Avr-gcc Bugs
Bugs
PR Description Note
57597 ICE: in get_section, Segmentation fault with -fmerge-all-constants varasm
Binutils / avr-libc
PR Description Note
binutils
binutils fixed
avr-libc
38125 Distribute gcrt1.S
Optimierung
PR Optimization Note
Debug-Info, Build, ...
Erweiterungen
PR Extensions Note
43745 Put VTABLES in Flash
Ungültig
PR Invalid Note
57501 crttn24a.o missing path with -mmcu=attiny24a → Caused by AVR-LibC #35407
PR Won't fix Note
Fixed
PR Fixed Note
57844 ICE: unrecognizable addqi3 insn with -msp8 and frame size of 128 bytes 4.8.2, 4.7.4
57631 Use assembler name for sanity checking of ISR names 4.8.2, 4.7.4
57516 Incorrect fixed-point rounding result in the overflow case 4.8.2
57506 Some devices are present twice in avr-mcus.def 4.8.2, 4.7.4
50293 -flto fails if GCC is installed in directory with space in path name 4.7.3
52261 Add XMEGA support 4.7.0
