[CLOC] [MEMC] [ITLB] [COPY] [CODE] [DATA] [JRAM] [CACH] [SIGN] Uncompressing DBL 1... [ZBSS] [CREG] [MAIN] Kreatel IP-STB booting... Firmware built Jul 24 2006 15:17:54, v1.34b6 IDT5V9885: EEPROM was already up-to-date Using framebuffer at 0x07800000 (8192 kB) Active mode Kreatel IP-STB @ 300 MHz (333 MHz, CL 2.5), 131072 kB RAM Booted in 473 msecs. Found ATI Xilleon X210 Found National DP83815 at 0x2000, ROM address 0x00000000 Probing...[DP83815] National DP83815: MAC addr 00:02:9B:09:32:85 National DP83815: Setting 100 Mbit full-duplex Infocast HW ID = kreatel-ip-stb-rev-10 Searching for server (DHCP)... Me: 212.178.98.166, Server: 212.178.98.165, Gateway 212.178.98.165 flash: Invalid address space. Aborting! flash: Could not read header information! flash: Invalid address space. Aborting! flash: Could not read header information! Splash boot order: 2 Kernel boot order: 2 Bootcast address : 224.2.2.2:22222 Sap address : 224.2.127.254:9875 Sap HW ID : ip-stb_1710 ***** Loading splash image ***** Using TFTP Name: splash-1710 Server: 212.178.98.165 TFTP error 1 (File not found) TFTP: Failed! Skipping splash! ***** Loading kernel image ***** Using TFTP TFTP: Downloading... Name: kernel-1710 Server: 212.178.98.165 (ELF)... done loaded at: 82000000 820C4604 zimage at: 8200F000 820C4604 Uncompressing Linux at load address 80100000 initrd at: 820C4604 82EB88C6 relocated to: 802DAFF8 810CF2BA Booting linux kernel LINUX started... ATI Xilleon 210 (little endian), Solo mode PCI bus speed is 33MHz Initializing IRQs memsize: 112MB CPU revision is: 00018448 Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes. Primary data cache 16kB, 4-way, linesize 16 bytes. Linux version 2.4.30 (dailybuild@svn) (gcc version 3.4.6) #1 Thu Jan 11 14:28:39 CET 2007 Start xilleon_setup... Determined physical RAM map: memory: 00080000 @ 00000000 (ROM data) memory: 00080000 @ 00080000 (reserved) memory: 06f00000 @ 00100000 (usable) Initial ramdisk at: 0x802db000 (14631610 bytes) On node 0 totalpages: 28672 zone(0): 28672 pages. zone(1): 0 pages. zone(2): 0 pages. Kernel command line: ip=212.178.98.166:212.178.98.165:212.178.98.165:255.255.255.0 rbl=1 dbl=1 bch=224.2.2.2:22222 1 calculating r4koff... 0016dd02(1498370) with HZ(100) CPU frequency 299.67 MHz Using 149.837 MHz high precision timer. Console: colour dummy device 80x25 Calibrating delay loop... 299.00 BogoMIPS Memory: 96224k/113664k available (1445k kernel code, 17440k reserved, 116k data, 112k init, 0k highmem) Dentry cache hash table entries: 16384 (order: 5, 131072 bytes) Inode cache hash table entries: 8192 (order: 4, 65536 bytes) Mount cache hash table entries: 512 (order: 0, 4096 bytes) Buffer cache hash table entries: 4096 (order: 2, 16384 bytes) Page-cache hash table entries: 32768 (order: 5, 131072 bytes) Checking for 'wait' instruction... available. POSIX conformance testing by UNIFIX Autoconfig PCI channel 0x802a6ad8 Scanning bus 00, I/O 0x00002000:0x00010001, Mem 0x10000000:0x18000001 00:11.0 Class 0c03: 1033:0035 (rev 43) Mem at 0x10000000 [size=0x1000] 00:11.1 Class 0c03: 1033:0035 (rev 43) Mem at 0x10001000 [size=0x1000] 00:11.2 Class 0c03: 1033:00e0 (rev 04) Mem at 0x10002000 [size=0x100] 00:12.0 Class 0000: 104c:9065 (rev 01) Mem at 0x10400000 [size=0x400000] Mem at 0x10800000 [size=0x800000] I/O at 0x00002000 [size=0x10] 00:13.0 Class 0200: 100b:0020 I/O at 0x00002100 [size=0x100] Mem at 0x11000000 [size=0x1000] 00:14.0 Class 0480: 1002:4860 (rev 02) Mem at 0x08000000 [size=0x4000000] I/O at 0x00002200 [size=0x100] Mem at 0x11008000 [size=0x8000] Mem at 0x1c000000 [size=0x2000000] 00:14.1 Class 0101: 1002:4861 (rev 01) I/O at 0x00002300 [size=0x8] I/O at 0x00002308 [size=0x4] I/O at 0x00002310 [size=0x8] I/O at 0x00002318 [size=0x4] I/O at 0x00002320 [size=0x10] 00:14.2 Class 0c03: 1002:4862 (rev 0a) Mem at 0x11010000 [size=0x1000] 00:14.5 Class 0401: 1002:4863 (rev 01) Mem at 0x11011000 [size=0x100] 00:14.6 Class 0703: 1002:4864 (rev 01) Mem at 0x11011100 [size=0x100] irq fixup slot 17 vendor 1033 irq 33 irq fixup slot 17 vendor 1033 irq 34 irq fixup slot 17 vendor 1033 irq 35 irq fixup slot 18 vendor 104c irq 33 irq fixup slot 19 vendor 100b irq 33 Linux NET4.0 for Linux 2.4 Based upon Swansea University Computer Society NET3.039 Initializing RT netlink socket Starting kswapd devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au) devfs: boot_options: 0x0 JFFS2 version 2.1. (C) 2001 Red Hat, Inc., designed by Axis Communications AB. Xilleonfb: Xilleon Framebuffer Driver Xilleonfb: Initial framebuffer at 0x0f800000, mapped to af800000, size 8388608 Console: switching to colour frame buffer device 90x30 Dummy keyboard driver installed. pty: 256 Unix98 ptys configured Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled ttyS00 at 0xbe000010 (irq = 100) is a 16550A ttyS01 at 0xbe000000 (irq = 99) is a 16550A ttyS02 at 0xbe000020 (irq = 122) is a 16550A Kboxdev: registered device with major 120 Software Watchdog Timer: 0.05, timer margin: 60 sec RAMDISK driver initialized: 16 RAM disks of 32768K size 1024 blocksize natsemi dp8381x driver, version 1.07+LK1.0.17, Sep 27, 2002 originally by Donald Becker http://www.scyld.com/network/natsemi.html 2.4.x kernel port by Jeff Garzik, Tjeerd Mulder eth0: NatSemi DP8381[56] at 0xb1000000, 00:02:9b:09:32:85, IRQ 33. Xilleonfb: Xilleon Framebuffer Driver Xilleonfb: Unable to reserve framebuffer at 0xf800000 mice: PS/2 mouse device common for all mice NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP, IGMP IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 8192 bind 16384) eth0: link up. eth0: Setting full-duplex based on negotiated link capability. IP-Config: Complete: device=eth0, addr=212.178.98.166, mask=255.255.255.0, gw=212.178.98.165, host=212.178.98.166, domain=, nis-domain=(none), bootserver=212.178.98.165, rootserver=212.178.98.165, rootpath= ip_tables: (C) 2000-2002 Netfilter core team NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. RAMDISK: Compressed image found at block 0 Freeing initrd memory: 14288k freed VFS: Mounted root (ext2 filesystem) readonly. Freeing unused kernel memory: 112k freed --- Linuxrc mounting /rootdisk using up to maximum 512 MB RAM if available --- Linuxrc populating /rootdisk --- Mounting devfs --- Pivoting root mount: Mounting none on /proc/bus/usb failed: No such file or directory ldconfig: /lib/libusb-0.1.so.4 is not a symbolic link createuserproc: Added production parameters createuserproc: Added user parameters insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/07kb.o Warning: loading 07kb will taint the kernel: non-GPL license - Proprietary See http://www.tux.org/lkml/#export-tainted for information about tainted modules insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/08ir.o Warning: loading 08ir will taint the kernel: non-GPL license - Proprietary See http://www.tux.org/lkml/#export-tainted for information about tainted modules insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/10usbcore.o usb.c: registered new driver usbdevfs usb.c: registered new driver hub insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/11usb-ohci.o usb-ohci.c: USB OHCI at membase 0xb0000000, IRQ 33 usb-ohci.c: usb-00:11.0, PCI device 1033:0035 usb.c: new USB bus registered, assigned bus number 1 hub.c: USB hub found hub.c: 3 ports detected usb-ohci.c: USB OHCI at membase 0xb0001000, IRQ 34 usb-ohci.c: usb-00:11.1, PCI device 1033:0035 usb.c: new USB bus registered, assigned bus number 2 hub.c: USB hub found hub.c: 2 ports detected usb-ohci.c: USB OHCI at membase 0xb1010000, IRQ 2 usb-ohci.c: usb-00:14.2, PCI device 1002:4862 usb.c: new USB bus registered, assigned bus number 3 hub.c: USB hub found hub.c: 2 ports detected insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/12ehci-hcd.o ehci_hcd 00:11.2: PCI device 1033:00e0 ehci_hcd 00:11.2: irq 35, pci mem b0002000 usb.c: new USB bus registered, assigned bus number 4 ehci_hcd 00:11.2: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4 hub.c: USB hub found hub.c: 5 ports detected insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/15hid.o usb.c: registered new driver hid hid-core.c: v1.8.1 Andreas Gal, Vojtech Pavlik hid-core.c: USB HID support drivers insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/atyx220.o Warning: loading atyx220 will taint the kernel: no license See http://www.tux.org/lkml/#export-tainted for information about tainted modules insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/dm642.o >> dm642pci_fxn_probe - Revision ID = 1 >> dm642pci_fxn_probe - Interrupt Line = 33 >> dm642pci_fxn_probe - PCI Device Enabled >> dm642pci_fxn_probe - Mapping MEM Space to Kernel Phys = 0x10400000 >> dm642pci_fxn_probe - Mapping MEM Space to Kernel Phys = 0x10800000 >> drvPciDm642ModuleInit - Requesting IRQ, irqId = 33 insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/fat.o insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/kboxmtd.o Warning: loading kboxmtd will taint the kernel: non-GPL license - Proprietary See http://www.KBoxMTD: Found Winbond flash. tux.org/lkml/#exKBoxMTD: Winbond W39L040 flash detected port-tainted forKBoxMTD: Standard firmware detected information aboUsing the production data for NAND settings ut tainted modulKBoxMTD: Done es insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/kfusd.o fusd: starting, $Revision: 1.97 $, $Date: 2003/07/11 22:29:39 $, debugging messages disabled insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/scsi_mod.o SCSI subsystem driver Revision: 1.00 insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/sd_mod.o insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/usb-storage.o Initializing USB Mass Storage driver... usb.c: registered new driver usb-storage USB Mass Storage support registered. insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/vfat.o insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/yaffs.o yaffs Jan 11 2007 14:32:34 Installing. Mounting flash PVR: USB disk not found (1 of 3) Failed to open flash device: No such file or directory Failed to open flash device: No such file or directory Mounting filesystem (/flash2) mount: Mounting /dev/mtdblock/4 on /flash2 failed: No such file or directory Failed to mount filesystem! Erasing flash. Failed to open flash device Mounting filesystem again (/flash2) mount: Mounting /dev/mtdblock/4 on /flash2 failed: No such file or directory FATAL ERROR: flash filesystem (/flash2) could not be mounted! No time zone setting, using UTC Reading address from /tmp/bootloader_channel.conf Current system time is 946684821 Scanning infocast channel 224.2.2.2:22222 Setting timeout to 10 seconds PVR: USB disk not found (2 of 3) PVR: USB disk not found (3 of 3) hdparm: /dev/scsi/host0/bus0/target0/lun0/disc: No such file or directory PVR: USB disk is NOT attached Timeout while listening on infocast channel, skipping eth0 Link encap:Ethernet HWaddr 00:02:9B:09:32:85 inet addr:212.178.98.166 Bcast:212.178.98.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:4 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:184 (184.0 B) Interrupt:33 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) rm: cannot remove `/sbin/fdisk': No such file or directory rm: cannot remove `/sbin/jfs_fsck': No such file or directory rm: cannot remove `/sbin/jfs_mkfs': No such file or directory Starting up Analog TV from rc.sysinit... startup.sh exists, executing... Bummer, could not run '/pvr/USB/kickstart.sh': No such file or directory BusyBox v1.01 (2007.01.11-16:43+0000) Built-in shell (ash) Enter 'help' for a list of built-in commands. / # cat /proc/version Linux version 2.4.30 (dailybuild@svn) (gcc version 3.4.6) #1 Thu Jan 11 14:28:39 CET 2007 / #
