Version 4 SHEET 1 2888 2316 WIRE 752 608 752 688 WIRE 752 768 752 864 WIRE 912 608 880 608 WIRE 992 608 1104 608 WIRE 752 864 752 880 WIRE 1184 656 1184 608 WIRE 1184 608 1104 608 WIRE 1184 816 1184 864 WIRE 1184 864 752 864 WIRE 1312 752 1472 752 WIRE 1696 720 1312 720 WIRE 1312 560 1696 560 WIRE 1312 912 1472 912 WIRE 1472 800 1472 752 WIRE 1696 592 1696 560 WIRE 1472 880 1472 912 WIRE 1696 720 1696 672 WIRE 1472 912 1472 928 WIRE 1696 736 1696 720 WIRE 800 608 752 608 FLAG 752 880 GND FLAG 752 608 in0 FLAG 1104 608 in1 FLAG 1696 560 out1 FLAG 1472 752 out2 FLAG 1472 928 0 FLAG 1696 736 0 SYMBOL res 1680 576 R0 SYMATTR InstName R2 SYMATTR Value 250 SYMBOL res 896 624 R270 WINDOW 0 32 56 VTop 0 WINDOW 3 0 56 VBottom 0 SYMATTR InstName R1 SYMATTR Value 1 SYMBOL VOLTAGE 752 672 R0 WINDOW 39 0 0 Left 0 WINDOW 123 28 112 Left 0 WINDOW 3 17 112 Left 0 SYMATTR Value SINE(0 150 60 0 0 0) SYMATTR InstName V2 SYMBOL res 1456 784 R0 SYMATTR InstName R3 SYMATTR Value 6.3 SYMBOL transformer3_1_2 1168 560 R0 SYMATTR InstName TR1 SYMATTR Value TRAFO150W SYMATTR SpiceLine L1=2H L2=3.7H L3=8.4mH K=0.98 SYMATTR SpiceLine2 R1= 2 R2=2.8 R3=0.1 SYMBOL ind2 784 624 R270 WINDOW 0 32 56 VTop 0 WINDOW 3 4 56 VBottom 0 SYMATTR InstName L1 SYMATTR Value 100µ SYMATTR Type ind TEXT 664 408 Left 0 !.tran 0 100m 0 10u TEXT 1152 504 Left 0 ;transformer3_1_2.asy TEXT 648 -16 Left 0 ;Mains Transformer With Subcircuit\n \n1. Place the symbol " transformer3_1_2".\n2. The symbol comes up with the name X-TRAFO.\n Click the right mouse button over this field and replace X-TRAFO\n with the name of your subcircuit, e.g. TRAFO150W.\n3. The reference designator U1 may be replaced by TR1 ,\n4. Adjust the inductance values and the coupling factor K.\n Hint: L2/L1 = V2^2/V1^2, K= 0.95 .. 1\n5. Add the following line as SPICE line, if you the model(s) \n are in a file "trafos.txt" .\n .include trafos.txt TEXT 1512 -24 Left 0 ;* trafos.txt\n* Transformer Specified With Inductance Per Coil\n* "Primary" inductance L1, series resistor R1\n* "Secondary" inductance L2, series resistor R2\n* "Secondary" inductance L3, series resistor R3\n* Coupling factor K123 <=1\n* Ideal transformer voltage ratio = SQRT(L2/L1), SQRT(L3/L1)\n*\n.SUBCKT TRAFO150W 1 2 3 4 5 6 \n*\nL1 1 2 {L1} Rser={R1}\nL2 3 4 {L2} Rser={R2}\nL3 5 6 {L3} Rser={R3}\nK123 L1 L2 L3 {K}\n*\n.ENDS TRAFO150W TEXT 664 360 Left 0 !.include trafos.txt TEXT 664 448 Left 0 !.options plotwinsize=0 TEXT 840 704 Left 0 ;POWER LINE TEXT 1544 832 Left 0 ;Tube Heating TEXT 1768 616 Left 0 ;Effective Load RECTANGLE Normal 1040 928 656 528
