Avr-gcc Bugs
Bugs
PR Description Note
54814 ICE: Hundreds of spill fails in test suite for class R0_REG
Binutils / avr-libc
PR Description Note
binutils
binutils fixed
avr-libc
Optimierung
PR Optimization Note
Debug-Info, Build, ...
55243 STAMP variable is not defined in t-avr ada, build
Erweiterungen
PR Extensions Note
43745 Put VTABLES in Flash
Ungültig
PR Invalid Note
PR Won't fix Note
Fixed
PR Fixed Note
52261 Add XMEGA support 4.7.0
