/* * Copyright 2005-2010 Matthias Weisser * * This file is part of Eagle3D * * Eagle3D is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; version 2 of the License. * * Eagle3D is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License * along with this program. If not, see . */ #ifndef(__e3d_tools_inc) #declare __e3d_tools_inc = true; global_settings{charset utf8} //POVRay include files #include "arrays.inc" #include "chars.inc" #include "colors.inc" #include "finish.inc" #include "functions.inc" #include "glass.inc" #include "golds.inc" #include "math.inc" #include "metals.inc" #include "rand.inc" #include "shapes.inc" #include "shapes2.inc" #include "shapesq.inc" #include "skies.inc" #include "stoneold.inc" #include "stones.inc" #include "stones1.inc" #include "stones2.inc" #include "strings.inc" #include "textures.inc" #include "transforms.inc" //Library files #include "e3d_tex.inc" #include "e3d_ic.inc" #include "e3d_resistor.inc" #include "e3d_trafo.inc" #include "e3d_transistor.inc" #include "e3d_connector.inc" #include "e3d_cap.inc" #include "e3d_diode.inc" #include "e3d_special.inc" #include "e3d_socket.inc" #include "e3d_qfp.inc" #include "e3d_switch.inc" //****************************************************************************************************** #if(inc_testmode=true) #declare pin_short = on; #declare pcb_height = 1.500000; #declare pin_length = 2.5; #declare global_res_colselect=1; #declare global_res_col=1; #declare global_res_shape=1; #declare global_res_bend_radius=1; #declare global_diode_bend_radius=1; #declare global_seed=seed(1234); #declare global_show_screws = on; #declare global_show_washers = on; #declare global_show_nuts = on; #declare global_ambient_mul = 1.0; #end #declare besch_font = "DejaVuLGCSansMono-Bold.ttf" #declare col_gold = texture {T_Gold_3C finish{ambient 0}}; #declare col_silver = texture {T_Chrome_3C finish{ambient 0}}; //****************************************************************************************************** //Font symbols //Here we declare fonts and fallbacks if the font could not be found //The fallback font for all fonts is courbd.ttf as we used this font in earlier versions of Eagle3D #declare global_fontfile_fallback = besch_font; //Check the availability of the fall back font. If not available throw an error. #if(file_exists(global_fontfile_fallback)=0) #warning "Fallback font not found. Please specify the path to courbd.ttf in the ini-file" #declare global_fontfile_fallback = "cyrvetic.ttf" #if(file_exists(global_fontfile_fallback) = 0) #error "Even the font installed with POVRay could not be found. Giving up." #end #end #declare global_fontfile_eagle3d = "eagle3d.ttf" #declare global_fontfile_courier = "DejaVuLGCSansMono.ttf"; #declare global_fontfile_courier_bold = "DejaVuLGCSansMono-Bold.ttf"; #declare global_fontfile_arial = "DejaVuLGCSans.ttf"; #declare global_fontfile_arial_bold = "DejaVuLGCSans-Bold.ttf"; #declare global_fontfile_alphalcd = "alphalcd.ttf" //The Eagle3D font has to exist #if(file_exists(global_fontfile_eagle3d) = 0) #error "Eagle3D font not found. Please specify the path to eagle3d.ttf in the ini-file" #end //Check the availability of font files and set fallback font if not available #if(file_exists(global_fontfile_courier) = 0) #warning "Font Courier not found. Fallback font used" #declare global_fontfile_courier = global_fontfile_fallback; #end #if(file_exists(global_fontfile_courier_bold) = 0) #warning "Font Courier Bold not found. Fallback font used" #declare global_fontfile_courier_bold = global_fontfile_fallback; #end #if(file_exists(global_fontfile_arial) = 0) #warning "Font Arial not found. Fallback font used" #declare global_fontfile_arial = global_fontfile_fallback; #end #if(file_exists(global_fontfile_arial_bold) = 0) #warning "Font Arial Bold not found. Fallback font used" #declare global_fontfile_arial_bold = global_fontfile_fallback; #end #if(file_exists(global_fontfile_alphalcd)=0) #warning "Font AlphaLCD not found. Fallback font arial used" #declare global_fontfile_alphalcd = global_fontfile_arial; #end //****************************************************************************************************** #macro COL_GOLD() #warning "Please use direct texture{} or better the texture{col_gold} identifier instead of COL_GOLD()" texture {col_gold} #end #macro COL_SILVER() #warning "Please use direct texture{} or better the texture{col_silver} identifier instead of COL_SILVER()" texture{col_silver} #end #ifdef(col_preset) //Verschieden Farb-Presets #switch(col_preset) #case(1)//Standard PCB LÜtstop #declare col_brd = texture{pigment{DarkGreen} normal {bozo 0.1 scale 6 } finish{reflection{.05,.05} ambient 0.0 brilliance 1}}//Farbe der Platine #declare col_wrs = texture{pigment{ForestGreen}normal {bozo 0.15 scale 3 } finish{reflection{.05,.05} ambient 0.0}} //Farbe der Leiterbahnen #declare col_pds = texture{T_Silver_5A finish{F_MetalB reflection{.05,.02} ambient 0.0}} //Farbe der Pad's und SMD's #declare col_hls = texture{pigment{Black}} //Farbe der Pseudobohrungen #declare col_bgr = White; //Hintergrundfarbe wenn keine Umgebung aktiviert #declare col_slk = texture{pigment{White}} //Farbe des Best�ckungsdruck #declare col_thl = texture{T_Silver_5A finish{F_MetalB reflection{.25,.2} ambient 0}} //Farbe der Durchkontaktierungen #declare col_pol = col_wrs //Farbe der Polygone #break #case(2)//PCB LÜtstop Mßcke #declare col_brd = texture{pigment{rgb Gray10} normal {bozo 0.1 scale 6 } finish{reflection{.05,.05} ambient 0.0 brilliance 1}} //Farbe der Platine #declare col_wrs = texture{pigment{rgb Gray30} normal {bozo 0.15 scale 3 } finish{reflection{.05,.05} ambient 0.0}} //Farbe der Leiterbahnen #declare col_pds = texture{T_Silver_5A finish{F_MetalB reflection{.05,.02} ambient 0.0}} //Farbe der Pad's und SMD's #declare col_hls = texture{pigment{Black} finish{ambient 0}} //Farbe der Pseudobohrungen #declare col_bgr = Gray50; //Hintergrundfarbe wenn keine Umgebung aktiviert #declare col_slk = texture{pigment{Gray90} finish{ambient 0}} //Farbe des Best ckungsdruck #declare col_thl = texture{T_Silver_5A finish{F_MetalB reflection{.25,.2} ambient 0}} #declare col_pol = col_wrs //Farbe der Polygone #break #case(3)//PCB LÜtstop Mßcke 2 #declare col_brd = texture{ pigment{rgb<0.117647,0.243137,0.015686>} normal {bumps 0.2 scale 0.00015} finish {ambient 0.2 diffuse 0.5 phong 0.1}} //Farbe der Platine #declare col_wrs = texture{ pigment{rgb<0.368627,0.352941,0.054902>} normal{bumps 0.1 scale 0.0001} finish{ambient 0.2 diffuse 0.5 phong 0.1}} //Farbe der Leiterbahnen #declare col_pds = texture{pigment{Gray70} finish{F_MetalB}} //Farbe der Pad's und SMD's #declare col_hls = texture{pigment{Black}} //Farbe der Pseudobohrungen #declare col_bgr = Gray50; //Hintergrundfarbe wenn keine Umgebung aktiviert #declare col_slk = texture{pigment{White}} //Farbe des Bestßckungsdruck #declare col_thl = texture{pigment{Gray70} finish{F_MetalB}} //Farbe der Durchkontaktierungen #declare col_pol = col_wrs //Farbe der Polygone #break #case(4)//Homemade PCB (with black silkscreen) #declare col_brd = texture{pigment{rgb< 0.470588,0.313725,0.000000>}} //Farbe der Platine #declare col_wrs = texture{col_gold} //Farbe der Leiterbahnen #declare col_pds = texture{col_gold} //Farbe der Pad's und SMD's #declare col_hls = texture{pigment{Black}} //Farbe der Pseudobohrungen #declare col_bgr = White; //Hintergrundfarbe wenn keine Umgebung aktiviert #declare col_slk = texture{pigment{Black}} //Farbe des Bestßckungsdruck #declare col_thl = texture{col_silver} //Farbe der Durchkontaktierungen #declare col_pol = texture{T_Stone1} //Farbe der Polygone #break #case(5)//Bunt #declare col_brd = texture{pigment{Red}} //Farbe der Platine #declare col_wrs = texture{pigment{Blue}} //Farbe der Leiterbahnen #declare col_pds = texture{T_Silver_5A} //Farbe der Pad's und SMD's #declare col_hls = texture{pigment{Black}} //Farbe der Pseudobohrungen #declare col_bgr = White; //Hintergrundfarbe wenn keine Umgebung aktiviert #declare col_slk = texture{pigment{Green}} //Farbe des Bestßckungsdruck #declare col_thl = texture{pigment{White}} //Farbe der Durchkontaktierungen #declare col_pol = texture{T_Stone1} //Farbe der Polygone #break #case(6)//Glass #declare col_brd = texture{T_Dark_Green_Glass } //Farbe der Platine #declare col_wrs = texture{pigment{rgb<0.368627,0.352941,0.054902>}} //Farbe der Leiterbahnen #declare col_pds = texture{pigment{Gray70} finish{F_MetalB}} //Farbe der Pad's und SMD's #declare col_hls = texture{pigment{Black}} //Farbe der Pseudobohrungen #declare col_bgr = White; //Hintergrundfarbe wenn keine Umgebung aktiviert #declare col_slk = texture{pigment{White}} //Farbe des Bestßckungsdruck #declare col_thl = texture{pigment{Gray70} finish{F_MetalB}} //Farbe der Durchkontaktierungen #declare col_pol = col_wrs //Farbe der Polygone #break #range(7,2000)//Standard wenn Auswahlfehler #declare col_brd = texture{pigment{DarkGreen}} //Farbe der Platine #declare col_wrs = texture{pigment{ForestGreen}} //Farbe der Leiterbahnen #declare col_pds = texture{T_Silver_5A} //Farbe der Pad's und SMD's #declare col_hls = texture{pigment{Black}} //Farbe der Pseudobohrungen #declare col_bgr = White; //Hintergrundfarbe wenn keine Umgebung aktiviert #declare col_slk = texture{pigment{White}} //Farbe des Bestßckungsdruck #declare col_thl = texture{T_Silver_5A} //Farbe der Durchkontaktierungen #declare col_pol = col_wrs //Farbe der Polygone #break #end #end //Zeichnet einen Bogen //rad = radius //wid = width of the "line" //st_wi = start angle //en_wi = end angle //height = well, the height #macro ARC(rad,wid,st_wi,en_wi,height) union{ #local i=st_wi; #local l=((rad*pi)/360) * 1.1; cylinder{<0,0,-rad> <0,height,-rad> wid/2 pigment{Red} rotate<0,-i-90,0> } #while(i<=en_wi) box{<-l,0,-rad-wid/2> rotate<0,-i-90,0>} #declare i=i+1; #end cylinder{<0,0,-rad> <0,height,-rad> wid/2 pigment{Red} rotate<0,-i+1-90,0> } } #end //Joseph Zeglinski #macro TOOLS_WIRE_LEADS (Length, Width, Wirelength, Wirewidth, Raster, BendRadius, Seperation, H_V) //Erzeugt Drahtbßgel passend fßr ein Bauteil //Length: Länge des Bauteils (length of body part) //Width: Durchmesser des Bauteils (diameter of body part) //Wirelength: Länge des eines Drahtes (length of one wire lead) //Wirewidth: Durchmesser des Drahtes (diameter of the wire) //Raster: Raster //BendRadius: Biegeradius (bending radius) //Seperation: Distance between component bottom and pcb for heat dissipation //H_V: Part Orientation - "H" for horizontal; "V" for vertical (quotes required) // Adds Resistor (or any component), Horizontal or Vertical wire leads, based on (raster,body & wire) // dimensions. It forms a semi-circular bend with a radius with the value of "BendRadius". // The component making the call must be centred at the origin, at that point. Lead clipping is also handled. // This macro will handle "RADIAL LEAD COMPONENTS as well. Here, the "RASTER" argument is set equal to, or narrower than // the body "LENGTH" argument, and "H_V" is specified as "H" - for Horizontal orientation. For Tall" components, // the "body Length" is the horizontal width, as mounted. Similarly, the "body Width", is the height of the // fully mounted radial-leaded component (e.g capacitor, or vertical ceramic block resistor PVxx). // Finally, "Seperation" - (height above the PCB, after attaching wires), is also accounted for, in the wires. // This seperation is typically for raising power components >= 1 watt, 1.5 mm above the surface to prevent // scorching the PCB. However, for items like Radial Lead Capacitors, this value can be any size. The calling module // must perform the actual "translate" of the fully assembled part, from the origin, to the final position, upon return. // ******************** // PWB Assembly Pratice: For Components drawing LESS than 1 watt, should be in contact with PCB. // Seperation above pcb must NOT exceed 3.0 mm (CLASS 1 and CLASS 2), // or 0.7 mm for CLASS 3 components. // // The calling routine should have tested the WATTS argument // and added the seperation, there, to the "Width" argument. // // COMMON construction of lead-wires for ALL COMPONENTS: // Correct PWB assembly practice requires that, a bend NOT begin, closer than // "one lead wire diameter (thickness) from the body, with a minimum of at least 0.8 mm" #if (Width > Wirewidth) #local W=Width/2; #else #local W=Wirewidth/2 #end #local L=Length/2; #local LW=Wirewidth/2; #local WA=(Width-Wirewidth)/2; #local Stub = max( 0.8, Wirewidth ); // Set the component's "Stub Length" from the body to the start of bending #local Horizontal = !(strcmp(strupr(H_V), "H") ); // string compare returns "0" (false) if equal; therefore, Negate this. // Special section to handle "RADIAL LEAD" components, like capacitors, inductors, or ceramic block vertical power resistors. #if(Horizontal=yes) #if ( Raster <= Length ) #local BendRadius = 0.0; // Special case for "Leads inside of the body length" (e.g. "RADIAL LEAD" Components) #local Stub = 0.0; #end #end // ******************** union { // // Attach the wire leads to the "COMPONENT" body: #if (Horizontal = no) // Which way will the wires go? // Wires for "VERTICAL" Component: //TOP axial stub cylinder{<0,L/2,0> <0, (L+Stub) ,0> Wirewidth/2} //TOP (Perpendicular to body, WIRE) cylinder{ <(Raster-BendRadius), (L+BendRadius+Stub), 0> Wirewidth/2 } difference{ //LEFT-TOP (wire elbow bend) torus{BendRadius, Wirewidth/2 rotate<90,0,0>} box{<-2*BendRadius, 0, BendRadius> <2*BendRadius, -2*BendRadius, -BendRadius>} box{<2*BendRadius, -BendRadius, BendRadius> <0, 2*BendRadius, -BendRadius>} translate } difference{ //RIGHT-TOP (second wire elbow bend) torus{BendRadius, Wirewidth/2 rotate<90,0,0>} box{<-2*BendRadius, 0, BendRadius> <2*BendRadius, -2*BendRadius, -BendRadius>} box{<2*BendRadius, -BendRadius, BendRadius> <0, 2*BendRadius, -BendRadius>} rotate<0,180,0> translate <(Raster-BendRadius), (L+Stub), 0> } #if(pin_short = on) difference{union{ #end //RIGHT (vertical wire) - if "Raster" happens to be LONGER than remaining lead wire length, then // "solder-on an extension wire", to reach the PCB cutoff position #local cutoff = (pin_length+pcb_height) + (L+Stub+Seperation) ; cylinder{ Wirewidth/2} //LEFT-BOTTOM (axial wire) cylinder{<0,-(L),0> <0,min(-cutoff, -(Wirelength+(L+Stub)) ),0> Wirewidth/2 } #if(pin_short = on) }box{<-LW,-cutoff,LW> }} #end #else // Otherwise, Wires for "HORIZONTAL" Component: difference{ //LEFT (wire elbow bend) torus{BendRadius, Wirewidth/2 rotate<90,0,0>} box{<-2*BendRadius, 0, BendRadius> <2*BendRadius, -2*BendRadius, -BendRadius>} box{<2*BendRadius, -BendRadius, BendRadius> <0, 2*BendRadius, -BendRadius>} translate <-(Raster/2-BendRadius), -BendRadius, 0> } difference{ //RIGHT (second wire elbow bend) torus{BendRadius, Wirewidth/2 rotate<90,0,0>} box{<-2*BendRadius, 0, BendRadius> <2*BendRadius, -2*BendRadius, -BendRadius>} box{<2*BendRadius, -BendRadius, BendRadius> <0, 2*BendRadius, -BendRadius>} rotate<0,180,0> translate <(Raster/2-BendRadius), -BendRadius, 0> } cylinder{<-(Raster/2-BendRadius), 0, 0> <(Raster/2-BendRadius), 0, 0> Wirewidth/2} //Horizontal WIRE end-to-end, between elbows #if(pin_short = on) difference{union{ #end // If lead wire is somehow specified too short, then "solder-on an extension wire", to reach the PCB cutoff position, anyway #local cutoff = (pin_length+pcb_height) + (W + Seperation) ; //RIGHT vertical wire cylinder{ Wirewidth/2 } //LEFT vertical wire cylinder{<-Raster/2,-BendRadius,0> <-Raster/2, min(-cutoff, -(Wirelength-pi*BendRadius/2) ),0> Wirewidth/2 } #if(pin_short = on) }box{<-Raster/2-LW, -cutoff, LW> }} #end #end texture{col_silver} } #end /********************************************************************** //Designed by Friedrich Bleikamp, Lenord, Bauer & Co. Gmbh //Privat: //Macro fuer gebogene Rechteckprofile mit Oeffnungswinkel von 1-179 Grad //Der Schenkel mit der laenge1 liegt mittig auf der x-Achse //bei einem Winkel von 90Grad der andere auf der y-Achse //der Innenradius muss >= 0 sein, //der Winkel zwischen den Schenkeln 0 > Winkel <180, //mittlerer Biegeradius = i_radius + dicke/2 **********************************************************************/ #macro TOOLS_RECT_BOGEN(i_radius,winkel,dicke,breite,laenge1,laenge2) union{ difference { cylinder{<(breite/2) * -1,0,0>(i_radius + dicke)} cylinder{<(breite/2 + 0.1) * -1,0,0>i_radius} box{ <(breite/2 + 0.1) * -1,(i_radius + dicke + 0.1) * -1, 0>, } box{ <(breite/2 + 0.1) * -1,(i_radius + dicke + 0.1) * -1, 0>, rotate } } box{<(breite/2) * -1,i_radius, 0>, } box{<(breite/2) * -1, 0, i_radius * -1>, rotate <(90 - winkel) * -1,0,0> } translate < 0,(i_radius + dicke/2) * -1,(i_radius + dicke/2)> rotate <0,-90,180> } #end /********************************************************************** //Generates a VIA //dia_min: diameter of the hole //dia_max: diameter of the via //upper: the upper layer which the via contains to //lower: the lower layer which the via contains to //shape: the shape of the via // 0 square // 1 octagon // 2 round // 3 long // 4 offset // if shape >= 100 solder will be added to the via **********************************************************************/ #macro TOOLS_PCB_VIA(dia_max,dia_min,upper,lower,shape,elongation) #if((global_solder=on)&(shape>=100)) union{ #else object{ #end #local lupper = -global_pcb_layer_dis[upper-1]+pcb_cuheight+0.002; #local llower = -global_pcb_layer_dis[lower-1]-0.002; #if(shape>=100) #local shape=shape-100; #if(global_solder=on) difference{ #local dia = dia_max*0.5; cylinder{<0,lupper,0>, <0,lupper+dia,0>dia} torus{ dia,dia translate<0,dia,0> scale<1,2,1> translate<0,lupper,0>} } difference{ #local dia = dia_max*0.5; cylinder{<0,llower,0>, <0,llower-dia,0>dia} torus{ dia,dia translate<0,-dia,0> scale<1,2,1> translate<0,llower,0>} } #end #end #if(dia_min>=global_pcb_real_hole) difference{ #end //square #if(shape=0) box{<-dia_max/2,llower,-dia_max/2>} #end //round #if(shape=1) cylinder{<0,lupper,0><0,llower,0>dia_max/2} #end //octagon #if(shape=2) prism { linear_spline lupper, llower, 9, #local i = 0; #while(i<9) ,<0,i*45+22.5,0>).x,vrotate(,<0,i*45+22.5,0>).z> #local i = i + 1; #end } #end //long #if(shape=3) prism { linear_spline lupper, llower, 9, #local i = 0; #while(i<9) #local pos = ,<0,i*45+22.5,0>).x,0,vrotate(,<0,i*45+22.5,0>).z>; #if((i=0)|(i=1)|(i=6)|(i=7)|(i=8)) #else #end #local i = i + 1; #end } #end //offset #if(shape=4) prism { linear_spline lupper, llower, 9, #local i = 0; #while(i<9) #local pos = ,<0,i*45+22.5,0>).x,0,vrotate(,<0,i*45+22.5,0>).z>; #if((i=2)|(i=3)|(i=4)|(i=5)) #else #end #local i = i + 1; #end } #end #if(dia_min>=global_pcb_real_hole) cylinder{<0,lupper+0.1,0><0,llower-0.1,0> dia_min/2-0.001} } #end } #end /********************************************************************** //Generates an SMD //xsize: x-size of the SMD //ysize: y-size of the SMD //thick: the thikness of the copper //r: roundness (0%-100%) **********************************************************************/ #macro TOOLS_PCB_SMD(xsize,ysize,thick,r) #if(r=0) box{<-xsize/2,0,-ysize/2>} #else union{ #if(xsize>ysize) #local xsmall=xsize-(ysize)*(r/100); #local ysmall=ysize-(ysize)*(r/100); #local cyldif=(ysize)*(r/100); #else #local xsmall=xsize-(xsize)*(r/100); #local ysmall=ysize-(xsize)*(r/100); #local cyldif=(xsize)*(r/100); #end box{<-xsmall/2,0,-ysize/2>} box{<-xsize/2,0,-ysmall/2>} cylinder{<-xsize/2+cyldif/2,0,-ysize/2+cyldif/2><-xsize/2+cyldif/2,thick,-ysize/2+cyldif/2>cyldif/2} cylinder{<-xsize/2+cyldif/2,0, ysize/2-cyldif/2><-xsize/2+cyldif/2,thick, ysize/2-cyldif/2>cyldif/2} cylinder{< xsize/2-cyldif/2,0,-ysize/2+cyldif/2>< xsize/2-cyldif/2,thick,-ysize/2+cyldif/2>cyldif/2} cylinder{< xsize/2-cyldif/2,0, ysize/2-cyldif/2>< xsize/2-cyldif/2,thick, ysize/2-cyldif/2>cyldif/2} } #end #end /********************************************************************** //By John van Sickle // // This macro creates a bar with four of its edges rounded. It fills the same //space as box { Startcorner,EndCorner }, except that the edges running along the //y-axis are rounded. StartCorner and EndCorner are opposite corners of the box, //and Radius is the radius of the rounded edges. // The bar is made up of a prism object and four cylinder objects that run //parallel to the y-axis. If you want the bar to run along any other axis, you //will have to transform it just as you would any prism object. There is no merge //or union declared around them, to leave the choice up to the user; merge is //better for applications with transparency, union is better for others. Here is //an example of the macro's use: // //object { // TOOLS_ROUNDED_BAR(<-10,0,0>,<10,40,20>,2) // pigment { rgb .75 } //} // //Although the example code uses vector literals for StartCorner and EndCorner, //you can use any vector expression, and scalars will be promoted to full vectors. // //Modified by fbleikamp(replace with at)web.de for Eagle3D objects // **********************************************************************/ #macro TOOLS_ROUNDED_BAR(v_SP,v_EP,R) #local vSP=(v_SP)*<1,1,1>; #local vEP=(v_EP)*<1,1,1>; #if (vSP.x > vEP.x) #local tSave=vSP.x; #local vSP=; #local vEP=; #end #if (vSP.y > vEP.y) #local tSave=vSP.y; #local vSP=; #local vEP=; #end #if (vSP.z > vEP.z) #local tSave=vSP.z; #local vSP=; #local vEP=; #end #union{ box {,} box {,} cylinder { ,,R } cylinder { ,,R } cylinder { ,,R } cylinder { ,,R } } #end /********************************************************************** //TOOLS_TORUS_SPLINE() By: Ron Parker // // This macro is used to create a smooth spline of toruses connecting //a sequence of points. To use it, use code like the following: // //#declare Pts=array[5]{<0,0,0>, <1,1,1>, <-.5,1,2>, <.5,1,3>, <0,1,4>} //object { // TOOLS_TORUS_SPLINE( .1, Pts, <1,0,.5> ) // texture {...} // } // //The first parameter to the TorusSpline macro is the minor radius of //the toruses to be used in creating the spline. // //The second parameter is the array of points through which the spline //should pass. // //The third parameter is the direction vector to be used at the start //of the spline. Varying this vector can have surprising results on //the resulting object. If the spline should leave another object at //a specific angle, as with a lamp cord or rope, use this vector to //show the angle. If it is zero, The first torus will be calculated to //pass through the first three points. This is usually what you want, //but you can get some neat effects if you override the default. // //It is possible to specify invalid parameters. If you do, you will //likely get a parse error. // //Achtung!!! Axis in MyAxis umbenannt, konflikt mit macro-name in special.inc //Fehler in Verbindung mit bentpipe.mcr abgefangen bei vcross((B-A),V) = 0 und den daraus folgenden Fehlern. *********************************************************************/ #macro TOOLS_TORUS_SPLINE( TorRadius, Points, StartVect ) // promote the start vector to a vector, even if they gave us a scalar (e.g. 0) #local V=<0,0,0>+StartVect; #local Numpoints = dimension_size( Points, 1 ); #local Cur = 0; union { #while (Cur < Numpoints-1 ) #local A=Points[Cur]; #local B=Points[Cur+1]; #if (V.x=0&V.y=0&V.z=0) #local C=Points[Cur+2]; #if (vlength(vcross(C-A,B-A))=0) #local V=B-A; #local Cos=0; #local MyAxis=<0,0,0>; #else #local MyAxis=vnormalize(vcross((C-A),(B-A))); #local Base1=vnormalize(C-A); #local Base2=vnormalize(vcross(MyAxis,Base1)); #local VB=<0.5*vlength(C-A),0,0>; #local VA=vcross(VB,z); #local VD=.5*; #local VC=vcross(VD,z); #local Beta=((VD-VB).y*VA.x-(VD-VB).x*VA.y)/(VC.x*VA.y-VC.y*VA.x); #local Center=A+VD.x*Base1+VD.y*Base2+Beta*(VC.x*Base1+VC.y*Base2); #local Radius=vlength(Center-A); #local Cos=1; #local V=vcross( MyAxis,Center-A ); #end #local B=C; #local Cur=Cur+1; #else #local C=vcross((B-A),V); // fbleikamp(replace with at)web.de #if ( C.x!=0|C.y!=0|C.z!=0) #local MyAxis=vnormalize(vcross((B-A),V)); #local Dir=vnormalize(vcross(V, MyAxis )); #local Cos=vdot(vnormalize(B-A), Dir); #local Radius=abs(.5*vlength(B-A)/Cos); #local Center=A+Radius*Dir; #else #local MyAxis=<0,0,0>; #local Center=A; #local Cos=0; #end #end #local V1=V; #if ( Cos & (MyAxis.x!=0|MyAxis.y!=0|MyAxis.z!=0)) #if (MyAxis.y = 0 & vlength() = 0) #local RZ=0; #else #local RZ=-degrees(atan2(vlength(), MyAxis.y)); #end #if (MyAxis.z = 0 & MyAxis.x = 0 ) #local RY=0; #else #local RY=-degrees(atan2(MyAxis.z, MyAxis.x)); #end #local V1=vcross(B-Center, MyAxis); #if ( vdot(vcross(V,A-Center),vcross(V, V1))>0 ) #local Planes = union{ plane{-V, vdot( A-.0001*TorRadius*V, vnormalize(-V) ) } plane{V1, vdot( .0001*TorRadius*V1+B, vnormalize(V1))} } #else #local Planes = intersection { plane{-V, vdot( A-.0001*TorRadius*V, vnormalize(-V) ) } plane{V1, vdot( .0001*TorRadius*V1+B, vnormalize(V1))} } #end intersection{ object {Planes} torus{ Radius, TorRadius rotate RZ*z rotate RY*y translate Center } } #else cylinder {A-.0001*TorRadius*V, B+.0001*TorRadius*V, TorRadius} #end #declare Cur=Cur+1; #declare V=V1; #end } #end /********************************************************************** //TOOLS_BENTPIPE() By: Ron Parker // // This macro allows you to specify a TorusSpline as a series of "turtle-like" moves rather than as // a series of points. You tell it to start at a particular position and orientation and give it // a series of commands (go straight x units, turn left/right x degrees with radius r) // and a radius for the pipe and it creates the specified pipe. // It does assume you are operating in the X-Y plane. // This macro requires my TorusSpline macro as well. It is possible to provide bad arguments; // if you do, you'll get bad results. // For example, a 1-unit bend in a 2-unit radius pipe is probably not too smart. // //Sample usage: //#declare bends=array[6] { // // or <0, distance, 0> for straight pipe // // negative angles bend left, positive bend right. // <0, 10, 0>, <-45, 5, 0>, <225,5,0>, <-225,5,0>, <45, 5, 0>, <0, 10, 0> //} // //object { // // this pipe has a radius of 1, starts at the origin, and initially goes in the x direction // TOOLS_BENTPIPE( 1, <0,0,0>, x, bends ) // texture {pigment {color rgb 1}} //} **********************************************************************/ #macro TOOLS_BENTPIPE( PipeRadius, Loc, Dir, Bends ) #local Pts=array[dimension_size( Bends, 1 )+1] #local Pts[0] = <0,0,0>+Loc; #local StartDir = <0,0,0>+Dir; #local Cur = 0; #while ( Cur < dimension_size( Bends, 1 ) ) #if (Bends[Cur].u = 0 ) #local Pts[Cur+1] = Pts[Cur]+Bends[Cur].v*vnormalize(Dir); #else #local Offset = Bends[Cur].v * vnormalize(vcross( Dir, -Bends[Cur].u*z )); #local Pts[Cur+1]=Pts[Cur]-Offset+vrotate(Offset, -Bends[Cur].u*z); #local Dir = vrotate( Dir, -Bends[Cur].u*z ); #end #local Cur=Cur+1; #end TOOLS_TORUS_SPLINE( PipeRadius, Pts, StartDir ) #end /******************************************************************************************************************************************** //Macros for Screws : M2 M2.5 M3 M4 M5 //Designed by Philippe Boucheny //Rev. 1.1 - 04/01/06 //Lg=lenght Col= color //Hd:0=PAN 1=PHILIPS-ROUND-PAN 10=SLOTTED HEXA 11=FULL-BEARING 20=CHEESE 21=RAISED-CHEESE //30=RAISED-COUNTER-SUNK 31=PHILIPS-RAISED-COUNTER-SUNK 32=COUNTER-SUNK 33=PHILIPS-COUNTER-SUNK 34=COUNTER-SUNK-HEXA-SOCKET //zero is under head for #0 to #21 headed screws and on top for all counter sunk headed screws ********************************************************************************************************************************************/ #macro TOOLS_SCREW (M,lg,Hd,Col) #switch (M) #case(2) #local R = 1.6; //4 0.8 #local r = 0.4; #local ep = 1.3; #local r1 = 0.65; #local A = 3.6; #local delta = 1.12; #local B = 1.2; #local H = 1.5; #local T = 0.4; #local S = 1.3; #break #case(2.5) #local R = 2; #local r = 0.5; //5 0.8 #local ep = 1.6; #local r1 = 0.8; #local A = 4.4; #local delta = 1.32; #local B = 1.5; #local H = 2; #local T = 0.45; #local S = 1.6; #break #case(3) #local R = 2.4; // 6 0.8 #local r = 0.6; #local ep = 2; #local r1 = 1; #local A = 5.3; #local delta = 1.52; #local B = 1.65; #local H = 2.5; #local T = 0.5; #local S = 1.94; #break #case(4) #local R = 3.2; //8 0.8 #local r = 0.8; #local ep = 2.6; #local r1 = 1.3; #local A = 6.6; #local delta = 1.82; #local B = 2.2; #local H = 3; #local T = 0.7; #local S = 2.42; #break #case(5) #local R = 4; //10 0.8 #local r = 1; #local ep = 3.3; #local r1 = 1.65; #local A = 8; #local delta = 2.05; #local B = 2.5; #local H = 4; #local T = 0.8; #local S = 2.92; #break #end union{ #if(Hd > -1) difference //head { #switch (Hd) #range(0,1) // PAN HEAD & PHILIPS ROUND-PAN union { torus {R+r-r1,r1 translate (ep-r1)*y} // round edge cylinder {<0,0,0>, <0,ep,0>, R+r-r1} // base cylinder {<0,0.1,0>, <0,ep-r1,0>, R+r} // top } #if(Hd=0) box {<-r,ep*.5,-R-2*r>, <+r,+10,R+2*r> } // Grove #else box {<-r,-R/2,-R/2>, <+r,+R/2,+R/2> rotate 45*x translate ep*y } // Grove box {<-r,-R/2,-R/2>, <+r,+R/2,+R/2> rotate 45*x translate ep*y rotate 90*y} // Grove #end #break #range(10,11) // SLOTTED HEXA HEAD & FULL BEARING HEAD intersection { //3 boxes for Hexa nut box {<-A/2,0,-2*M>, <+A/2,+ep+0.1,+2*M> } box {<-A/2,0,-2*M>, <+A/2,+ep+0.1,+2*M> rotate -60*y} box {<-A/2,0,-2*M>, <+A/2,+ep+.01,+2*M> rotate +60*y} sphere { <0, -delta, 0> 0.83*A } } union{ cylinder {<0,+ep,0>, <0,+ep+0.2,0> A/2+r } // to get spotless surface #if(Hd=10) box {<-r,ep*.5,-R-2*r>, <+r,+10,R+2*r> rotate -30*y } // Grove #end } #break #case(20) // CHEESE #local R=0.8*R; cylinder {<0,0,0>, <0,ep,0>, R+r} // base box {<-r,ep*.5,-R-2*r>, <+r,+10,R+2*r> } // Grove #break #case(21) // RAISED CHEESE #local R=0.8*R; intersection{ sphere{<0,-R/2,0> 1.7*R} cylinder {<0,0,0>, <0,2*ep,0>, R+r} // base } box {<-r,ep*.4,-R-2*r>, <+r,+10,R+2*r> } // Grove #break #range(30,31) // RAISED-COUNTER-SUNK & PHILIPS-RAISED-COUNTER-SUNK union{ intersection{ sphere{<0,-A/2-S,0> A} cylinder {<0,0,0>, <0,2*ep,0>, A*0.5} // base } cone{0*y, A*0.5, -B*y,M/2} } #if(Hd=30) box {<-r,-ep*.4,-R-2*r>, <+r,A,R+2*r> } // Grove #else box {<-r,-R/2,-R/2>, <+r,+R/2,+R/2> rotate 45*x translate ep/3*y } // Grove box {<-r,-R/2,-R/2>, <+r,+R/2,+R/2> rotate 45*x translate ep/3*y rotate 90*y} // Grove #end #break #range(32,34) // COUNTER SUNK cone{0*y, A*0.5, -B*y, M/2.1 } #switch(Hd) #case(32) box {<-r,-ep*.4,-R-2*r>, <+r,0.1,R+2*r> } // Grove #break #case(33) box {<-r,-R/2,-R/2>, <+r,+R/2,+R/2> rotate 45*x translate 0*y } // Grove box {<-r,-R/2,-R/2>, <+r,+R/2,+R/2> rotate 45*x translate 0*y rotate 90*y} // Grove #break #case(34) difference{ intersection{ box {<-H/2,0.1,-2*M>, <+H/2,-ep,+2*M> } box {<-H/2,0.1,-2*M>, <+H/2,-ep,+2*M> rotate -60*y} box {<-H/2,0.1,-2*M>, <+H/2,-ep,+2*M> rotate +60*y} } cylinder {<0,-ep*.6,0>, <0,-ep,0> A/2+r } // to get spotless surface } #break #end #break #end rotate(rand(global_seed)*180)*y } #end #if(Hd<30) #local B1=0; #local N=2; #else #local B1=B; #local N=0; #end difference //body { union { cylinder {<0,-B1,0>, <0,-lg+r,0>, M/2} cone { <0,-lg+r,0>, M/2, <0,-lg,0>, M/3 } } union { #while (N < (lg/T+1)) torus {M/1.95,T/2.6 translate (-B1-N*T)*y} #local N = N + 1; #end } } pigment{Col} } #end /******************************************************************************************************************************************** //Macros for Washers : diameter 2, 2.5, 3, 4, 5 //Designed by Philippe Boucheny //Rev. 1.1 - 04/01/06 //Col= color Type: 0=Z, 1=M, 2=L, 3=LL ********************************************************************************************************************************************/ #macro TOOLS_WASHER (d,Type,Col) #switch (d) #case(2) #local AZ = 4; #local AM = 6; #local AL = 8; #local ALL = 10; #local C = 0.6; #local B = 2.25; #break #case(2.5) #local AZ = 5; #local AM = 7; #local AL = 9; #local ALL = 11; #local C = 0.7; #local B = 2.75; #break #case(3) #local AZ = 6; #local AM = 8; #local AL = 12; #local ALL = 14; #local C = 0.8; #local B = 3.25; #break #case(4) #local AZ = 8; #local AM = 10; #local AL = 14; #local ALL = 16; #local C = 0.8; #local B = 4.25; #break #case(5) #local AZ = 10; #local AM = 12; #local AL = 16; #local ALL = 20; #local C = 1; #local B = 5.25; #break #end #switch (Type) #case(0) #local A=AZ; #break #case(1) #local A=AM; #break #case(2) #local A=AL; #break #case(3) #local A=ALL; #break #end difference { cylinder {<0,0,0>, <0,C,0>, A/2} cylinder {<0,-0.1,0>, <0,C+0.1,0>, B/2} pigment{Col} } #end /******************************************************************************************************************************************** //Macros for Nuts : M2, M2.5, M3, M4, M5 //Designed by Philippe Boucheny //Rev. 1.1 - 04/01/06 //Col= color Type: 0=Hu, 1=Hh ********************************************************************************************************************************************/ #macro TOOLS_NUT (M, Type, Col) #switch (M) #case(2) #local A = 3.6; #local B = 1.4; #local T = 0.4; #local Delta = 1.75; #break #case(2.5) #local A = 4.5; #local B = 1.7; #local T = 0.45; #local Delta = 2.2; #break #case(3) #local A = 5.5; #local B = 2.4; #local T = 0.5; #local Delta = 2.5; #break #case(4) #local A = 7; #local B = 3.2; #local T = 0.7; #local Delta = 3.1; #break #case(5) #local A = 8; #local B = 4; #local T = 0.8; #local Delta = 3.35; #break #end #if(Type=1) #local Delta = Delta-(M-B)/2; #local B=M; #end difference { intersection { //3 boxes for hexagonal shape box {<-A/2,-2*M,-B/2-0.1>, <+A/2,+2*M,+B/2+0.1> } box {<-A/2,-2*M,-B/2-0.1>, <+A/2,+2*M,+B/2+0.1> rotate -60*z} box {<-A/2,-2*M,-B/2-0.1>, <+A/2,+2*M,+B/2+0.1> rotate +60*z} //make some roundness sphere { <0, 0, +Delta> 0.83*A } sphere { <0, 0, -Delta> 0.83*A } } union { //hole cylinder {<0,0,-B>, <0,0,+B>, M/2} //thread union { #local N=0; # while (N < 10) torus {M/1.95,T/2.6 rotate 90*x translate (-M/2+N*T)*z} #local N = N + 1; #end } cylinder {<0,0,+B/2+0.2>, <0,0,+B/2> A/2+T } // to get spotless surface cylinder {<0,0,-B/2-0.2>, <0,0,-B/2> A/2+T } // to get spotless surface } pigment{Col} rotate 90*x translate B/2*y rotate(rand(global_seed)*180)*y } #end #macro TOOLS_LOGO_AND_CAPTION(caption, logo, min_p, max_p) union{ #local tgt_size = - ; #if(strcmp(logo,"AMD") = 0.0) #local logo_obj = text{ttf global_fontfile_eagle3d "6" 0.01,0} #local logo_extra_scale = 0.3; #end #if(strcmp(logo,"ATMEL") = 0.0) #local logo_obj = text{ttf global_fontfile_eagle3d "a" 0.01,0} #local logo_extra_scale = 0.7; #end #if(strcmp(logo,"FTDI") = 0.0) #local logo_obj = text{ttf global_fontfile_eagle3d "f" 0.01,0} #local logo_extra_scale = 0.7; #end #if(strcmp(logo,"MAXIM") = 0.0) #local logo_obj = text{ttf global_fontfile_eagle3d "-" 0.01,0} #local logo_extra_scale = 0.9; #end //Size and other calculations for logo placement #local logo_min = min_extent(logo_obj); #local logo_max = max_extent(logo_obj); #local logo_size = logo_max - logo_min; #local logo_obj = object{logo_obj translate -(logo_size / 2) rotate<90, 0, 0>}; #local logo_min = min_extent(logo_obj); #local logo_max = max_extent(logo_obj); #local logo_size = logo_max - logo_min; #if(tgt_size.x < tgt_size.z) #local logo_size = ; #end #local logo_scale = min((tgt_size / logo_size).x, (tgt_size / logo_size).z) * logo_extra_scale; //Size and other calculations for caption placement #local caption_obj = text{ttf global_fontfile_arial caption 0.01, 0} #local caption_min = min_extent(caption_obj); #local caption_max = max_extent(caption_obj); #local caption_size = caption_max - caption_min; #local caption_obj = object{caption_obj translate -(caption_size / 2) rotate<90, 0, 0>}; #local caption_min = min_extent(caption_obj); #local caption_max = max_extent(caption_obj); #local caption_size = caption_max - caption_min; #if(tgt_size.x < tgt_size.z) #local caption_size = ; #end #local caption_scale = min((tgt_size / caption_size).x, (tgt_size / caption_size).z) * (0.9 - logo_extra_scale); union { //Logo placement object{ logo_obj scale #if(tgt_size.x >= tgt_size.z) translate - translate <0, 0, tgt_size.z / 2 - logo_size.z / 2 * logo_scale> #else rotate<0, 90, 0> translate translate <0, 0, tgt_size.z / 2 - logo_size.z / 2 * logo_scale> #end } /* //Caption placement object{ caption_obj scale #if(tgt_size.x >= tgt_size.z) #else rotate<0, 90, 0> translate translate <0, 0, tgt_size.z / 2 - caption_size.z / 2 * caption_scale> #end pigment{Red} } */ } //box{logo_min, logo_max} } #end /********************************************************************** This macro is used for simple object generation **********************************************************************/ #macro TOOLS_SSDL_BOX( corner1, corner2, trans, rot, sca, c) #ifdef(global_create_ssdl_file) #local corner1 = vrotate(corner1,B) #write( ssdl_file, "BOX:", corner1, corner2, c, "\n") #end #end #end
