smartctl -a /dev/hda smartctl version 5.38 [i686-pc-linux-gnu] Copyright (C) 2002-8 Bruce Allen Home page is http://smartmontools.sourceforge.net/ === START OF INFORMATION SECTION === Model Family: Maxtor DiamondMax Plus 9 family Device Model: Maxtor 6Y160P0 Serial Number: Y44JBXME Firmware Version: YAR41BW0 User Capacity: 163.928.604.672 bytes Device is: In smartctl database [for details use: -P show] ATA Version is: 7 ATA Standard is: ATA/ATAPI-7 T13 1532D revision 0 Local Time is: Sun Sep 13 17:46:30 2009 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x80) Offline data collection activity was never started. Auto Offline Data Collection: Enabled. Self-test execution status: ( 116) The previous self-test completed having the read element of the test failed. Total time to complete Offline data collection: ( 302) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. No General Purpose Logging support. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 72) minutes. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 3 Spin_Up_Time 0x0027 203 202 063 Pre-fail Always - 11732 4 Start_Stop_Count 0x0032 253 253 000 Old_age Always - 1557 5 Reallocated_Sector_Ct 0x0033 253 253 063 Pre-fail Always - 5 6 Read_Channel_Margin 0x0001 253 253 100 Pre-fail Offline - 0 7 Seek_Error_Rate 0x000a 253 252 000 Old_age Always - 0 8 Seek_Time_Performance 0x0027 252 236 187 Pre-fail Always - 33317 9 Power_On_Minutes 0x0032 237 237 000 Old_age Always - 372h+45m 10 Spin_Retry_Count 0x002b 253 252 157 Pre-fail Always - 0 11 Calibration_Retry_Count 0x002b 253 252 223 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 250 250 000 Old_age Always - 1518 192 Power-Off_Retract_Count 0x0032 253 253 000 Old_age Always - 0 193 Load_Cycle_Count 0x0032 253 253 000 Old_age Always - 0 194 Temperature_Celsius 0x0032 253 253 000 Old_age Always - 40 195 Hardware_ECC_Recovered 0x000a 253 252 000 Old_age Always - 1595 196 Reallocated_Event_Count 0x0008 252 252 000 Old_age Offline - 1 197 Current_Pending_Sector 0x0008 253 253 000 Old_age Offline - 0 198 Offline_Uncorrectable 0x0008 252 252 000 Old_age Offline - 1 199 UDMA_CRC_Error_Count 0x0008 199 199 000 Old_age Offline - 0 200 Multi_Zone_Error_Rate 0x000a 253 252 000 Old_age Always - 0 201 Soft_Read_Error_Rate 0x000a 240 240 000 Old_age Always - 8443 202 TA_Increase_Count 0x000a 253 252 000 Old_age Always - 0 203 Run_Out_Cancel 0x000b 253 252 180 Pre-fail Always - 2 204 Shock_Count_Write_Opern 0x000a 253 252 000 Old_age Always - 0 205 Shock_Rate_Write_Opern 0x000a 253 252 000 Old_age Always - 0 207 Spin_High_Current 0x002a 253 252 000 Old_age Always - 0 208 Spin_Buzz 0x002a 253 252 000 Old_age Always - 0 209 Offline_Seek_Performnce 0x0024 147 147 000 Old_age Offline - 0 99 Unknown_Attribute 0x0004 253 253 000 Old_age Offline - 0 100 Unknown_Attribute 0x0004 253 253 000 Old_age Offline - 0 101 Unknown_Attribute 0x0004 253 253 000 Old_age Offline - 0 SMART Error Log Version: 1 ATA Error Count: 855 (device log contains only the most recent five errors) CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 855 occurred at disk power-on lifetime: 5422 hours (225 days + 22 hours) When the command that caused the error occurred, the device was in an unknown state. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 01 8d 99 fb e0 Error: UNC 1 sectors at LBA = 0x00fb998d = 16488845 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 25 00 02 8d 99 fb e0 08 02:04:56.832 READ DMA EXT 25 00 02 8d 99 fb e0 08 02:04:55.776 READ DMA EXT 25 00 08 12 0a 70 e0 08 02:04:55.744 READ DMA EXT 25 00 08 da 09 44 e0 08 02:04:55.744 READ DMA EXT 35 00 10 ca 09 1c e0 08 02:04:55.712 WRITE DMA EXT Error 854 occurred at disk power-on lifetime: 5422 hours (225 days + 22 hours) When the command that caused the error occurred, the device was in an unknown state. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 02 8d 99 fb e0 Error: UNC 2 sectors at LBA = 0x00fb998d = 16488845 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 25 00 02 8d 99 fb e0 08 02:04:55.776 READ DMA EXT 25 00 08 12 0a 70 e0 08 02:04:55.744 READ DMA EXT 25 00 08 da 09 44 e0 08 02:04:55.744 READ DMA EXT 35 00 10 ca 09 1c e0 08 02:04:55.712 WRITE DMA EXT 35 00 08 ca 09 14 e0 08 02:04:55.712 WRITE DMA EXT Error 853 occurred at disk power-on lifetime: 5422 hours (225 days + 22 hours) When the command that caused the error occurred, the device was in an unknown state. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 ce 8d 99 fb e0 Error: UNC 206 sectors at LBA = 0x00fb998d = 16488845 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 25 00 ce 8d 99 fb e0 08 02:04:52.656 READ DMA EXT 25 00 d0 8b 99 fb e0 08 02:04:51.456 READ DMA EXT 25 00 d2 89 99 fb e0 08 02:04:50.224 READ DMA EXT 25 00 d4 87 99 fb e0 08 02:04:49.040 READ DMA EXT 25 00 d6 85 99 fb e0 08 02:04:47.824 READ DMA EXT Error 852 occurred at disk power-on lifetime: 5422 hours (225 days + 22 hours) When the command that caused the error occurred, the device was in an unknown state. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 cf 8b 99 fb e0 Error: UNC 207 sectors at LBA = 0x00fb998b = 16488843 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 25 00 d0 8b 99 fb e0 08 02:04:51.456 READ DMA EXT 25 00 d2 89 99 fb e0 08 02:04:50.224 READ DMA EXT 25 00 d4 87 99 fb e0 08 02:04:49.040 READ DMA EXT 25 00 d6 85 99 fb e0 08 02:04:47.824 READ DMA EXT 25 00 d8 83 99 fb e0 08 02:04:46.592 READ DMA EXT Error 851 occurred at disk power-on lifetime: 5422 hours (225 days + 22 hours) When the command that caused the error occurred, the device was in an unknown state. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 cf 89 99 fb e0 Error: UNC 207 sectors at LBA = 0x00fb9989 = 16488841 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 25 00 d2 89 99 fb e0 08 02:04:50.224 READ DMA EXT 25 00 d4 87 99 fb e0 08 02:04:49.040 READ DMA EXT 25 00 d6 85 99 fb e0 08 02:04:47.824 READ DMA EXT 25 00 d8 83 99 fb e0 08 02:04:46.592 READ DMA EXT 25 00 da 81 99 fb e0 08 02:04:45.392 READ DMA EXT SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed: read failure 40% 5419 33265660 # 2 Short offline Completed without error 00% 5406 - # 3 Extended offline Completed without error 00% 4644 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
