> "make.exe" all -------- begin -------- avr-gcc (WinAVR 20080610) 4.3.0 Copyright (C) 2008 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. Size before: AVR Memory Usage ---------------- Device: atmega8 Program: 104 bytes (1.3% Full) (.text + .data + .bootloader) Data: 0 bytes (0.0% Full) (.data + .bss + .noinit) Compiling C: main.c avr-gcc -c -mmcu=atmega8 -I. -gdwarf-2 -DF_CPU=16000000UL -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=./main.lst -std=gnu99 -Wundef -MMD -MP -MF .dep/main.o.d main.c -o main.o Linking: main.elf avr-gcc -mmcu=atmega8 -I. -gdwarf-2 -DF_CPU=16000000UL -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=main.o -std=gnu99 -Wundef -MMD -MP -MF .dep/main.elf.d main.o --output main.elf -Wl,-Map=main.map,--cref -lm Creating load file for Flash: main.hex avr-objcopy -O ihex -R .eeprom -R .fuse -R .lock main.elf main.hex Creating load file for EEPROM: main.eep avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" \ --change-section-lma .eeprom=0 --no-change-warnings -O ihex main.elf main.eep || exit 0 Creating Extended Listing: main.lss avr-objdump -h -S -z main.elf > main.lss Creating Symbol Table: main.sym avr-nm -n main.elf > main.sym Size after: AVR Memory Usage ---------------- Device: atmega8 Program: 104 bytes (1.3% Full) (.text + .data + .bootloader) Data: 0 bytes (0.0% Full) (.data + .bss + .noinit) -------- end -------- > Process Exit Code: 0 > Time Taken: 00:01
