Linksammlung
Hinzufügen von Links:
  1. Bearbeiten anklicken
  2. Link unter der entsprechenden Kategorie eintragen
  3. "Artikel speichern" klicken
Suchen & Finden
AVR
Herstellerseiten
  • Atmel.com Herstellerseiten
  • Atmel.com updates Liste der letzten Änderungen in Datenblättern und Beispielcode auf ATMEL.com (nicht nur für AVRs)
C
  • WinAVR (pronounced "whenever") is a suite of executable, open source software development tools for the Atmel AVR series [for the] Windows platform" (includes GNU GCC)
  • KontrollerLab is a free GPL open-source development environment based on KDE, using the avr-gcc, UISP and AVRDUDE
  • avr-libc avr-gcc's "standard"-library
  • Procyon AVRlib a lot of device drivers and Visual-Studio link for avr-gcc
  • rod.info on AVR esp. for AVR GNU development tools setup under Linux
  • SiSy AVR - graphische Entwicklungsumgebung mit C/C++ Codegenerierung aus Struktogrammen und Klassendiagrammen
  • AtmanAVR C/C++ IDE
  • IAR Embedded Workbench
  • CodeVisionAVR C-Compiler für AVRs mit Terminal
  • myAVRWorkpad kompakte Entwicklungsumgebung für AVRs mit Terminal
  • VMLab komplette IDE mit Debugger und Simulator (auch Peripheriehardware)
  • AVR IO Designer is a utility to generate initialization source code in C/C++ for the various devices, ports and registers of Atmel AVR processors. The intent is to allow the user to explore the devices specific to a selected processor and experiment with settings thru a user interface that assists in understanding the complexities involved. The user can also assign custom variable names to PORT IO pins thereby keeping track of the IO resources in use. These names are emitted in the generated code for use in the user’s program. (Windows .NET 2.0 erforderlich)
  • Piconomic AVRLIB is a collection of firmware for Atmel AVR microcontrollers. The aim is to share source code, experience and expertise (in the eye of the beholder) with the community of engineers, scientists and enthusiasts.
Assembler
  • Atmel AVR ASM Site
  • tavrasm - Toms Linux (Atmel) AVR Assembler
  • gavrasm - Gerds Linux/Win/DOS AVR Assembler
  • avra - avra ATMEL AVR Assembler für Linux, FreeBSD, AmigaOS und Win32
  • Algorithm Builder - graphische Makro-Assembler Entwicklungsumgebung
  • SiSy AVR - graphische Entwicklungsumgebung mit Assembler Codegenerierung aus Programmablaufplänen
  • SB-Assembler - Freeware Cross-Assembler unter DOS. (6502, 6800, 6801, 6804, 6805, 6809, 68HC08, 68HC11, Z8, Z80, Z180, 8080, 8085, 8021, 8041, 8048, 8051, AVR, PIC1684,...)
Disassembler
  • IDA-Pro -Disassembler und Debugger für fast alle bekannten Prozessoren. Evaluation Version verfügbar. Tagline: The most advanced tool for Hostile Code Analysis, Vulnerability and Software Reverse Engineering
  • ReAVR - Disassembler und ACXutility Binary Tool
  • revava - Disassembler
  • vAVRdisasm - Free AVR Disassembler
BASIC
  • Bascom AVR
  • FastAVR - und mit 'ASM' Ausgabe, Nokia3310 LCD Unterstützung
  • mikrocontrollerBASIC Freeware - mit Simulator für ATmega32, ATmega128 und C-CONTROL.
  • mikroBasic - Comprehensive, stand-alone Basic compiler for AVR microcontrollers
  • MCS BASIC-52 - Original-Übersetzung 1988 INTEL MCS BASIC-52 USERS MANUAL 220 Seiten frei Download als PDF
Pascal
  • AVRco Pascal Compiler - AVR Pascal Compiler mit umfangreicher Funktionslibrary
  • mikroPascal - Comprehensive, stand-alone Pascal compiler for AVR microcontrollers
Forth
  • www.robo-forth.de - AVR Forth Compiler mit umfangreicher Funktionslibrary für Servos, Motore und Sensoren
  • amforth - Forth for Atmel ATmega micro controllers von Matthias Trute. Diskussion
Java
Ada
  • AVR-Ada - Ada Compiler innerhalb von GCC (GNAT) für AVR. Enthält eine kleine Laufzeitbibliothek ohne Tasking und ohne Exceptions.
Virgil
  • The Virgil Programming Language is designed for building robust, flexible, and scalable software systems on embedded hardware platforms. Virgil builds on ideas from object-oriented, statically typed languages like Java, providing a clean, consistent source language. Its compiler system provides an efficient implementation for resource-constrained environments.
LabVIEW
Tutorials und Beispiele
C
Assembler
Bascom
Pascal
Programmierhard- und Software
Bibliotheken
Betriebssysteme & Co.
  • YAVRTOS - Yet Another Atmel® AVR® Real-Time Operating System von Chris O'Byrne (C, Atmega32, GPL3 Lizenz)
  • FreeRTOS is a portable, open source, mini Real Time Kernel - a free to download and royalty free RTOS that can be used in commercial applications. (AVR, MSP430, PIC, ARM7, ...)
  • AvrX Real Time Kernel (IAR ASM oder IAR/GCC C, GPL2 Lizenz)
  • scmRTOS - Single-Chip Microcontroller Real-Time Operating System (C++, AVR, MSP430, Blackfin, ARM7, FR (Fujitsu, MIT Lizenz).
  • csRTOS - cooperative single-stack RTOS aus dem Circuit Cellar AVR 2004 Design Contest. csRTOS port to ATmega32 und Diskussion auf www.avrfreaks.net führte zur Weiterentwicklung als 4AvrOS - cooperative scheduler
  • OPEX - freeware cooperative scheduler with lots of calendar and I/O functions von Steve Childress (Download auf www.avrfreaks.net ggf. Registrierung notwendig)
  • Scheduler von Peter Dannegger
  • RTC-Scheduler von ape
  • Protothreads - Lightweight, Stackless Threads in C (open source BSD-style license)
  • uC/OS-II is a real time operating system developed by Jean J. Labrosse. You can obtain the source code for the OS by buying Labrosse's excellent book MicroC/OS-II The Real-Time Kernel (2nd edition). Port for AVR (gcc 3.x) and AVR (gcc 2.x).
  • QP is a lightweight, portable framework/RTOS for embedded systems (ARM, Cortex-M3, 8051, AVR, MSP430, M16C, HC08, NiosII, and x86). GPL (und kommerzielle Lizenz verfügbar)
  • Femto OS von Ruud Vlaming ist ein preemptives Betriebssystem für die kleinsten Mikrocontroller aus der AVR Serie bis ca. 16 KB ROM und 1 KB RAM. Spezielle Targets sind: ATtiny861/461/261. Geschrieben in C. Freie Software, GPLv3.
  • kaOS is a real-time, multithreaded, preemptive operating system for the ATmega32 microcontroller, which loads and executes programs from a Secure Digital or MMC card. Authors Nicholas Clark & Adam Liechty. (Circuit Cellar AVR Wettbewerb 2006)
Projektsammlungen
Schnittstellen
TCP/IP
CAN
USB
  • Igor-Plug - USB Device interface in AVR Firmware - no extra Interface IC needed, read the License
  • AVR-USB – USB-Implementation in C nach gleichem Prinzip wie Igor-Plug, aber einfacher zu verwenden, GPL-ähnliche Lizenz (Nutzung des Projekts erfordert Veröffentlichung), englisch kommentierter Code
  • USBTiny – weitere Software-USB-Implementierung in C; sehr ähnlich AVR-USB; steht aber unter GPL; relativ wenige Beispiele
  • MJoy USB Joystick Controller on AVR ATmega8
  • TUSB3210-Controller, HID, LIBUSB Ein Projektseminar, in dem es darum ging, die USB-Schnittstelle des TUSB3210 zu aktivieren und die Daten eines ADC an den PC zu senden. USB-Implementierung für µC und PC.
  • Steuern und Messen mit USB - FT232, 245 und 2232 Das aktuelle Buch zu den USB-Controllern von FTDI. Viele Beispielprogramme in C, zwei Projektbeschreibungen: I²C-Bus mit LM75A und ein Web-Projekt. Bauteilesatz und USB-Modul mit dem FT2232 zum schnellen Einstieg in die Thematik. Buch / Teilesatz über Segor oder dieser Seite erhältlich.
  • USB to Ehternet Connector - Share your USB devices via LAN/Internet
  • Viele kleine USB Projekte Rund um die Bibliothek usbn2mc http://usbn2mc.berlios.de. Dies ist eine einfache Bibliothek für den USBN9604/03 von National Semiconductor
  • Mega8D12 - Einsteiger-Tutorial zur CDC-Klasse (virtueller COM-Port) mit Schaltung und Firmware (ATmega8 und PDIUSBD12).
DMX512
  • Konverter RS232 zum DMX512 Steuerung DMX-fähigen Geräten mit einem PC. Es gibt Low cost Variante zum selber basteln.
  • Hennes Sites Bauanleitungen für DMX-Dimmerpacks, DMX-Switchpacks, PWM-Controller, ... Tutorial für Senden und Empfangen von DMX-Daten mit AVRs.
  • DMX Lichtanlage im Selbstbau Projekt für den Selbstbau einer kompletten Lichtanlage zur Steuerung über DMX. Projekt beinhaltet alles was man für den Betrieb einer eigenen Lichtanlage benötigt (Mischpult, Steuersoftware, Dimmer, Scanner mit Iris, Shutter-Dimmer, 2 rotierenden Goborädern, 2 Farbrädern, CMY-Farbmischeinheit, Prisma, Fokus ...).
  • Digital Enlightenment Verschiedene DMX-Selbstbauprojekte
PS2
LANC
  • 3D LANC Master from Damir Vrancic is a device which keeps in synchronisation some of Sony camcorders by using LANC (CONTROL-L, ACC) protocol. (Open Hardware + Open Source, Atmega8).
MMC/SD-Card
LC-Displays
Text (character-mode) HD44870
Grafik T6963C etc.
Siemens S65/M65/CX65
  • S65-Display vom Siemens S65/M65/CX65, 132x176 Pixel, 65536 Farben, günstig als Ersatzteil zu bekommen.
Nokia 3210/3310
Nokia 6100 LCD
KS0108
GPS
8051 / MCS51
MSP430
ARM
Herstellerseiten
  • ARM - Entwickler des ARM-Prozessorkerns (kein Hersteller von ICs)
  • ARM Infocenter Sammlung Technischer Informationen
  • Anglia Idealist IDE und Anglia Toolchain GNU toolchain für Win32-hosts inkl. Beispielen für STR7, STR9 und STM32. IDE kostenlost aber registrierungspflichtig
  • Codesourcery GNU Toolchains für ARM (Hosts: Linux, MS Windows, Solaris; Targets: arm-elf, arm-linux, SybianOS)
  • devkitPro/devkitARM GNU-Toolchain für MS-Windows "Hosts". Vor allem auf GBA abgestimmt aber auch für andere ARM-Controller geeignet (arm-elf)
  • GNU ARM GNU Compiler-Toolchain für ARM mit binutils, gcc für C, C++, Java, newlib, gdb/Insight. Binaries für Linux und MS-Windows mit Cygwin
  • Green Hills Software
  • Hitex IDE für diverse Compiler, Debugger
  • IAR Embedded Workbench, kommerzielle IDE/Compiler, codegrößenbeschränkte Evaluierungsversion verfügbar
  • iSYSTEM Integrated Development Environment, USB/JTAG interface, OnChip Emulation and Trace
  • Keil/ARM RVDK/uVision kommerzielle IDE/Compiler, unterstützt zwei Compiler (ARM RealView, GNU/gcc), codegrößenbeschränkte Evaluierungsversion verfügbar (IDE/Compiler unbeschränkt für GNU), guter Debugger, guter Simulator (teilw. mit Hardwaresimulation) Simulator und Debugger in der Evaluierungsversion auch bei Nutzung der GNU-Toolchain auf 16kB beschränkt
  • MCT Demoversion C-Compiler fuer ARM und 68k ARM C-Compiler basiert auf GCC laut Herstellerinformation jedoch mit Codegrößenbeschränkung
  • www.mpeforth.com - A free Forth system with 125 page manual for all Philips LPC2xxx CPUs with at least 64k Flash and 16k RAM and cystal frequency of 10, 12, or 14.7456 MHz.
  • Rowley Kommerzielle IDE für GNU-Compiler, eigene libc (nicht newlib), Debugger (inkl. gutem Support für Wiggler)
  • Tantos gcc for ARM Targets eine weitere ARM-GNU-Toolchain für MS-Windows "Hosts"
  • Yagarto GNU arm-elf-Toolchain, Eclipse, OpenOCD für Win32 inkl. Setup
  • WinARM eine an WinAVR angelehnte Sammlung von Entwicklungswerkzeugen (binutils, arm-elf-gcc, newlib, newlib-lpc, Programmers Notepad, Beispiel-Makefiles und Beispielcode) für alle ARM-Controller. Beispiele für Philips LPC2000 und Atmel AT91SAM7S (ARM7TDMI) u.a.
  • Dissy is a disassembler for Linux and UNIX which supports multiple architectures and allows easy navigation through the code. Dissy is implemented in Python and uses objdump for disassembling files.
  • OpenOCD Open On-Chip Debugger: Schnittstelle ("gdb-Server") zwischen Wiggler-komaptiblem JTAG-Interface und GNU-debugger (gdb/Insight-gdb), ebenfalls Unterstützung für JTAG-Hardware auf FTDI2232-Basis, Flash-Programmierfunktion für LPC2k, AT91SAM7S u.a.
  • OCDLibRemote Schnittstelle zwischen WIGGLER-kompatibler JTAG Hardware und dem GNU-Debugger (gdb)
  • GDB-JTAG-ARM GDB JTAG Tools
  • JTAG-Pack GDB JTAG Tools
  • H-JTAG RDI-Interface für Wiggler, Flash-Funktionen für diverse interne und externe Speicher
  • lpc21isp Flashutility für LPC21xx, ISP via "Bootloader" ("multiplattform")
  • http://www.abatron.ch Abatron] BDI1000 & BDI2000, On-Chip Debuggers für ARM, 68k, Coldfire uvm.
  • Amontec JTAGkey, JTAG-Adapter auf Basis des FTDI2232
  • Keil/ARM ULINK/ULINK2/ULINK-ME JTAG-Adapter, USB-Anschluss, wird von Keil uVision unterstützt, ULINK2 teilw. auch von Codesourcery G++ (lt. Hestellerangaben)
  • Kristech USB-Scarab, JTAG Adapter, kommt mit eigener Debugger-UI, kompatibel zu Olimex
  • Lauterbach TRACE32 JTAG-Adapter, USB und Ethernet-Anschluss, eigene Software
  • Olimex JTAG-Adapter: Wiggler-Nachbau (ParPort) und Adapter auf Basis des FTDI2232 (USB)
  • Ronetix Peedi
  • Segger J-Link JTAG-Adapter, USB-Anschluss, unterstützt z.B. von IAR, Keil uVision (via RDI) (OEM: IAR J-Link, SAM-ICE)
  • Signalyzer Signalyzer Tool, u.a. JTAG-Adapter auf Basis des FTDI2232
  • sinelaboreRT - generiert leicht lesbaren C-Code aus einer Zustandsmaschine. Die Generierung berücksichtig speziell die Bedürfnisse eingebetteter Echtzeitsysteme.
Betriebssysteme
  • Agnix
  • eCos - "Real-Time-Operating-System" o.a. auch für ARM7
  • FreeRTOS (.org!) - "Real-Time-Kernel" unter anderem für ARM7 (LPC2xxx) auch AVR, MSP430, '51er
  • L4Ka
  • Linux 2.4.29 für Toradex Colibri basierend auf Intel XScale PXA270
  • Linux4SAM Informationen, Anleitungen und Code zur Anwendung von Linux auf AT91SAM9xxx
  • NicheTask (URL ist www.freertos.com aber hat nichts mit FreeRTOS(.org) zu tun)
  • Nut/OS
  • NuttX RTOS (ARM7TDMI port for TI TMS320C5471 also called a C5471 or TMS320DM180).
  • Phoenix-RTOS
  • PicoOS
  • Prex is a portable real-time operating system for embedded systems. The small, reliable, and low power kernel is written in the C language based on microkernel design. The file system, Unix process, and networking features are provided by user mode tasks. (ARM, i386, geplant: MIPS, PowerPC, Hitachi-SH und Win32)
  • RTEMS
  • TNKernel - "Real-Time-Kernel" TNKernel ist ein kompakter und sehr schneller Echtzeitkernel unter anderem für ARM7 (Philips LPC2106/LPC21XX/LPC22xx, Samsung S3C44B0X, Atmel AT91SAM7S128, STMicroelectronics STR711FR2)
  • uC/OS-II RTOS
  • cpu-module.de Module mit AT91RM9200, AT91SAM9261, RAM, Flash, USB, Ethernet, fast alle IOs zugänglich.
  • Embest Philips, Samsung und Atmel ARM Boards und Module, JTAG-Hard- und Software
  • Embedded-Waveplayer mit ARM7-Prozessor EP7309 (MIDI- und RS232-Steuerung)
  • Embedded Artists bietet verschiedene preisgünstige Platinen (ab 25 Euro für LPC213x Familie)
  • Hiteg SAMSUNG und Intel XScale basierende boards. (Deutsches Unternehmen in China)
  • Hitex Starter-Kits für Philips LPC2000, ST STR7, Atmel AT91M
  • IAR Starter-Kits für Atmel, Oki, Philips, ST und TI
  • ic-board.de Kommunikationsplattform auf Basis des AT91SAM7X256 mit Ethernet, USB, CAN und Funk Schnittstellen
  • Keil Philips LPC2000 und ST STR7/9 Boards und Starter-Kits
  • LPCTools bietet verschiedene Starter Kits für die LPC2000-Familie
  • MakingThings Make Controller Kit (AT91SAM7X256)
  • MCT Paul und Scherer Starterkits für ARM7 (NXP LPC2000, ADI ADUC7000)
  • Mikrocontroller.net Shop Platinen mit AT91SAM7, LPC2xxx, JTAG
  • Microcontroller-Starterkits Starter-Kits für verschiedene Microcontroller (D) preisgünstige Platinen (ab 12,95 Euro für LPC2129 und 2194) sowie Entwicklungsboard komplett bestückt
  • Micro-Research Development- und Header-Boards für LPC2000 und ADuC7000
  • Olimex Bulgarischer Anbieter günstiger ARM Prototypen- und Header-Boards (LPC2000, STR7, AT91SAM, ADI, TI, OKI u.a.)
  • Propox
  • Revely Evaluations- und Demo-Boards mit Sharp ARM Controllern. Teilweise mit SVGA-Anschluss.
  • SKPang electronics Entwicklungsboards für diverse ARM7/9 (UK)
  • SSV Embedded Systems bietet verschiedene Starter Kits für die verschiedenen DIL/NetPC u.a. (A)DNP/9200 SBC mit AT91RM9200
  • taskit Development- und Header-Boards für AT91SAM7S/X, AT91RM9200, AT91SAM9
  • Toradex Colibri: Intel XScale PXA270 DevKit (Schweiz)
PIC
Herstellerseiten
  • Microchip Hersteller der PIC Microcontroller
  • Microchip C18 Student Edition - die "Student Edition" des Microchip C18 C Compilers für die PIC18 Serie ist kostenlos verfügbar.
  • Systemtechnik Leber Offizieller Microchip Design Partner für professionelles Microcontroller Design und Hersteller von Leistungsstellern, Thyristorstellern und Halbleiterelais.
  • PIC Guide Eine große Sammlung von PIC-Projekten für den Anfänger
  • www.rentron.com Anfänger-taugliche Projekte für PIC und 8051 von Reynolds Electronics (Englisch)
  • PIC-Projekte Einige PIC-Projekte zum Nachbauen wie IR-Lichtschranke, Frequenzzähler.
  • SuperProbe - Logic Probe, Logic pulser, Frequency Counter, Event Counter, Voltmeter, Diode Junction Voltage, Capacitance Measurement, Inductance Measurement, Signal Generator, Video Patern, Serial Ascii, Midi Note, R/C Servo, Square Wave, Pseudo Random Number, ir38, PWM in einem... (PIC16F870)
  • Microchip 16-Bit Embedded Control 2007 Design Contest bei Circuit cellar
Z8
DSP
Embedded Linux & DSP
ADSP-2181 / EZ-Kit Lite
Misc.
Interfaces & Protokolle
iPod
RFID
This site stand 1 000 000 $ http://madname.info
134,2 kHz RFID
13,56 MHz RFID
  • OpenPCD - a free 13.56MHz RFID reader design for Proximity Coupling Devices (PCD) based on 13,56MHz communication. This device is able to screen informations from Proximity Integrated Circuit Cards (PICC) conforming to vendor-independent standards such as ISO 14443, ISO 15693 as well as proprietary protocols such as Mifare Classic. (AT91SAM7S128 ARM Projekt)
  • RFDump is a backend GPL tool to directly interoperate with any RFID ISO-Reader to make the contents stored on RFID tags accessible. (Linux)
2,4 GHz RFID
  • OpenBeacon - a free active 2.4GHz beacon design. (Reader: USB oder Ethernet; Tags: RF_Chip: NRF24L01, PIC16F684)
DMX512
Verschiedenes
  • T&A Kommandos - RC und RCII Kommandoset der Philips PRONTO Familie zur Steuerung von Audiogeräten. Dokumentation siehe unter Downloads.
Leiterplattenhersteller
siehe Platinenhersteller
Schulungen (Online)
Skripte
Messequipment
Logikanalyse
  • Intronix LogicPort, Günstiger, aber sehr leistungsfähiger Logikanalysator mit USB-Anschluß an PC (34Ch, 500MHz Timing, 34 x 2kSa mit Kompression, ca. 235 Euro hier)
  • TechTools DigiView, Günstiger Logikanalysator mit USB-Anschluß an PC (18Ch, 100MHz Timing, 128kSa mit Kompression, ca. 430Euro)
  • Tribalmicro, PC hosted LA (32ch, 40MHz Timing, 128kSa, ca. 1700$)
  • NCI GoLogic, Logikanalysator mit USB-Anschluß an PC (34 oder 72Ch, 500MHz Timing, 1 oder 2MSa, ca. 3000..5500$)
  • Tektronix, Verschiedene Geräte, standalone oder modular (ab 34ch, 2GHz Timing, ab 512kSa, gut und teuer)
  • Agilent, Verschiedene Geräte, standalone, modular oder PC-hosted (ab 34ch, ab 800MHz timing, ab 256kSa, gut und teuer)
  • Sumps LA, günstiges Projekt für einen LA basierend auf einem Digilent Spartan Board (32ch, 100MHz Timing, 256kSa, Kosten Digilent Board ca. 100$ + Versand/Zoll)
  • Meilhaus Electronic - MEphisto Scope UM203 Robustes, mobiles 16 bit Kombi-Instrument 7 Mess-Geräte in einem! (ab 348€)
  • TravelLogic TL2x36, Logikanalysator zum Anschluß an PC über USB, (36ch, 4GHz timing, 200MHz state, Speicher bis 72MBit, Preis ab ca. 500,- netto)
  • Bus und Logic Analyzer 100MHz Samplerate und integrierten SPI, I²C, CAN Interpreter, erweiterbar als Oszilloskop
Oszilloskope
Generatoren
Vermischtes
Foren
Projektsammlungen
Meist in Englisch.
Online-Bücher
  • BAMA Archiv
  • Big-List.com - This is a directory of over 600 dealers in used high technology equipment. Most deal in used electronic test equipment or semiconductor production equipment. Included are dealers in related high technology items, rental companies, equipment auction sites, test equipment manual dealers, foreign (non-U.S.) used equipment dealers, cal labs, and repair services.
  • Projektsammlungen
    • Final Projects der Kurse ECE476 (Microcontroller Design) und ECE576 (Advanced Microcontroller Systems on a Programmable Chip) an der Cornell University
