------------------------------------------------------------------------------ -- user_logic.vhd - entity/architecture pair ------------------------------------------------------------------------------ -- -- *************************************************************************** -- ** Copyright (c) 1995-2008 Xilinx, Inc. All rights reserved. ** -- ** ** -- ** Xilinx, Inc. ** -- ** XILINX IS PROVIDING THIS DESIGN, CODE, OR INFORMATION "AS IS" ** -- ** AS A COURTESY TO YOU, SOLELY FOR USE IN DEVELOPING PROGRAMS AND ** -- ** SOLUTIONS FOR XILINX DEVICES. BY PROVIDING THIS DESIGN, CODE, ** -- ** OR INFORMATION AS ONE POSSIBLE IMPLEMENTATION OF THIS FEATURE, ** -- ** APPLICATION OR STANDARD, XILINX IS MAKING NO REPRESENTATION ** -- ** THAT THIS IMPLEMENTATION IS FREE FROM ANY CLAIMS OF INFRINGEMENT, ** -- ** AND YOU ARE RESPONSIBLE FOR OBTAINING ANY RIGHTS YOU MAY REQUIRE ** -- ** FOR YOUR IMPLEMENTATION. XILINX EXPRESSLY DISCLAIMS ANY ** -- ** WARRANTY WHATSOEVER WITH RESPECT TO THE ADEQUACY OF THE ** -- ** IMPLEMENTATION, INCLUDING BUT NOT LIMITED TO ANY WARRANTIES OR ** -- ** REPRESENTATIONS THAT THIS IMPLEMENTATION IS FREE FROM CLAIMS OF ** -- ** INFRINGEMENT, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS ** -- ** FOR A PARTICULAR PURPOSE. ** -- ** ** -- *************************************************************************** -- ------------------------------------------------------------------------------ -- Filename: user_logic.vhd -- Version: 1.00.a -- Description: User logic. -- Date: Tue Jun 01 13:30:55 2010 (by Create and Import Peripheral Wizard) -- VHDL Standard: VHDL'93 ------------------------------------------------------------------------------ -- Naming Conventions: -- active low signals: "*_n" -- clock signals: "clk", "clk_div#", "clk_#x" -- reset signals: "rst", "rst_n" -- generics: "C_*" -- user defined types: "*_TYPE" -- state machine next state: "*_ns" -- state machine current state: "*_cs" -- combinatorial signals: "*_com" -- pipelined or register delay signals: "*_d#" -- counter signals: "*cnt*" -- clock enable signals: "*_ce" -- internal version of output port: "*_i" -- device pins: "*_pin" -- ports: "- Names begin with Uppercase" -- processes: "*_PROCESS" -- component instantiations: "I_<#|FUNC>" ------------------------------------------------------------------------------ -- DO NOT EDIT BELOW THIS LINE -------------------- library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; library proc_common_v2_00_a; use proc_common_v2_00_a.proc_common_pkg.all; -- DO NOT EDIT ABOVE THIS LINE -------------------- --USER libraries added here ------------------------------------------------------------------------------ -- Entity section ------------------------------------------------------------------------------ -- Definition of Generics: -- C_SLV_DWIDTH -- Slave interface data bus width -- C_NUM_REG -- Number of software accessible registers -- C_RDFIFO_DEPTH -- Read FIFO depth -- C_WRFIFO_DEPTH -- Write FIFO depth -- -- Definition of Ports: -- Bus2IP_Clk -- Bus to IP clock -- Bus2IP_Reset -- Bus to IP reset -- Bus2IP_Data -- Bus to IP data bus -- Bus2IP_BE -- Bus to IP byte enables -- Bus2IP_RdCE -- Bus to IP read chip enable -- Bus2IP_WrCE -- Bus to IP write chip enable -- IP2Bus_Data -- IP to Bus data bus -- IP2Bus_RdAck -- IP to Bus read transfer acknowledgement -- IP2Bus_WrAck -- IP to Bus write transfer acknowledgement -- IP2Bus_Error -- IP to Bus error response -- IP2RFIFO_WrReq -- IP to RFIFO : IP write request -- IP2RFIFO_Data -- IP to RFIFO : IP write data bus -- IP2RFIFO_WrMark -- IP to RFIFO : mark beginning of packet being written -- IP2RFIFO_WrRelease -- IP to RFIFO : return RFIFO to normal FIFO operation -- IP2RFIFO_WrRestore -- IP to RFIFO : restore the RFIFO to the last packet mark -- RFIFO2IP_WrAck -- RFIFO to IP : RFIFO write acknowledge -- RFIFO2IP_AlmostFull -- RFIFO to IP : RFIFO almost full -- RFIFO2IP_Full -- RFIFO to IP : RFIFO full -- RFIFO2IP_Vacancy -- RFIFO to IP : RFIFO vacancy -- IP2WFIFO_RdReq -- IP to WFIFO : IP read request -- IP2WFIFO_RdMark -- IP to WFIFO : mark beginning of packet being read -- IP2WFIFO_RdRelease -- IP to WFIFO : return WFIFO to normal FIFO operation -- IP2WFIFO_RdRestore -- IP to WFIFO : restore the WFIFO to the last packet mark -- WFIFO2IP_Data -- WFIFO to IP : WFIFO read data -- WFIFO2IP_RdAck -- WFIFO to IP : WFIFO read acknowledge -- WFIFO2IP_AlmostEmpty -- WFIFO to IP : WFIFO almost empty -- WFIFO2IP_Empty -- WFIFO to IP : WFIFO empty -- WFIFO2IP_Occupancy -- WFIFO to IP : WFIFO occupancy ------------------------------------------------------------------------------ entity user_logic is generic ( -- ADD USER GENERICS BELOW THIS LINE --------------- --USER generics added here -- ADD USER GENERICS ABOVE THIS LINE --------------- -- DO NOT EDIT BELOW THIS LINE --------------------- -- Bus protocol parameters, do not add to or delete C_SLV_DWIDTH : integer := 32; C_NUM_REG : integer := 3; C_RDFIFO_DEPTH : integer := 512; C_WRFIFO_DEPTH : integer := 512 -- DO NOT EDIT ABOVE THIS LINE --------------------- ); port ( -- ADD USER PORTS BELOW THIS LINE ------------------ --USER ports added here -- ADD USER PORTS ABOVE THIS LINE ------------------ -- DO NOT EDIT BELOW THIS LINE --------------------- -- Bus protocol ports, do not add to or delete Bus2IP_Clk : in std_logic; Bus2IP_Reset : in std_logic; Bus2IP_Data : in std_logic_vector(0 to C_SLV_DWIDTH-1); Bus2IP_BE : in std_logic_vector(0 to C_SLV_DWIDTH/8-1); Bus2IP_RdCE : in std_logic_vector(0 to C_NUM_REG-1); Bus2IP_WrCE : in std_logic_vector(0 to C_NUM_REG-1); IP2Bus_Data : out std_logic_vector(0 to C_SLV_DWIDTH-1); IP2Bus_RdAck : out std_logic; IP2Bus_WrAck : out std_logic; IP2Bus_Error : out std_logic; IP2RFIFO_WrReq : out std_logic; IP2RFIFO_Data : out std_logic_vector(0 to C_SLV_DWIDTH-1); IP2RFIFO_WrMark : out std_logic; IP2RFIFO_WrRelease : out std_logic; IP2RFIFO_WrRestore : out std_logic; RFIFO2IP_WrAck : in std_logic; RFIFO2IP_AlmostFull : in std_logic; RFIFO2IP_Full : in std_logic; RFIFO2IP_Vacancy : in std_logic_vector(0 to log2(C_RDFIFO_DEPTH)); IP2WFIFO_RdReq : out std_logic; IP2WFIFO_RdMark : out std_logic; IP2WFIFO_RdRelease : out std_logic; IP2WFIFO_RdRestore : out std_logic; WFIFO2IP_Data : in std_logic_vector(0 to C_SLV_DWIDTH-1); WFIFO2IP_RdAck : in std_logic; WFIFO2IP_AlmostEmpty : in std_logic; WFIFO2IP_Empty : in std_logic; WFIFO2IP_Occupancy : in std_logic_vector(0 to log2(C_WRFIFO_DEPTH)) -- DO NOT EDIT ABOVE THIS LINE --------------------- ); attribute SIGIS : string; attribute SIGIS of Bus2IP_Clk : signal is "CLK"; attribute SIGIS of Bus2IP_Reset : signal is "RST"; end entity user_logic; ------------------------------------------------------------------------------ -- Architecture section ------------------------------------------------------------------------------ architecture IMP of user_logic is --USER signal declarations added here, as needed for user logic component counter port( clk : in std_logic; clear : in std_logic; count : in std_logic; countst : in std_logic_vector(31 downto 0)); end component; ------------------------------------------ -- Signals for user logic slave model s/w accessible register example ------------------------------------------ signal slv_reg0 : std_logic_vector(0 to C_SLV_DWIDTH-1); signal slv_reg1 : std_logic_vector(0 to C_SLV_DWIDTH-1); signal slv_reg2 : std_logic_vector(0 to C_SLV_DWIDTH-1); signal slv_reg_write_sel : std_logic_vector(0 to 2); signal slv_reg_read_sel : std_logic_vector(0 to 2); signal slv_ip2bus_data : std_logic_vector(0 to C_SLV_DWIDTH-1); signal slv_read_ack : std_logic; signal slv_write_ack : std_logic; ------------------------------------------ -- Signals for read/write fifo loopback example ------------------------------------------ type FIFO_CNTL_SM_TYPE is (IDLE, RD_REQ, WR_REQ); signal fifo_cntl_ns : FIFO_CNTL_SM_TYPE; signal fifo_cntl_cs : FIFO_CNTL_SM_TYPE; signal fifo_rdreq_cmb : std_logic; signal fifo_wrreq_cmb : std_logic; begin --USER logic implementation added here counter_0: counter port map( clk => Bus2IP_Clk, clear => slv_reg0(0), -- count => slv_reg1(0), -- countst => IP2RFIFO_Data); ------------------------------------------ -- Example code to read/write user logic slave model s/w accessible registers -- -- Note: -- The example code presented here is to show you one way of reading/writing -- software accessible registers implemented in the user logic slave model. -- Each bit of the Bus2IP_WrCE/Bus2IP_RdCE signals is configured to correspond -- to one software accessible register by the top level template. For example, -- if you have four 32 bit software accessible registers in the user logic, -- you are basically operating on the following memory mapped registers: -- -- Bus2IP_WrCE/Bus2IP_RdCE Memory Mapped Register -- "1000" C_BASEADDR + 0x0 -- "0100" C_BASEADDR + 0x4 -- "0010" C_BASEADDR + 0x8 -- "0001" C_BASEADDR + 0xC -- ------------------------------------------ slv_reg_write_sel <= Bus2IP_WrCE(0 to 2); slv_reg_read_sel <= Bus2IP_RdCE(0 to 2); slv_write_ack <= Bus2IP_WrCE(0) or Bus2IP_WrCE(1) or Bus2IP_WrCE(2); slv_read_ack <= Bus2IP_RdCE(0) or Bus2IP_RdCE(1) or Bus2IP_RdCE(2); -- implement slave model software accessible register(s) SLAVE_REG_WRITE_PROC : process( Bus2IP_Clk ) is begin if Bus2IP_Clk'event and Bus2IP_Clk = '1' then if Bus2IP_Reset = '1' then slv_reg0 <= (others => '0'); slv_reg1 <= (others => '0'); slv_reg2 <= (others => '0'); else case slv_reg_write_sel is when "100" => for byte_index in 0 to (C_SLV_DWIDTH/8)-1 loop if ( Bus2IP_BE(byte_index) = '1' ) then slv_reg0(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7); end if; end loop; when "010" => for byte_index in 0 to (C_SLV_DWIDTH/8)-1 loop if ( Bus2IP_BE(byte_index) = '1' ) then slv_reg1(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7); end if; end loop; when "001" => for byte_index in 0 to (C_SLV_DWIDTH/8)-1 loop if ( Bus2IP_BE(byte_index) = '1' ) then slv_reg2(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7); end if; end loop; when others => null; end case; end if; end if; end process SLAVE_REG_WRITE_PROC; -- implement slave model software accessible register(s) read mux SLAVE_REG_READ_PROC : process( slv_reg_read_sel, slv_reg0, slv_reg1, slv_reg2 ) is begin case slv_reg_read_sel is when "100" => slv_ip2bus_data <= slv_reg0; when "010" => slv_ip2bus_data <= slv_reg1; when "001" => slv_ip2bus_data <= slv_reg2; when others => slv_ip2bus_data <= (others => '0'); end case; end process SLAVE_REG_READ_PROC; ------------------------------------------ -- Example code to transfer data between read/write fifo -- -- Note: -- The example code presented here is to show you one way of operating on -- the read/write FIFOs provided for you. There's a set of IPIC ports -- dedicated to the FIFO operations, beginning with RFIFO2IP_* or IP2RFIFO_* -- or WFIFO2IP_* or IP2WFIFO_*. Some FIFO ports are only available when -- certain FIFO services are present, s.t. vacancy calculation, etc. -- Typically you will need to have a state machine to read data from the -- write FIFO or write data to the read FIFO. This code snippet simply -- transfer the data from the write FIFO to the read FIFO. ------------------------------------------ IP2RFIFO_WrMark <= '0'; IP2RFIFO_WrRelease <= '0'; IP2RFIFO_WrRestore <= '0'; IP2WFIFO_RdMark <= '0'; IP2WFIFO_RdRelease <= '0'; IP2WFIFO_RdRestore <= '0'; FIFO_CNTL_SM_COMB : process( WFIFO2IP_empty, WFIFO2IP_RdAck, RFIFO2IP_full, RFIFO2IP_WrAck, fifo_cntl_cs ) is begin -- set defaults fifo_rdreq_cmb <= '0'; fifo_wrreq_cmb <= '0'; fifo_cntl_ns <= fifo_cntl_cs; case fifo_cntl_cs is when IDLE => -- data is available in the write fifo and there's space in the read fifo, -- so we can start transfering the data from write fifo to read fifo if ( WFIFO2IP_empty = '0' and RFIFO2IP_full = '0' ) then fifo_rdreq_cmb <= '1'; fifo_cntl_ns <= RD_REQ; end if; when RD_REQ => -- data has been read from the write fifo, -- so we can write it to the read fifo if ( WFIFO2IP_RdAck = '1' ) then fifo_wrreq_cmb <= '1'; fifo_cntl_ns <= WR_REQ; end if; when WR_REQ => -- data has been written to the read fifo, -- so data transfer is done if ( RFIFO2IP_WrAck = '1' ) then fifo_cntl_ns <= IDLE; end if; when others => fifo_cntl_ns <= IDLE; end case; end process FIFO_CNTL_SM_COMB; FIFO_CNTL_SM_SEQ : process( Bus2IP_Clk ) is begin if ( Bus2IP_Clk'event and Bus2IP_Clk = '1' ) then if ( Bus2IP_Reset = '1' ) then IP2WFIFO_RdReq <= '0'; IP2RFIFO_WrReq <= '0'; fifo_cntl_cs <= IDLE; else IP2WFIFO_RdReq <= fifo_rdreq_cmb; IP2RFIFO_WrReq <= fifo_wrreq_cmb; fifo_cntl_cs <= fifo_cntl_ns; end if; end if; end process FIFO_CNTL_SM_SEQ; --IP2RFIFO_Data <= WFIFO2IP_Data; ------------------------------------------ -- Example code to drive IP to Bus signals ------------------------------------------ IP2Bus_Data <= slv_ip2bus_data when slv_read_ack = '1' else (others => '0'); IP2Bus_WrAck <= slv_write_ack; IP2Bus_RdAck <= slv_read_ack; IP2Bus_Error <= '0'; end IMP;
