* @file startup_stm32f10x_cl.c
* @author MCD Application Team,
* @version V3.0.0
* @date 01. April 2010
* @brief STM32F10x Medium Density Devices vector table for GNU toolchain.
* This module performs:
* - Set the initial SP
* - Set the initial PC == Reset_Handler,
* - Set the vector table entries with the exceptions ISR address,
* - Branches to main in the C library (which eventually
* calls main()).
* After Reset the Cortex-M3 processor is in Thread mode,
* priority is Privileged, and the Stack is set to Main.
* @copy
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
© COPYRIGHT 2009 STMicroelectronics
/* Modified by Martin Thomas
- to take VECT_TAB_RAM setting into account, also see the linker-script
- to avoid warning "ISO C forbids initialization between function pointer and 'void *'".
- added optional startup-delay to avoid unwanted operations while connecting with
debugger/programmer
- tested with the GNU arm-eabi toolchain as in CS G++ lite Q1/2009-161
- minor modification in .data copy to avoid copy while "run from RAM"
during debugging
/* Includes ------------------------------------------------------------------*/
/* Private typedef -----------------------------------------------------------*/
typedef void( *const intfunc )( void );
/* Private define ------------------------------------------------------------*/
#define WEAK __attribute__ ((weak))
/* Private macro -------------------------------------------------------------*/
extern unsigned long _etext;
/* start address for the initialization values of the .data section.
defined in linker script */
extern unsigned long _sidata;
/* start address for the .data section. defined in linker script */
extern unsigned long _sdata;
/* end address for the .data section. defined in linker script */
extern unsigned long _edata;
/* start address for the .bss section. defined in linker script */
extern unsigned long _sbss;
/* end address for the .bss section. defined in linker script */
extern unsigned long _ebss;
/* init value for the stack pointer. defined in linker script */
extern unsigned long _estack;
/* Emul Eeprom start address. defined in linker script */
extern unsigned long _seemul2;
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
void Reset_Handler(void) __attribute__((__interrupt__));
void __Init_Data(void);
void Default_Handler(void);
/* External function prototypes ----------------------------------------------*/
extern int main(void); /* Application's main function */
extern void __libc_init_array(void); /* calls CTORS of static objects */
* Forward declaration of the default fault handlers.
//mthomas void WEAK Reset_Handler(void);
void WEAK NMI_Handler(void);
void WEAK HardFault_Handler(void);
void WEAK MemManage_Handler(void);
void WEAK BusFault_Handler(void);
void WEAK UsageFault_Handler(void);
//mthomas void WEAK MemManage_Handler(void);
void WEAK SVC_Handler(void);
void WEAK DebugMon_Handler(void);
void WEAK PendSV_Handler(void);
void WEAK SysTick_Handler(void);
/* External Interrupts */
void WEAK WWDG_IRQHandler(void);
void WEAK PVD_IRQHandler(void);
void WEAK TAMPER_IRQHandler(void);
void WEAK RTC_IRQHandler(void);
void WEAK FLASH_IRQHandler(void);
void WEAK RCC_IRQHandler(void);
void WEAK EXTI0_IRQHandler(void);
void WEAK EXTI1_IRQHandler(void);
void WEAK EXTI2_IRQHandler(void);
void WEAK EXTI3_IRQHandler(void);
void WEAK EXTI4_IRQHandler(void);
void WEAK DMA1_Channel1_IRQHandler(void);
void WEAK DMA1_Channel2_IRQHandler(void);
void WEAK DMA1_Channel3_IRQHandler(void);
void WEAK DMA1_Channel4_IRQHandler(void);
void WEAK DMA1_Channel5_IRQHandler(void);
void WEAK DMA1_Channel6_IRQHandler(void);
void WEAK DMA1_Channel7_IRQHandler(void);
void WEAK ADC1_2_IRQHandler(void);
//void WEAK USB_HP_CAN1_TX_IRQHandler(void);
//void WEAK USB_LP_CAN1_RX0_IRQHandler(void);
void WEAK CAN1_TX_IRQHandler(void);
void WEAK CAN1_RX0_IRQHandler(void);
void WEAK CAN1_RX1_IRQHandler(void);
void WEAK CAN1_SCE_IRQHandler(void);
void WEAK EXTI9_5_IRQHandler(void);
void WEAK TIM1_BRK_IRQHandler(void);
void WEAK TIM1_UP_IRQHandler(void);
void WEAK TIM1_TRG_COM_IRQHandler(void);
void WEAK TIM1_CC_IRQHandler(void);
void WEAK TIM2_IRQHandler(void);
void WEAK TIM3_IRQHandler(void);
void WEAK TIM4_IRQHandler(void);
void WEAK I2C1_EV_IRQHandler(void);
void WEAK I2C1_ER_IRQHandler(void);
void WEAK I2C2_EV_IRQHandler(void);
void WEAK I2C2_ER_IRQHandler(void);
void WEAK SPI1_IRQHandler(void);
void WEAK SPI2_IRQHandler(void);
void WEAK USART1_IRQHandler(void);
void WEAK USART2_IRQHandler(void);
void WEAK USART3_IRQHandler(void);
void WEAK EXTI15_10_IRQHandler(void);
void WEAK RTCAlarm_IRQHandler(void);
//void WEAK USBWakeUp_IRQHandler(void);
void WEAK OTG_FS_WKUP_IRQHandler(void);
void WEAK TIM5_IRQHandler(void);
void WEAK SPI3_IRQHandler(void);
void WEAK UART4_IRQHandler(void);
void WEAK UART5_IRQHandler(void);
void WEAK TIM6_IRQHandler(void);
void WEAK TIM7_IRQHandler(void);
void WEAK DMA2_Channel1_IRQHandler(void);
void WEAK DMA2_Channel2_IRQHandler(void);
void WEAK DMA2_Channel3_IRQHandler(void);
void WEAK DMA2_Channel4_IRQHandler(void);
void WEAK DMA2_Channel5_IRQHandler(void);
void WEAK ETH_IRQHandler(void);
void WEAK ETH_WKUP_IRQHandler(void);
void WEAK CAN2_TX_IRQHandler(void);
void WEAK CAN2_RX0_IRQHandler(void);
void WEAK CAN2_RX1_IRQHandler(void);
void WEAK CAN2_SCE_IRQHandler(void);
void WEAK OTG_FS_IRQHandler(void);
/* Private functions ---------------------------------------------------------*/
* mthomas: If been built with VECT_TAB_RAM this creates two tables:
* (1) a minimal table (stack-pointer, reset-vector) used during startup
* before relocation of the vector table using SCB_VTOR
* (2) a full table which is copied to RAM and used after vector relocation
* (NVIC_SetVectorTable)
* If been built without VECT_TAB_RAM the following comment from STM is valid:
* The minimal vector table for a Cortex M3. Note that the proper constructs
* must be placed on this to ensure that it ends up at physical address
* 0x0000.0000.
#ifdef VECT_TAB_RAM
__attribute__ ((section(".isr_vectorsflash")))
void (* const g_pfnVectorsStartup[])(void) =
(intfunc)((unsigned long)&_estack), /* The initial stack pointer during startup */
Reset_Handler, /* The reset handler during startup */
__attribute__ ((section(".isr_vectorsram")))
void (* g_pfnVectors[])(void) =
#else /* VECT_TAB_RAM */
void (* const g_pfnVectors[])(void) =
#endif /* VECT_TAB_RAM */
(intfunc)((unsigned long)&_estack), /* The stack pointer after relocation */
Reset_Handler, /* Reset Handler */
NMI_Handler, /* NMI Handler */
HardFault_Handler, /* Hard Fault Handler */
MemManage_Handler, /* MPU Fault Handler */
BusFault_Handler, /* Bus Fault Handler */
UsageFault_Handler, /* Usage Fault Handler */
0, /* Reserved */
0, /* Reserved */
0, /* Reserved */
0, /* Reserved */
SVC_Handler, /* SVCall Handler */
DebugMon_Handler, /* Debug Monitor Handler */
0, /* Reserved */
PendSV_Handler, /* PendSV Handler */
SysTick_Handler, /* SysTick Handler */
WWDG_IRQHandler, /* Window Watchdog */
PVD_IRQHandler, /* PVD through EXTI Line detect */
TAMPER_IRQHandler, /* Tamper */
RTC_IRQHandler, /* RTC */
FLASH_IRQHandler, /* Flash */
RCC_IRQHandler, /* RCC */
EXTI0_IRQHandler, /* EXTI Line 0 */
EXTI1_IRQHandler, /* EXTI Line 1 */
EXTI2_IRQHandler, /* EXTI Line 2 */
EXTI3_IRQHandler, /* EXTI Line 3 */
EXTI4_IRQHandler, /* EXTI Line 4 */
DMA1_Channel1_IRQHandler, /* DMA1 Channel 1 */
DMA1_Channel2_IRQHandler, /* DMA1 Channel 2 */
DMA1_Channel3_IRQHandler, /* DMA1 Channel 3 */
DMA1_Channel4_IRQHandler, /* DMA1 Channel 4 */
DMA1_Channel5_IRQHandler, /* DMA1 Channel 5 */
DMA1_Channel6_IRQHandler, /* DMA1 Channel 6 */
DMA1_Channel7_IRQHandler, /* DMA1 Channel 7 */
ADC1_2_IRQHandler, /* ADC1 & ADC2 */
CAN1_TX_IRQHandler, /* CAN1 TX */
CAN1_RX0_IRQHandler, /* CAN1 RX0 */
CAN1_RX1_IRQHandler, /* CAN1 RX1 */
CAN1_SCE_IRQHandler, /* CAN1 SCE */
EXTI9_5_IRQHandler, /* EXTI Line 9..5 */
TIM1_BRK_IRQHandler, /* TIM1 Break */
TIM1_UP_IRQHandler, /* TIM1 Update */
TIM1_TRG_COM_IRQHandler, /* TIM1 Trigger and Commutation */
TIM1_CC_IRQHandler, /* TIM1 Capture Compare */
TIM2_IRQHandler, /* TIM2 */
TIM3_IRQHandler, /* TIM3 */
TIM4_IRQHandler, /* TIM4 */
I2C1_EV_IRQHandler, /* I2C1 Event */
I2C1_ER_IRQHandler, /* I2C1 Error */
I2C2_EV_IRQHandler, /* I2C2 Event */
I2C2_ER_IRQHandler, /* I2C2 Error */
SPI1_IRQHandler, /* SPI1 */
SPI2_IRQHandler, /* SPI2 */
USART1_IRQHandler, /* USART1 */
USART2_IRQHandler, /* USART2 */
USART3_IRQHandler, /* USART3 */
EXTI15_10_IRQHandler, /* EXTI Line 15..10 */
RTCAlarm_IRQHandler, /* RTC Alarm through EXTI Line */
OTG_FS_WKUP_IRQHandler, /* USB On-The-Go FS Wakeup through EXTI line interrupt */
0,0,0,0,0,0,0, // reserved
TIM5_IRQHandler, // TIM5 global interrupt 0x0000_0108
SPI3_IRQHandler, // SPI3 global interrupt 0x0000_010C
UART4_IRQHandler, // UART4 global interrupt 0x0000_0110
UART5_IRQHandler, // UART5 global interrupt 0x0000_0114
TIM6_IRQHandler, // TIM6 global interrupt 0x0000_0118
TIM7_IRQHandler, // TIM7 global interrupt 0x0000_011C
DMA2_Channel1_IRQHandler, // DMA2 Channel1 global interrupt 0x0000_0120
DMA2_Channel2_IRQHandler, // DMA2 Channel2 global interrupt 0x0000_0124
DMA2_Channel3_IRQHandler, // DMA2 Channel3 global interrupt 0x0000_0128
DMA2_Channel4_IRQHandler, // DMA2 Channel4 global interrupt 0x0000_012C
DMA2_Channel5_IRQHandler, // DMA2 Channel5 global interrupt 0x0000_0130
ETH_IRQHandler, // Ethernet global interrupt 0x0000_0134
ETH_WKUP_IRQHandler, // Ethernet Wakeup through EXTI line interrupt0x0000_0138
CAN2_TX_IRQHandler, // CAN2 TX interrupts 0x0000_013C
CAN2_RX0_IRQHandler, // CAN2 RX0 interrupts 0x0000_0140
CAN2_RX1_IRQHandler, // CAN2 RX1 interrupt 0x0000_0144
CAN2_SCE_IRQHandler, // CAN2 SCE interrupt 0x0000_0148
OTG_FS_IRQHandler, // USB On The Go FS global interrupt 0x0000_014C
0,0,0,0,0,0,0,0,0,0, // reserved
0,0,0,0,0,0,
(intfunc)0xF1E0F85F /* @0x1E0. This is for boot in RAM mode for
STM32F10x Connectivity Line devices. */
* @brief This is the code that gets called when the processor first
* starts execution following a reset event. Only the absolutely
* necessary set is performed, after which the application
* supplied main() routine is called.
* @param None
* @retval : None
void Reset_Handler(void) {
#ifdef STARTUP_DELAY
volatile unsigned long i;
for (i=0;i<500000;i++) { ; }
#endif
/* Initialize data and bss */
__Init_Data();
/* Call CTORS of static objects */
/// not needed for "pure C":
__libc_init_array();
/* Call the application's entry point.*/
main();
while(1) { ; }
* @brief initializes data and bss sections
* @param None
* @retval : None
void __Init_Data(void) {
unsigned long *pulSrc, *pulDest;
/* Copy the data segment initializers from flash to SRAM */
pulSrc = &_sidata;
pulDest = &_sdata;
if ( pulSrc != pulDest ) {
for(; pulDest < &_edata; ) {
*(pulDest++) = *(pulSrc++);
/* Zero fill the bss segment. */
for(pulDest = &_sbss; pulDest < &_ebss; ) {
*(pulDest++) = 0;
//EEEPROM_START = _seemul2;
* Provide weak aliases for each Exception handler to the Default_Handler.
* As they are weak aliases, any function with the same name will override
* this definition.
#pragma weak MMI_Handler = Default_Handler
#pragma weak MemManage_Handler = Default_Handler
#pragma weak BusFault_Handler = Default_Handler
#pragma weak UsageFault_Handler = Default_Handler
#pragma weak SVC_Handler = Default_Handler
#pragma weak DebugMon_Handler = Default_Handler
#pragma weak PendSV_Handler = Default_Handler
#pragma weak SysTick_Handler = Default_Handler
#pragma weak WWDG_IRQHandler = Default_Handler
#pragma weak PVD_IRQHandler = Default_Handler
#pragma weak TAMPER_IRQHandler = Default_Handler
#pragma weak RTC_IRQHandler = Default_Handler
#pragma weak FLASH_IRQHandler = Default_Handler
#pragma weak RCC_IRQHandler = Default_Handler
#pragma weak EXTI0_IRQHandler = Default_Handler
#pragma weak EXTI1_IRQHandler = Default_Handler
#pragma weak EXTI2_IRQHandler = Default_Handler
#pragma weak EXTI3_IRQHandler = Default_Handler
#pragma weak EXTI4_IRQHandler = Default_Handler
#pragma weak DMA1_Channel1_IRQHandler = Default_Handler
#pragma weak DMA1_Channel2_IRQHandler = Default_Handler
#pragma weak DMA1_Channel3_IRQHandler = Default_Handler
#pragma weak DMA1_Channel4_IRQHandler = Default_Handler
#pragma weak DMA1_Channel5_IRQHandler = Default_Handler
#pragma weak DMA1_Channel6_IRQHandler = Default_Handler
#pragma weak DMA1_Channel7_IRQHandler = Default_Handler
#pragma weak ADC1_2_IRQHandler = Default_Handler
#pragma weak CAN1_TX_IRQHandler = Default_Handler
#pragma weak CAN1_RX0_IRQHandler = Default_Handler
#pragma weak CAN1_RX1_IRQHandler = Default_Handler
#pragma weak CAN1_SCE_IRQHandler = Default_Handler
#pragma weak EXTI9_5_IRQHandler = Default_Handler
#pragma weak TIM1_BRK_IRQHandler = Default_Handler
#pragma weak TIM1_UP_IRQHandler = Default_Handler
#pragma weak TIM1_TRG_COM_IRQHandler = Default_Handler
#pragma weak TIM1_CC_IRQHandler = Default_Handler
#pragma weak TIM2_IRQHandler = Default_Handler
#pragma weak TIM3_IRQHandler = Default_Handler
#pragma weak TIM4_IRQHandler = Default_Handler
#pragma weak I2C1_EV_IRQHandler = Default_Handler
#pragma weak I2C1_ER_IRQHandler = Default_Handler
#pragma weak I2C2_EV_IRQHandler = Default_Handler
#pragma weak I2C2_ER_IRQHandler = Default_Handler
#pragma weak SPI1_IRQHandler = Default_Handler
#pragma weak SPI2_IRQHandler = Default_Handler
#pragma weak USART1_IRQHandler = Default_Handler
#pragma weak USART2_IRQHandler = Default_Handler
#pragma weak USART3_IRQHandler = Default_Handler
#pragma weak EXTI15_10_IRQHandler = Default_Handler
#pragma weak RTCAlarm_IRQHandler = Default_Handler
#pragma weak OTG_FS_WKUP_IRQHandler = Default_Handler
#pragma weak TIM5_IRQHandler = Default_Handler
#pragma weak SPI3_IRQHandler = Default_Handler
#pragma weak UART4_IRQHandler = Default_Handler
#pragma weak UART5_IRQHandler = Default_Handler
#pragma weak TIM6_IRQHandler = Default_Handler
#pragma weak TIM7_IRQHandler = Default_Handler
#pragma weak DMA2_Channel1_IRQHandler = Default_Handler
#pragma weak DMA2_Channel2_IRQHandler = Default_Handler
#pragma weak DMA2_Channel3_IRQHandler = Default_Handler
#pragma weak DMA2_Channel4_IRQHandler = Default_Handler
#pragma weak DMA2_Channel5_IRQHandler = Default_Handler
#pragma weak ETH_IRQHandler = Default_Handler
#pragma weak ETH_WKUP_IRQHandler = Default_Handler
#pragma weak CAN2_TX_IRQHandler = Default_Handler
#pragma weak CAN2_RX0_IRQHandler = Default_Handler
#pragma weak CAN2_RX1_IRQHandler = Default_Handler
#pragma weak CAN2_SCE_IRQHandler = Default_Handler
#pragma weak OTG_FS_IRQHandler = Default_Handler
* @brief This is the code that gets called when the processor receives an
* unexpected interrupt. This simply enters an infinite loop, preserving
* the system state for examination by a debugger.
* @param None
* @retval : None
void Default_Handler(void) {
/* Go into an infinite loop. */
/*while (1) {
asm volatile ("nop");
void NMI_Handler(void) {
void HardFault_Handler(void){
/******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
