avrdude -p atxmega128a1 -P usb -c dragon_jtag -vvvv -U flash:w:test5.hex avrdude: Version 5.10, compiled on Jan 19 2010 at 15:10:54 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch System wide configuration file is "C:\Program Files\WinAVR-20100110\bin\avrdude.conf" Using Port : usb Using Programmer : dragon_jtag avrdude: jtagmkII_dragon_open() avrdude: usbdev_open(): Found AVRDRAGON, serno: 00A200004001 avrdude: usbdev_open(): using read endpoint 0x82 avrdude: jtagmkII_getsync() avrdude: jtagmkII_getsync(): Sending sign-on command: avrdude: jtagmkII_send(): sending 1 bytes avrdude: Sent: . [1b] . [00] . [00] . [01] . [00] . [00] . [00] . [0e] . [01] . [f3] . [97] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 0 (command_sequence == 0) avrdude: Recv: . [86] . [01] . [ff] . [0b] . [06] . [01] . [ff] . [0b] . [06] . [06] . [00] . [a2] . [00] . [00] @ [40] . [01] A [41] V [56] R [52] D [44] R [52] A [41] G [47] O [4f] N [4e] . [00] Raw message: 0x86 0x01 0xff 0x0b 0x06 0x01 0xff 0x0b 0x06 0x06 0x00 0xa2 0x00 0x00 0x40 0x01 0x41 0x56 0x52 0x44 0x52 0x41 0x47 0x4f 0x4e 0x00 Sign-on succeeded JTAG ICE mkII sign-on message: Communications protocol version: 1 M_MCU: boot-loader FW version: 255 firmware version: 6.11 hardware version: 1 S_MCU: boot-loader FW version: 255 firmware version: 6.11 hardware version: 6 Serial number: 00:a2:00:00:40:01 Device ID: AVRDRAGON avrdude: jtagmkII_getsync(): Using a 298-byte device descriptor avrdude: jtagmkII_setparm() avrdude: jtagmkII_setparm(): Sending set parameter command (parm 0x03, 1 bytes): avrdude: jtagmkII_send(): sending 3 bytes avrdude: Sent: . [1b] . [01] . [00] . [03] . [00] . [00] . [00] . [0e] . [02] . [03] . [01] . [9b] E [45] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 1 (command_sequence == 1) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude: jtagmkII_getsync(): Sending get sync command: avrdude: jtagmkII_send(): sending 1 bytes avrdude: Sent: . [1b] . [02] . [00] . [01] . [00] . [00] . [00] . [0e] . [0f] . [e2] u [75] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 2 (command_sequence == 2) avrdude: Recv: . [80] Raw message: 0x80 OK AVR Part : ATXMEGA128A1 Chip Erase delay : 0 us PAGEL : P00 BS2 : P00 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 0 StabDelay : 0 CmdexeDelay : 0 SyncLoops : 0 ByteDelay : 0 PollIndex : 0 PollValue : 0x00 Memory Detail : Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 0 0 0 0 no 2048 32 0 0 0 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- application 0 0 0 0 no 131072 256 0 0 0 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- apptable 0 0 0 0 no 8192 256 0 0 0 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- boot 0 0 0 0 no 8192 256 0 0 0 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- flash 0 0 0 0 no 139264 256 0 0 0 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- prodsig 0 0 0 0 no 512 256 0 0 0 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- usersig 0 0 0 0 no 512 256 0 0 0 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- fuse0 0 0 0 0 no 1 0 0 0 0 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- fuse1 0 0 0 0 no 1 0 0 0 0 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- fuse2 0 0 0 0 no 1 0 0 0 0 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- fuse4 0 0 0 0 no 1 0 0 0 0 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- fuse5 0 0 0 0 no 1 0 0 0 0 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- lock 0 0 0 0 no 1 0 0 0 0 0x00 0x00 Programmer Type : DRAGON_JTAG Description : Atmel AVR Dragon in JTAG mode avrdude: jtagmkII_getparm() avrdude: jtagmkII_getparm(): Sending get parameter command (parm 0x01): avrdude: jtagmkII_send(): sending 2 bytes avrdude: Sent: . [1b] . [03] . [00] . [02] . [00] . [00] . [00] . [0e] . [03] . [01] . [d3] . [99] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 3 (command_sequence == 3) avrdude: Recv: . [81] . [01] . [06] Raw message: 0x81 0x01 0x06 parameter values: 0x01 0x06 avrdude: jtagmkII_getparm() avrdude: jtagmkII_getparm(): Sending get parameter command (parm 0x02): avrdude: jtagmkII_send(): sending 2 bytes avrdude: Sent: . [1b] . [04] . [00] . [02] . [00] . [00] . [00] . [0e] . [03] . [02] . [aa] B [42] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 4 (command_sequence == 4) avrdude: Recv: . [81] . [0b] . [06] . [0b] . [06] Raw message: 0x81 0x0b 0x06 0x0b 0x06 parameter values: 0x0b 0x06 0x0b 0x06 M_MCU hardware version: 1 M_MCU firmware version: 6.11 S_MCU hardware version: 6 S_MCU firmware version: 6.11 Serial number: 00:a2:00:00:40:01 avrdude: jtagmkII_getparm() avrdude: jtagmkII_getparm(): Sending get parameter command (parm 0x06): avrdude: jtagmkII_send(): sending 2 bytes avrdude: Sent: . [1b] . [05] . [00] . [02] . [00] . [00] . [00] . [0e] . [03] . [06] s [73] I [49] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 5 (command_sequence == 5) avrdude: Recv: . [81] . [a2] . [0c] Raw message: 0x81 0xa2 0x0c parameter values: 0xa2 0x0c Vtarget : 3.2 V avrdude: jtagmkII_getparm() avrdude: jtagmkII_getparm(): Sending get parameter command (parm 0x07): avrdude: jtagmkII_send(): sending 2 bytes avrdude: Sent: . [1b] . [06] . [00] . [02] . [00] . [00] . [00] . [0e] . [03] . [07] . [fd] . [8e] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 6 (command_sequence == 6) avrdude: Recv: . [81] . [06] Raw message: 0x81 0x06 parameter values: 0x06 JTAG clock : 891.7 kHz (1.1 us) avrdude: jtagmkII_setparm() avrdude: jtagmkII_setparm(): Sending set parameter command (parm 0x1b, 4 bytes): avrdude: jtagmkII_send(): sending 6 bytes avrdude: Sent: . [1b] . [07] . [00] . [06] . [00] . [00] . [00] . [0e] . [02] . [1b] . [00] . [00] . [00] . [00] . [f0] | [7c] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 7 (command_sequence == 7) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude: jtagmkII_set_devdescr(): Sending set device descriptor command: avrdude: jtagmkII_send(): sending 299 bytes avrdude: Sent: . [1b] . [08] . [00] + [2b] . [01] . [00] . [00] . [0e] . [0c] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [01] [20] . [00] . [00] . [00] . [00] . [00] . [00] . [00] [20] . [02] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] [20] . [02] . [00] . [00] . [00] . [00] . [00] . [01] . [02] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [ef] D [44] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 8 (command_sequence == 8) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude: jtagmkII_getsync() avrdude: jtagmkII_getsync(): Sending sign-on command: avrdude: jtagmkII_send(): sending 1 bytes avrdude: Sent: . [1b] . [09] . [00] . [01] . [00] . [00] . [00] . [0e] . [01] . [f0] ; [3b] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 9 (command_sequence == 9) avrdude: Recv: . [86] . [01] . [ff] . [0b] . [06] . [01] . [ff] . [0b] . [06] . [06] . [00] . [a2] . [00] . [00] @ [40] . [01] A [41] V [56] R [52] D [44] R [52] A [41] G [47] O [4f] N [4e] . [00] Raw message: 0x86 0x01 0xff 0x0b 0x06 0x01 0xff 0x0b 0x06 0x06 0x00 0xa2 0x00 0x00 0x40 0x01 0x41 0x56 0x52 0x44 0x52 0x41 0x47 0x4f 0x4e 0x00 Sign-on succeeded JTAG ICE mkII sign-on message: Communications protocol version: 1 M_MCU: boot-loader FW version: 255 firmware version: 6.11 hardware version: 1 S_MCU: boot-loader FW version: 255 firmware version: 6.11 hardware version: 6 Serial number: 00:a2:00:00:40:01 Device ID: AVRDRAGON avrdude: jtagmkII_getsync(): Using a 298-byte device descriptor avrdude: jtagmkII_setparm() avrdude: jtagmkII_setparm(): Sending set parameter command (parm 0x03, 1 bytes): avrdude: jtagmkII_send(): sending 3 bytes avrdude: Sent: . [1b] . [0a] . [00] . [03] . [00] . [00] . [00] . [0e] . [02] . [03] . [05] . [ff] . [1e] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 10 (command_sequence == 10) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude: jtagmkII_getsync(): Sending get sync command: avrdude: jtagmkII_send(): sending 1 bytes avrdude: Sent: . [1b] . [0b] . [00] . [01] . [00] . [00] . [00] . [0e] . [0f] . [e1] . [d9] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 11 (command_sequence == 11) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude: jtagmkII_reset(): Sending reset command: avrdude: jtagmkII_send(): sending 2 bytes avrdude: Sent: . [1b] . [0c] . [00] . [02] . [00] . [00] . [00] . [0e] . [0b] . [01] ; [3b] . [c1] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 12 (command_sequence == 12) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude: AVR device initialized and ready to accept instructions Reading | avrdude: jtagmkII_read_byte(.., signature, 0x0, ...) avrdude: jtagmkII_program_enable(): Sending enter progmode command: avrdude: jtagmkII_send(): sending 1 bytes avrdude: Sent: . [1b] . [0d] . [00] . [01] . [00] . [00] . [00] . [0e] . [14] . [02] j [6a] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 65535 (command_sequence == 13) avrdude: jtagmkII_recv(): got asynchronous event avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 13 (command_sequence == 13) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude: jtagmkII_program_enable(): Sending enter progmode command: avrdude: jtagmkII_send(): sending 1 bytes avrdude: Sent: . [1b] . [0e] . [00] . [01] . [00] . [00] . [00] . [0e] . [14] . [d2] . [e0] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 14 (command_sequence == 14) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude: jtagmkII_read_byte(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] . [0f] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b4] . [01] . [00] . [00] . [00] . [90] . [00] . [00] . [01] ) [29] . [b4] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 15 (command_sequence == 15) avrdude: Recv: . [82] . [1e] Raw message: 0x82 0x1e memory contents: 0x1e avrdude: jtagmkII_read_byte(.., signature, 0x1, ...) avrdude: jtagmkII_read_byte(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] . [10] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b4] . [01] . [00] . [00] . [00] . [91] . [00] . [00] . [01] & [26] P [50] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 16 (command_sequence == 16) avrdude: Recv: . [82] . [97] Raw message: 0x82 0x97 memory contents: 0x97 ################avrdude: jtagmkII_read_byte(.., signature, 0x2, ...) avrdude: jtagmkII_read_byte(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] . [11] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b4] . [01] . [00] . [00] . [00] . [92] . [00] . [00] . [01] . [e4] e [65] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 17 (command_sequence == 17) avrdude: Recv: . [82] L [4c] Raw message: 0x82 0x4c memory contents: 0x4c ################################## | 100% 0.02s avrdude: Device signature = 0x1e974c avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option. avrdude: jtagmkII_read_byte(.., eeprom, 0x7fc, ...) avrdude: jtagmkII_read_byte(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] . [12] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] " [22] . [01] . [00] . [00] . [00] . [fc] . [07] . [8c] . [00] . [ef] E [45] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 18 (command_sequence == 18) avrdude: Recv: . [82] . [ff] Raw message: 0x82 0xff memory contents: 0xff avrdude: jtagmkII_read_byte(.., eeprom, 0x7fd, ...) avrdude: jtagmkII_read_byte(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] . [13] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] " [22] . [01] . [00] . [00] . [00] . [fd] . [07] . [8c] . [00] [ [5b] I [49] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 19 (command_sequence == 19) avrdude: Recv: . [82] . [ff] Raw message: 0x82 0xff memory contents: 0xff avrdude: jtagmkII_read_byte(.., eeprom, 0x7fe, ...) avrdude: jtagmkII_read_byte(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] . [14] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] " [22] . [01] . [00] . [00] . [00] . [fe] . [07] . [8c] . [00] . [bb] . [1c] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 20 (command_sequence == 20) avrdude: Recv: . [82] . [ff] Raw message: 0x82 0xff memory contents: 0xff avrdude: jtagmkII_read_byte(.., eeprom, 0x7ff, ...) avrdude: jtagmkII_read_byte(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] . [15] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] " [22] . [01] . [00] . [00] . [00] . [ff] . [07] . [8c] . [00] . [0f] . [10] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 21 (command_sequence == 21) avrdude: Recv: . [82] . [ff] Raw message: 0x82 0xff memory contents: 0xff avrdude: erasing chip avrdude: jtagmkII_chip_erase(): Sending Xmega chip erase command: avrdude: jtagmkII_send(): sending 6 bytes avrdude: Sent: . [1b] . [16] . [00] . [06] . [00] . [00] . [00] . [0e] 4 [34] . [00] . [00] . [00] . [00] . [00] . [0b] . [0f] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 22 (command_sequence == 22) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude: reading input file "test5.hex" avrdude: input file test5.hex auto detected as Intel Hex avrdude: writing flash (1860 bytes): Writing | avrdude: jtagmkII_paged_write(.., flash, 256, 1860) avrdude: jtagmkII_setparm() avrdude: jtagmkII_setparm(): Sending set parameter command (parm 0x32, 4 bytes): avrdude: jtagmkII_send(): sending 6 bytes avrdude: Sent: . [1b] . [17] . [00] . [06] . [00] . [00] . [00] . [0e] . [02] 2 [32] . [00] . [00] . [80] . [00] . [19] . [9b] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 23 (command_sequence == 23) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude: jtagmkII_setparm() avrdude: jtagmkII_setparm(): Sending set parameter command (parm 0x33, 4 bytes): avrdude: jtagmkII_send(): sending 6 bytes avrdude: Sent: . [1b] . [18] . [00] . [06] . [00] . [00] . [00] . [0e] . [02] 3 [33] . [00] [20] . [82] . [00] . [fd] . [95] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 24 (command_sequence == 24) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude: jtagmkII_paged_write(): block_size at addr 0 is 256 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 266 bytes avrdude: Sent: . [1b] . [19] . [00] . [0a] . [01] . [00] . [00] . [0e] . [04] . [c0] . [00] . [01] . [00] . [00] . [00] . [00] . [80] . [00] . [0c] . [94] . [fa] . [00] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [b7] . [a4] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 25 (command_sequence == 25) avrdude: Recv: . [80] Raw message: 0x80 OK ######avrdude: jtagmkII_paged_write(): block_size at addr 256 is 256 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 266 bytes avrdude: Sent: . [1b] . [1a] . [00] . [0a] . [01] . [00] . [00] . [0e] . [04] . [c0] . [00] . [01] . [00] . [00] . [00] . [01] . [80] . [00] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [11] $ [24] . [1f] . [be] . [cf] . [ef] . [df] . [e3] . [de] . [bf] . [cd] . [bf] . [ce] . [94] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 26 (command_sequence == 26) avrdude: Recv: . [80] Raw message: 0x80 OK #######avrdude: jtagmkII_paged_write(): block_size at addr 512 is 256 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 266 bytes avrdude: Sent: . [1b] . [1b] . [00] . [0a] . [01] . [00] . [00] . [0e] . [04] . [c0] . [00] . [01] . [00] . [00] . [00] . [02] . [80] . [00] . [00] . [e0] . [0c] . [bf] . [18] . [be] . [19] . [be] . [1a] . [be] . [1b] . [be] . [10] . [e2] . [a0] . [e0] . [b0] . [e2] . [e4] . [e4] . [f7] . [e0] . [00] . [e0] . [0b] . [bf] . [02] . [c0] . [07] . [90] . [0d] . [92] . [a0] 0 [30] . [b1] . [07] . [d9] . [f7] . [1b] . [be] . [0e] . [94] $ [24] . [01] . [0c] . [94] . [a0] . [03] . [0c] . [94] . [00] . [00] [20] . [ed] 7 [37] . [e0] . [04] . [c0] . [f9] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [00] . [97] . [d1] . [f7] . [08] . [95] . [7f] . [92] . [8f] . [92] . [9f] . [92] . [af] . [92] . [bf] . [92] . [cf] . [92] . [df] . [92] . [ef] . [92] . [ff] . [92] . [0f] . [93] . [1f] . [93] . [8f] . [ef] . [80] . [93] . [84] . [06] . [80] . [93] . [80] . [06] ` [60] . [ed] w [77] . [e0] w [77] $ [24] s [73] . [94] H [48] . [ec] P [50] . [e0] . [a2] . [e0] . [da] . [2e] . [f4] . [e0] . [cf] . [2e] . [e8] . [e0] . [be] . [2e] 0 [30] . [e1] . [a3] . [2e] . [00] . [e2] [20] . [e4] . [f2] . [2e] . [90] . [e8] . [99] . [2e] . [88] $ [24] . [83] . [94] . [88] . [e1] . [e8] . [2e] . [80] . [91] . [84] . [06] . [8f] . [ef] . [80] . [93] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8e] . [7f] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8d] . [7f] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8b] . [7f] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [87] . [7f] . [80] . [93] . [84] . [06] . [f6] . [b8] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 27 (command_sequence == 27) avrdude: Recv: . [80] Raw message: 0x80 OK #######avrdude: jtagmkII_paged_write(): block_size at addr 768 is 256 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 266 bytes avrdude: Sent: . [1b] . [1c] . [00] . [0a] . [01] . [00] . [00] . [0e] . [04] . [c0] . [00] . [01] . [00] . [00] . [00] . [03] . [80] . [00] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8f] ~ [7e] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8f] } [7d] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8f] { [7b] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8f] w [77] . [80] . [93] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8f] . [ef] . [80] . [93] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [10] . [92] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [80] h [68] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [80] d [64] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [80] b [62] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [80] a [61] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [91] 4 [34] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 28 (command_sequence == 28) avrdude: Recv: . [80] Raw message: 0x80 OK #######avrdude: jtagmkII_paged_write(): block_size at addr 1024 is 256 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 266 bytes avrdude: Sent: . [1b] . [1d] . [00] . [0a] . [01] . [00] . [00] . [0e] . [04] . [c0] . [00] . [01] . [00] . [00] . [00] . [04] . [80] . [00] . [88] ` [60] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [84] ` [60] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [82] ` [60] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [81] ` [60] . [80] . [93] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [10] . [92] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] [20] . [e0] 0 [30] . [e0] . [80] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [d0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [c0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [b0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [a0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [00] . [93] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [f0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [90] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] & [26] [20] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 29 (command_sequence == 29) avrdude: Recv: . [80] Raw message: 0x80 OK #######avrdude: jtagmkII_paged_write(): block_size at addr 1280 is 256 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 266 bytes avrdude: Sent: . [1b] . [1e] . [00] . [0a] . [01] . [00] . [00] . [0e] . [04] . [c0] . [00] . [01] . [00] . [00] . [00] . [05] . [80] . [00] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [f0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [00] . [93] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [a0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [b0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [c0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [d0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] p [70] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] / [2f] _ [5f] ? [3f] O [4f] * [2a] 0 [30] 1 [31] . [05] . [09] . [f0] s [73] . [cf] . [80] . [91] . [84] . [06] . [10] . [92] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] [20] . [e0] 0 [30] . [e0] . [b4] . [e2] . [a2] . [e4] . [11] . [e8] . [e0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [b0] . [93] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [a0] . [93] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [10] . [93] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [a0] . [93] . [84] . [06] . [88] . [e5] . [92] . [e0] O [4f] . [ee] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 30 (command_sequence == 30) avrdude: Recv: . [80] Raw message: 0x80 OK #######avrdude: jtagmkII_paged_write(): block_size at addr 1536 is 256 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 266 bytes avrdude: Sent: . [1b] . [1f] . [00] . [0a] . [01] . [00] . [00] . [0e] . [04] . [c0] . [00] . [01] . [00] . [00] . [00] . [06] . [80] . [00] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [b0] . [93] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [e0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] / [2f] _ [5f] ? [3f] O [4f] * [2a] 0 [30] 1 [31] . [05] . [09] . [f0] . [bb] . [cf] . [80] . [91] . [84] . [06] . [10] . [92] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8f] . [ef] . [80] . [93] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [87] ~ [7e] . [80] . [93] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8b] } [7d] . [80] . [93] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8d] { [7b] . [80] . [93] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8e] w [77] . [80] . [93] . [84] . [06] . [80] . [e1] . [97] . [e2] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [81] h [68] . [80] . [93] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [82] d [64] . [80] . [93] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [84] b [62] . [80] . [93] . [b8] ( [28] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 31 (command_sequence == 31) avrdude: Recv: . [80] Raw message: 0x80 OK #######avrdude: jtagmkII_paged_write(): block_size at addr 1792 is 68 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 266 bytes avrdude: Sent: . [1b] [20] . [00] . [0a] . [01] . [00] . [00] . [0e] . [04] . [c0] . [00] . [01] . [00] . [00] . [00] . [07] . [80] . [00] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [88] a [61] . [80] . [93] . [84] . [06] . [80] . [e1] . [97] . [e2] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [10] . [92] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [ab] . [cd] . [f8] . [94] . [ff] . [cf] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] V [56] . [08] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 32 (command_sequence == 32) avrdude: Recv: . [80] Raw message: 0x80 OK ## | 100% 0.59s avrdude: 1860 bytes of flash written avrdude: verifying flash memory against test5.hex: avrdude: load data flash data from input file test5.hex: avrdude: input file test5.hex auto detected as Intel Hex avrdude: input file test5.hex contains 1860 bytes avrdude: reading on-chip flash data: Reading | avrdude: jtagmkII_paged_load(.., flash, 256, 1860) avrdude: jtagmkII_paged_load(): block_size at addr 0 is 256 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] ! [21] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [c0] . [00] . [01] . [00] . [00] . [00] . [00] . [80] . [00] z [7a] . [f9] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 33 (command_sequence == 33) avrdude: Recv: . [82] . [0c] . [94] . [fa] . [00] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] Raw message: 0x82 0x0c 0x94 0xfa 0x00 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 memory contents: 0x0c 0x94 0xfa 0x00 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 ######avrdude: jtagmkII_paged_load(): block_size at addr 256 is 256 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] " [22] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [c0] . [00] . [01] . [00] . [00] . [00] . [01] . [80] . [00] . [b7] . [93] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 34 (command_sequence == 34) avrdude: Recv: . [82] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [0c] . [94] . [18] . [01] . [11] $ [24] . [1f] . [be] . [cf] . [ef] . [df] . [e3] . [de] . [bf] . [cd] . [bf] Raw message: 0x82 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x11 0x24 0x1f 0xbe 0xcf 0xef 0xdf 0xe3 0xde 0xbf 0xcd 0xbf memory contents: 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x0c 0x94 0x18 0x01 0x11 0x24 0x1f 0xbe 0xcf 0xef 0xdf 0xe3 0xde 0xbf 0xcd 0xbf #######avrdude: jtagmkII_paged_load(): block_size at addr 512 is 256 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] # [23] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [c0] . [00] . [01] . [00] . [00] . [00] . [02] . [80] . [00] . [dc] l [6c] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 35 (command_sequence == 35) avrdude: Recv: . [82] . [00] . [e0] . [0c] . [bf] . [18] . [be] . [19] . [be] . [1a] . [be] . [1b] . [be] . [10] . [e2] . [a0] . [e0] . [b0] . [e2] . [e4] . [e4] . [f7] . [e0] . [00] . [e0] . [0b] . [bf] . [02] . [c0] . [07] . [90] . [0d] . [92] . [a0] 0 [30] . [b1] . [07] . [d9] . [f7] . [1b] . [be] . [0e] . [94] $ [24] . [01] . [0c] . [94] . [a0] . [03] . [0c] . [94] . [00] . [00] [20] . [ed] 7 [37] . [e0] . [04] . [c0] . [f9] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [00] . [97] . [d1] . [f7] . [08] . [95] . [7f] . [92] . [8f] . [92] . [9f] . [92] . [af] . [92] . [bf] . [92] . [cf] . [92] . [df] . [92] . [ef] . [92] . [ff] . [92] . [0f] . [93] . [1f] . [93] . [8f] . [ef] . [80] . [93] . [84] . [06] . [80] . [93] . [80] . [06] ` [60] . [ed] w [77] . [e0] w [77] $ [24] s [73] . [94] H [48] . [ec] P [50] . [e0] . [a2] . [e0] . [da] . [2e] . [f4] . [e0] . [cf] . [2e] . [e8] . [e0] . [be] . [2e] 0 [30] . [e1] . [a3] . [2e] . [00] . [e2] [20] . [e4] . [f2] . [2e] . [90] . [e8] . [99] . [2e] . [88] $ [24] . [83] . [94] . [88] . [e1] . [e8] . [2e] . [80] . [91] . [84] . [06] . [8f] . [ef] . [80] . [93] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8e] . [7f] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8d] . [7f] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8b] . [7f] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [87] . [7f] . [80] . [93] . [84] . [06] Raw message: 0x82 0x00 0xe0 0x0c 0xbf 0x18 0xbe 0x19 0xbe 0x1a 0xbe 0x1b 0xbe 0x10 0xe2 0xa0 0xe0 0xb0 0xe2 0xe4 0xe4 0xf7 0xe0 0x00 0xe0 0x0b 0xbf 0x02 0xc0 0x07 0x90 0x0d 0x92 0xa0 0x30 0xb1 0x07 0xd9 0xf7 0x1b 0xbe 0x0e 0x94 0x24 0x01 0x0c 0x94 0xa0 0x03 0x0c 0x94 0x00 0x00 0x20 0xed 0x37 0xe0 0x04 0xc0 0xf9 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0x00 0x97 0xd1 0xf7 0x08 0x95 0x7f 0x92 0x8f 0x92 0x9f 0x92 0xaf 0x92 0xbf 0x92 0xcf 0x92 0xdf 0x92 0xef 0x92 0xff 0x92 0x0f 0x93 0x1f 0x93 0x8f 0xef 0x80 0x93 0x84 0x06 0x80 0x93 0x80 0x06 0x60 0xed 0x77 0xe0 0x77 0x24 0x73 0x94 0x48 0xec 0x50 0xe0 0xa2 0xe0 0xda 0x2e 0xf4 0xe0 0xcf 0x2e 0xe8 0xe0 0xbe 0x2e 0x30 0xe1 0xa3 0x2e 0x00 0xe2 0x20 0xe4 0xf2 0x2e 0x90 0xe8 0x99 0x2e 0x88 0x24 0x83 0x94 0x88 0xe1 0xe8 0x2e 0x80 0x91 0x84 0x06 0x8f 0xef 0x80 0x93 0x84 0x06 0x88 0xee 0x93 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8e 0x7f 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8d 0x7f 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8b 0x7f 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x87 0x7f 0x80 0x93 0x84 0x06 memory contents: 0x00 0xe0 0x0c 0xbf 0x18 0xbe 0x19 0xbe 0x1a 0xbe 0x1b 0xbe 0x10 0xe2 0xa0 0xe0 0xb0 0xe2 0xe4 0xe4 0xf7 0xe0 0x00 0xe0 0x0b 0xbf 0x02 0xc0 0x07 0x90 0x0d 0x92 0xa0 0x30 0xb1 0x07 0xd9 0xf7 0x1b 0xbe 0x0e 0x94 0x24 0x01 0x0c 0x94 0xa0 0x03 0x0c 0x94 0x00 0x00 0x20 0xed 0x37 0xe0 0x04 0xc0 0xf9 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0x00 0x97 0xd1 0xf7 0x08 0x95 0x7f 0x92 0x8f 0x92 0x9f 0x92 0xaf 0x92 0xbf 0x92 0xcf 0x92 0xdf 0x92 0xef 0x92 0xff 0x92 0x0f 0x93 0x1f 0x93 0x8f 0xef 0x80 0x93 0x84 0x06 0x80 0x93 0x80 0x06 0x60 0xed 0x77 0xe0 0x77 0x24 0x73 0x94 0x48 0xec 0x50 0xe0 0xa2 0xe0 0xda 0x2e 0xf4 0xe0 0xcf 0x2e 0xe8 0xe0 0xbe 0x2e 0x30 0xe1 0xa3 0x2e 0x00 0xe2 0x20 0xe4 0xf2 0x2e 0x90 0xe8 0x99 0x2e 0x88 0x24 0x83 0x94 0x88 0xe1 0xe8 0x2e 0x80 0x91 0x84 0x06 0x8f 0xef 0x80 0x93 0x84 0x06 0x88 0xee 0x93 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8e 0x7f 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8d 0x7f 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8b 0x7f 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x87 0x7f 0x80 0x93 0x84 0x06 #######avrdude: jtagmkII_paged_load(): block_size at addr 768 is 256 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] $ [24] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [c0] . [00] . [01] . [00] . [00] . [00] . [03] . [80] . [00] - [2d] F [46] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 36 (command_sequence == 36) avrdude: Recv: . [82] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8f] ~ [7e] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8f] } [7d] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8f] { [7b] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8f] w [77] . [80] . [93] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8f] . [ef] . [80] . [93] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [10] . [92] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [80] h [68] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [80] d [64] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [80] b [62] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [80] a [61] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] Raw message: 0x82 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8f 0x7e 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8f 0x7d 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8f 0x7b 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8f 0x77 0x80 0x93 0x84 0x06 0x88 0xee 0x93 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8f 0xef 0x80 0x93 0x84 0x06 0x88 0xee 0x93 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x10 0x92 0x84 0x06 0x88 0xee 0x93 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x80 0x68 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x80 0x64 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x80 0x62 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x80 0x61 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 memory contents: 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8f 0x7e 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8f 0x7d 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8f 0x7b 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8f 0x77 0x80 0x93 0x84 0x06 0x88 0xee 0x93 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8f 0xef 0x80 0x93 0x84 0x06 0x88 0xee 0x93 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x10 0x92 0x84 0x06 0x88 0xee 0x93 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x80 0x68 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x80 0x64 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x80 0x62 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x80 0x61 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 #######avrdude: jtagmkII_paged_load(): block_size at addr 1024 is 256 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] % [25] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [c0] . [00] . [01] . [00] . [00] . [00] . [04] . [80] . [00] ' [27] . [da] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 37 (command_sequence == 37) avrdude: Recv: . [82] . [88] ` [60] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [84] ` [60] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [82] ` [60] . [80] . [93] . [84] . [06] . [84] . [ef] . [91] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [81] ` [60] . [80] . [93] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [10] . [92] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] [20] . [e0] 0 [30] . [e0] . [80] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [d0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [c0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [b0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [a0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [00] . [93] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [f0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [90] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] Raw message: 0x82 0x88 0x60 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x84 0x60 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x82 0x60 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x81 0x60 0x80 0x93 0x84 0x06 0x88 0xee 0x93 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x10 0x92 0x84 0x06 0x88 0xee 0x93 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x20 0xe0 0x30 0xe0 0x80 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xd0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xc0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xb0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xa0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x00 0x93 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xf0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x90 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 memory contents: 0x88 0x60 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x84 0x60 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x82 0x60 0x80 0x93 0x84 0x06 0x84 0xef 0x91 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x81 0x60 0x80 0x93 0x84 0x06 0x88 0xee 0x93 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x10 0x92 0x84 0x06 0x88 0xee 0x93 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x20 0xe0 0x30 0xe0 0x80 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xd0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xc0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xb0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xa0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x00 0x93 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xf0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x90 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 #######avrdude: jtagmkII_paged_load(): block_size at addr 1280 is 256 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] & [26] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [c0] . [00] . [01] . [00] . [00] . [00] . [05] . [80] . [00] . [ea] . [b0] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 38 (command_sequence == 38) avrdude: Recv: . [82] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [f0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [00] . [93] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [a0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [b0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [c0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [d0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] p [70] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] / [2f] _ [5f] ? [3f] O [4f] * [2a] 0 [30] 1 [31] . [05] . [09] . [f0] s [73] . [cf] . [80] . [91] . [84] . [06] . [10] . [92] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] [20] . [e0] 0 [30] . [e0] . [b4] . [e2] . [a2] . [e4] . [11] . [e8] . [e0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [b0] . [93] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [a0] . [93] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [10] . [93] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [a0] . [93] . [84] . [06] . [88] . [e5] . [92] . [e0] Raw message: 0x82 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xf0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x00 0x93 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xa0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xb0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xc0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xd0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x70 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x2f 0x5f 0x3f 0x4f 0x2a 0x30 0x31 0x05 0x09 0xf0 0x73 0xcf 0x80 0x91 0x84 0x06 0x10 0x92 0x84 0x06 0x88 0xee 0x93 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x20 0xe0 0x30 0xe0 0xb4 0xe2 0xa2 0xe4 0x11 0xe8 0xe0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xb0 0x93 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xa0 0x93 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x10 0x93 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xa0 0x93 0x84 0x06 0x88 0xe5 0x92 0xe0 memory contents: 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xf0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x00 0x93 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xa0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xb0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xc0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xd0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x70 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x2f 0x5f 0x3f 0x4f 0x2a 0x30 0x31 0x05 0x09 0xf0 0x73 0xcf 0x80 0x91 0x84 0x06 0x10 0x92 0x84 0x06 0x88 0xee 0x93 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x20 0xe0 0x30 0xe0 0xb4 0xe2 0xa2 0xe4 0x11 0xe8 0xe0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xb0 0x93 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xa0 0x93 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x10 0x93 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xa0 0x93 0x84 0x06 0x88 0xe5 0x92 0xe0 #######avrdude: jtagmkII_paged_load(): block_size at addr 1536 is 256 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] ' [27] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [c0] . [00] . [01] . [00] . [00] . [00] . [06] . [80] . [00] . [81] O [4f] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 39 (command_sequence == 39) avrdude: Recv: . [82] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [b0] . [93] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [e0] . [92] . [84] . [06] . [88] . [e5] . [92] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] / [2f] _ [5f] ? [3f] O [4f] * [2a] 0 [30] 1 [31] . [05] . [09] . [f0] . [bb] . [cf] . [80] . [91] . [84] . [06] . [10] . [92] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8f] . [ef] . [80] . [93] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [87] ~ [7e] . [80] . [93] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8b] } [7d] . [80] . [93] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8d] { [7b] . [80] . [93] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [8e] w [77] . [80] . [93] . [84] . [06] . [80] . [e1] . [97] . [e2] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [81] h [68] . [80] . [93] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [82] d [64] . [80] . [93] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [84] b [62] . [80] . [93] Raw message: 0x82 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xb0 0x93 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xe0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x2f 0x5f 0x3f 0x4f 0x2a 0x30 0x31 0x05 0x09 0xf0 0xbb 0xcf 0x80 0x91 0x84 0x06 0x10 0x92 0x84 0x06 0x88 0xee 0x93 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8f 0xef 0x80 0x93 0x84 0x06 0x88 0xee 0x93 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x87 0x7e 0x80 0x93 0x84 0x06 0x88 0xee 0x93 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8b 0x7d 0x80 0x93 0x84 0x06 0x88 0xee 0x93 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8d 0x7b 0x80 0x93 0x84 0x06 0x88 0xee 0x93 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8e 0x77 0x80 0x93 0x84 0x06 0x80 0xe1 0x97 0xe2 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x81 0x68 0x80 0x93 0x84 0x06 0x88 0xee 0x93 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x82 0x64 0x80 0x93 0x84 0x06 0x88 0xee 0x93 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x84 0x62 0x80 0x93 memory contents: 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xb0 0x93 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xe0 0x92 0x84 0x06 0x88 0xe5 0x92 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x2f 0x5f 0x3f 0x4f 0x2a 0x30 0x31 0x05 0x09 0xf0 0xbb 0xcf 0x80 0x91 0x84 0x06 0x10 0x92 0x84 0x06 0x88 0xee 0x93 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8f 0xef 0x80 0x93 0x84 0x06 0x88 0xee 0x93 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x87 0x7e 0x80 0x93 0x84 0x06 0x88 0xee 0x93 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8b 0x7d 0x80 0x93 0x84 0x06 0x88 0xee 0x93 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8d 0x7b 0x80 0x93 0x84 0x06 0x88 0xee 0x93 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x8e 0x77 0x80 0x93 0x84 0x06 0x80 0xe1 0x97 0xe2 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x81 0x68 0x80 0x93 0x84 0x06 0x88 0xee 0x93 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x82 0x64 0x80 0x93 0x84 0x06 0x88 0xee 0x93 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x84 0x62 0x80 0x93 #######avrdude: jtagmkII_paged_load(): block_size at addr 1792 is 68 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] ( [28] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [c0] D [44] . [00] . [00] . [00] . [00] . [07] . [80] . [00] . [f2] . [09] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 40 (command_sequence == 40) avrdude: Recv: . [82] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [88] a [61] . [80] . [93] . [84] . [06] . [80] . [e1] . [97] . [e2] . [fa] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [80] . [91] . [84] . [06] . [10] . [92] . [84] . [06] . [88] . [ee] . [93] . [e0] . [fb] . [01] 1 [31] . [97] . [f1] . [f7] . [01] . [97] . [d9] . [f7] . [ab] . [cd] . [f8] . [94] . [ff] . [cf] Raw message: 0x82 0x84 0x06 0x88 0xee 0x93 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x88 0x61 0x80 0x93 0x84 0x06 0x80 0xe1 0x97 0xe2 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x10 0x92 0x84 0x06 0x88 0xee 0x93 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xab 0xcd 0xf8 0x94 0xff 0xcf memory contents: 0x84 0x06 0x88 0xee 0x93 0xe0 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x88 0x61 0x80 0x93 0x84 0x06 0x80 0xe1 0x97 0xe2 0xfa 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0x80 0x91 0x84 0x06 0x10 0x92 0x84 0x06 0x88 0xee 0x93 0xe0 0xfb 0x01 0x31 0x97 0xf1 0xf7 0x01 0x97 0xd9 0xf7 0xab 0xcd 0xf8 0x94 0xff 0xcf ## | 100% 0.84s avrdude: verifying ... avrdude: 1860 bytes of flash verified avrdude: jtagmkII_program_disable(): Sending leave progmode command: avrdude: jtagmkII_send(): sending 1 bytes avrdude: Sent: . [1b] ) [29] . [00] . [01] . [00] . [00] . [00] . [0e] . [15] . [a5] . [db] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 41 (command_sequence == 41) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude: jtagmkII_reset(): Sending reset command: avrdude: jtagmkII_send(): sending 2 bytes avrdude: Sent: . [1b] * [2a] . [00] . [02] . [00] . [00] . [00] . [0e] . [0b] . [01] . [1d] . [92] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 42 (command_sequence == 42) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude: jtagmkII_close() avrdude: jtagmkII_close(): Sending GO command: avrdude: jtagmkII_send(): sending 1 bytes avrdude: Sent: . [1b] + [2b] . [00] . [01] . [00] . [00] . [00] . [0e] . [08] . [ae] . [1b] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 65535 (command_sequence == 43) avrdude: jtagmkII_recv(): got asynchronous event avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 43 (command_sequence == 43) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude: jtagmkII_close(): Sending sign-off command: avrdude: jtagmkII_send(): sending 1 bytes avrdude: Sent: . [1b] , [2c] . [00] . [01] . [00] . [00] . [00] . [0e] . [00] . [e8] . [0b] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 44 (command_sequence == 44) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude done. Thank you.
