#include #define HEIZUNG_PIN 16 #define NTC_PIN 34 #define NTC_SCHWELLE 2000 // 1750-1800 = 1-2 °C, ~2000 = ~5,6 °C, 3000-3100 = Handwarm #define NTC_SAMPLES 5 #define NTC_INTERVALL_MS 60000 // Messung alle 60 Sekunden #define BME_INTERVALL_MS 60000 // Messung alle 60 Sekunden Adafruit_BME280 bme; bool bmeAvailable = false; volatile bool zustand = false; float global_temp = 33.33; float global_druck = 999.99; float global_feuchte = 99.9; void bmeTask(void *pvParameters) { const TickType_t delay = pdMS_TO_TICKS(BME_INTERVALL_MS); for (;;) { float t, p, h; if (bmeAvailable) { t = bme.readTemperature(); p = bme.readPressure() / 100.0F; h = bme.readHumidity(); if (isnan(t) || isnan(p) || isnan(h)) { Serial.println("Falsche BME280-Daten!"); } else { global_temp = t; global_druck = p; global_feuchte = h; } } else { Serial.println("BME280 nicht verfügbar"); } Serial.printf("\n---------- BME280 -------------\nTemperatur: %.2f °C\nLuftdruck: %.2f hPa\nLuftfeuchtigkeit: %.2f %%\n", global_temp, global_druck, global_feuchte); Serial.println("-------------------------------"); Serial.println("\n"); vTaskDelay(delay); } } void ntcTask(void *pvParameters) { (void)pvParameters; for (;;) { long summe = 0; for (int i = 0; i < NTC_SAMPLES; i++) { summe += analogRead(NTC_PIN); vTaskDelay(pdMS_TO_TICKS(2)); } int mittelwert = summe / NTC_SAMPLES; float temperatur = 3.27 + (mittelwert - 1888.0) * (9.76 - 3.23) / (2240 - 1905); zustand = (mittelwert < NTC_SCHWELLE); Serial.println(F("-------------------------------")); Serial.print(F("NTC Mittelwert: ")); Serial.println(mittelwert); Serial.print(F("Geschätzte Temperatur: ")); Serial.print(temperatur); Serial.println(" °C"); Serial.println(zustand ? F("Zu kalt") : F("Warm genug")); Serial.print(F("Heizung ist ")); Serial.println(zustand ? F("an") : F("aus")); Serial.println(F("-------------------------------")); vTaskDelay(pdMS_TO_TICKS(NTC_INTERVALL_MS)); } } void heizungTask(void *pvParameters) { (void)pvParameters; bool letzter_zustand = false; for (;;) { if (zustand != letzter_zustand) { letzter_zustand = zustand; if (zustand) { digitalWrite(HEIZUNG_PIN, HIGH); } else { digitalWrite(HEIZUNG_PIN, LOW); } } vTaskDelay(pdMS_TO_TICKS(100)); } } void setup() { Serial.begin(115200); Serial.println(F("Starte ...")); pinMode(NTC_PIN, INPUT); pinMode(HEIZUNG_PIN, OUTPUT); digitalWrite(HEIZUNG_PIN, LOW); if (bme.begin(0x76)) { Serial.println("BME280 gefunden."); bmeAvailable = true; } else { Serial.println("Kein BME280 gefunden! Nutze Standard-Werte."); bmeAvailable = false; } xTaskCreatePinnedToCore(ntcTask, "NTC", 2048, nullptr, 1, nullptr, 0); xTaskCreatePinnedToCore(heizungTask, "Heizung", 2048, nullptr, 2, nullptr, 1); xTaskCreatePinnedToCore(bmeTask, "BME280", 4096, nullptr, 1, nullptr, 1); } void loop() { vTaskDelay(pdMS_TO_TICKS(1000)); }
