_SLICE_SetInterruptNode(CCU43_CC43, XMC_CCU4_SLICE_IRQ_ID_PERIOD_MATCH, XMC_CCU4_SLICE_SR_ID_1); // Enables timer(period match) event */ XMC_CCU4_SLICE_EnableEvent(CCU43_CC43, XMC_CCU4_SLICE_IRQ_ID_PERIOD_MATCH); XMC_CCU4_SLICE_ClearTimer(CCU43_CC43); XMC_CCU4_SLICE_StartTimer(CCU43_CC43); // NVIC-Konfiguration: Priorität setzen und Interrupt aktivieren NVIC_SetPriority(CCU43_1_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(), 63, 0)); NVIC_EnableIRQ(CCU43_1_IRQn); // INITIALIZE LED1 ON PORT 5.9 FOR OUTPUT (PUSH-PULL) XMC_GPIO_SetMode(P5_9, XMC_GPIO_MODE_OUTPUT_PUSH_PULL); // INITIALIZE BUTTON1 ON PORT 15.13 FOR INPUT XMC_GPIO_SetMode(P15_13, XMC_GPIO_MODE_INPUT_TRISTATE); XMC_GPIO_EnableDigitalInput(P15_13); // INITIALIZE BUTTON2 ON PORT 15.12 FOR INPUT XMC_GPIO_SetMode(P15_12, XMC_GPIO_MODE_INPUT_TRISTATE); XMC_GPIO_EnableDigitalInput(P15_12); while(1U) { // any button pushed? if (!XMC_GPIO_GetInput(P15_13) || !XMC_GPIO_GetInput(P15_12)) { // new edge on any button? if (button_edge == true) { // which button ? if (!XMC_GPIO_GetInput(P15_13)) { // Button1 pushed. Decrease cycle time of flashing LED. timer_interval = (timer_interval > 100) ? (timer_interval - 100) : timer_interval; } else { // Button2 pushed. Increase cycle time of flashing LED. timer_interval = (timer_interval < 1500) ? (timer_interval + 100) : timer_interval; } XMC_CCU4_SLICE_StopTimer(CCU43_CC43); XMC_CCU4_SLICE_SetTimerPeriodMatch(CCU43_CC43, CALCULATE_PERIOD(timer_interval)); XMC_CCU4_EnableShadowTransfer(CCU43, XMC_CCU4_SHADOW_TRANSFER_SLICE_3 | XMC_CCU4_SHADOW_TRANSFER_PRESCALER_SLICE_3); XMC_CCU4_SLICE_StartTimer(CCU43_CC43); } button_edge = false; } else { // currently no button pushed // next trigger on button is new edge button_edge = true; } } // Interrupt-Service-Routine für CCU43-Slice 1 void CCU43_1_IRQHandler(void) { // Prüfen, ob der Perioden-Match-Interrupt ausgelöst wurde if (XMC_CCU4_SLICE_GetEvent(CCU43_CC43, XMC_CCU4_SLICE_IRQ_ID_PERIOD_MATCH)) { // Interrupt-Flag löschen XMC_CCU4_SLICE_ClearEvent(CCU43_CC43, XMC_CCU4_SLICE_IRQ_ID_PERIOD_MATCH); // LED-Zustand umschalten XMC_GPIO_ToggleOutput(P5_9); } } void UserIRQHandler(void) { XMC_GPIO_ToggleOutput(P5_9); }
