/* Identifica o ponto de entrada  */
ENTRY(_startup)
/* Especifica as areas de memoria do LPC2368  */
MEMORY 
  flash (rx) : ORIGIN = 0x00000000, LENGTH = (512k-4k)
  ram (rw) : ORIGIN = 0x40000000, LENGTH = (32k-32)
/* define a global symbol _stack_end  */
_stack_end = 0x40007EDC;
/* now define the output sections  */
SECTIONS 
	. = 0;	/* set location counter to address zero  */
	startup : { *(.startup)
		    _estartup = .;
	} >flash	/* the startup code goes into FLASH */
	.text :		/* collect all sections that should go into FLASH after startup  */ 
		_text = .;		
		*(.text)		/* all .text sections (code)  */
		crt.o(.rodata)		/* all .rodata sections (constants, strings, etc.)  */
		crt.o(.rodata*)		/* all .rodata* sections (constants, strings, etc.)  */
		crt.o(.glue_7)		/* all .glue_7 sections  (no idea what these are) */
		crt.o(.glue_7t)		/* all .glue_7t sections (no idea what these are) */
		_etext = .;		/* define a global symbol _etext just after the last code byte */
	} >flash 			/* put all the above into FLASH */
	.kex :
		_kex = .;
		*(.text)
		*(.rodata)
		*(.rodata*)
		*(.glue_7)
		*(.glue_7t)
		_ekex = .;
	} >ram AT >flash
	.data :			/* As secçoes .data sao dados inicializados  */ 
		_data = .;	/* O simbolo _data marca o inicio da secção .data */
		*(.data)	/* all .data sections  */
		_edata = .;	/* _edata marca o fim de .data section  */
	} >ram AT >flash	/* put all the above into RAM (but load the LMA copy into FLASH) */
	.bss :			/* collect all uninitialized .bss sections that go into RAM  */
		_bss_start = .;	/* define a global symbol marking the start of the .bss section */
		*(.bss)		/* all .bss sections  */
	} >ram			/* put all the above in RAM (it will be cleared in the startup code */
	. = ALIGN(4);		/* advance location counter to the next 32-bit boundary */
	.eh_frame :
     	KEEP (*(.eh_frame))
	} > ram
	_bss_end = . ;		/* define a global symbol marking the end of the .bss section */
	_end = .;		/* define a global symbol marking the end of application RAM */
