Option Explicit
' SCHNELLER PCM AUDIO PLAYER
' 96.000 Hz
' 24 Bit
' Mono
' Excel:
'   Blatt "Audio"
'   A2:A48001 = 48.000 Samples
' 48.000 Samples / 96.000 Hz = 0,5 Sekunden
' 12 Wiederholungen = 6 Sekunden
' Letzte Wiederholung:
'   100 % -> 0 % Fade-Out
' Device 0
#If VBA7 Then
    Private Declare PtrSafe Function waveOutOpen Lib "winmm.dll" ( _
        lphwo As LongPtr, _
        ByVal uDeviceID As Long, _
        lpFormat As WAVEFORMATEX, _
        ByVal dwCallback As LongPtr, _
        ByVal dwInstance As LongPtr, _
        ByVal dwFlags As Long) As Long
    Private Declare PtrSafe Function waveOutPrepareHeader Lib "winmm.dll" ( _
        ByVal hwo As LongPtr, _
        lpWaveHdr As WAVEHDR, _
        ByVal uSize As Long) As Long
    Private Declare PtrSafe Function waveOutWrite Lib "winmm.dll" ( _
    Private Declare PtrSafe Function waveOutReset Lib "winmm.dll" ( _
        ByVal hwo As LongPtr) As Long
    Private Declare PtrSafe Function waveOutUnprepareHeader Lib "winmm.dll" ( _
    Private Declare PtrSafe Function waveOutClose Lib "winmm.dll" ( _
    Private Declare PtrSafe Function GlobalAlloc Lib "kernel32" ( _
        ByVal uFlags As Long, _
        ByVal dwBytes As LongPtr) As LongPtr
    Private Declare PtrSafe Function GlobalFree Lib "kernel32" ( _
        ByVal hMem As LongPtr) As LongPtr
    Private Declare PtrSafe Function GlobalLock Lib "kernel32" ( _
    Private Declare PtrSafe Function GlobalUnlock Lib "kernel32" ( _
    Private Declare PtrSafe Sub CopyMemory Lib "kernel32" Alias "RtlMoveMemory" ( _
        ByVal Destination As LongPtr, _
        ByRef Source As Any, _
        ByVal Length As LongPtr)
#End If
' EINSTELLUNGEN
Private Const DEVICE_ID As Long = 0
Private Const SAMPLE_RATE As Long = 96000
Private Const BITS_PER_SAMPLE As Long = 24
Private Const CHANNELS As Long = 1
Private Const BYTES_PER_SAMPLE As Long = 3
Private Const SAMPLE_COUNT As Long = 48000
Private Const LOOP_COUNT As Long = 12
Private Const PLAY_TIME As Double = 6#
' WINDOWS-KONSTANTEN
Private Const WAVE_FORMAT_PCM As Integer = 1
Private Const GMEM_MOVEABLE As Long = &H2
Private Const GMEM_ZEROINIT As Long = &H40
' WAVEFORMATEX
Private Type WAVEFORMATEX
    wFormatTag As Integer
    nChannels As Integer
    nSamplesPerSec As Long
    nAvgBytesPerSec As Long
    nBlockAlign As Integer
    wBitsPerSample As Integer
    cbSize As Integer
End Type
' WAVEHDR
Private Type WAVEHDR
    lpData As LongPtr
    dwBufferLength As Long
    dwBytesRecorded As Long
    dwUser As LongPtr
    dwFlags As Long
    dwLoops As Long
    lpNext As LongPtr
    Reserved As LongPtr
End Type
' GLOBALE VARIABLEN
Private g_hWave As LongPtr
Private g_hMem As LongPtr
Private g_pMem As LongPtr
Private g_Header As WAVEHDR
Private g_Playing As Boolean
Private g_HeaderPrepared As Boolean
' START
Public Sub PCM_Start_4Sekunden()
    Dim ws As Worksheet
    Dim i As Long
    Dim rep As Long
    Dim value As Double
    Dim sample As Long
    Dim sampleValues() As Long
    Dim oneWave() As Byte
    Dim fullBuffer() As Byte
    Dim oneWaveBytes As Long
    Dim totalBytes As Long
    Dim sourcePos As Long
    Dim destPos As Long
    Dim fadeFactor As Double
    Dim fadedSample As Double
    Dim fmt As WAVEFORMATEX
    Dim result As Long
    Dim startTime As Double
    Dim elapsed As Double
    On Error GoTo Fehler
    ' EVENTUELLE WIEDERGABE STOPPEN
    If g_Playing Then
        PCM_Stop
    End If
    ' EXCEL-BLATT
    Set ws = ThisWorkbook.Worksheets("Audio")
    If ws.Cells(ws.Rows.count, 1).End(xlUp).Row < 48001 Then
        MsgBox _
            "Es werden 48.000 Samples benötigt." & vbCrLf & _
            "Erwarteter Bereich: A2:A48001", _
            vbExclamation
        Exit Sub
    End If
    ' GRÖSSEN
    oneWaveBytes = _
        SAMPLE_COUNT * BYTES_PER_SAMPLE
    totalBytes = _
        oneWaveBytes * LOOP_COUNT
    ' SAMPLE-ARRAY
    ' Excel wird nur EINMAL gelesen.
    ReDim sampleValues(0 To SAMPLE_COUNT - 1)
    For i = 0 To SAMPLE_COUNT - 1
        If Not IsNumeric(ws.Cells(i + 2, 1).value) Then
            MsgBox _
                "Ungültiger Wert in A" & _
                (i + 2), _
                vbCritical
            Exit Sub
        End If
        value = _
            CDbl(ws.Cells(i + 2, 1).value)
        If value < -8388608# Or _
           value > 8388607# Then
            MsgBox _
                "Wert außerhalb des 24-Bit-Bereichs:" & _
                vbCrLf & _
                "A" & (i + 2) & _
                " = " & CStr(value), _
                vbCritical
            Exit Sub
        End If
        sampleValues(i) = CLng(value)
    Next i
    ' EINE NORMALE 0,5-SEKUNDEN-WELLE ERZEUGEN
    ReDim oneWave(0 To oneWaveBytes - 1)
        sample = sampleValues(i)
        If sample < 0 Then
            sample = sample + 16777216
        End If
        sourcePos = i * 3
        oneWave(sourcePos) = _
            sample And &HFF
        oneWave(sourcePos + 1) = _
            (sample \ 256) And &HFF
        oneWave(sourcePos + 2) = _
            (sample \ 65536) And &HFF
    Next i
    ' GESAMTEN 6-SEKUNDEN-PUFFER ERZEUGEN
    ' Wiederholungen 1-11:
    '       unverändert
    ' Wiederholung 12:
    '       100 % -> 0 %
    ReDim fullBuffer(0 To totalBytes - 1)
    destPos = 0
    ' WIEDERHOLUNGEN 1-11
    For rep = 1 To LOOP_COUNT - 1
        CopyMemory _
            VarPtr(fullBuffer(destPos)), _
            oneWave(0), _
            oneWaveBytes
        destPos = _
            destPos + oneWaveBytes
    Next rep
    ' LETZTE WIEDERHOLUNG MIT FADE-OUT
        ' Fade-Faktor:
        ' Anfang = 1,0
        ' Ende   = 0,0
        fadeFactor = _
            1# - _
            (CDbl(i) / _
             CDbl(SAMPLE_COUNT - 1))
        fadedSample = _
            CDbl(sampleValues(i)) * _
            fadeFactor
        ' RUNDEN
        If fadedSample >= 0 Then
            sample = _
                CLng(fadedSample + 0.5)
        Else
            sample = _
                CLng(fadedSample - 0.5)
        End If
        ' SICHERHEIT
        If sample > 8388607 Then
            sample = 8388607
        ElseIf sample < -8388608 Then
            sample = -8388608
        End If
        ' 24-BIT-ZWEIERKOMPLEMENT
        If sample < 0 Then
        End If
        sourcePos = i * 3
        ' LITTLE ENDIAN
        fullBuffer(destPos + sourcePos) = _
            sample And &HFF
        fullBuffer(destPos + sourcePos + 1) = _
        fullBuffer(destPos + sourcePos + 2) = _
    Next i
    ' NICHT MEHR BENÖTIGT
    Erase oneWave
    Erase sampleValues
    ' AUDIOFORMAT
    With fmt
        .wFormatTag = WAVE_FORMAT_PCM
        .nChannels = CHANNELS
        .nSamplesPerSec = SAMPLE_RATE
        .nBlockAlign = _
            BYTES_PER_SAMPLE
        .nAvgBytesPerSec = _
            SAMPLE_RATE * BYTES_PER_SAMPLE
        .wBitsPerSample = _
            BITS_PER_SAMPLE
        .cbSize = 0
    End With
    ' WINDOWS-SPEICHER
    g_hMem = GlobalAlloc( _
                GMEM_MOVEABLE Or GMEM_ZEROINIT, _
                totalBytes)
    If g_hMem = 0 Then
        MsgBox _
            "Speicher konnte nicht reserviert werden.", _
            vbCritical
        Exit Sub
    End If
    ' SPEICHER SPERREN
    g_pMem = GlobalLock(g_hMem)
    If g_pMem = 0 Then
        GlobalFree g_hMem
        g_hMem = 0
        MsgBox _
            "Speicher konnte nicht gesperrt werden.", _
            vbCritical
        Exit Sub
    End If
    ' EIN EINZIGER GROSSER COPY
    CopyMemory _
        g_pMem, _
        fullBuffer(0), _
        totalBytes
    Erase fullBuffer
    ' DEVICE 0 ÖFFNEN
    result = waveOutOpen( _
                g_hWave, _
                DEVICE_ID, _
                fmt, _
                0, _
                0, _
                0)
    If result <> 0 Then
        PCM_Cleanup
        MsgBox _
            "Device 0 konnte nicht geöffnet werden." & _
            vbCrLf & _
            "Fehlercode: " & result, _
            vbCritical
        Exit Sub
    End If
    ' WAVE HEADER
    g_Header.lpData = g_pMem
    g_Header.dwBufferLength = _
        totalBytes
    g_Header.dwBytesRecorded = _
        totalBytes
    g_Header.dwUser = 0
    g_Header.dwFlags = 0
    g_Header.dwLoops = 0
    g_Header.lpNext = 0
    g_Header.Reserved = 0
    ' HEADER VORBEREITEN
    result = waveOutPrepareHeader( _
                g_hWave, _
                g_Header, _
                LenB(g_Header))
    If result <> 0 Then
        PCM_Cleanup
        MsgBox _
            "waveOutPrepareHeader Fehler: " & _
            result, _
            vbCritical
        Exit Sub
    End If
    g_HeaderPrepared = True
    ' AUDIO STARTEN
    result = waveOutWrite( _
                g_hWave, _
                g_Header, _
                LenB(g_Header))
    If result <> 0 Then
        PCM_Cleanup
        MsgBox _
            "waveOutWrite Fehler: " & _
            result, _
            vbCritical
        Exit Sub
    End If
    g_Playing = True
    Application.StatusBar = _
        "PCM läuft | 96 kHz / 24 Bit | " & _
        "48.000 Samples × 12 | " & _
        "6 Sekunden | Fade-Out"
    ' WARTEN
    ' DoEvents hält Excel bedienbar.
    startTime = Timer
    Do While g_Playing
        DoEvents
        elapsed = _
            Timer - startTime
        If elapsed < 0 Then
            elapsed = _
                elapsed + 86400#
        End If
        If elapsed >= PLAY_TIME Then
            Exit Do
        End If
    Loop
    ' NORMALER STOP
    PCM_Stop
    Exit Sub
' FEHLER
Fehler:
    PCM_Stop
    MsgBox _
        "Fehler:" & _
        vbCrLf & vbCrLf & _
        Err.Number & " - " & _
        Err.Description, _
        vbCritical
End Sub
' STOP
Public Sub PCM_Stop()
    On Error Resume Next
    g_Playing = False
    If g_hWave <> 0 Then
        waveOutReset _
            g_hWave
        If g_HeaderPrepared Then
            waveOutUnprepareHeader _
                g_hWave, _
                g_Header, _
                LenB(g_Header)
        End If
        waveOutClose _
            g_hWave
        g_hWave = 0
        g_HeaderPrepared = False
    End If
    If g_hMem <> 0 Then
        If g_pMem <> 0 Then
            GlobalUnlock _
                g_hMem
        End If
        GlobalFree _
            g_hMem
        g_hMem = 0
        g_pMem = 0
    End If
    Application.StatusBar = False
End Sub
' CLEANUP
Private Sub PCM_Cleanup()
    g_Playing = False
        waveOutReset _
            g_hWave
                g_hWave, _
                g_Header, _
                LenB(g_Header)
        End If
        waveOutClose _
            g_hWave
        g_hWave = 0
    End If
    If g_hMem <> 0 Then
        If g_pMem <> 0 Then
            GlobalUnlock _
                g_hMem
        End If
        GlobalFree _
            g_hMem
        g_hMem = 0
        g_pMem = 0
    End If
End Sub
