Avr-gcc Bugs
Bugs
PR Description Note
46779 wrong code generation for array access = 46779
45291 avr miscompilations related to frame pointer registers = 46779
45263 registers used in __do_global_ctors can get clobbered
44940 XMEGA RAMPZ Initialization
44643 ice in c-typeck.c
44506 -mtiny-stack causes internal compiler error on gcc for avr
42240 [4.3/4.4 Regression] wrong epilogue on naked function 4.6.0, 4.5.3, 4.4.x, 4.3.x
42149 ICE:verify_gimple failed for avr target
42146 ICE in tree_low_cst
41894 wrong code with -fno-split-wide-types = 46779
41885 AVR Rotate patterns do not correctly consider overlap. 4.5.0
39633 [avr] loop bug
39386 [avr] different computation results for O1 and O0 executables
39212 ice for AVR target: unable to find a register to spill in class 'POINTER_REGS'
38549 [avr] eicall not properly set for > 128K program space
38342 [4.3/4.4/4.5/4.6 Regression] __attribute__((__progmem__)) not propagated from typedef to data
38159 [avr] ICE: gcc.c-torture/execute/pr38051.c compilation, -O3 -fomit-frame-pointer -funroll-all-loops -finline-functions
37165 [4.4/4.5/4.6 Regression] FAIL: gcc.dg/matrix/matrix-1.c scan-ipa-dump-times matrix-reorg "Flattened 3 dimensions" 1
35073 illegal opcode movw for mcu avr3
34734 attribute((progmem)) not handled properly in C++ for AVRs
28718 Call to -lgcc added prior to user libraries
26883 ICE when assigning memory attribute to class with simple constructor
26882 [AVR][C++] ICE when using template function with memory attributes
Optimierung
PR Optimization
46278 avr-gcc 4.5.1 doing suboptimal reloads using X
43745 [avr] g++ puts VTABLES in SRAM
43746 -fmerge-constants and -fmerge-all-constants don't work at AVR target
43088 [avr] Suspect optimizer missed code in gcc 4.4.3..
43095 [avr] GCC produces poor code for 4- and 8-byte values
42210 avr: optimizing assignment to a bit field
39250 unsigned char times 64U produces long slow loop
33970 Missed optimization using unsigned char loop variable
33050 [avr] unnessary register save
33049 [avr] bit extraction non optimal, inversing logic solves problem
29560 [avr] Poor optimization for byte shifts
29524 [4.3/4.4/4.5/4.6 Regression] Too much RAM used: __clz_tab[] linked
41076 [avr] pessimal code for logical OR of 8-bit fields
39819 [avr] Missed optimisation when setting 4-byte values
39621 Delaying operation to end of function causes high stack usage
36884 ifcvt poor optimization
36467 [avr] Missed optimization with pointer arithmetic and mul*
41849 optimization fails when register variables are used for an interrupt
35860 [4.3/4.4/4.5/4.6 Regression] [avr] code bloat caused by -fsplit-wide-types
34888 Stack patterns for AVR not optimal
34792 [avr] c++ worse than c compiler at 8-bit optimisations
34791 [avr] optimisation of 8-bit logic sometimes fails
34789 [avr] sometimes the compiler keeps addresses in registers unnecessarily
11180 [avr-gcc] Optimization decrease performance of struct assignment.
20296 Speeding up small interrupts on avr
18145 Do not emit __do_copy_data or __do_clear_bss if .data or .bss is empty.
27663 missed-optimization transforming a byte array to unsigned long
Debug-Info, Build, Ada, Fortran, ...
45261 Doesn't indicate failure status when it doesn't support (attiny2313A) 4.6.0, 4.5.3, 4.4.x, 4.3.x
47597 ICE: call frame debugging information is not handled when case is post_dec
20072 make install doesn't create /usr/local/info/dir if .../dir not already present.
46426 [avr] avr/libgcc.S in SVN r166596 fails to compile
46192 renaming of a volatile variable generates wrong code ada
34040 Support for DOUBLE_TYPE_SIZE != 64 targets fortran
17994 avr-gcc does not output a dwarf2 .debug_frame section
18989 A few potentially ominous, and several likely harmless warnings during 4.0 build
14118 h8300-elf, avr-elf, m68k-elf ports cannot build libmudflap
Erweiterungen
PR Extensions
45099 [avr] Warning could be issued for use of register variables that will fail.
Ungültig
PR Invalid
[1]
