library IEEE; use IEEE.STD_LOGIC_1164.ALL; use ieee.numeric_std.all; entity SDModulator is -- Ports Anlegen-- port ( dIn: in unsigned (9 downto 0); clk: in std_logic; dOut: out std_logic ); end SDModulator; architecture Modulator of SDModulator is -- Hilfssignale anlegen-- signal dIn_temp: unsigned (10 downto 0); signal dIn_neu: unsigned (10 downto 0); signal dIn_alt: unsigned (10 downto 0); signal dOutm: unsigned (9 downto 0); signal Q: unsigned (10 downto 0); signal dOut_read: signed; signal dIn_un: unsigned (9 downto 0); begin -- Signale mit '0' initalisieren -- doutm <= (others => '0'); din_alt <= (others => '0'); Differenz: process (dIn, dOutm) -- Differenzbildung am 1. Knoten -- begin dIn_temp <= dIn - dOutm & '0'; end process Differenz; Addiere: process (dIn_temp, dIn_alt) -- Addition am 2. Knoten -- begin dIn_neu <= dIn_temp + dIn_alt; end process Addiere; Flipflop: process (clk, din_neu) -- Erzeugen des D-FlipFlop zum Zwischenspeichern -- begin if clk ='1' and clk'event then Q <= din_neu after 40 ps; din_alt <= Q; else Q <= "00000000000"; end if; end process flipflop; --Hier ist das Problem, da man bei unsigned nicht das bit herausfiltern kann-- Komperator: process (din_alt) -- Herausfiltern des MSBit -- begin dout_read <= din_alt (10); end process Komperator; Auffuellen: process (dout_read) -- Erzeugen eines 10 Bit Vektors aus dem Bitstrom -- begin case dout_read is when '0' => doutm <= "0000000000"; when '1' => doutm <= "1111111111"; end case; end process Auffuellen; dout <= std_logic (dout_read); end Modulator;
