ÿ* [CLOC] [MEMC] [ITLB] [COPY] [CODE] [DATA] [JRAM] [CACH] [SIGN] [ZBSS] [CREG] [MAIN] Kreatel IP-STB booting... Firmware built Apr 3 2007 17:01:07, v1.37 IDT5V9885: EEPROM was already up-to-date Using framebuffer at 0x07800000 (8192 kB) Active mode Motorola VIP @ 300 MHz (333 MHz, CL 2.5), 131072 kB RAM Found ATI Xilleon X210 NAND flash support detected. Probing... Found flash on CS1: ST NAND128W3A (16777216 bytes) Found flash on CS0: ST NAND128W3A (16777216 bytes) Secure box detected: Verifying AK...Done Verifying headers...Done Found National DP83815 at IO base address 0x00002000 Found National DP83815 at memory base address 0x10000000 Probing...[DP83815] National DP83815: MAC addr 00:02:9B:32:D6:21 National DP83815: Setting 100 Mbit full-duplex Infocast HW ID = kreatel-ip-stb-rev-19 Searching for server (DHCP)... Me: 192.168.100.217, Server: 192.168.100.1, Gateway 192.168.100.1 Splash boot order: 323 Kernel boot order: 323 Bootcast address : 224.2.2.2:22222 Sap address : 224.2.127.254:9875 ***** Loading splash image ***** Using Local Storage LS: No valid image stored. Using TFTP Name: ssplash-1710 Server: 213.75.17.134 TFTP: Failed! Using Local Storage LS: No valid image stored. Skipping splash! ***** Loading kernel image ***** Using Local Storage LS: No valid image stored. Using TFTP TFTP: Downloading... Name: skernel-1710 Server: 213.75.17.134 TFTP: Failed! TFTP: Downloading... Name: skernel-1710 Server: 212.178.98.165 TFTP: Failed! TFTP: Downloading... Name: skernel-1710 Server: 213.75.17.135 TFTP: Failed! TFTP: Downloading... Name: skernel-1710 Server: 212.178.96.34 TFTP: Failed! TFTP: Downloading... Name: skernel-1710 Server: 213.75.17.134 TFTP: Failed! TFTP: Downloading... Name: skernel-1710 Server: 212.178.98.165 /
