Avr-gcc Bugs
Bugs
PR Description Note
57516 Incorrect fixed-point rounding result in the overflow case
57506 Some devices are present twice in avr-mcus.def
57482] --help=optimizers reports a wrong list
Binutils / avr-libc
PR Description Note
binutils
binutils fixed
avr-libc
38125 Distribute gcrt1.S
Optimierung
PR Optimization Note
Debug-Info, Build, ...
Erweiterungen
PR Extensions Note
43745 Put VTABLES in Flash
Ungültig
PR Invalid Note
PR Won't fix Note
Fixed
PR Fixed Note
52261 Add XMEGA support 4.7.0
