IRMP - english
Version vom 26. April 2023, 13:54 Uhr von Ukw (Diskussion | Beiträge) (→‎Acknowledgment)
By Frank M. (ukw)
This is the English translation of the German IRMP documentation.
Waveform of an NEC-format remote control signal
Project Intent:
Because RC5 is not only outdated, but obsolete, and because more and more electronic devices from Asian consumer electronics manufacturers are found in the home, it is time to develop an IR decoder that can 'understand' about 90% of IR remotes that are used in our daily life.
This article introduces 'IRMP' as "Infrared Multi Protocol Decoder" in detail. The counterpart, the IRSND IR encoder, can be found in this document.
IRMP - Infrared Multi Protocol Decoder
Supported MCUs
IRMP runs on numerous MCU families:
AVR
  • ATtiny87, ATtiny167
  • ATtiny45, ATtiny85
  • ATtiny44, ATtiny84
  • ATmega8, ATmega16, ATmega32
  • ATmega162
  • ATmega164, ATmega324, ATmega644, ATmega644P, ATmega1284
  • ATmega88, ATmega88P, ATmega168, ATmega168P, ATmega328P
XMega
  • ATXmega128
PIC (CCS and XC8/C18 compiler)
  • PIC12F1840
  • PIC18F4520
STM32
  • STM32F4xx (tested on STM32F401RE/F411RE Nucleo, STM32F4 Discovery)
  • STM32F10x (tested on STM32F103C8T6 Mini Development Board)
  • STM32 with HAL library (NEW!)
STM8
  • STM8S103F3
TI Stellaris
  • LM4F120 Launchpad (ARM Cortex M4)
ESP8266 (NEW!)
  • ESP8266-EVB
TEENSY 3.0
  • MK20DX256VLH7 (ARM Cortex-M4 72MHz)
MBED (NEW!)
  • LPC1347 Cortex-M3 72 MHz
  • LPC4088 (Embedded Artists)
ChibiOS HAL (NEW!)
Connection of a IR receiver module to MCU
Supported IR Protocols
IRMP - the infrared remote decoder, which can decode several protocols at once - is capable of decoding the following protocols (in alphabetical order):
Supported Protocols
Protocol Vendor
A1TVBOX ADB (Advanced Digital Broadcast), e.g. A1 TV Box
APPLE Apple
ACP24 Stiebel Eltron
B&O Bang & Olufsen
BOSE Bose
DENON Denon, Sharp
FAN FAN, remote for fans
FDC FDC Keyboard
GRUNDIG Grundig
NOKIA Nokia, e.g. D-Box
IR60 (SDA2008) various European vendors
JVC JVC
KASEIKYO Panasonic, Technics, Denon and other vendors which are members of the Japanese "Association for Electric Home Appliances" (AEHA).
KATHREIN KATHREIN
LEGO Lego
LGAIR LG air conditioners
MATSUSHITA Matsushita
MITSU_HEAVY Mitsubishi air conditioners
NEC16 JVC, Daewoo
NEC42 JVC
MERLIN MERLIN remote (Pollin article number: 620 185)
NEC NEC, Yamaha, Canon, Tevion, Harman/Kardon, Hitachi, JVC, Pioneer, Toshiba, Xoro, Orion, generic and many other Asian vendors.
NETBOX Netbox
Nikon Nikon
NUBERT Nubert, e.g. Subwoofer Systems
ORTEK Ortek, Hama
PANASONIC PANASONIC video projectors
PENTAX PENTAX
RC5 Philips and other European vendors
RC6A Philips, Kathrein and others, e.g. XBOX
RC6 Philips and other European vendors
RCCAR RC Car: IR remote for RC toys
RCII T+A (NEW!)
RCMM Fujitsu-Siemens e.g. Activy keyboard
ROOMBA iRobot Roomba vacuum cleaner
S100 similar to RC5, but 14 instead of 13 bits and 56kHz modulation. Vendor unknown.
SAMSUNG32 Samsung
SAMSUNG48 various air conditioners
SAMSUNG Samsung
RUWIDO RUWIDO (e.g. T-Home Media Receiver, MERLIN keyboard(Pollin))
SIEMENS Siemens, e.g. Gigaset M740AV
SIRCS Sony
SPEAKER Speaker systems like X-Tensions
TECHNICS Technics
TELEFUNKEN Telefunken
THOMSON Thomson
VINCENT Vincent
New:
Starting with version 3.2, IRMP can also decode 433 MHz RF radio protocols.
Supported RF Protocols
Protocol Vendor
RF_GEN24 Generiv 24-bit format, e.g. Pollin 550666 radio-controlled receptacle
RF_X10 X10 PC RF remote control (Medion), Pollin 721815
Each of these protocols can be activated separately. If you want, you can activate all protocols. If you need only one protocol, you can disable all others. Only the code selected by the user will be compiled .
History
The IRMP source for the AVR and PIC MCUs was created as part of the Word Clock project.
Thread in Forum
Intention for an own IRMP article is the following thread in Projects&Code IRMP - Infrared Multi Protocol Decoder (in German language).
IR Protocols
Some vendors use their own proprietary protocols, such as Sony, Samsung, and Matsushita. Philips developed and used RC5. RC5 was seen in Europe as the standard IR protocol which was adopted by many European vendors. Nowadays RC5 is practically not used and can be considered "dead". Although the successor RC6 is used in current European hardware, it is also used rarely.
Japanese vendors also tried to establish their own standard, the so called Kaseikyo (or "Japan") protocol. With a word length of 48 bits, it is more versatile. But it has not found wide use, though it is found in some appliances.
Nowadays the NEC protocol is used (also mainly in Japanese devices) in both premium and generic products. I estimate the market share at 80% for the NEC protocol. Nearly all remotes in my daily use utilize the NEC IR code. This starts with the TV set, continues with the DVD player and the notebook remote all the way to the generic multimedia hard drive, just to mention a few examples.
NEC protocol, RGB remote control, T->A: 9.14ms, A->B: 4.42ms, B->C: 660us
Coding methods
IRMP supports the following IR coding methods:
The pulses are modulated - usually at 36 kHz or 38 kHz - to reduce environmental influences such as indoor lighting or sunlight.
Pulse Distance
Pulse distance coding can be identified by the following rule:
  • there is only one pulse length and there are two different space lengths
Pulse Width
Pulse width coding can be identified by the following rule:
  • there are two different pulse lengths and only one space length
Pulse width coding
Pulse Distance Width
This is a mix of pulse distance and pulse width coding. Often the sum of pulse and space length is constant. The rule is:
  • there are two different pulse lengths and two different space lengths.
Pulse distance width coding
Biphase
In biphase coding the order of pulse and space gives the bit value. Therefore a biphase boding can be identified by this criteria:
  • there is exactly one pulse and space length, as well as the double pulse/space length
Usually the length for the pulse and space are equal, meaning that the signal shape is symmetric. But IRMP also recognizes protocols which use different pulse and space lengths, for example the A1TVBOX protocol.
Biphase coding
Pulse Position
Pulse position coding is known from commmon UARTs. Here, every bit has a fixed length. Depending on the value (0 or 1), it is a pulse or a space.
Typical criteria for a pulse position protocol are:
  • there are multiples of a basic pulse/space length
A tabular listing of different IR protocols can be found here: IR Protocols in Detail. The specified timings are typical values. In some remotes they differ up to 40% in real life. Therefore IRMP uses minimum/maximum limits to be tolerant with the timing.
Protocol Detection
Most of the protocols IRMP decodes have something in common: they exhibit a start bit whose timing is unique.
According to this start bit timing, most protocols can be identified. IRMP measures the timing of the start bit and adjusts its timing tables "on-the-fly" to the discovered protocol. Subsequent bits can then be read sequentially without the need to first store a complete frame. Thus, IRMP does not wait to read a complete frame but starts decoding directly after detecting the first pulse.
If the start bit is not unique, IRMP proceeds in parallel with multiple possible protocols. For example with two candidate protocols, once plausible reasons disqualify one protocol, the other protocol is used.
Detection is implemented as an interrupt-driven state machine which is called at a frequency of typically 15000 times per second. Among others, the state machine has the following states:
  • detect the first pulse length of the start bit
  • detect the space length of the start bit
  • detect the space length of the first data bit
After that, the pulse and space lengths of the start bit are known. Now all enabled protocols are searched for these lengths. If a protocol matches, the timing table for this protocol is loaded. Subsequent bits are checked against the timing table to ensure they conform to it.
The state machine continues with the following states:
  • detect the spaces of the data bits
  • detect the pulse length of the data bits
  • check timing. If different, switch back to another valid IR protocol, otherwise return
  • detect the stop bit, if present in the protocol
  • check data for plausibility, like CRC or other redundancy bits
  • convert data to device address and command
  • detect code repetition by long key press, set corresponding flag
Indeed the state machine is even more complex because some protocols have no start bit (e.g. Denon) or have multiple start bits (4 in B&O) or have another sync bit within the frame (e.g. Samsung). These extra conditions are caught in the code by protocol-specific "special cases".
Switching to an other protocol can happen multiple times while receiving a frame, e.g. from NEC42 (42 bits) to NEC16 (8 bits + sync bit + 8 bits), if a premature sync bit is detected. Or from NEC/NEC42 (32/42 bits) to JVC (16 bits) if the stop bit occurs prematurely. It becomes difficult when, after detecting the start bit, two possible protocols use different coding methods, e.g. when the one protocol uses pulse distance coding and the other uses biphase coding (Manchester). In this case IRMP stores the necessary bits for both coding methods and later discards one or the other.
Furthermore, some remotes using particular protocols transmit repeat frames, either for redundancy (error detection) or for long key presses. Both kinds are detected by IRMP: error detection frames are detected by IRMP, but not passed to the application. Others are detected as long key presses and flagged by IRMP.
Download
Version 3.2.6, Date: 2021-01-27
Download stable version: Irmp.zip
Current development version of IRMP & IRSND:
Download Arduino library: GitHub or use Arduino "Tools / Manage Libraries..." and search for IRMP.
You can see the history of the software changes here: Software History
License
IRMP is Open Source Software and is released under the GPL v2, or (at your option) any later version.
Source Code
The source code can be easily compiled for AVR MCUs by loading the project file irmp.aps in AVR Studio 4.
For other development environments it is simple to create a project or makefile. The source includes:
Sample applications (main functions and timer configurations):
Important
include only irmp.h in your application:
#include "irmp.h"
All other include files are included within irmp.h. See also the sample application irmp-main-avr.c.
Furthermore, the preprocessor constant F_CPU in project or makefile must be defined. This should have at least the value of 8000000UL, processor speed should be at least 8 MHz. This applies to AVR targets and not for MCUs with PLL.
IRMP also runs on PIC processors. For the PIC-CCS compiler the necessary preprocessor defines are already set, such that irmp.c can be directly used in the CCS environment. Only a short interrupt service routine like
void  TIMER2_isr(void)
 irmp_ISR ();
must be added. The interrupt period time must be set to 66 µs (15 kHz).
For AVR processors you will find an example for the usage of IRMP in irmp-main-avr.c. The main things are the Timer initializing of the timer and the processing of received IR commands. The received protocol, the device address and the command will be output on the HW-UART.
For the Stellaris LM4F120 Launchpad from TI (ARM Cortex M4) is a propriate timer init function already integrated in irmp-main-avr.c.
IRMP can be used also with STM32 microcontrollers.
Another new implementation is available on the mbed platform.
avr-gcc Optimizations
From version 4.7.x of avr-gcc, the LTO option can be used to make the call of the external function irmp_ISR() from the main ISR more efficient. This improves the performance of the ISR a little.
Add the following compiler and linker options:
  • additional compiler option: -flto
  • additional linker options: -flto -Os
If you forget the additional linker option -Os, the binary will be significantly larger as it will not be optimized further. Also, the option -flto must be passed to the linker, otherwise link time optimization will not work.
Configuration
IRMP is configured by parameters in irmpconfig.h:
Settings in irmpconfig.h
IRMP will decode all protocols listed above in one ISR. For this, some settings are needed. These are set in irmpconfig.h.
F_INTERRUPTS
Number of interrupts per second. Should be set to a value from 10000 to 20000. The higher the value, the better the resolution and therefore the quality of detection. But a higher interrupt rate means also higher CPU load. A value of 15000 is usually a good compromise.
Default value:
#define F_INTERRUPTS                            15000      // interrupts per second
On AVR controllers, the irmp-main-avr.c example uses Timer1 with 16 bits of resolution. If for any reasons Timer1 is not available, you can also use Timer2 with 8 bits of resolution.
In that case, configure Timer2 as follows:
OCR2   =  (uint8_t) ((F_CPU / F_INTERRUPTS) / 8) - 1 + 0.5);   // Compare Register OCR2
TCCR2  = (1 << WGM21) | (1 << CS21);                           // CTC Mode, prescaler = 8
TIMSK  = 1 << OCIE2;                                           // enable Timer2 interrupt
The above example is valid for ATmega88/ATmega168/ATmega328. For other AVR MCUs check the datasheet.
You must not forget to change the ISR to Timer2 as well:
ISR(TIMER2_COMP_vect)
  (void) irmp_ISR();
IRMP_SUPPORT_xxx_PROTOCOL
Here you can select which protocols to enable in IRMP. Common protocols are emabled by default.
To enable additional protocols or disable others to save memory, set the corresponding values in irmpconfig.h.
// typical protocols, disable here!             Enable  Remarks                 F_INTERRUPTS            Program Space
#define IRMP_SUPPORT_SIRCS_PROTOCOL             1       // Sony SIRCS           >= 10000                 ~150 bytes
#define IRMP_SUPPORT_NEC_PROTOCOL               1       // NEC + APPLE          >= 10000                 ~300 bytes
#define IRMP_SUPPORT_SAMSUNG_PROTOCOL           1       // Samsung + Samsung32  >= 10000                 ~300 bytes
#define IRMP_SUPPORT_MATSUSHITA_PROTOCOL        1       // Matsushita           >= 10000                  ~50 bytes
#define IRMP_SUPPORT_KASEIKYO_PROTOCOL          1       // Kaseikyo             >= 10000                 ~250 bytes
// more protocols, enable here!                 Enable  Remarks                 F_INTERRUPTS            Program Space
#define IRMP_SUPPORT_DENON_PROTOCOL             0       // DENON, Sharp         >= 10000                 ~250 bytes
#define IRMP_SUPPORT_RC5_PROTOCOL               0       // RC5                  >= 10000                 ~250 bytes
#define IRMP_SUPPORT_RC6_PROTOCOL               0       // RC6 & RC6A           >= 10000                 ~250 bytes
#define IRMP_SUPPORT_JVC_PROTOCOL               0       // JVC                  >= 10000                 ~150 bytes
#define IRMP_SUPPORT_NEC16_PROTOCOL             0       // NEC16                >= 10000                 ~100 bytes
#define IRMP_SUPPORT_NEC42_PROTOCOL             0       // NEC42                >= 10000                 ~300 bytes
#define IRMP_SUPPORT_IR60_PROTOCOL              0       // IR60 (SDA2008)       >= 10000                 ~300 bytes
#define IRMP_SUPPORT_GRUNDIG_PROTOCOL           0       // Grundig              >= 10000                 ~300 bytes
#define IRMP_SUPPORT_SIEMENS_PROTOCOL           0       // Siemens Gigaset      >= 15000                 ~550 bytes
#define IRMP_SUPPORT_NOKIA_PROTOCOL             0       // Nokia                >= 10000                 ~300 bytes
// exotic protocols, enable here!               Enable  Remarks                 F_INTERRUPTS            Program Space
#define IRMP_SUPPORT_BOSE_PROTOCOL              0       // BOSE                 >= 10000                 ~150 bytes
#define IRMP_SUPPORT_KATHREIN_PROTOCOL          0       // Kathrein             >= 10000                 ~200 bytes
#define IRMP_SUPPORT_NUBERT_PROTOCOL            0       // NUBERT               >= 10000                  ~50 bytes
#define IRMP_SUPPORT_BANG_OLUFSEN_PROTOCOL      0       // Bang & Olufsen       >= 10000                 ~200 bytes
#define IRMP_SUPPORT_RECS80_PROTOCOL            0       // RECS80 (SAA3004)     >= 15000                  ~50 bytes
#define IRMP_SUPPORT_RECS80EXT_PROTOCOL         0       // RECS80EXT (SAA3008)  >= 15000                  ~50 bytes
#define IRMP_SUPPORT_THOMSON_PROTOCOL           0       // Thomson              >= 10000                 ~250 bytes
#define IRMP_SUPPORT_NIKON_PROTOCOL             0       // Nikon camera         >= 10000                 ~250 bytes
#define IRMP_SUPPORT_NETBOX_PROTOCOL            0       // Netbox keyboard      >= 10000                 ~400 bytes (PROTOTYPE!)
#define IRMP_SUPPORT_ORTEK_PROTOCOL             0       // ORTEK (Hama)         >= 10000                 ~150 bytes
#define IRMP_SUPPORT_TELEFUNKEN_PROTOCOL        0       // Telefunken 1560      >= 10000                 ~150 bytes
#define IRMP_SUPPORT_FDC_PROTOCOL               0       // FDC3402 keyboard     >= 10000 (better 15000)  ~150 bytes (~400 in combination with RC5)
#define IRMP_SUPPORT_RCCAR_PROTOCOL             0       // RC Car               >= 10000 (better 15000)  ~150 bytes (~500 in combination with RC5)
#define IRMP_SUPPORT_ROOMBA_PROTOCOL            0       // iRobot Roomba        >= 10000                 ~150 bytes
#define IRMP_SUPPORT_RUWIDO_PROTOCOL            0       // RUWIDO, T-Home       >= 15000                 ~550 bytes
#define IRMP_SUPPORT_A1TVBOX_PROTOCOL           0       // A1 TV BOX            >= 15000 (better 20000)  ~300 bytes
#define IRMP_SUPPORT_LEGO_PROTOCOL              0       // LEGO Power RC        >= 20000                 ~150 bytes
#define IRMP_SUPPORT_RCMM_PROTOCOL              0       // RCMM 12, 24, or 32    >= 20000                 ~150 bytes
Each IR protocol enabled in IRMP consumes the amount of code noted above. Here you can apply optimizations: for example, the modulation frequency of 455 kHz for the B&O protocol is far away from the frequencies that are used by other protocols. This usually requires a different IR receiver, so without that, you can disable these protocols. For example, you cannot receive the B&O protocol (455kHz) with a TSOP1738/TSOP31238.
Additionally, the SIEMENS/FDC/RCCAR can only be detected reliably at a frequency of 15 kHz or higher. For LEGO, 20 kHz is needed. To use these protocols, you must modify F_INTERRUPTS. Otherwise, during compilation you will get a warning and the corresponding protocols will automatically be disabled.
IRMP_PORT_LETTER + IRMP_BIT_NUMBER
This constant defines the pin where the IR receiver is connected.
Default value is PORT B6:
 * Change hardware pin here for ATMEL AVR
#if defined (ATMEL_AVR)                         // use PB6 as IR input on AVR
#  define IRMP_PORT_LETTER                      B
#  define IRMP_BIT_NUMBER                       6
These two values must match your hardware configuration.
This applies also to STM32 MCUs:
 * Change hardware pin here for ARM STM32
#elif defined (ARM_STM32)                       // use C13 as IR input on STM32
#  define IRMP_PORT_LETTER                      C
#  define IRMP_BIT_NUMBER                       13
When using STM32 HAL library, define the constants IRSND_Transmit_GPIO_Port and IRSND_Transmit_Pin in STM32Cube (Main.h). In this case, it is not necessary to change the constants in irmpconfig.h:
 * ARM STM32 with HAL section - don't change here, define IRSND_Transmit_GPIO_Port & IRSND_Transmit_Pin in STM32Cube (Main.h)
#elif defined (ARM_STM32_HAL)                                           // IRSND_Transmit_GPIO_Port & IRSND_Transmit_Pin must be defined in STM32Cube
#  define IRSND_PORT_LETTER                     IRSND_Transmit_GPIO_Port//Port of Transmit PWM Pin e.g.
#  define IRSND_BIT_NUMBER                      IRSND_Transmit_Pin      //Pim of Transmit PWM Pin e.g.
#  define IRSND_TIMER_HANDLER                   htim2                   //Handler of Timer e.g. htim (see tim.h)
#  define IRSND_TIMER_CHANNEL_NUMBER            TIM_CHANNEL_2           //Channel of the used Timer PWM Pin e.g. TIM_CHANNEL_2
#  define IRSND_TIMER_SPEED_APBX                64000000                //Speed of the corresponding APBx. (see STM32CubeMX: Clock Configuration)
And the corresponding section for STM8 MCUs:
 * Change hardware pin here for STM8
#elif defined (SDCC_STM8)                       // use PA1 as IR input on STM8
#  define IRMP_PORT_LETTER                      A
For PIC microcontrollers only the constant IRMP_PIN needs to be changed - depending on the compiler:
 * Change hardware pin here for PIC C18 compiler
#elif defined (PIC_C18)                         // use RB4 as IR input on PIC
#  define IRMP_PIN                              PORTBbits.RB4
 * Change hardware pin here for PIC CCS compiler
#elif defined (PIC_CCS)                         // use PB4 as IR input on PIC
#  define IRMP_PIN                              PIN_B4
When using ChibiOS HAL, define a pin with the name IR_IN in your board config (board.chcfg) of ChibiOS and regenerate the board files. To use another name for the pin, edit the constant IRMP_PIN in irmpconfig.h. Use the name of the pin from the board config and prefix it with "LINE_", as IRMP is using the "line" variant of the PAL interface:
 * Change hardware pin here for ChibiOS HAL
#elif defined(_CHIBIOS_HAL_)
#  define IRMP_PIN                              LINE_IR_IN              // use pin names as defined in the board config file, prefixed with "LINE_"
IRMP_HIGH_ACTIVE
Default value:
#  define IRMP_HIGH_ACTIVE                      0                       // set to 1 if you use a RF receiver!
Most RF receivers use active-high signals, so when using an RF receiver instead of an IR sensor, set this value to 1.
NEU:
IRMP_ENABLE_RELEASE_DETECTION
Default value:
#  define IRMP_ENABLE_RELEASE_DETECTION         0                       //  enable detection of key releases
Set this value to 1 to enable detection of button release events. The function irmp_get_data() then sets the IRMP_FLAG_RELEASE bit in the struct member irmp_data.flags once code transmission ends. See the example in the section Debouncing.
IRMP_USE_CALLBACK
Default value:
#define IRMP_USE_CALLBACK                      0        // flag: 0 = don't use callbacks, 1 = use callbacks, default is 0
When you turn on callbacks, any level change at the input causes the callback function to be called. This can be used to visualize incoming IR signals by driving another output pin.
Here is an example:
#define LED_PORT PORTD                                  // LED at PD6
#define LED_DDR  DDRD
#define LED_PIN  6
 * Called (back) from IRMP module
 * This example switches a LED (which is connected to Vcc)
void
led_callback (uint_fast8_t on)
    if (on)
       LED_PORT &= ~(1 << LED_PIN);
    else
       LED_PORT |= (1 << LED_PIN);
int
main ()
    irmp_init ();
    LED_DDR |= (1 << LED_PIN);         // LED pin to output
    LED_PORT |= (1 << LED_PIN);        // switch LED off (active low)
    irmp_set_callback_ptr (led_callback);
    sei ();
IRMP_USE_IDLE_CALL
Normally the irmp_ISR() function is called continuously at the F_INTERRUPTS (10-20kHz) frequency. The microcontroller can rarely enter an energy-saving sleep mode, or must constantly wake up from it. If power consumption is important, e.g. on battery power, this approach is not optimal.
If IRMP_USE_IDLE_CALL' is enabled, IRMP detects if no IR transmission is ongoing and then calls the function irmp_idle(). This is microcontroller-specific and must be provided and linked by the user. The microcontroller can then be put to sleep while there is no ongoing transmission, thus reducing energy consumption.
It is recommended to deactivate the timer interrupt in irmp_idle() and to activate a pin change interrupt instead. Then the microcontroller can be put to sleep. When a falling edge is detected on the IR input pin, the pin change interrupt is disabled, the timer is reenabled and irmp_ISR() is called immediately. You can find an example for the use of irmp_idle() in irmp-main-chibios.c.
Using IRMP purely with pin change interrupts and without timer interrupts is not supported.
IRMP_USE_EVENT
When using IRMP with ChibiOS/RT or ChibiOS/NIL, you can use their Event module to wake a thread as soon as new IR data is received and decoded.
Set the IRMP_USE_EVENT constant in irmpconfig.h to 1 to enable this. IRMP_EVENT_BIT definies the value in the Event bitmask that should symbolize the IRMP event. Use IRMP_EVENT_THREAD_PTR to define the variable name of the thread pointer that the event is sent to.
Change irmpconfig.h like this:
 * Use ChibiOS Events to signal that valid IR data was received
#if defined(_CHIBIOS_RT_) || defined(_CHIBIOS_NIL_)
#  ifndef IRMP_USE_EVENT
#    define IRMP_USE_EVENT                      1                     // 1: use event. 0: do not. default is 0
#  endif
#  if IRMP_USE_EVENT == 1 && !defined(IRMP_EVENT_BIT)
#    define IRMP_EVENT_BIT                      1                     // event flag or bit to send
#  endif
#  if IRMP_USE_EVENT == 1 && !defined(IRMP_EVENT_THREAD_PTR)
#    define IRMP_EVENT_THREAD_PTR               ir_receive_thread_p   // pointer to the thread to send the event to
extern thread_t *IRMP_EVENT_THREAD_PTR;                               // the pointer must be defined and initialized elsewhere
#  endif
#endif // _CHIBIOS_RT_ || _CHIBIOS_NIL_
Now you can use the event in your ChibiOS project like this:
thread_t *ir_receive_thread_p = NULL;
static THD_FUNCTION(IRThread, arg)
    ir_receive_thread_p = chThdGetSelfX();
    while (true)
        // wait for event sent from irmp_ISR
        chEvtWaitAnyTimeout(ALL_EVENTS,TIME_INFINITE);
            // use data in irmp_data
IRMP_LOGGING
With IRMP_LOGGING the logging of received IR frames can be turned on.
Default value:
#define IRMP_LOGGING                            0       // 1: log IR signal (scan), 0: do not. default is 0
Further documentation can be found here: Scanning Unknown IR Protocols.
Using IRMP
The protocols supported by IRMP use partly variable, partly fixed bit lengths from 2 up to 48 bits. These are described by preprocessor defines.
IRMP separates these IR frames into 3 sections:
1. protocol ID
2. address or vendor code
3. command
With the function
you can recall a decoded message. The return value is 1 if a message has been received, otherwise it is 0. In the first case the struct members
    irmp_data_p->protocol (8 Bit)
    irmp_data_p->address (16 Bit)
    irmp_data_p->command (16 Bit)
    irmp_data_p->flags (8 Bit)
contain valid information.
That means that ultimately, you have three values (protocol, address and command) that can be evaluated with an if or switch statement. Here is a sample decoder which listens for keys 1-9 on a remote:
   IRMP_DATA irmp_data;
      if (irmp_data.protocol == IRMP_NEC_PROTOCOL &&     // NEC protocol
          irmp_data.address == 0x1234)                   // Address 0x1234
         switch (irmp_data.command)
            case 0x0001: key1_pressed(); break;          // Key 1
            case 0x0002: key2_pressed(); break;          // Key 2
            case 0x0009: key9_pressed(); break;          // Key 9
Here are possible constants for irmp_data.protocol, see also irmpprotocols.h:
#define IRMP_SIRCS_PROTOCOL                      1              // Sony
#define IRMP_NEC_PROTOCOL                        2              // NEC, Pioneer, JVC, Toshiba, generic, etc.
#define IRMP_SAMSUNG_PROTOCOL                    3              // Samsung
#define IRMP_MATSUSHITA_PROTOCOL                 4              // Matsushita
#define IRMP_KASEIKYO_PROTOCOL                   5              // Kaseikyo (Panasonic, etc.)
#define IRMP_RECS80_PROTOCOL                     6              // Philips, Thomson, Nordmende, Telefunken, Saba
#define IRMP_RC5_PROTOCOL                        7              // Philips etc
#define IRMP_DENON_PROTOCOL                      8              // Denon, Sharp
#define IRMP_RC6_PROTOCOL                        9              // Philips etc
#define IRMP_SAMSUNG32_PROTOCOL                 10              // Samsung32: no sync pulse at bit 16, length 32 instead of 37
#define IRMP_APPLE_PROTOCOL                     11              // Apple, very similar to NEC
#define IRMP_RECS80EXT_PROTOCOL                 12              // Philips, Technisat, Thomson, Nordmende, Telefunken, Saba
#define IRMP_NUBERT_PROTOCOL                    13              // Nubert
#define IRMP_BANG_OLUFSEN_PROTOCOL              14              // Bang & Olufsen
#define IRMP_GRUNDIG_PROTOCOL                   15              // Grundig
#define IRMP_NOKIA_PROTOCOL                     16              // Nokia
#define IRMP_SIEMENS_PROTOCOL                   17              // Siemens, e.g. Gigaset
#define IRMP_FDC_PROTOCOL                       18              // FDC keyboard
#define IRMP_RCCAR_PROTOCOL                     19              // RC Car
#define IRMP_JVC_PROTOCOL                       20              // JVC (NEC with 16 bits)
#define IRMP_RC6A_PROTOCOL                      21              // RC6A, e.g. Kathrein, XBOX
#define IRMP_NIKON_PROTOCOL                     22              // Nikon
#define IRMP_RUWIDO_PROTOCOL                    23              // Ruwido, e.g. T-Home Media Receiver
#define IRMP_IR60_PROTOCOL                      24              // IR60 (SDA2008)
#define IRMP_KATHREIN_PROTOCOL                  25              // Kathrein
#define IRMP_NETBOX_PROTOCOL                    26              // Netbox keyboard (bitserial)
#define IRMP_NEC16_PROTOCOL                     27              // NEC with 16 bits (incl. sync)
#define IRMP_NEC42_PROTOCOL                     28              // NEC with 42 bits
#define IRMP_LEGO_PROTOCOL                      29              // LEGO Power Functions RC
#define IRMP_THOMSON_PROTOCOL                   30              // Thomson
#define IRMP_BOSE_PROTOCOL                      31              // BOSE
#define IRMP_A1TVBOX_PROTOCOL                   32              // A1 TV Box
#define IRMP_ORTEK_PROTOCOL                     33              // ORTEK - Hama
#define IRMP_TELEFUNKEN_PROTOCOL                34              // Telefunken (1560)
#define IRMP_ROOMBA_PROTOCOL                    35              // iRobot Roomba vacuum cleaner
#define IRMP_RCMM32_PROTOCOL                    36              // Fujitsu-Siemens (Activy remote control)
#define IRMP_RCMM24_PROTOCOL                    37              // Fujitsu-Siemens (Activy keyboard)
#define IRMP_RCMM12_PROTOCOL                    38              // Fujitsu-Siemens (Activy keyboard)
#define IRMP_SPEAKER_PROTOCOL                   39              // Another loudspeaker protocol, similar to Nubert
#define IRMP_LGAIR_PROTOCOL                     40              // LG air conditioner
#define IRMP_SAMSUNG48_PROTOCOL                 41              // air conditioner with Samsung protocol (48 bits)
#define IRMP_MERLIN_PROTOCOL                    42              // Merlin (Pollin 620 185)
#define IRMP_PENTAX_PROTOCOL                    43              // Pentax camera
#define IRMP_FAN_PROTOCOL                       44              // FAN (ventilator), very similar to NUBERT, but last bit is data bit instead of stop bit
#define IRMP_S100_PROTOCOL                      45              // very similar to RC5, but 14 instead of 13 data bits
#define IRMP_ACP24_PROTOCOL                     46              // Stiebel Eltron ACP24 air conditioner
#define IRMP_TECHNICS_PROTOCOL                  47              // Technics, similar to Matsushita, but 22 instead of 24 bits
#define IRMP_PANASONIC_PROTOCOL                 48              // Panasonic (video projector), start bits similar to KASEIKYO
#define IRMP_MITSU_HEAVY_PROTOCOL               49              // Mitsubishi heavy air conditioner, similar timing to Panasonic video projector
#define IRMP_VINCENT_PROTOCOL                   50              // Vincent
#define IRMP_SAMSUNGAH_PROTOCOL                 51              // Samsung AH
#define IRMP_IRMP16_PROTOCOL                    52              // IRMP specific protocol for data transfer, e.g. between two microcontrollers via IR
#define IRMP_GREE_PROTOCOL                      53              // Gree climate
#define IRMP_RCII_PROTOCOL                      54              // RC II Infrared Remote Control Protocol for FM8
#define IRMP_METZ_PROTOCOL                      55              // METZ
#define IRMP_ONKYO_PROTOCOL                     56              // Onkyo
The values of address and the command code of an unknown remote can be received and printed to UART or LCD. Then these values can be hard-coded in your decoder routine. Or you can write a learning routine, where you press keys to store the code into EEPROM. A sample for this can be found in Lernfähige IR-Fernbedienung mit IRMP.
Another example main function is included in the zip file, showing also the timer initialization.
Debouncing
To distinguish between a long key press or a single press, the IRMP_FLAG_REPETITION bit is provided. It is set in the struct member flags when a key on the remote is held, causing the same command to be repeated within a short period of time.
Example:
      // long key press
      // either:
      //   ignore the (repeated) key
      // or:
      //   use this information for a repeat function
    else
      // key was pressed again
This can be used to debounce the keys 0-9 by ignoring commands with the IRMP_FLAG_REPETITION bit set. For keys like 'VOLUME+' or 'VOLUME-' using the repetition can be useful, for example to fade a LED.
If you want to decode only single keys, you can reduce the block above to:
      // New key
      // ACTION!
NEW:
From version 3.2.2, key releases can be detected. In this case, the IRMP_FLAG_RELEASE flag is set once the remote control has ceased sending IR or RF frames.
Example:
    while (1)
            if (irmp_data.protocol == NEC_PROTOCOL && irmp_data.address == 0x1234)
                 if (irmp_data.command == 0x42 && irmp_data.flags == 0x00) // First frame, flags not set
                     motor_on ();
                 else if (irmp_data.flags & IRMP_FLAG_RELEASE)             // Key is released
                     motor_off ();
In the above example, a motor is turned on when a specific button on the remote control is pressed. The motor will not stop again until you release the button.
Important when evaluating IRMP_FLAG_RELEASE:
You must not rely on irmp_data.command to still contain the original command code (0x42 here). There are remote controls (e.g. RF remotes for remote controlled receptacles) which send a special key release code when the key is released. Simply check that the irmp_data.address matches before evaluating the flag.
This feature must be enabled explicitly in irmpconfig.h by changing the configuration variable IRMP_ENABLE_RELEASE_DETECTION.
Principles of Operation
The "workhorse" of IRMP is the interrupt service routine irmp_ISR() which should be called 15000 times per second. When using a different rate, the constant F_INTERRUPTS in irmpconfig.h needs to be modified accordingly.
First, irmp_ISR() detects the length and the type of the start bit(s) and uses this to determine the protocol in use. As soon as the protocol is identified, subsequent bits are parametrized to read them efficiently until the IR transmission is complete.
To cut off critics:
I know that the ISR is quite large. But since it behaves like a state machine, the effective executed code per cycle is relatively small. As long as the input is "dark" (and that is the case most of the time ;-)) the spent time is vanishingly short. In the WordClock project for example, 8 ISRs are called with the same timer, of which irmp_ISR() just one of many. With a MCU clock of at least 8 MHz, no timing problems occured. Consequently, I see no problem with the length of the ISR.
A crystal is not mandatory, it works well with the internal AVR oscillator. Remember to set the correct fuses for the CPU to run at 8 MHz, check irmp-main-avr.c for correct values for an ATMEGA88.
To enable logging in IRMP, modify the value of IRMP_LOGGING to 1 of irmpconfig.h on the line
When logging is enabled, the bright and dark phases are sent via UART at 9600 bits/s: 1=dark, 0=bright. The constants in the functions uart_init() and uart_putc() may need to be modified, depending on the AVR MCU used.
Note: for PIC microcontrollers there is a dedicated logging module named irmpextlog.c. This makes it possible to log via USB. This does not apply to the AVR version
By capturing these protocol scans with a terminal program and saving them to a text file, you can use these files to analyze the frames in order to add new protocols to IRMP - see next chapter.
If you have a remote control that is not supported by IRMP, you can send me (ukw) the scan files. Then I can check if the protocol is compatible with the IRMP model and modify the source code if applicable.
IRMP under Linux and Windows
Compilation
irmp.c can be compiled under Linux for testing IR scans in textfiles. In the subdirectory 'IR-Data' you will find such files that you can use as input files for IRMP.
To compile IRMP, enter:
   make -f makefile.lnx
This will generate 3 IRMP versions:
  • irmp-10kHz: Version for 10kHz scans
  • irmp-15kHz: Version for 15kHz scans
  • irmp-20kHz: Version for 20kHz scans
Starting IRMP
The calling syntax is:
 ./irmp-nnkHz [-l|-p|-a|-v] < scan-file
Options are mutually exclusive, so only one option per call is valid:
Option:
  -l  List             print a list with pulses and pauses
  -a analyze           analyse the pulses/pauses and write a "spectrum" in ASCII format
  -v verbose           verbose output
  -p  Print Timings    print a timing table for all protocols
Samples:
Normal Output
  ./irmp-10kHz < IR-Data/orion_vcr_07660BM070.txt
 # Taste 1
 # Taste 2
 # Taste 3
 # Taste 4
Output Lists
  ./irmp-10kHz -l < IR-Data/orion_vcr_07660BM070.txt
# Taste 1
pulse: 91 pause: 44
pulse: 6 pause: 5
pulse: 6 pause: 6
pulse: 6 pause: 5
pulse: 6 pause: 5
pulse: 6 pause: 5
pulse: 6 pause: 6
pulse: 6 pause: 5
pulse: 6 pause: 16
Analysis
  ./irmp-10kHz -a < IR-Data/orion_vcr_07660BM070.txt
START PULSES:
 90 o 1
 92 ooo 2
pulse avg: 91.0=9102.8 us, min: 90=9000.0 us, max: 92=9200.0 us, tol:  1.1%
START PAUSES:
 43 oo 1
pause avg: 44.2=4425.0 us, min: 43=4300.0 us, max: 45=4500.0 us, tol:  2.8%
PULSES:
  5 o 17
pulse avg:  6.5= 649.8 us, min:  5= 500.0 us, max:  7= 700.0 us, tol: 23.1%
PAUSES:
  4 ooooooooooooooooooooooo 169
  6 oooo 31
pause avg:  4.8= 477.5 us, min:  4= 400.0 us, max:  6= 600.0 us, tol: 25.7%
 15 oooooo 43
 17 oooooooooo 72
pause avg: 16.1=1605.4 us, min: 15=1500.0 us, max: 17=1700.0 us, tol:  6.6%
Here you see the measured times of all pulses and pauses (spaces) as horizontal bar graphs, whose distributions are not ideal bell curves due to the ASCII formatting. The narrower the measured peaks, the better the timing of the remote.
The above output can be read as:
  • the start bit has a pulse length between 9000 and 9200 µs, on average 9102 µs. The deviation from this average is about 1.1%
  • the start bit has a space length between 4300 and 4500 µs, the average is 4424 µs. The error is about 2.8%.
  • the pulse length of a data bit is between 500 and 700 µs, on average 650 µs, the error is (quite large!) 23.1%
Further there are two more spaces of different lengths (for bits 0 and 1). Reading these is left as an exercise to the reader. ;-)
Verbose Output
   ./irmp-10kHz -v < IR-Data/orion_vcr_07660BM070.txt
# 1 - IR-cmd: 0x0001
   0.200ms [starting pulse]
  13.700ms [start-bit: pulse = 91, pause = 44]
protocol = NEC, start bit timings: pulse:  62 - 118, pause:  30 -  60
pulse_1:   3 -   8
pause_1:  11 -  23
pulse_0:   3 -   8
pause_0:   3 -   8
command_offset: 16
command_len:     16
complete_len:    32
stop_bit:         1
  14.800ms [bit  0: pulse =   6, pause =   5] 0
  16.000ms [bit  1: pulse =   6, pause =   6] 0
  17.100ms [bit  2: pulse =   6, pause =   5] 0
  18.200ms [bit  3: pulse =   6, pause =   5] 0
  19.300ms [bit  4: pulse =   6, pause =   5] 0
  20.500ms [bit  5: pulse =   6, pause =   6] 0
  21.600ms [bit  6: pulse =   6, pause =   5] 0
  23.800ms [bit  7: pulse =   6, pause =  16] 1
  26.100ms [bit  8: pulse =   6, pause =  17] 1
  28.300ms [bit  9: pulse =   6, pause =  16] 1
  29.500ms [bit 10: pulse =   6, pause =   6] 0
  31.700ms [bit 11: pulse =   6, pause =  16] 1
  34.000ms [bit 12: pulse =   6, pause =  17] 1
  36.200ms [bit 13: pulse =   6, pause =  16] 1
  38.500ms [bit 14: pulse =   6, pause =  17] 1
  39.600ms [bit 15: pulse =   6, pause =   5] 0
  41.900ms [bit 16: pulse =   6, pause =  17] 1
  43.000ms [bit 17: pulse =   6, pause =   5] 0
  44.100ms [bit 18: pulse =   6, pause =   5] 0
  45.200ms [bit 19: pulse =   6, pause =   5] 0
  46.400ms [bit 20: pulse =   7, pause =   5] 0
  47.500ms [bit 21: pulse =   6, pause =   5] 0
  48.600ms [bit 22: pulse =   6, pause =   5] 0
  49.800ms [bit 23: pulse =   6, pause =   6] 0
  50.900ms [bit 24: pulse =   5, pause =   6] 0
  53.100ms [bit 25: pulse =   6, pause =  16] 1
  55.400ms [bit 26: pulse =   6, pause =  17] 1
  57.600ms [bit 27: pulse =   6, pause =  16] 1
  59.900ms [bit 28: pulse =   6, pause =  17] 1
  62.100ms [bit 29: pulse =   6, pause =  16] 1
  64.400ms [bit 30: pulse =   6, pause =  17] 1
  66.700ms [bit 31: pulse =   6, pause =  17] 1
stop bit detected
  67.300ms code detected, length = 32
  67.300ms p =  2, a = 0x7b80, c = 0x0001, f = 0x00
Starting under Windows
IRMP can be used under Windows as well:
  • start command line console
  • change to directory 'irmp'
  • enter:
           irmp-10kHz.exe < IR-Data\rc5x.txt
The same options apply as for the Linux version.
Long Output
As some output is very long, it is recommended to redirect the output to a file or filter for paging:
Linux:
           ./irmp-10kHz < IR-Data/rc5x.txt | less
Windows:
           irmp-10kHz.exe < IR-Data\rc5x.txt | more
Remote Controls
VCR|-
Protocol Name Device Device Address
NEC Toshiba CT-9859 TV 0x5F40
Elta 8848 MP 4 DVD player 0x7F00
AS-218 Askey TV-View CHP03X (TV tuner card) 0x3B86
Cyberhome ??? Cyberhome DVD player 0x6D72
WD TV Live Western Digital Multimediaplayer 0x1F30
Canon WL-DC100 Kamera Canon PowerShot G5 0xB1CA
NEC16 Daewoo VCR 0x0015
KASEIKYO Technics EUR646497 SA-AX 730 AV receiver 0x2002
Panasonic TV TX-L32EW6 TV 0x2002
RC5 Loewe Assist/RC3/RC4 TV (remote control in TV mode) 0x0000
RC6 Philips TV TV (remote control in TV mode) 0x0000
SIRCS Sony RM-816 TV (remote control in TV mode) 0x0000
DENON DENON RC970 AVR3805 AV receiver 0x0008
DENON RC970 DVD/CD player 0x0002
DENON RC970 Tuner 0x0006
SAMSUNG32 Samsung AA59-00484A LE40D550 TV 0x0707
LG AKB72033901 BD370 Blu-Ray player 0x2D2D
APPLE Apple Apple iPod Dock 0x0020
Cameras
IRMP supports more and more camera remotes like:
The array of commands is quite limited. Cameras understand only the shutter release command.
PENTAX protocol
Here is a short table for PENTAX cameras:
Command Function
0x0000 Shutter release
0x0001 change zoom level
Because there is no address designated in the PENTAX protocol, for transmitting, it should be set to 0x0000 in IRSND.
For Nikon cameras, a crystal should be used because these cameras are quite sensitive to timing accuracy.
IR Keyboards
From version 1.7.0 on, IRMP also supports IR keyboards, namely the FDC-3402 from www.pollin.de (partno. 711 056) for less than 2 Euro. (not available as of 19.09.2017 )
On detection of a key press the following data is returned:
Protocol number  (irmp_data.protocol): 18
Address          (irmp_data.address) : 0x003F
FDC-3402 keyboard
The following values are returned as commands (irmp_data.command) :
Code Key Code Key Code Key Code Key Code Key Code Key Code Key Code Key
Special keys on the left:
Code Key
0x0400 KEY_MOUSE_1
0x0800 KEY_MOUSE_2
The above values are for pressing a key. On release, IRMP sets also bit 8 (0x80) in the command.
Example:
     Key 'a' pressed:   0x001F
     Key 'a' released:  0x009F
The ON/OFF key is an exception: This key only sends a code for a key press, not for the release.
If a key is held, this is indicated in irmp_data.flag.
Example:
                          command   flag
     Key 'a' pressed:   0x001F    0x00
     Key 'a' pressed:   0x001F    0x01
     Key 'a' released:  0x009F    0x00
When key combinations (like a capital 'A') are pressed, then the return values are a sequence like this:
     Left SHIFT-key pressed:    0x0002
     Left SHIFT-key released:   0x0082
In irmp.c you will find a function get_fdc_key() for the Linux version, which can be used as a template to convert the FDC keycodes into the corresponding ASCII codes. This function can be used either locally on the MCU to decode the keycodes, or on the host system (e.g. PC) where the IRMP data structure is sent to. Therefore the function including preprocessor constants should be copied to your application code.
Here is an excerpt:
#define STATE_LEFT_SHIFT    0x01
#define STATE_RIGHT_SHIFT   0x02
#define STATE_LEFT_CTRL     0x04
#define STATE_LEFT_ALT      0x08
#define STATE_RIGHT_ALT     0x10
#define KEY_ESCAPE          0x1B            // keycode = 0x006e
#define KEY_MENUE           0x80            // keycode = 0x0070
#define KEY_BACK            0x81            // keycode = 0x0071
#define KEY_FORWARD         0x82            // keycode = 0x0072
#define KEY_ADDRESS         0x83            // keycode = 0x0073
#define KEY_WINDOW          0x84            // keycode = 0x0074
#define KEY_1ST_PAGE        0x85            // keycode = 0x0075
#define KEY_STOP            0x86            // keycode = 0x0076
#define KEY_MAIL            0x87            // keycode = 0x0077
#define KEY_FAVORITES       0x88            // keycode = 0x0078
#define KEY_NEW_PAGE        0x89            // keycode = 0x0079
#define KEY_SETUP           0x8A            // keycode = 0x007a
#define KEY_FONT            0x8B            // keycode = 0x007b
#define KEY_PRINT           0x8C            // keycode = 0x007c
#define KEY_ON_OFF          0x8E            // keycode = 0x007c
#define KEY_INSERT          0x90            // keycode = 0x004b
#define KEY_DELETE          0x91            // keycode = 0x004c
#define KEY_LEFT            0x92            // keycode = 0x004f
#define KEY_HOME            0x93            // keycode = 0x0050
#define KEY_END             0x94            // keycode = 0x0051
#define KEY_UP              0x95            // keycode = 0x0053
#define KEY_DOWN            0x96            // keycode = 0x0054
#define KEY_PAGE_UP         0x97            // keycode = 0x0055
#define KEY_PAGE_DOWN       0x98            // keycode = 0x0056
#define KEY_RIGHT           0x99            // keycode = 0x0059
#define KEY_MOUSE_1         0x9E            // keycode = 0x0400
#define KEY_MOUSE_2         0x9F            // keycode = 0x0800
static uint8_t
get_fdc_key (uint16_t cmd)
     // 0     1    2    3    4    5    6    7    8     9     A     B     C     D    E    F
         0,   '^', '1', '2', '3', '4', '5', '6', '7',  '8',  '9',  '0',  0xDF, '´', 0,   '\b',
        '\t', 'q', 'w', 'e', 'r', 't', 'z', 'u', 'i',  'o',  'p',  0xFC, '+',  0,   0,   'a',
        's',  'd', 'f', 'g', 'h', 'j', 'k', 'l', 0xF6, 0xE4, '#',  '\r', 0,    '<', 'y', 'x',
        'c',  'v', 'b', 'n', 'm', ',', '.', '-', 0,    0,    0,    0,    0,    ' ', 0,   0,
         0,   '°', '!', '"', '§', '$', '%', '&', '/',  '(',  ')',  '=',  '?',  '`', 0,   '\b',
        '\t', 'Q', 'W', 'E', 'R', 'T', 'Z', 'U', 'I',  'O',  'P',  0xDC, '*',  0,   0,   'A',
        'S',  'D', 'F', 'G', 'H', 'J', 'K', 'L', 0xD6, 0xC4, '\'', '\r', 0,    '>', 'Y', 'X',
        'C',  'V', 'B', 'N', 'M', ';', ':', '_', 0,    0,    0,    0,    0,    ' ', 0,   0
    static uint8_t state;
    uint8_t key = 0;
    switch (cmd)
        default:
                        switch (cmd)
                            case 0x0003: key = 0xB2;    break; // ²
                            case 0x0034: key = 0xB5;    break; // µ
                        else
                            key = key_table[cmd];
                    else
                        if (key_table[idx])
                            key = key_table[idx];
            break;
    return (key);
As a final example, use of the get_fdc_key() function:
        uint8_t key;
Non-printable characters are coded as follows:
Key Constant Value
ESC KEY_ESCAPE 0x1B
Menu KEY_MENUE 0x80
Back KEY_BACK 0x81
Forward KEY_FORWARD 0x82
Adress KEY_ADDRESS 0x83
Window KEY_WINDOW 0x84
1. Page KEY_1ST_PAGE 0x85
Stop KEY_STOP 0x86
Mail KEY_MAIL 0x87
Fav. KEY_FAVORITES 0x88
New Page KEY_NEW_PAGE 0x89
Setup KEY_SETUP 0x8A
Font KEY_FONT 0x8B
Print KEY_PRINT 0x8C
On/Off KEY_ON_OFF 0x8E
Backspace '\b' 0x08
CR/ENTER '\r' 0x0C
TAB '\t' 0x09
Insert KEY_INSERT 0x90
Delete KEY_DELETE 0x91
Cursor left KEY_LEFT 0x92
Pos1 KEY_HOME 0x93
End KEY_END 0x94
Cursor right KEY_UP 0x95
Cursor down KEY_DOWN 0x96
Page up KEY_PAGE_UP 0x97
Page down KEY_PAGE_DOWN 0x98
Cursor left KEY_RIGHT 0x99
Left Mousebutton KEY_MOUSE_1 0x9E
Right Mousebutton KEY_MOUSE_2 0x9F
The get_fdc_key() function considers the state of the Shift, Ctrl, and Alt keys. As a result, not only capital letters can be entered, but also special characters with Alt + key combinations, e.g. Alt + m -> µ or Alt + q -> @. You can also send Ctrl + A to Ctrl + Z by using the Ctrl key. The Caps Lock key is ignored, as I regard this key as the most unnecessary key at all ;-)
Appendix
Pulse Distance Protocols
Pulse Distance Coding
NEC + extended NEC
NEC + extended NEC Value
Frequency 36 kHz / 38 kHz
Coding pulse distance
Frame 1 start bit + 32 data bits + 1 stop bit
Data NEC 8 address bits + 8 inverted address bits + 8 command bits + 8 inverted command bits
Data ext. NEC 16 address bits + 8 command bits + 8 inverted command bits
Start bit 9000µs pulse, 4500µs pause
0 bit 560µs pulse, 560µs pause
1 bit 560µs pulse, 1690µs pause
Stop bit 560µs pulse
Repetition none
Key repeat 9000µs pulse, 2250µs pause, 560µs pulse, ~100ms pause
Bit order LSB first
JVC
JVC Value
Frequency 38 kHz
Frame 1 start bit + 16 data bits + 1 stop bit
Data 4 address bits + 12 command bits
Start bit 9000µs pulse, 4500µs pause, 6000µs pause if key repeat
Repetition none
Key repeat after pause of 25ms
Bit order LSB first
NEC16
NEC16 Value
Frequency 38 kHz
Frame 1 start bit + 8 address bits + 1 sync bit + 8 data bits + 1 stop bit
sync bit 560µs pulse, 4500µs pause
Repetition none
Key repeat after pause of 25ms?
Bit order LSB first
NEC42
NEC42 Value
Frequency 38 kHz?
Frame 1 start bit + 42 data bits + 1 stop bit
Data 13 address bits + 13 inverted address bits + 8 command bits + 8 inverted command bits
Repetition none
Key repeat after 110ms (beginning from start bit), 9000µs pulse, 2250µs pause, 560µs pulse
Bit order LSB first
ACP24
ACP24 Value
Frequency 38 kHz?
Frame 1 start bit + 70 data bits + 1 stop bit
Data 0 address bits + 70 command bits
Start bit 390µs pulse, 950µs pause
0 bit 390µs pulse, 950µs pause
1 bit 390µs pulse, 13000µs pause
Stop bit 390µs pulse
Repetition none
Key repeat unknown
Bit order MSB first
LGAIR
LGAIR Value
Frequency 38 kHz
Frame 1 start bit + 28 data bits + 1 stop bit
Data 8 address bits + 16 command bits + 4 checksum bits
Start bit 9000µs pulse, 4500µs pause (identical to NEC)
0 bit 560µs pulse, 560µs pause (identical to NEC)
1 bit 560µs pulse, 1690µs pause (identical to NEC)
Stop bit 560µs pulse (identical to NEC)
Repetition none
Key repeat unknown
Bit order MSB first (differs from NEC)
SAMSUNG
SAMSUNG Value
Frequency ?? kHz
Frame 1 start bit + 16 data(1) bits + 1 sync bit + 20 data(2)-bits + 1 stop bit
Data(1) 16 address bits
Data(2) 4 ID bits + 8 command bits + 8 inverted command bits
Start bit 4500µs pulse, 4500µs pause
0 bit 550µs pulse, 550µs pause
1 bit 550µs pulse, 1650µs pause
sync bit 550µs pulse, 4500µs pause
Stop bit 550µs pulse
Repetition none
Key repeat after approx. 100ms
Bit order LSB first
SAMSUNG32
SAMSUNG32 Value
Frequency 38 kHz
Data 16 address bits + 16 command bits
Repetition none
Key repeat after approx. 47msec
Bit order LSB first
SAMSUNG48
SAMSUNG48 Value
Frequency 38 kHz
Frame 1 start bit + 48 data bits + 1 stop bit
Data 16 address bits + 32 command bits
Command 8 bits + 8 inverted bits + 8 bits + 8 inverted bits
Repetition one after approx. 5 msec
Key repeat after approx. 45 msec
Bit order LSB first
MATSUSHITA
MATSUSHITA Value
Frequency 36 kHz
Coding pulse distance, timing identical to TECHNICS
Frame 1 start bit + 24 data bits + 1 stop bit
Data 6 customer bits + 6 command bits + 12 address bits
Start bit 3488µs pulse, 3488µs pause
0 bit 872µs pulse, 872µs pause
1 bit 872µs pulse, 2616µs pause
Stop bit 872µs pulse
Repetition none
Key repeat after 40ms pause
Bit order LSB first?
TECHNICS
TECHNICS Value
Frequency 36 kHz?
Coding pulse distance, timing identical to MATSUSHITA
Frame 1 start bit + 22 data bits + 1 stop bit
Data 11 command bits + 11 inverted command bits
Repetition none
KASEIKYO
KASEIKYO Value
Frequency 38 kHz
Data 16 customer bits + 4 parity bits + 4 genre1 bits + 4 genre2 bits + 10 command bits + 2 ID bits + 8 parity bits
Start bit 3380µs pulse, 1690µs pause
0 bit 423µs pulse, 423µs pause
1 bit 423µs pulse, 1269µs pause
Stop bit 423µs pulse
Repetition none
Key repeat after approx. 80ms pause
RECS80
RECS80 Value
Frequency 38 kHz
Frame 1 start bits + 10 data bits + 1 stop bit
Data 1 toggle bit + 3 address bits + 6 command bits
Start bit 158µs pulse, 7432µs pause
0 bit 158µs pulse, 4902µs pause
1 bit 158µs pulse, 7432µs pause
Stop bit 158µs pulse
Repetition none
Bit order MSB first
RECS80EXT
RECS80EXT Value
Frequency 38 kHz
Frame 2 start bits + 11 data bits + 1 stop bit
Data 1 toggle bit + 4 address bits + 6 command bits
Start bit 158µs pulse, 3637µs pause
Repetition none
Bit order MSB first
DENON
DENON Value
Frequency 38 kHz (in practice, theoretically: 32 kHz)
Frame 0 start bits + 15 data bits + 1 stop bit
Data 5 address bits + 10 command bits
Command 6 data bits + 2 extension bits + 2 data construction bits (normal: 00, inverted: 11)
Start bit none
0 bit 310µs pulse, 745µs pause (in practice, theoretically: 275µs pulse, 775µs pause)
1 bit 310µs pulse, 1780µs pause (in practice, theoretically: 275µs pulse, 1900µs pause)
Stop bit 310µs pulse (310µs pulse, 745µs pause (in practice, theoretically: 275µs pulse)
Repetition after 65ms with inverted command bits (data construction bits = 11)
Key repeat both frames after 65ms
Bit order MSB first
APPLE
APPLE Value
Frequency 38 kHz?
Data 16 address bits + 11100000 + 8 command bits
Start bit see NEC
0 bit see NEC
1 bit see NEC
Stop bit see NEC
Repetition none
Bit order LSB first
BOSE
BOSE Value
Frequency 38 kHz?
Data 0 address bits + 8 command bits + 8 inverted command bits
Start bit 1060µs pulse, 1425µs pause
0 bit 550µs pulse, 437µs pause
1 bit 550µs pulse, 1425µs pause
Repetition none
Key repeat unknown
Bit order LSB first
B&O
B&O Value
Frequency 455 kHz
Frame 4 start bits + 16 data bits + 1 trailer bit + 1 stop bit
Data 0 address bits + 16 command bits
Start bit 1 200µs pulse, 2925µs pause
Start bit 2 200µs pulse, 2925µs pause
Start bit 3 200µs pulse, 15425µs pause
Start bit 4 200µs pulse, 2925µs pause
0 bit 200µs pulse, 2925µs pause
1 bit 200µs pulse, 9175µs pause
R bit 200µs pulse, 6050µs pause, repeats the last bit
Trailer bit 200µs pulse, 12300µs pause
Stop bit 200µs pulse
Repetition none
Bit order MSB first
FDC
FDC Value
Frequency 38 kHz
Frame 1 start bit + 40 data bits + 1 stop bit
Data 8 address bits + 12 x 0 bits + 4 press/release bits + 8 command bits + 8 inverted command bits
Start bit 2085µs pulse, 966µs pause
0 bit 300µs pulse, 220µs pause
1 bit 300µs pulse, 715µs pause
Stop bit 300µs pulse
Repetition none
Press Key press/release bits = 0000
Release Key press/release bits = 1111
Key repeat after pause of approx. 60ms
Bit order LSB first
Nikon
Nikon Value
Frequency 38 kHz?
Frame 1 start bit + 2 data bits + 1 stop bit
Data 2 command bits
Start bit 2200µs pulse, 27100µs pause
0 bit 500µs pulse, 1500µs pause
1 bit 500µs pulse, 3500µs pause
Stop bit 500µs pulse
Repetition none
Key repeat unknown
Bit order MSB first
PANASONIC
PANASONIC Value
Frequency 38 kHz?
Frame 1 start bit + 56 data bits + 1 stop bit
Data 24 bits (010000000000010000000001) + 16 address bits + 16 command bits
Start bit 3600µs pulse, 1600µs pause
0 bit 565µs pulse, 316µs pause
1 bit 565µs pulse, 1140µs pause
Stop bit 565µs pulse
Repetition none
Key repeat unknown
PENTAX
PENTAX Value
Frequency 38 kHz
Frame 1 start bit + 6 data bits + 1 stop bit
Data 6 command bits
0 bit 1000µs pulse, 1000µs pause
1 bit 1000µs pulse, 3000µs pause
Stop bit 1000µs pulse
Repetition none
Key repeat unknown
Bit order MSB first
KATHREIN
KATHREIN Value
Frequency 38 kHz?
Frame 1 start bit + 11 data bits + 1 stop bit
Data 4 address bits + 7 command bits
Start bit 210µs pulse, 6218µs pause
0 bit 210µs pulse, 1400µs pause
1 bit 210µs pulse, 3000µs pause
Stop bit 210µs pulse
Repetition none
Key repeat after 35ms?
Bit order MSB first
LEGO
LEGO Value
Frequency 38 kHz?
Data 12 command bits + 4 crc bits
Start bit 158µs pulse, 1026µs pause
0 bit 158µs pulse, 263µs pause
1 bit 158µs pulse, 553µs pause
Repetition none
Key repeat unknown
Bit order MSB first
VINCENT
VINCENT Value
Frequency 38 kHz?
Data 16 address bits + 8 command bits + 8 repeated command bits
Start bit 2500µs pulse, 4600µs pause
1 bit 550µs pulse, 1540µs pause
Repetition none
Key repeat unknown
Bit order MSB first?
THOMSON
THOMSON Value
Frequency 33 kHz
Frame 0 start bits + 12 data bits + 1 stop bit
Data 4 address bits + 1 toggle bit + 7 command bits
0 bit 550µs pulse, 2000µs pause
1 bit 550µs pulse, 4500µs pause
Repetition none
TELEFUNKEN
TELEFUNKEN Value
Frequency 38 kHz?
Frame 1 start bit + 15 data bits + 1 stop bit
Data 0 address bits + 15 command bits
Start bit 600µs pulse, 1500µs pause
0 bit 600µs pulse, 600µs pause
1 bit 600µs pulse, 1500µs pause
Stop bit 600µs pulse
Repetition none
Key repeat unknown
RCCAR
RCCAR Value
Frequency 38 kHz?
Frame 1 start bit + 13 data bits + 1 stop bit
Data 13 command bits
Start bit 2000µs pulse, 2000µs pause
0 bit 600µs pulse, 900µs pause
1 bit 600µs pulse, 450µs pause
Repetition none
Key repeat after 40ms?
Bit order LSB first
RCMM
RCMM Value
Frequency 36 kHz
Frame RCMM32 1 start bit + 32 data bits + 1 stop bit
Frame RCMM24 1 start bit + 24 data bits + 1 stop bit
Frame RCMM12 1 start bit + 12 data bits + 1 stop bit
Data RCMM32 16 address bits (= 4 mode bits + 12 device bits) + 1 toggle bit + 15 command bits
Data RCMM24 16 address bits (= 4 mode bits + 12 device bits) + 1 toggle bit + 7 command bits
Data RCMM12 4 address bits (= 2 mode bits + 2 device bits) + 8 command bits
Start bit 500µs pulse, 220µs pause
00 bits 230µs pulse, 220µs pause
01 bits 230µs pulse, 380µs pause
10 bits 230µs pulse, 550µs pause
11 bits 230µs pulse, 720µs pause
Stop bit 230µs pulse
Repetition none
Key repeat after 80ms
Bit order LSB first
Pulse Width Protocols
Pulse Width Coding
SIRCS
SIRCS Value
Frequency 40 kHz
Coding pulse width
Frame 1 start bit + 12-20 data bits, no stop bit
Data 7 command bits + 5 address bits + up to 8 additional bits
Start bit 2400µs pulse, 600µs pause
1 bit 1200µs pulse, 600µs pause
Repetition twice after approx. 25ms, that means: 2nd and 3rd frame
Key repeat starting with 4th identical frame, distance approx. 25ms
Bit order LSB first
Pulse distance Width Protocols
Pulse Distance Width Coding
NUBERT
NUBERT Value
Frequency 36 kHz?
Coding pulse distance width
Frame 1 start bit + 10 data bits + 1 stop bit
Data 0 address bits + 10 command bits ?
Start bit 1340µs pulse, 340µs pause
0 bit 500µs pulse, 1300µs pause
1 bit 1340µs pulse, 340µs pause
Repetition once after 35ms
Key repeat 3rd, 5th, 7th etc. indentical frame
FAN
This protocol is very similar to NUBERT, but here it will be sent only one frame. Additionally there are 11 instead of 10 data bits and no stop bit. The pause time between frame repetitions is substantial lower.
FAN Value
Frequency 36 kHz
Frame 1 start bit + 11 data bits + 0 stop bits
Data 0 address bits + 11 command bits
Start bit 1280µs pulse, 380µs pause
0 bit 380µs pulse, 1280µs pause
1 bit 1280µs pulse, 380µs pause
Repetition none
Key repeat after 6.6ms pause
Bit order MSB first
SPEAKER
SPEAKER Value
Frequency 38 kHz?
Start bit 440µs pulse, 1250µs pause
0 bit 440µs pulse, 1250µs pause
1 bit 1250µs pulse, 440µs pause
Stop bit 440µs pulse
Repetition once after approx. 38ms
Key repeat 3rd, 5th, 7th ... identical frame
ROOMBA
ROOMBA Value
Frequency 38 kHz?
Frame 1 start bit + 7 data bits + 0 stop bits
Data 0 address bits + 7 command bits
Start bit 2790µs pulse, 930µs pause
0 bit 930µs pulse, 2790µs pause
1 bit 2790µs pulse, 930µs pause
Stop bit no stop bit
Repetition 3 times after 18ms?
Key repeat unknown
Bit order MSB first
Biphase Protocols
Biphase Coding
RC5 + RC5X
RC5 + RC5X Value
Frequency 36 kHz
Coding Biphase (Manchester)
Frame RC5 2 start bits + 12 data bits + 0 stop bits
Data RC5 1 toggle bit + 5 address bits + 6 command bits
Frame RC5X 1 start bit + 13 data bits + 0 stop bits
Data RC5X 1 inverteds command bit + 1 toggle bit + 5 address bits + 6 command bits
Start bit 889µs pause, 889µs pulse
0 bit 889µs pulse, 889µs pause
1 bit 889µs pause, 889µs pulse
Repetition none
Bit order MSB first
RCII
RCII Value
Frequency 31.25 kHz
Frame 1 pre bit + 1 start bit + 9 data bits + 0 stop bits
Data 0 address bits + 9 command bits
Pre Bit 512µs pulse, 2560µs pause
Start bit 1024µs pulse, no space
0 bit 512µs pause, 512µs pulse
1 bit 512µs pulse, 512µs pause
Repetition none
Key repeat after approx. 118ms
Remarks An end command (111111111 = 0x1FF) is sent immediately after the button is released.
Bit-Order MSB first
S100
Similar to RC5x, but 14 instead of 13 data bits and 56kHz modulation
S100 Value
Frequency 56 kHz
Frame 1 start bit + 14 data bits + 0 stop bits
Data 1 inverted command bit + 1 toggle bit + 5 address bits + 7 command bits
Repetition none
Bit order MSB first
RC6 + RC6A
RC6 + RC6A Value
Frequency 36 kHz
Frame RC6 1 start bit + 1 bit "1" + 3 mode bits ("000") + 1 toggle bit + 16 data bits + 2666µs pause
Frame RC6A 1 start bit + 1 bit "1" + 3 mode bits ("110") + 1 toggle bit + 31 data bits + 2666µs pause
Data RC6 8 address bits + 8 Command Bits
Data RC6A "1" + 14 customer bits + 8 system bits + 8 command bits
Data RC6A Pace (Sky) "1" + 3 mode bits ("110") + 1 toggle bit (UNUSED "0") + 16 bits + 1 toggle(!) + 15 command bits
Start bit 2666µs pulse, 889µs pause
Toggle 0 bit 889µs pause, 889µs pulse
Toggle 1 bit 889µs pulse, 889µs pause
0 bit 444µs pause, 444µs pulse
1 bit 444µs pulse, 444µs pause
Repetition none
Bit order MSB first
GRUNDIG + NOKIA
GRUNDIG + NOKIA Value
Frequency 38 kHz (?)
Frame packet 1 start frame + 19.968ms pause + N data frames + 117.76ms pause + 1 stop frame
Start frame 1 pre bit + 1 start bit + 9 data bits (all 1) + 0 stop bits
Data frame 1 pre bit + 1 start bit + 9 data bits + 0 stop bits
Stop frame 1 pre bit + 1 start bit + 9 data bits (all 1) + 0 stop bits
Data Grundig 9 command bits + 0 address bits
Data Nokia 8 command bits + 8 address bits
Pre bit 528µs pulse, 2639µs pause
Start bit 528µs pulse, 528µs pause
0 bit 528µs pause, 528µs pulse
1 bit 528µs pulse, 528µs pause
Repetition none
Key repeat after approx. 117.76ms
Bit order LSB first
IR60 (SDA2008)
IR60 Value
Frequency 30 kHz
Start frame 1 start bit + 101111 + 0 stop bits + 22ms pause
Data frame 1 start bit + 7 data bits + 0 stop bits
Start bit 528µs pulse, 2639µs pause
Repetition none
Bit order LSB first
SIEMENS + RUWIDO
SIEMENS + RUWIDO Value
Frequency 36 kHz? (Merlin keyboard with Ruwido protocol: 56 kHz)
Frame Siemens 1 start bit + 22 data bits + 0 stop bits
Frame Ruwido 1 start bit + 17 data bits + 0 stop bits
Data Siemens 11 address bits + 10 command bits + 1 inverted bit (preceding bit inverted)
Data Ruwido 9 address bits + 7 command bits + 1 inverted bit (preceding bit inverted)
Start bit 275µs pulse, 275µs pause
0 bit 275µs pause, 275µs pulse
1 bit 275µs pulse, 275µs pause
Repetition once with repeat bit set (?)
Key repeat after approx. 100ms (?)
Bit order MSB first
A1TVBOX
A1TVBOX Value
Frequency 38 kHz?
Coding Biphase (Manchester) asymmetric
Frame 2 start bits + 16 data bits + 0 stop bits
Data 8 address bits + 8 command bits
Start bits "10", also 250µs pulse, 150µs + 150µs pause, 250µs pulse
0 bit 150µs pause, 250µs pulse
1 bit 250µs pulse, 150µs pause
Repetition none
Key repeat unknown
Bit order MSB first
MERLIN
MERLIN Value
Frequency 56 kHz
Frame 2 start bits + 18 data bits + 0 stop bits
Data 8 address bits + 10 command bits
Start bits "10", also 210µs pulse, 210µs + 210µs pause, 210µs pulse
0 bit 210µs pause, 210µs pulse
1 bit 210µs pulse, 210µs pause
Repetition none
Key repeat unknown
Bit order MSB first
ORTEK
ORTEK Value
Frequency 38 kHz?
Coding Biphase (Manchester) symmetric
Data 6 address bits + 2 special bits + 6 command bits + 4 special bits
Start bit 2000µs pulse, 1000µs pause
0 bit 500µs pause, 500µs pulse
1 bit 500µs pulse, 500µs pause
Repetition 2 additional frames with special bits set
Key repeat only repeats the 2nd frame
Bit order MSB first
Pulse Position Protocols
NETBOX
NETBOX Value
Frequency 38 kHz?
Coding pulse position
Frame 1 start bit + 16 data bits, no stop bit
Data 3 address bits + 13 command bits
Start bit 2400µs pulse, 800µs pause
Bit Length 800µs
Repetition none
Key repeat after approx. 35ms?
Bit order LSB first
Software History
Changes of IRMP in 3.2.x
Version 3.2.6:
  • 2021-01-27: New IR Protocol: MELINERA
  • 2021-01-27: Protocol LEGO: Improved timing
  • 2021-01-27: Protocol RUWIDO: Improved timing
  • 2021-01-27: Protocol NEC: Implemented send of raw NEC repetition frames
Version 3.2.3:
Version 3.2.2:
  • 2020-07-09: Additional recognition of the radio channels with the RF_X10 protocol
  • 2020-07-09: Improved RF frame detection with new stop bit handling.
  • 2020-07-09: Improved detection of RF_GEN24 protocols
  • 2020-07-09: NEU: Detection if/when a remote control button is released, see chapter Debouncing.
Version 3.2.1:
  • 2020-06-22: Mini bugfix
Version 3.2.0:
  • 2020-06-22: Support of 433MHz RF modules
  • 2020-06-22: New protocol: RF_GEN24
  • 2020-06-22: New protocol: X10
Older Versions
  • 2019-08-26: New protocol: METZ
  • 2019-08-26: New protocol: ONKYO
  • 2018-09-10: New protocol: RCII
  • 2018-09-06: Added support of STM32 mit HAL-Library
  • 2018-08-30: New option: IRMP_USE_IDLE_CALL
  • 2018-08-29: Port to ChibiOS
  • 2018-08-29: New protocol: GREE
  • 2018-02-19: corrected handling of irmp_flags for invalid frames
  • 2017-08-25: New protocol: IRMP16 for transparent 16 bit data communication
  • 2016-11-18: Corrected buffer overflow in irmp-main-avr-uart.c
  • 2016-09-19: New protocol VINCENT
  • 2016-09-09: New protocol Mitsubishi Heavy (air conditioner)
  • 2016-09-09: Some modifications for Compiler PIC C18
  • 2016-01-16: Some corrections of port to ESP8266
  • 2016-01-16: Added port to MBED
  • 2016-01-16: Added several hardware dependent example main source files
  • 2015-11-17: New protocol: PANASONIC (Beamer)
  • 2015-11-17: Port to ESP8266
  • 2015-11-17: Port to Teensy (3.x)
  • 2015-11-10: Added support for STM8 microcontroller
  • 2015-09-20: New protocol: TECHNICS
  • 2015-06-15: New protocol: ACP24
  • 2015-05-29: New protocol: S100
  • 2015-05-29: Some smaller corrections
  • 2015-05-28: Added Logging for XMega
  • 2015-05-28: Timing corrections for FAN protocol
  • 2015-05-27: New protocol: MERLIN
  • 2015-05-27: New protocol: FAN
  • 2015-05-18: Added F_CPU macro for STM32L1XX
  • 2015-05-18: Some corrections for XMega port
  • 2015-04-23: New protocol: PENTAX
  • 2015-04-23: Port to AVR XMega
  • 2014-09-19: Bugfix: added missing newline before #else
  • 2014-09-18: Added logging for ARM STM32F10X
  • 2014-09-17: Corrected PROGMEM access to array irmp_protocol_names[].
  • 2014-09-15: Changed timing tolerances for KASEIKYO protocol
  • 2014-09-15: Moved irmp_protocol_names to flash, additional UART routines in irmp-main-avr-uart.c
  • 2014-07-21: Port to PIC 12F1840
  • 2014-07-09: New protocol: SAMSUNG48
  • 2014-07-09: Some small corrections
  • 2014-07-01: Added logging for ARM_STM32F4XX
  • 2014-07-01: IRMP port for PIC XC8 compiler, removed variadic macros because of stupid XC8 compiler :-(
  • 2014-06-05: New protocol: LGAIR
  • 2014-05-30: New protocol: SPEAKER
  • 2014-05-30: Optimized timings for SAMSUNG protocol
  • 2014-02-20: Corrected decoding of SIEMENS protocol
  • 2014-02-19: New protocols: RCMM32, RCMM24 and RCMM12
  • 2014-09-17: Optimized timing for ROOMBA
  • 2013-04-09: New protocol: ROOMBA
  • 2013-04-09: Optimized detection of ORTEK (Hama) frames
  • 2013-03-19: New protocol: ORTEK (Hama)
  • 2013-03-19: New protocol: TELEFUNKEN
  • 2013-03-12: Changed timing tolerancies for RECS80- and RECS80EXT protocol
  • 2013-01-21: Corrected detection of repetition frame beim DENON protocol
  • 2013-01-17: Corrected frame detection beim DENON protocol
  • 2012-12-11: New protocol: A1TVBOX
  • 2012-12-07: Improved detection von DENON repetition frame
  • 2012-11-19: Port to Stellaris LM4F120 TI Launchpad (ARM Cortex M4)
  • 2012-11-06: Corrected DENON frame detection
  • 2012-10-26: Some timer corrections and adaptations for Arduino
  • 2012-07-11: New protocol: BOSE
  • 2012-06-18: Added support for ATtiny87/167
  • 2012-06-05: Some smaller corrections of port to ARM STM32
  • 2012-06-05: Correction of include in irmpextlog.c
  • 2012-06-05: Bugfix, if only NEC and NEC42 activated
  • 2012-05-23: Port to ARM STM32
  • 2012-05-23: Bugfix frame detection for DENON protocol
  • 2012-02-27: Bugfix in IR60-Decoder
  • 2012-02-27: Bugfix in CRC calculation of KASEIKYO frames
  • 2012-02-27: Port to C18 Compiler for PIC microcontrollers
  • 2012-02-13: Bugfix: most significant bit in Address wrong in NEC protocol, if NEC42 protocol activated, too
  • 2012-02-13: Corrected timing of SAMSUNG- and SAMSUNG32 protocol
  • 2012-02-13: KASEIKYO: Genre2 bits will be now stored in upper nibble of flags
  • 2011-09-20: New protocol: KATHREIN
  • 2011-09-20: New protocol: RUWIDO
  • 2011-09-20: New protocol: THOMSON
  • 2011-09-20: New protocol: IR60 (SDA2008)
  • 2011-09-20: New protocol: LEGO
  • 2011-09-20: New protocol: NEC16
  • 2011-09-20: New protocol: NEC42
  • 2011-09-20: New protocol: NETBOX
  • 2011-09-20: Port to ATtiny84 and ATtiny85
  • 2011-09-20: Improved key repetition detection in RC5 protocol
  • 2011-09-20: Improved decoding of Biphase protocols
  • 2011-09-20: Fixed some smaller bugs in RECS80 decoder
  • 2011-09-20: Corrected detection of additional bits in SIRCS protocol
  • 2011-01-18: Some corrections for SIEMENS protocol
  • 2011-01-18: New protocol: Nikon
  • 2011-01-18: SIRCS: additional bits (>12) will be stored in address
  • 2011-01-18: Some timing corrections for DENON protocol
  • 2010-09-04: Bugfix for F_INTERRUPTS >= 16000
  • 2010-09-02: New protocol: RC6A
  • 2010-08-29: New protocol: JVC
  • 2010-08-29: KASEIKYO protocol: genre bits will be now stored
  • 2010-08-29: KASEIKYO protocol: Improved handling of repetition frames
  • 2010-08-29: Improved support of APPLE protocols.
  • 2010-07-01: Bugfix: added a timeout for NEC repetition frames. This avoids 'ghost commands'.
  • 2010-06-26: Bugfix: deactivated RECS80, RECS80EXT & SIEMENS if interrupts frequency is low
  • 2010-06-25: New protocol: RCCAR
  • 2010-06-25: Extended keyboard detection for FDC protocol (IR keyboard)
  • 2010-06-25: Interrupt frequency now up to 20kHz possible
  • 2010-06-09: New protocol: FDC (IR-keyboard)
  • 2010-06-09: Corrected timing for DENON protocol
  • 2010-06-02: New protocol: SIEMENS (Gigaset)
  • 2010-05-26: New protocol: NOKIA
  • 2010-05-26: Bugfix: detection of long keyboard press for GRUNDIG protocol
  • 2010-05-17: Bugfix SAMSUNG32 protocol: corrected command bit mask
  • 2010-05-16: New protocol: GRUNDIG
  • 2010-05-16: Improved handling of automatic frame repetitions for SIRCS-, SAMSUNG32-, and NUBERT protocol
  • 2010-04-28: Only some cosmetic code optimizations
  • 2010-04-16: Improved all timing tolerancies
  • 2010-04-12: New protocol: Bang & Olufsen
  • 2010-03-29: Bugfix: detection of multiple NEC repetition frames
  • 2010-03-29: Moved configuration data to irmpconfig.h
  • 2010-03-29: Introduced a program version in README.txt: Version 1.0
  • 2010-03-17: New protocol: NUBERT
  • 2010-03-16: Correction of RECS80 start bit timings
  • 2010-03-16: New protocol: RECS80 Extended
  • 2010-03-15: Some optimizations
  • 2010-03-14: Port to PIC
  • 2010-03-11: Some adjustements for some ATMegas
  • 2010-03-07: Bugfix: Reset of state machine after a incomplete RC5 frame
  • 2010-03-05: New protocol: APPLE
  • 2010-03-05: Data irmp_data.addr + irmp_data.command will be now stored in the bit order of the appropriate protocol
  • 2010-03-04: New protocol: SAMSUNG32 (Mix aus SAMSUNG & NEC protocol)
  • 2010-03-04: Changed some timer tolerances changes of SIRCS- and KASEIKYO
  • 2010-03-02: SIRCS: corrected detection and suppression of automatic frame repetitions
  • 2010-03-02: SIRCS: device ID bits will be now stored in irmp_data.command (not irmp_data.address anymore)
  • 2010-03-02: Enlargement of scan buffers (for logging)
  • 2010-02-24: New variable flags in IRMP_DATA for detection of long key press
  • 2010-02-20: Bugfix DENON protocol: repetition frame is now basically inverted
  • 2010-02-19: Detection of NEC protocol-Varianten, z. B. APPLE-Fernbedienung
  • 2010-02-19: Detection of RC6- and DENON protocol
  • 2010-02-19: Some improvements for RC5 decoders (Bugfixes)
  • 2010-02-13: Bugfix: Puls/Pause counters were 1 too low, now better detection of protokols with very short pulses
  • 2010-02-13: Improved detection of NEC repetition frames
  • 2010-02-12: New: RC5 protocol
  • 2010-02-05: Eliminated a conflict between SAMSUNG- and MATSUSHITA protocol
  • 2010-01-07: First version
Literature
IR Abstract
SIRCS Protocol
NEC Protocol
ACP24 Protocol
The ACP24-Protocol is used by Stiebel-Eltron-Aircons
The structure of the 70 databits is :
             1         2         3         4         5         6
   0123456789012345678901234567890123456789012345678901234567890123456789
   N VVMMM    ? ???    t vmA x                 y                     TTTT
   0011001000000111000010001010000000000000000010000000000000000000001111on, temp=30
These are converted into the following 16 bits from irmp_data.command:
       5432109876543210
       NAVVvMMMmtxyTTTT
Meaning of the symbols:
   TTTT = Temperature + 15 degree
           TTTT
           0000        ???
           0001        ???
           0010        ???
           0011        18 degree
           0100        19 degree
           0101        20 degree
           0110        21 degree
           1111        30 degree
   N    = Nightmode
           N
           0           off
           1           on
   VV   = fan, v must be 1!
           VV   v
           00   1      level 1
           01   1      level 2
           10   1      level 3
           11   1      Automatic
   MMM  = Mode
           MMM  m
           000  0      turn off
           001  0      turn on
           001  1      cooling
           010  1      fan
           011  1      demist
           100  1      ???
           101  1      ---
           110  1      ---
           111  1      ---
   A    = Automatic-Programm
           A
           0           off
           1           on
   t   = Timer
           t   x y
           1   1 0     Timer 1
           1   0 1     Timer 2
To control the air con via IRSND, the following functions can be used:
#include "irmp.h"
#include "irsnd.h"
#define IRMP_ACP24_TEMPERATURE_MASK         0x000F                                          // TTTT
#define IRMP_ACP24_SET_TIMER_MASK           (1<<6)                                          // t
#define IRMP_ACP24_TIMER1_MASK              (1<<5)                                          // x
#define IRMP_ACP24_TIMER2_MASK              (1<<4)                                          // y
#define IRMP_ACP24_SET_MODE_MASK            (1<<7)                                          // m
#define IRMP_ACP24_MODE_POWER_ON_MASK       (1<<8)                                          // MMMm = 0010 Einschalten
#define IRMP_ACP24_MODE_COOLING_MASK        (IRMP_ACP24_SET_MODE_MASK | (1<<8))             // MMMm = 0011 Kuehlen
#define IRMP_ACP24_MODE_VENTING_MASK        (IRMP_ACP24_SET_MODE_MASK | (1<<9))             // MMMm = 0101 Lueften
#define IRMP_ACP24_MODE_DEMISTING_MASK      (IRMP_ACP24_SET_MODE_MASK | (1<<10) | (1<<8))   // MMMm = 1001 Entfeuchten
#define IRMP_ACP24_SET_FAN_STEP_MASK        (1<<11)                                         // v
#define IRMP_ACP24_FAN_STEP_MASK            0x3000                                          // VV
#define IRMP24_ACP_FAN_STEP_BIT             12                                              // VV
#define IRMP_ACP24_AUTOMATIC_MASK           (1<<14)                                         // A
#define IRMP_ACP24_NIGHT_MASK               (1<<15)                                         // N
// possible values for acp24_set_mode();
#define ACP24_MODE_COOLING                  1
#define ACP24_MODE_VENTING                  2
#define ACP24_MODE_DEMISTING                3
static uint8_t temperature = 18;                                                    // 18 degrees
static void
acp24_send (uint16_t cmd)
    cmd |=  (temperature - 15) & IRMP_ACP24_TEMPERATURE_MASK;
    irmp_data.protocol = IRMP_ACP24_PROTOCOL;
    irmp_data.address  = 0x0000;
    irmp_data.command  = cmd;
    irmp_data.flags    = 0;
    irsnd_send_data (&irmp_data, 1);
void
acp24_set_temperature (uint8_t temp)
    uint16_t    cmd = IRMP_ACP24_MODE_POWER_ON_MASK;
    temperature = temp;
    acp24_send (cmd);
void
acp24_off (void)
    uint16_t    cmd = 0;
    acp24_send (cmd);
#define ACP_FAN_STEP1       0
#define ACP_FAN_STEP2       1
#define ACP_FAN_STEP3       2
#define ACP_FAN_AUTOMATIC   3
void
acp24_fan (uint8_t fan_step)
    cmd |= IRMP_ACP24_SET_FAN_STEP_MASK | ((fan_step << IRMP24_ACP_FAN_STEP_BIT) & IRMP_ACP24_FAN_STEP_MASK);
    acp24_send (cmd);
void
acp24_set_mode (uint8_t mode)
    uint16_t    cmd = 0;
    switch (mode)
        case ACP24_MODE_COOLING:    cmd = IRMP_ACP24_MODE_COOLING_MASK;     break;
        case ACP24_MODE_VENTING:    cmd = IRMP_ACP24_MODE_VENTING_MASK;     break;
        case ACP24_MODE_DEMISTING:  cmd = IRMP_ACP24_MODE_DEMISTING_MASK;   break;
        default: return;
    acp24_send (cmd);
void
acp24_program_automatic (void)
    uint16_t    cmd = IRMP_ACP24_MODE_POWER_ON_MASK | IRMP_ACP24_AUTOMATIC_MASK;
    acp24_send (cmd);
void
acp24_program_night (void)
    uint16_t    cmd = IRMP_ACP24_MODE_POWER_ON_MASK | IRMP_ACP24_NIGHT_MASK;
    acp24_send (cmd);
LGAIR Protocol
The LG Air Con is controlled by an 'intelligent' remote. These are the encoded data:
   Command                 AAAAAAAA  PW  Z  S  T  mmm  tttt  vvvv  PPPP
   ON 23C                  10001000  00  0  0  0  000  1000  0100  1100
   ON 26C                  10001000  00  0  0  0  000  1011  0100  1111
   OFF                     10001000  11  0  0  0  000  0000  0101  0001
   TURN OFF                10001000  11  0  0  0  000  0000  0101  0001  (18C currently, identical to off)
   TEMP DOWN 23C           10001000  00  0  0  1  000  1000  0100  0100
   MODE (to mode0, 23C)    10001000  00  0  0  1  000  1000  0100  0100
   TEMP UP (24C)           10001000  00  0  0  1  000  1001  0100  0101
   TEMP DOWN 24C           10001000  00  0  0  1  000  1001  0100  0101
   TEMP UP (25C)           10001000  00  0  0  1  000  1010  0100  0110
   TEMP DOWN 25C           10001000  00  0  0  1  000  1010  0100  0110
   TEMP UP (26C)           10001000  00  0  0  1  000  1011  0100  0111
   MODE                    10001000  00  0  0  1  011  0111  0100  0110  (to mode1, 22C - when switching to mode1 temp automaticall sets to 22C)
   ON (mode1, 22C)         10001000  00  0  0  0  011  0111  0100  1110
   MODE                    10001000  00  0  0  1  001  1000  0100  0101  (to mode2, no temperature displayed)
   ON (mode2)              10001000  00  0  0  0  001  1000  0100  1101
   MODE (to mode3, 23C)    10001000  00  0  0  1  100  1000  0100  1000
   ON (mode3, 23C)         10001000  00  0  0  0  100  1000  0100  0000
   VENTILATION SLOW        10001000  00  0  0  1  000  0011  0000  1011
   VENTILATION MEDIUM      10001000  00  0  0  1  000  0011  0010  1101
   VENTILATION HIGH        10001000  00  0  0  1  000  0011  0100  1111
   VENTILATION LIGHT       10001000  00  0  0  1  000  0011  0101  0000
   SWING ON/OFF            10001000  00  0  1  0  000  0000  0000  0001
   Format:     1 start bit + 8 address bits + 16 data bits + 4 checksum bits + 1 stop bit
   Address:    AAAAAAAA = 0x88 (8 bits)
   Data:       PW Z S T MMM tttt vvvv PPPP (16 bits)
               PW:         Power:     00 = On, 11 = Off
               Z:          N/A:       Always 0
               S:          Swing:     1 = Toggle swing, all other data bits are zeros.
               T:          Temp/Vent: 1 = Set temperature and ventilation
               MMM:        Mode, can be combined with temperature
                           000=Mode 0
                           001=Mode 2
                           010=????
                           011=Mode 1
                           100=Mode 3
                           101=???
                           111=???
               tttt:       Temperature:
                           0000=used by OFF command
                           0001=????
                           0010=????
                           0011=18°C
                           0100=19°C
                           0101=20°C
                           0110=21°C
                           0111=22°C
                           1000=23°C
                           1001=24°C
                           1010=25°C
                           1011=26°C
                           1011=27°C
                           1100=28°C
                           1101=29°C
                           1111=30°C
               vvvv:       Ventilation:
                           0000=slow
                           0010=medium
                           0011=????
                           0100=high
                           0101=light
                           0110=????
                           0111=????
                           1111=????
   Checksum:   PPPP = (DataNibble1 + DataNibble2 + DataNibble3 + DataNibble4) & 0x0F
NEC16 Protocol (JVC)
Samsung Protocol
(was reverse engineered by several protocols (Daewoo or similar), so no direct link to Samsung documents is available)
Here is a link to the Daewoo-protocol, which uses the same principle of the sync-bits in the center of a frame, but words with different timings:
MATSUHITA Protocol
KASEIKYO Protocol ("Japan Protocol")
RECS80 and RECS80 Extended Protocol
RC5 and RC5x Protocol
Denon Protocol
RC6 and RC6A Protocol
Bang & Olufsen
Grundig Protocol
Nokia Protocol
IR60 (SDA2008 and MC14497P)
RCMM Protocol
Other Protocols
IRMP on Youtube
Other Artikels
Whitepaper von Martin Gotschlich, Infineon Technologies AG
Hardware / IRMP Projects
Remote IRMP
Infrared sender und receiver controlled via ip network with Android smartphone as remote control:
* http://www.mikrocontroller.net/articles/Remote_IRMP
IR Tester
IR tester with LCD by Klaus Leidinger:
IR Tester with AVR-NET-IO
IR tester for Pollin AVR-NET-IO with Pollin ADD-ON Board:
USB IR Remote Receiver
USB IR remote receiver by Hugo Portisch:
USB IR Receiver/Sender/Switch with Wakeup-Timer
USBASP
IR switch based on USBasp
Servo controlled IR Sender
Servo controlled IR Sender (adaptive) by Stefan Pendsa:
Adaptive IR Remote Control
Adaptive IR remote control by Robert and Frank M.
AVR Moodlight
AVR Moodlight by Axel Schwenke
STM8 Moodlight by Axel Schwenke
Infinity Mirror LED Ceiling Lamp
Infinity Mirror LED ceiling lamp with remote control by Philipp Meißner
Cinema Control
Cinema control by Owagner
Leading-Edge Control
leading-edge control:
IRDioder – Ikea Dioder Hack
Ikea Dioder Hack:
Expedit Coffee Bar
Ikea Expedit as coffee bar:
Arduino as IR Receiver
Arduino as IR Receiver:
More example from the Arduino library:
IR Volume Control with Stellaris Launchpad
volume control with Stellaris Launchpad (ARM Cortex-M4F):
RemotePi Board
Shutdown RaspPI with IR remote control:
Ethernut & IRMP
IRMP under RTOS Ethernut:
LED strip Remote Control
LED strip remote control:
ADAT Audio Mixer
Audio Mixer:
Ethersex & IRMP
IRMP + IRSND Modul in Ethersex, a modular Firmware for AVR MCUs
Mastermind Solver
Mastermind solver with LED stripes and IR remote control:
A MythTV Remote Control without LIRC
PC Remote Control with ATtiny85
IRMP + IRSND Library for STM32F4
IRMP for STM32F4
IRSND for STM32F4
IRMP on STM32 - Construction Guidance
Seminar Paper - Extension of Arduino Platform
  • www.eislab.fim.uni-passau.de/files/publications/2010/StudentDiener_ErweiterungDerArduinoPlattform.pdf
Acknowledgment
I thank Vlad Tepesch, Klaus Leidinger, Peter K., and Dániel Körmendi, who sent me many scan files of their IR remote controls.
I thank Christian F. for his tipps relating to the port to PIC MCUs, gera for the port to PIC-C18 compiler, kichi (Michael K.) for the port to ARM STM32, Markus Schuster for the port to TI's Stellaris LM4F120 Launchpad (ARM Cortex M4), Matthias Frank for the port to XMega, Wolfgang S. for the port to ESP8266, Achill Hasler for the port to Teensy, Axel Schwenke for the port to STM8.
Thanks to Dániel Körmendi, who added the LG-AIR protocol to IRSND. Thanks to Ulrich v.d. Kammer for the Pentax protocol extension in IRSND.
At least I will thank Jojo S. and Antonio T. for their great job translating and revisioning this documentation!
Discussion
You can discuss IRMP & IRSND in the German thread Infrared Multi Protocol Decoder.
Have fun with IRMP!
