ENTITY rotate IS PORT( res, clock: IN bit; n: IN integer range 0 to 15; high_byte, low_byte: INOUT bitvector (7 DOWNTO 0) ); ARCHITECTURE arch OF rotate IS BEGIN PROCESS(res, clock) VARIABLE tmpl, tmph : std_logic; BEGIN IF (res = '1') THEN high_byte <= "00000000"; low_byte <= "00000000"; ELSIF(rising_edge(clock)) THEN FOR a IN 0 TO n LOOP tmph:=high_byte(7); tmpl:=low_byte(7); FOR i IN 6 DOWNTO 0 LOOP high_byte(i+1) <=high_byte(i); low_byte(i+1) <=low_byte(i); END LOOP; high_byte(0) := tmpl; low_byte(0) := tmph; END LOOP; END IF; END PROCESS; END arch;
