Avr-gcc Bugs
Bugs
PR Description Note
Binutils / avr-libc
PR Description Note
binutils
binutils fixed
avr-libc
38125 Distribute gcrt1.S
Optimierung
PR Optimization Note
Debug-Info, Build, ...
Erweiterungen
PR Extensions Note
56263 Strict address-space checking
43745 Put VTABLES in Flash
Ungültig
PR Invalid Note
PR Won't fix Note
Fixed
PR Fixed Note
56263 Provide strict address-space checking 4.8.0 in progress
52261 Add XMEGA support 4.7.0
