* [CLOC] [MEMC] [ITLB] [COPY] [CODE] [DATA] [JRAM] [CACH] [SIGN] Uncompressing DBL 1... [ZBSS] [CREG] [MAIN] Kreatel IP-STB booting... Firmware built Jul 24 2006 15:17:54, v1.34b6 IDT5V9885: EEPROM was already up-to-date Using framebuffer at 0x07800000 (8192 kB) Active mode Kreatel IP-STB @ 300 MHz (333 MHz, CL 2.5), 131072 kB RAM Booted in 478 msecs. Found ATI Xilleon X210 NAND flash support detected. Probing... Found flash on CS1: ST NAND128W3A (16777216 bytes) Found flash on CS0: ST NAND128W3A (16777216 bytes) flash: Block 729 on CS1 is marked invalid and is not used Found National DP83815 at 0x2000, ROM address 0x00000000 Probing...[DP83815] National DP83815: MAC addr 00:02:9B:32:D3:1D National DP83815: Setting 100 Mbit full-duplex Infocast HW ID = kreatel-ip-stb-rev-10 Searching for server (DHCP)... -\Me: 192.168.85.160, Server: 192.168.85.10, Gateway 192.168.85.1 Splash boot order: 2 Kernel boot order: 2 Bootcast address : 224.2.2.2:22222 Sap address : 224.2.127.254:9875 Sap HW ID : ip-stb_1710 ***** Loading splash image ***** Using TFTP Name: splash-1710 Server: 192.168.85.10 |/TFTP error 1 (File not found) TFTP: Failed! Skipping splash! ***** Loading kernel image ***** Using TFTP TFTP: Downloading... Name: kernel-1710 Server: 192.168.85.10 -\|(ELF)... /-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/done loaded at: 82000000 821077A8 zimage at: 8200F000 821077A6 Uncompressing Linux at load address 80100000 Booting linux kernel LINUX started... ATI Xilleon 210 (little endian), Solo mode PCI bus speed is 33MHz Initializing IRQs memsize: 112MB CPU revision is: 00018448 Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes. Primary data cache 16kB, 4-way, linesize 16 bytes. Linux version 2.4.30 (root@interceptor) (gcc version 3.4.6 (Debian 3.4.6-9)) #17 Wed Jun 16 21:08:44 UTC 2010 Start xilleon_setup... Determined physical RAM map: memory: 00080000 @ 00000000 (ROM data) memory: 00080000 @ 00080000 (reserved) memory: 06f00000 @ 00100000 (usable) Initial ramdisk at: 0x80341000 (0 bytes) On node 0 totalpages: 28672 zone(0): 28672 pages. zone(1): 0 pages. zone(2): 0 pages. Kernel command line: root=/dev/nfs rw ip=192.168.85.160:192.168.85.10:192.168.85.1:255.255.255.0 rbl=1 dbl=1 bch=224.2.2.2:22222 ramsize=131072 last_key=none nfsroot=192.168.85.10:/opt/sdb1/vip1710 serverid=192.168.85.10 console=ttyS0,115200,n,8,1 calculating r4koff... 0016dd03(1498371) with HZ(100) CPU frequency 299.67 MHz Using 149.837 MHz high precision timer. Console: colour dummy device 80x25 Calibrating delay loop... 299.00 BogoMIPS Memory: 109888k/113664k available (2028k kernel code, 3776k reserved, 136k data, 124k init, 0k highmem) Dentry cache hash table entries: 16384 (order: 5, 131072 bytes) Inode cache hash table entries: 8192 (order: 4, 65536 bytes) Mount cache hash table entries: 512 (order: 0, 4096 bytes) Buffer cache hash table entries: 4096 (order: 2, 16384 bytes) Page-cache hash table entries: 32768 (order: 5, 131072 bytes) Checking for 'wait' instruction... available. POSIX conformance testing by UNIFIX Autoconfig PCI channel 0x8033fdd8 Scanning bus 00, I/O 0x00002000:0x00010001, Mem 0x10000000:0x18000001 00:11.0 Class 0c03: 1033:0035 (rev 43) Mem at 0x10000000 [size=0x1000] 00:11.1 Class 0c03: 1033:0035 (rev 43) Mem at 0x10001000 [size=0x1000] 00:11.2 Class 0c03: 1033:00e0 (rev 04) Mem at 0x10002000 [size=0x100] 00:12.0 Class 0000: 104c:9065 (rev 01) Mem at 0x10400000 [size=0x400000] Mem at 0x10800000 [size=0x800000] I/O at 0x00002000 [size=0x10] 00:13.0 Class 0200: 100b:0020 I/O at 0x00002100 [size=0x100] Mem at 0x11000000 [size=0x1000] 00:14.0 Class 0480: 1002:4860 (rev 02) Mem unavailable -- skipping I/O at 0x00002200 [size=0x100] Mem at 0x11008000 [size=0x8000] Mem at 0x1c000000 [size=0x4000000] 00:14.1 Class 0101: 1002:4861 (rev 01) I/O at 0x00002300 [size=0x8] I/O at 0x00002308 [size=0x4] I/O at 0x00002310 [size=0x8] I/O at 0x00002318 [size=0x4] I/O at 0x00002320 [size=0x10] 00:14.2 Class 0c03: 1002:4862 (rev 0a) Mem at 0x11010000 [size=0x1000] 00:14.5 Class 0401: 1002:4863 (rev 01) Mem at 0x11011000 [size=0x100] 00:14.6 Class 0703: 1002:4864 (rev 01) Mem at 0x11011100 [size=0x100] irq fixup slot 17 vendor 1033 irq 33 irq fixup slot 17 vendor 1033 irq 34 irq fixup slot 17 vendor 1033 irq 35 irq fixup slot 18 vendor 104c irq 33 irq fixup slot 19 vendor 100b irq 33 Linux NET4.0 for Linux 2.4 Based upon Swansea University Computer Society NET3.039 Initializing RT netlink socket Starting kswapd Journalled Block Device driver loaded devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au) devfs: boot_options: 0x1 JFFS2 version 2.1. (C) 2001 Red Hat, Inc., designed by Axis Communications AB. Xilleonfb: Xilleon Framebuffer Driver Xilleonfb: Initial framebuffer at 0x0f800000, mapped to af800000, size 8388608 Console: switching to colour frame buffer device 90x36 Dummy keyboard driver installed. pty: 256 Unix98 ptys configured Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled ttyS00 at 0xbe000010 (irq = 100) is a 16550A ttyS01 at 0xbe000000 (irq = 99) is a 16550A ttyS02 at 0xbe000020 (irq = 122) is a 16550A Kboxdev: registered device with major 120 Software Watchdog Timer: 0.05, timer margin: 60 sec RAMDISK driver initialized: 16 RAM disks of 32768K size 1024 blocksize natsemi dp8381x driver, version 1.07+LK1.0.17, Sep 27, 2002 originally by Donald Becker http://www.scyld.com/network/natsemi.html 2.4.x kernel port by Jeff Garzik, Tjeerd Mulder eth0: NatSemi DP8381[56] at 0xb1000000, 00:02:9b:32:d3:1d, IRQ 33. SCSI subsystem driver Revision: 1.00 Xilleonfb: Xilleon Framebuffer Driver Xilleonfb: Unable to reserve framebuffer at 0xf800000 usb.c: registered new driver usbdevfs usb.c: registered new driver hub ehci_hcd 00:11.2: PCI device 1033:00e0 ehci_hcd 00:11.2: irq 35, pci mem b0002000 usb.c: new USB bus registered, assigned bus number 1 ehci_hcd 00:11.2: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4 hub.c: USB hub found hub.c: 5 ports detected usb.c: registered new driver hid hid-core.c: v1.8.1 Andreas Gal, Vojtech Pavlik hid-core.c: USB HID support drivers Initializing USB Mass Storage driver... usb.c: registered new driver usb-storage USB Mass Storage support registered. mice: PS/2 mouse device common for all mice NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP, IGMP IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 8192 bind 16384) eth0: link up. eth0: Setting full-duplex based on negotiated link capability. IP-Config: Complete: device=eth0, addr=192.168.85.160, mask=255.255.255.0, gw=192.168.85.1, host=192.168.85.160, domain=, nis-domain=(none), bootserver=192.168.85.10, rootserver=192.168.85.10, rootpath= ip_tables: (C) 2000-2002 Netfilter core team NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. RAMDISK: Couldn't find valid RAM disk image starting at 0. Looking up port of RPC 100003/2 on 192.168.85.10 Looking up port of RPC 100005/1 on 192.168.85.10 VFS: Mounted root (nfs filesystem). Mounted devfs on /dev Freeing unused kernel memory: 124k freed Algorithmics/MIPS FPU Emulator v1.5 INIT: version 2.86 booting * Filesystem type 'devpts' is not supported. Skipping mount. Activating swap...done. Cleaning up ifupdown.... Loading device-mapper support. Checking file systems...fsck 1.40-WIP (14-Nov-2006) WARNING: Your /etc/fstab does not contain the fsck passno field. I will kludge around things for you, but you should fix your /etc/fstab file as soon as you can. done. Setting kernel variables...done. Mounting local filesystems...done. Activating swapfile swap...done. Setting up networking.... Configuring network interfaces...done. INIT: Entering runlevel: 2 Starting system log daemon: syslogd. Starting kernel log daemon: klogd. * Not starting internet superserver: no services enabled. Starting OpenBSD Secure Shell server: sshd. Starting periodic command scheduler: crond. Debian GNU/Linux 4.0 mediamall tts/0 mediamall login: >> dm642pci_fxn_probe - Revision ID = 1 >> dm642pci_fxn_probe - Interrupt Line = 33 >> dm642pci_fxn_probe - PCI Device Enabled >> dm642pci_fxn_probe - Mapping MEM Space to Kernel Phys = 0x10400000 >> dm642pci_fxn_probe - Mapping MEM Space to Kernel Phys = 0x10800000 >> drvPciDm642ModuleInit - Requesting IRQ, irqId = 33
