library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity dualport_ram is generic ( DATA_WIDTH : natural := 32; ADDR_WIDTH : natural := 3 ); port ( clk : in std_logic; addr_a: in std_logic_vector ((ADDR_WIDTH-1) downto 0); addr_b: in std_logic_vector ((ADDR_WIDTH-1) downto 0); data_a: in std_logic_vector((DATA_WIDTH-1) downto 0); data_b: in std_logic_vector((DATA_WIDTH-1) downto 0); we_a: in std_logic := '1'; we_b: in std_logic := '1'; q_a : out std_logic_vector((DATA_WIDTH -1) downto 0); q_b : out std_logic_vector((DATA_WIDTH -1) downto 0) ); end dualport_ram; architecture rtl of dualport_ram is -- Build a 2-D array type for the RAM subtype word_t is std_logic_vector((DATA_WIDTH-1) downto 0); type memory_t is array((2**ADDR_WIDTH - 1) downto 0) of word_t; -- Declare the RAM signal. signal ram : memory_t; begin process(clk) begin if(rising_edge(clk)) then -- Port A if(we_a = '1') then ram(to_integer(unsigned(addr_a))) <= data_a; -- Read-during-write on the same port returns NEW data q_a <= data_a; else -- Read-during-write on the mixed port returns OLD data q_a <= ram(to_integer(unsigned(addr_a))); end if; end if; end process; process(clk) begin if(rising_edge(clk)) then -- Port B if(we_b = '1') then ram(to_integer(unsigned(addr_b))) <= data_b; -- Read-during-write on the same port returns NEW data q_b <= data_b; else -- Read-during-write on the mixed port returns OLD data q_b <= ram(to_integer(unsigned(addr_b))); end if; end if; end process; end rtl;
