Coolpix MC-EU1 Protocol Here are some informations about the serial protocol used between the Coolpix and the MC-EU1 remote. Speed is set to 19200 bauds * Introduction This protocol use 1 or 4 bytes "packets". 4 bytes packets are used to send command to the coolpix and receive information from it. 1 byte packet are used as acknowledge (0x86), not acknowledge (0x15), "attention packet" (0xFF). Each byte in these packet is divided in two part, bit 0-6 is the value on 7 bits and bit 7 is the odd parity bit (thanks Mark Roberts !) Returned value by the coolpix (in the two or three? last byte) have 0x1C offset, and least signifiant byte is sent first, for example the number of picture is : nb picture = ((byte[2] & 0x7F) - 0x1C) + 100 * ((byte[3] & 0x7F) - 0x1C) byte[0] == 0x9B, byte[1] == 0x10 * Going to MC-EU1 protocol Send Receive Informations 0x00 0x15 0x1B,0x53,0x06,0x00,0x00,0x11,0x02,0x00,0x00,0x00,0x13,0x00 Standard SetSpeed to 19200 command packet 0x06 0x1B,0x53,0x06,0x00,0x00,0x11,0x02,0x00,0x00,0x10,0x23,0x00 Go to MC-EU1 protocol packet, switch LCD ON 0x06 At first connection after Coolpix has been powerup, first 0x00 don't work, coolpix respond 0xFF 0xFF then nothing A second 0x00 do the job. * Initialisations Need more informations... Send Receive Informations 0x9B, 0x85, 0x1C, 0x1C 0x9B, 0x13, 0x1C, 0x1C ? 0x86 * Has camera power down ? Send Receive Informations 0x9B, 0x08, 0x1C, 0x1C 0x9B, 0x92, 0x7F, 0x7F Coolpix is ON or 0x9B, 0x19, 0x7F, 0x7F Coolpix powerdown. 0x86 * Take a shoot : Send Receive Informations 0x9B, 0x01, 0x1C, 0x1C Half press the shutter button. 0x86 0x9B, 0x01, 0x7F, 0x1C Full press the shutter button, take the picture 0x86 0x9B, 0x01, 0x7F, 0x7F Release the shutter button, usefull in bulb mode 0x8F 0x9B, 0x01, 0x1C, 0x7F Half press release (unlock shutter button). 0x86 * Zoom IN Send Receive Informations 0x9B, 0x02, 0x1C, 0x1C "Press" the zoom in button 0x86 0x9B, 0x02, 0x1C, 0x7F "Release" the zoom in button 0x86 * Zoom OUT Send Receive Informations 0x9B, 0x02, 0x7F, 0x1C "Press" the zoom out button 0x86 0x9B, 0x02, 0x7F, 0x7F "Release" the zoom out button 0x86 * Next picture Send Receive Informations 0x9B, 0x04, 0x1C, 0x1C "Press" right 0x86 0x9B, 0x04, 0x1C, 0x7F "Release" right 0x86 * Previous picture Send Receive Informations 0x9B, 0x04, 0x7F, 0x1C "Press" left 0x86 0x9B, 0x04, 0x7F, 0x7F "Release" left 0x86 * Number of picture left Send Receive Informations 0x9B, 0x07, 0x1C, 0x1C 0x9B, 0x10, 0xXX, 0xYY (0xXX & 0x7F) - 0x1C + 100 * ((0xYY & 0x7F) - 0x1C) is the number of pictures left 0x86 * A-REC/M-Rec Send Receive Informations 0x9B, 0x89, 0x1C, 0x1C 0x9B, 0x91, 0x9D, 0x7F for A Rec mode or 0x9B, 0x91, 0x0D, 0x1C for M Rec mode or 0x9B, 0x91, 0x7F, 0x9D for play mode 0x86 * Go back to standard protocol Send Receive Informations 0x9B, 0x8A, 0x1C, 0x1C LCD OFF 0x86 * "Attention" packet 0xFF from coolpix Coolpix send 0xFF in many cases : - After initialisation in response to 0x00. - When Coolpix self powerdown (powersave) - When Coolpix is powerdown - When a picture has been recorded - When mode selector is operated (A-Rec, M-Rec, Play) It's a good idea to send 0x9B, 0x08, 0x1C, 0x1C packet to check if coolpix has powerdown when a 0xFF is received, else check the picture number and current mode. * Notes - Camera send NAK (0x15) in response to bad command packet - You may send any useful informations about this protocol to : vladimir.vyskocil@wanadoo.fr
