.include "m8def.inc" .cseg .org 0 ;------------------------------------------------------------------------------- ; Reset and Interrupt vector ;VNr. Beschreibung ;------------------------------------------------------------------------------- .org 0x000 rjmp main .org INT0addr ; External Interrupt0 Vector Address reti .org INT1addr ; External Interrupt1 Vector Address reti .org OC2addr ; Output Compare2 Interrupt Vector Address reti .org OVF2addr ; Overflow2 Interrupt Vector Address reti .org ICP1addr ; Input Capture1 Interrupt Vector Address reti .org OC1Aaddr ; Output Compare1A Interrupt Vector Address rjmp TIMER .org OC1Baddr ; Output Compare1B Interrupt Vector Address reti .org OVF1addr ; Overflow1 Interrupt Vector Address reti .org OVF0addr ; Overflow0 Interrupt Vector Address reti .org SPIaddr ; SPI Interrupt Vector Address reti .org URXCaddr ; USART Receive Complete Interrupt Vector Address reti .org UDREaddr ; USART Data Reg. Empty Interr. Vector Address reti .org UTXCaddr ; USART Transmit Complete Interrupt Vector Address reti .org ADCCaddr ; ADC Interrupt Vector Address reti .org ERDYaddr ; EEPROM Interrupt Vector Address reti .org ACIaddr ; Analog Comparator Interrupt Vector Address reti .org TWIaddr ; Irq. vector address for Two-Wire Interface reti .org INT_VECTORS_SIZE .equ XTAL = 3686400;H ;------------------------------------------------------------------------------- ; Start, Power ON, Reset ;------------------------------------------------------------------------------- main: ldi r16, LOW(RAMEND) ; Stackpointer initialisieren out SPL, r16 ldi r16, HIGH(RAMEND) out SPH, r16 ldi r16, high( 7200 - 1 ) out OCR1AH, r16 ldi r16, low( 7200 - 1 ) out OCR1AL, r16 ldi r16, ( 1 << WGM12 ) | ( 1 << CS12 ) out TCCR1B, r16 ldi r16, 1 << OCIE1A ; OCIE1A: Interrupt bei Timer Compare out TIMSK, r16 sei ldi r16,0 sts B100,r16 sts B001,r16 sts B002,r16 sts B003,r16 cbi DDRD,2 ;Eingang "Quittierung" sbi PORTD,2 ;Pull Up cbi DDRD,3 ;Eingang "Auslösen" sbi PORTD,3 ;Pull Up cbi DDRD,4 ;Eingang "Überwachung" sbi PORTD,4 ;Pull Up cbi DDRD,5 ;Eingang "Extern-Error" sbi PORTD,5 ;Pull Up cbi DDRD,6 ;Eingang "Extern-Ein/Aus" sbi PORTD,6 ;Pull Up sbi DDRB,0 ;Ausgang "Steuerspannung" sbi DDRB,1 ;Ausgang "Zeitmessungs-LED" sbi DDRB,2 ;Ausgang "Betriebsbereit" sbi DDRB,3 ;Ausgang "Störungs LED" sbi DDRB,4 ;Ausgang "Taster-LED" sbi DDRB,5 ;Ausgang " Test " cbi PORTB,0 ;schalte "Steuerspannung" ein ;------------------------------------------------------------------------------- mainloop: rcall Zeitmessung rcall Output rcall Futterpause rjmp mainloop ;------------------------------------------------------------------------------- Zeitmessung:lds r16,B100 lds r17,B001 lds r18,B002 sbis PIND,4 ; Messeingang wenn 1, rjmp A_03 ; dann spring zu A_03 sbis PIND,2 ; Quittiertaste wenn betätigt wird, andi r17,0b11111110 ; dann lösche Time out bit sbis PIND,2 ; Quittiertaste wenn betätigt wird, ldi r18,0 ; dann lösche Timerregister A_03: sbic PIND,4 ; Messeingang wenn nicht 1, ldi r18,0 ; dann setze Timer(Zähler) zurück sbrc r17,0 ; Wenn Time out bit gesetzt, rjmp A_01 ; dann spring zu A_01 sbis PIND,3 ; Auslösetaste auf Patine wenn betätigt, ori r17,0b00000001 ; dann setze Time out bit sbis PIND,3 andi r17,0b11110111 sbic PIND,4 ; Überwachungseingang wenn 0, rjmp A_01 ; dann spring zu A_01 sbrs r16,0 ; Timer bit 0 (0,5sec Takt) 0, rjmp A_01 ; dann sping zu A_01 sbrc r17,1 ; Flankenauswertung für Timer rjmp A_01 ori r17,0b00000010 inc r18 ; Timer wird je sec um 1 erhöht A_01: sbrs r16,0 ; Flankenauswertung für Timer andi r17,0b11111101 cpi r18,240 ; Zähler wird ausgewertet (240sec.) brne A_02 ; Wenn nicht 240, spirng zu A_02 ori r17,0b00000001 andi r17,0b11110111 ldi r18,0 A_02: sts B001,r17 sts B002,r18 ret ;------------------------------------------------------------------------------- Output: lds r16,B100 lds r17,B001 sbrc r17,1 ; Zeitmessungs LED sbi PORTB,1 ; " sbrs r17,1 ; " cbi PORTB,1 ; " sbrc r17,0 rjmp B_01 sbi PORTB,2 sbrs r17,3 cbi PORTB,0 rjmp B_02 B_01: cbi PORTB,2 sbi PORTB,0 B_02: sbis PIND,2 cbi PORTB,3 sbrs r17,0 rjmp B_03 sbrs r16,0 cbi PORTB,3 sbrc r16,0 sbi PORTB,3 B_03: sbrc r17,0 cbi PORTB,4 sbrc r17,0 rjmp B_04 sbrs r17,3 rjmp B_04 sbrs r16,0 cbi PORTB,4 sbrc r16,0 sbi PORTB,4 B_04: sts B001,r17 ret ;------------------------------------------------------------------------------- Futterpause:lds r16,B100 lds r17,B001 lds r18,B003 sbic PIND,6 rjmp C_01 sbrc r17,0 andi r17,0b11110111 sbrc r17,0 rjmp C_01 rcall wait_1ms sbrc r17,2 rjmp C_01 ori r17,0b00000100 sbrs r17,3 rjmp C_02 andi r17,0b11110111 cbi PORTB,3 cbi PORTB,4 rjmp C_01 C_02: ori r17,0b00001000 sbi PORTB,0 sbi PORTB,3 C_01: sbis PIND,6 rjmp C_03 sbrs r17,2 rjmp C_03 rcall wait_1ms andi r17,0b11111011 C_03: sbrs r17,3 rjmp C_04 sbrs r16,2 rjmp C_04 sbrc r17,4 rjmp C_04 ori r17,0b00010000 inc r18 C_04: sbrs r16,2 andi r17,0b11101111 C_05: cpi r18,150 brne C_06 ldi r18,0 andi r17,0b11110111 cbi PORTB,3 cbi PORTB,4 C_06: sts B001,r17 sts B003,r18 ret ;------------------------------------------------------------------------------- wait_1ms: push r16 push r17 wait_1ms_1: inc r16 brne wait_1ms_1 inc r17 cpi r17,5 brne wait_1ms_1 ldi r17,0 pop r17 pop r16 ret ;------------------------------------------------------------------------------- TIMER: push r16 lds r16,B100 inc r16 sts B100,r16 pop r16 reti ;------------------------------------------------------------------------------- .dseg B100: .byte 1 ; wird im Interrupt behandelt B001: .byte 1 ; Statusregister 1 ; Bit 0: time out Messung oder Test von Taster ; Bit 1: Zeitmessungsflanke und LED Zeitmessung ; Bit 2: Flankenauswertung Taster Futterpause ; Bit 3: Futterpause und Störungs LED ein bei 1 ; Bit 4: Flankenauswertung Timer 10min. ; Bit 5: ; Bit 6: ; Bit 7: B002: .byte 1 ; Timerregister 60sec. B003: .byte 1 ; Timerregister 10min.
