Linksammlung
Hinzufügen von Links:
  1. Bearbeiten anklicken
  2. Link unter der entsprechenden Kategorie eintragen
  3. "Artikel speichern" klicken
Suchen & Finden
AVR
Herstellerseiten
C
  • WinAVR (pronounced "whenever") is a suite of executable, open source software development tools for the Atmel AVR series [for the] Windows platform" (includes GNU GCC)
  • KontrollerLab is a free GPL open-source development environment based on KDE, using the avr-gcc, UISP and AVRDUDE
  • avr-libc avr-gcc's "standard"-library
  • Procyon AVRlib a lot of device drivers and Visual-Studio link for avr-gcc
  • rod.info on AVR esp. for AVR GNU development tools setup under Linux
  • SiSy AVR - graphische Entwicklungsumgebung mit C/C++ Codegenerierung aus Struktogrammen und Klassendiagrammen
  • AtmanAVR C/C++ IDE
  • IAR Embedded Workbench
  • CodeVisionAVR C-Compiler für AVRs mit Terminal
  • myAVRWorkpad kompakte Entwicklungsumgebung für AVRs mit Terminal
  • VMLab komplette IDE mit Debugger und Simulator (auch Peripheriehardware)
  • AVR IO Designer is a utility to generate initialization source code in C/C++ for the various devices, ports and registers of Atmel AVR processors. The intent is to allow the user to explore the devices specific to a selected processor and experiment with settings thru a user interface that assists in understanding the complexities involved. The user can also assign custom variable names to PORT IO pins thereby keeping track of the IO resources in use. These names are emitted in the generated code for use in the user’s program. (Windows .NET 2.0 erforderlich)
  • Piconomic AVRLIB is a collection of firmware for Atmel AVR microcontrollers. The aim is to share source code, experience and expertise (in the eye of the beholder) with the community of engineers, scientists and enthusiasts.
  • Imagecraft Der ICCAVR C Compiler fuer AVR von Imagecraft.
Assembler
  • Atmel AVR ASM Site
  • tavrasm - Toms Linux (Atmel) AVR Assembler
  • gavrasm - Gerds Linux/Win/DOS AVR Assembler
  • avra - avra ATMEL AVR Assembler für Linux, FreeBSD, AmigaOS und Win32
  • Algorithm Builder - graphische Makro-Assembler Entwicklungsumgebung
  • SiSy AVR - graphische Entwicklungsumgebung mit Assembler Codegenerierung aus Programmablaufplänen
  • SB-Assembler - Freeware Cross-Assembler unter DOS. (6502, 6800, 6801, 6804, 6805, 6809, 68HC08, 68HC11, Z8, Z80, Z180, 8080, 8085, 8021, 8041, 8048, 8051, AVR, PIC1684,...)
  • Macro Assembler AS - AS is a portable macro cross assembler for a variety of microprocessors and -controllers
Disassembler
  • IDA-Pro -Disassembler und Debugger für fast alle bekannten Prozessoren. Evaluation Version verfügbar. Tagline: The most advanced tool for Hostile Code Analysis, Vulnerability and Software Reverse Engineering
  • ReAVR - Disassembler und ACXutility Binary Tool
  • revava - Disassembler
  • vAVRdisasm - Free AVR Disassembler
  • avrdisas - AVR Mikrocontroller Disassembler für Linux (und Win32)
BASIC
  • Bascom AVR
  • FastAVR - und mit 'ASM' Ausgabe, Nokia3310 LCD Unterstützung
  • mikrocontrollerBASIC Freeware - mit Simulator für ATmega32, ATmega128 und C-CONTROL.
  • mikroBasic - Comprehensive, stand-alone Basic compiler for AVR microcontrollers
  • MCS BASIC-52 - Original-Übersetzung 1988 INTEL MCS BASIC-52 USERS MANUAL 220 Seiten frei Download als PDF
  • Beetle-Basic Leistungsfähiges Basic-Betriebssystem im AVR.
  • AVR_BASIC Open Source Freeware: Minimalistischer Basic-Interpreter im AVR.
  • Great Cow BASIC "Open Source BASIC programming tools for Microchip PIC and Atmel AVR microcontrollers"
Pascal
  • AVRco Pascal Compiler - AVR Pascal Compiler mit umfangreicher Funktionslibrary
  • mikroPascal - Comprehensive, stand-alone Pascal compiler for AVR microcontrollers
Forth
  • www.robo-forth.de - AVR Forth Compiler mit umfangreicher Funktionslibrary für Servos, Motore und Sensoren
  • amforth - Forth for Atmel ATmega micro controllers von Matthias Trute. Diskussion
Java
  • NanoVM - Java VM für AVR-Mikrocontroller (deutsches Wiki)
  • SJC - Java-Compiler (erzeugt AVR-Maschinencode) für AVR-Mikrocontroller (SJC)
Ada
  • AVR-Ada - Ada Compiler innerhalb von GCC (GNAT) für AVR. Enthält eine kleine Laufzeitbibliothek ohne Tasking und ohne Exceptions. [1]
Virgil
  • The Virgil Programming Language is designed for building robust, flexible, and scalable software systems on embedded hardware platforms. Virgil builds on ideas from object-oriented, statically typed languages like Java, providing a clean, consistent source language. Its compiler system provides an efficient implementation for resource-constrained environments.
LabVIEW
Python
  • python-on-a-chip (pymite). There are two sample projects in the source tree. One for an 8-bit Atmel ATmega103 (but any AVR/ATmega with 4 KB RAM or more will do) and one for the 32-bit Atmel AT91SAM7S64 running on the AT91SAM7S-EK evaluation board. (GPL Lizenz)
Openeye
  • OpenEye ist eine Kombination aus PC-Programm (Windows, Delphi) und einer Monitor-Routine im AVR. Die Daten aus dem AVR werden mit RS232 übertragen und können fürs Debuggen der laufenden Anwendung benutzt werden. OpenEye wurde vom User Martin Vogel (oldmax) geschrieben [2].
Modkit
Modkit is a new kind of graphical programming environment that makes programming things in the physical world as easy as dragging and dropping little virtual code blocks in a web browser.. Heavily inspired by the Scratch programming environment (from MIT Media Lab's Lifelong Kindergarten Group), Modkit enables anyone including kids, artists and inventors to build with electronic kits and components including motors, sensors, lights, sound and the popular Arduino and Arduino compatible development boards... (Text vom Makezine)
Tutorials und Beispiele
C
Assembler
Bascom
Pascal
Ada
  • Atmel AVR Butterfly Site
  • Kanda Starter Kits and Development Tools for different Microcontrollers
  • Dontronics Starter Kits and Development Tools for different Microcontrollers, Linkpages for AVR and PIC
  • mikrocontroller.com u.a. Platine AVR-Ctrl, AVR-Webserver (D)
  • AVR webserver RTL8019, 3COM (E)
  • Microcontroller-Starterkits Starter Kits for different Microcontrollers (D)
  • Olimex Ltd. DevelopmentBoards and Tools
  • Krause Robotik Controller Boards & Zubehör
  • robotikhardware.de Controller Boards
  • Embedded-IT USB Module auf AVR Basis sowie Ethernut kompatible Embedded Ethernet Mikrocontroller Boards für Industrie und Hobby auf ARM mit Nut/OS Betriebssystem
  • SSV Embedded Systems 32-bit Mikrocontrollermodule und -boards, Starter Kits etc.
  • Embedit Mikrocontrollermodule und -boards
  • Display3000 Farbdisplays, Mikrocontrollermodule und -boards mit TFT-Farbdisplays; Experimentierplatinen und Ansteuerplatinen für TFT Farbdisplays
  • myAVR Einsteigerboards und Zubehör
  • SIPHEC Development Boards für AVR, MSP430, USB
  • ATMEL Evaluations-Board Bausatz (PDF) und ATMEL Funk-Evaluations-Board Bausatz (PDF) von Pollin
  • Etherrape Atmaga 644 mit Ethernet und TCP/IP als Bausatz.
  • AVR Programmieradapter,ZigBee-ready Funkmodule/Funk-USB-Sticks und Funk Starterkits von In-Circuit
  • AVR32 AP7000 Linux Board mit 2xEthernet, TFT, Audio, SDCARD, USB-Host/Devive, Funk...
  • Das Laborboard von das-labor.org (DIY)
  • number six - Open Source Design, Atmega32. Alle Pins sind auf eine 2x20 Pol Wannenstiftleiste herausgeführt.
  • http://www.maares.de/tools USB Memory Stick am AVR Butterfly. AVR Butterfly Trägerplatine zum Anschluß von VDRIVE, VMUSIC, RFM12.
  • Wiring is an open source programming environment and electronics i/o board for exploring the electronic arts, tangible media, teaching and learning computer programming and prototyping with electronics.
  • chip45 Atmel AVR Module und Boards mit USB, RS232/485, CAN, Ethernet, Funkmodule, sowie ISP Programmieradapter.
  • Dr. Rakers AVR Boards und Experimentierplatinen mit USB, Ethernet, RS232, CAN, LCD etc. in hochwertiger Qualität zu günstigen Preisen.
  • Roboterbausatz Nibo - autonomer Roboter mit einem ATmega128 und einem ATmega88
  • Modularis - AVR Mikrocontroller-Boards (z.T. mit Zusatz-Speicher und USB) die über Flachbandkabel erweitert werden können. Es gibt bis jetzt Zubehör-Module mit Taster, Motor H-Brücke, XBee und Winkelsensor.
  • Schramm-Software - AVR Mikrocontroller-Bausätze
  • Alvidi - Headerboards mit AVR & AVR32 Controllern
  • Steinert Technologies - Thailändischer Anbieter von Mikrocontroller Boards (AVR, ARM7, ARM9, PIC, dsPIC, PSoC, uvm.)
  • Arduino
  • Fritzing nützliches Programm für viele Betriebsysteme zur Unterstützung eines Brettboard-Aufbaus(ungetestet).
  • Specialprint InkjetDruck für den digitalen Direktdruck von Ätzmasken, Lötstoppmasken, Frontplatten, Kennzeichnungen
  • Onlinesteuerung.de USB Bausatz. Technische Geräte per PC, Browser, Netzwerk, Ethernet, TCP/IP, Internet, Excel, Timer oder Sensoren schalten.
Programmierhard- und Software
Bibliotheken
Betriebssysteme & Co.
  • TinyOS - Komponentenbasiertes Betriebssystem für Sensorknoten. Bringt eigene C-ähnliche Hochsprache nesC mit.
  • YAVRTOS - Yet Another Atmel® AVR® Real-Time Operating System von Chris O'Byrne (C, Atmega32, GPL3 Lizenz)
  • FreeRTOS is a portable, open source, mini Real Time Kernel - a free to download and royalty free RTOS that can be used in commercial applications. (AVR, MSP430, PIC, ARM7, ...)
  • AvrX Real Time Kernel (IAR ASM oder IAR/GCC C, GPL2 Lizenz)
  • scmRTOS - Single-Chip Microcontroller Real-Time Operating System (C++, AVR, MSP430, Blackfin, ARM7, FR (Fujitsu, MIT Lizenz).
  • csRTOS - cooperative single-stack RTOS aus dem Circuit Cellar AVR 2004 Design Contest. csRTOS port to ATmega32 und Diskussion auf www.avrfreaks.net führte zur Weiterentwicklung als 4AvrOS - cooperative scheduler
  • OPEX - freeware cooperative scheduler with lots of calendar and I/O functions von Steve Childress (Download auf www.avrfreaks.net ggf. Registrierung notwendig)
  • Scheduler von Peter Dannegger
  • RTC-Scheduler von ape
  • Protothreads - Lightweight, Stackless Threads in C (open source BSD-style license)
  • uC/OS-II is a real time operating system developed by Jean J. Labrosse. You can obtain the source code for the OS by buying Labrosse's excellent book MicroC/OS-II The Real-Time Kernel (2nd edition). Port for AVR (gcc 3.x) and AVR (gcc 2.x).
  • QP is a lightweight, portable framework/RTOS for embedded systems (ARM, Cortex-M3, 8051, AVR, MSP430, M16C, HC08, NiosII, and x86). GPL (und kommerzielle Lizenz verfügbar)
  • Femto OS von Ruud Vlaming ist ein preemptives Betriebssystem für die kleinsten Mikrocontroller aus der AVR Serie bis ca. 16 KB ROM und 1 KB RAM. Spezielle Targets sind: ATtiny861/461/261. Geschrieben in C. Freie Software, GPLv3. Artikel in Elektor Februar 2010
  • kaOS is a real-time, multithreaded, preemptive operating system for the ATmega32 microcontroller, which loads and executes programs from a Secure Digital or MMC card. Authors Nicholas Clark & Adam Liechty. (Circuit Cellar AVR Wettbewerb 2006)
  • Helium is a minimalistic real-time kernel for the HC(S)08 core by Freescale and Atmel AVR.
  • BeRTOS is a completely free, open source, real time operating system (RTOS) suitable for embedded platforms. Runs on many microprocessors and microcontrollers, ranging from 8 bits to 32 bits CPUs and even PCs.
  • funkos Targets: AVR, XMEGA, MSP430, Cortex M3, Open Source
  • Vergleich zwischen 4 Operating Systems for the Arduino auf Liquidware Antipasto
    • DuinOS by RobotGroup (FreeRTOS Portierung)
    • Pyxis OS by ArduinoWill
    • ArduinoMacOS by Mark
    • TaOS by Ziplock
  • Atomthreads is a free, lightweight, portable, real-time scheduler for embedded systems. (BSD Lizenz)
  • XMK (eXtreme Minimal Kernel) ist ein freies Echtzeitbetriebssystem für Mikrocontroller (AVR, H8, R8C, M16C).
  • iRTOS is an free Real Time Operating System. The iRTOS kernel is free to download and use under the terms of LGPL. It can be used in commercial applications. iRTOS is designed for tiny 8 bit microconroller chips with little RAM usage. OS can be installed also in 16 and 32 bit processor units.
  • cocoOS is a cooperative task scheduler, based on coroutines and it is written in C. (STK500, Atmega16)
  • BasicBeetle Basic-Betriebssystem im AVR
  • Shells für Arduino:
  • toolduino is a simple software tool that lets you easily interact with your Arduino hardware so you can test the circuits you create. Toolduino is written in the Processing languange and is available for Windows, Mac OS X, and Linux. Toolduino uses the the Arduino library for Processing to communicate with an Arduino board so you can manipulate output pins and read inputs. The Arduino must be running the Firmata firmware that comes with the Arduino IDE. (LGPL)
  • MOPS - A small C and Assembly based operating system for the ATMEL AVR® 8-Bit RISC controller family.
Projektsammlungen
  • Die Elektronik-Projektseite und Heimat des BasicBeetle Hauptthema ist der BasicBeetle. Ein modularer, leistungsfähiger, in Basic programmierbarer Mikrorechner speziell für Steuerungen. Mit vielen Programmen, Tiipps und Tricks, Informationen...
  • Happy-Micro.de Die Internetsite für Hobbyelektroniker, Mikrocontroller-Anwender, Programmierer und alle, die Spaß an Computern und Elektronik haben. Bei Happy-Micro.de steht der Spaß am Entwickeln von Programmen und Schaltungen im Vordergrund. Jeder Benutzer hat die Möglichkeit auch als Autor mitzumachen und seine Schaltungen oder Programme zu veröffentlichen. Freier Bilderdownload für die eigene Homepage. (Seite wurde geschlossen!)
  • Elektronik und Informationen Wissenswertes aus der Unterhaltungselektronik..
  • Cornell University ECE 476 Microcontroller Design Final Projects
  • Serasidis Vasilis' AVRsite u.a. GLCD, SMS, PAL
  • Alberto Ricci Bitti u.a. PAL Video-Interface
  • Mikrocontroller and more AVR - Projekte (Ethernet, LCD, Relaiskarte usw.) und mehr
  • Burkhard John (D)
  • AVRmicrocontrollerprojects u.a. Text-LCD, Schrittmotor, Thermometer (Seite existiert nicht mehr/ Error 404)
  • Robin Stridh Rotor-Anzeige, Video-Interface
  • dertien.dds.nl AVR-Projects
  • MicroSPS.com Grafische Programmierung des AVR mit EAGLE
  • h-mpeg Festplatten mp3 Player IDE Ansteuerung, IDE Filesystem, LCD Ansteuerung etc. in 8K Code. Quelltext unter GPL
  • embedtronics.com
  • M. Thomas' AVR Projekte untern Anderem AVR Butterfly avr-gcc-port, DB101 gcc-port, BC100 gcc-port, Bootloader, Programmier- und Debughardware, Software-UART, DS1820-Lib., experimentelle avrdude-Versionen, AVR und CAN mit MCP2515
  • Michaels Electronic Projects AVR Projekte (EN) - ua. Sony/Becker CD/MD Wechsler Emulator, RDS-Decoder, GPS Infos, OBD J1850 VPW Interface, USB<>CAN Bus Interface. Informationen zu CD Wechsler Protokollen. MP3stick - MP3 Player mit ATmega128, color LCD, SD/MMC Karte und VS1011b
  • node13 modulares AVR 8515 Projekt: eine Controller-Platine, an die sich weitere Ein-Ausgabemodule (Tastenfeld, LEDs, LCD-Modul) anschliessen lassen
  • www.mikrocontroller-projekte.de Diverse Projekte mit AVR Controllern. AVR910 Programmer, Testboard und Modellbauelektronik
  • Roboternetz-Mikrocontroller Projekte.de Diverse Projekte mit AVR und anderen Controllern, insbesondere im Bereich Robotik
  • AVR-Projekte.de Belichtungstimer, FT232RL Schaltungen,LED-Fading über Fernbedienung, HD44780-LCD über USB und Seriell, AVR910-USB Programmer, Basteleien: Ätzmaschine,Kompressor.
  • openeeg.sourceforge.net Das OpenEEG Projekt befasst sich mit der Entwicklung eines preiswerten Elektro-Enzephalographie (EEG) Geräts und dessen freier Steuersoftware zur Messung elektrischer Gehirnströme. Sein µPC-Herz ist ein AT90S4433 bzw. ein ATmega8. Ziel sind auch verschiedene EEG Anwendungen z. B. im Bereich mentaler Trainingsmethoden (Neurofeedback).
  • www.amateurfunkbasteln.de Seite von Michael Wöste (DL1DMW) u.a. CPU-Board mit AT89C2051, AT89C4051 oder AVR AT90S2313, CPU-Board mit Atmel AT90S8535, Experimentierplatine mit ATmega103, Programmer für AT89C2051/AT89C4051, 32-Kanal-Logik-Analysator bis 40 MHz (Entwurf von David L. Jones)
  • Atmel - AVR 8-Bit RISC - Application Notes Anwendungshinweise und Beispiele vom Hersteller
  • Dick Cappels' Project Pages
  • SeebyTouch - Blinden-Seh-Ersatzsystem Computerbilder fühlen durch ein einfaches Gerät (Bauanleitung) und freier Software (für 10 Betriebssysteme) - eine neue Erfahrung für alle
  • www.loetstelle.net Verschiedene kleinere AVR-Projekte rund um LEDs, z. B. RGB Dimmer, Moodlight. Diverse Elektronikprojekte und Grundlagen
  • Selbstbauprojekte Elektronik kleine Sammlung von Elektronikprojekten zum Thema Leiterplattenfertigung, Hochfrequenztechnik und Mikrocontroller.
  • Jesper's AVR pages Yampp MP3 Player, Yaap Programmer, DDS mit 2313+R2R, Gitarrentuner, Frequenzzähler.
  • MicroSyl MCU MP3 Player, MegaLoad, HCLoad, Propeller Clock, Freq Meter, BarCode Reader, Door Bell, OneWire Lib, Text LCD Lib, Graph LCD Lib, Nokia LCD Lib, Led Sign with MMC MemoryCard, Intercom
  • http://www.jeroen.homeunix.net/ Aufbau eines elektronischen Rouletts auf basis eines AVRs
  • thomaspfeifer.net Reflow-Ofen, Laminator-Temperaturregelung, USB-Atmel-Programmer, SMD-Tricks u.v.m.
  • Scienceprog - embedded theory and projects - AVR, ARM theory and projects
  • Hausautomatisierung - CAN-Bus mit ATmega32-Controllern und Bedienfeldern, Admin-Tools zum Updaten via CAN, Traffic Dumper etc.
  • AVRSAM - AT91SAM7S Header Board annährend 100% Pinkompatibel zu den folgenden AVR Mikrocontroller: AT90S8535 / ATMEGA8535 / ATMEGA16 / ATMEGA32
  • Hausbus Home - Hausbus-Projekt unter Verwendung von ATmega8, ATtiny13 und ATmega128
  • AVR-DCF-Clock - DCF-Uhr mit bunter LED-Anzeige - ATmega8
  • GenuhR - DCF-Funkuhr / Wecker/ Timer mit LED-Punktmatrixanzeige. Das Projekt beschreibt den Aufbau des kompletten Gerätes beginnend beim Schaltplan bis hin zur Montage in ein Gehäuse.
  • AVR Projektsammlung bei www.avrguide.com
  • AVR Synth http://www.elby-designs.com/avrsynth/avrsyn-about.htm http://www.jarek-synth.strona.pl/
  • Electronic Lives Manufacturing - Aufbauten in Fädeldrahttechnik, tlw. auf Japanisch, aber mit englischen Sourcecodes
  • AVR Synthesizer http://www.avrx.se/
  • Wedis-Bastelecke - Modellbahn DCC-Servo-Zubehördecoder DCC Servo Decoder mit ATmega8 / Servo Differenzierbaugruppe für Modellbau
  • http://www.electronicspit.com - Verschiedene Elektronikprojekte (LED-Matrix, PAL-Video)
  • http://web.archive.org/web/20050415222337/http://www.hebel23.de/ RDS RADIO: ATMega32, TEA5757, T6963C, TDA7330B in C
  • Analog/Digital and MPU Eletronic Projects PAL/VGA Terminal, CallerID, Ethernet, Wireless Bridge, LPC2214, AT91RM9200, Sony Unilink Controlled Wireless MP3 Player.
  • Circuit Cellar AVR Design Contest 2004 mit Projektbeschreibungen
  • Circuit Cellar AVR Design Contest 2006 mit Projektbeschreibungen
  • Homepage von Stefan Heesch - AVR Mikrokontroller Projekte, z.B. WLAN und AVR, netzwerkgesteuertes RGB Licht, IDE-Interface, DS1821 Thermometer, Morse-Dekoder u.a.
  • Das Schaltungsforum ist eine Seite für Anfänger und Profis welche ständig mit Tutorials erweitert wird. Stellt Eure Projekte online. Die Seite befindet noch im Aufbau und Eure Mithilfe ist erwünscht.
  • [3] Viele Projekte mit LEDs(LED-Matrixen) und AVRs
  • little-scale's arduino page
  • www.sebastianweidmann.de Grundlagen zum Thema Platinen ätzen, Bohren, Durchkontaktierungen und Projekte Tipps/Tricks mit Atmel AVR Microcontrollern
  • Junghans Electronic Page u.a Nokia 3310 LCD Ansteuerung in "C"(aktualisiert 2010), TWI/USI, Quadcopter
  • http://www.familie-finke.com/ Die Website von Thomas Finke mit diversen Elektronikprojekten, wie z.B. STK-LAN (AVR im Netzwerk mit HTTPD, SNMP,...), UV-LED-Belichter, HPGL-Plotter.
  • Funkuhr FT1 Funkuhr mit programmierbaren Terminkalender, Kalenderwochenanzeige und optischen Stundenschlag (Anzeige der empfangenen Daten vom Zeitzeichensender DCF77)
  • Philips Projektsammlung Elektronik Projekte (µC,CMOS,Analog,...), Tutorials und nützliche Online-Tools
  • Phoenix allows you to develop science experiments by connecting sensor / control elements to a computer and access them through software. The project was started by Inter University Accelerator Centre, with the objective of improving the laboratory facilities at Indian Universities, and growing with the support of the user community. Phoenix depends heavily on Python language. The data acquisition, analysis and writing simulation programs to teach science and computation. The hardware design is freely available. The project is based on Free Software tools and the code is distributed under GNU GPL. (Atmega16)
Schnittstellen
TCP/IP
CAN
USB
  • eUSB-162 und eUSB-LCD - At90USB162 basiertes universelles USB Prototypen / Mikrocontroller Modul und USB Terminal Interface für HD44780 kompatible LCDs auf Basis der Lufa Library
  • Igor-Plug - USB Device interface in AVR Firmware - no extra Interface IC needed, read the License
  • V-USB – USB-Implementation in C nach gleichem Prinzip wie Igor-Plug, aber einfacher zu verwenden, GPL-ähnliche Lizenz (Nutzung des Projekts erfordert Veröffentlichung), englisch kommentierter Code
  • USBTiny – weitere Software-USB-Implementierung in C; sehr ähnlich AVR-USB; steht aber unter GPL; relativ wenige Beispiele
  • MJoy USB Joystick Controller on AVR ATmega8
  • TUSB3210-Controller, HID, LIBUSB Ein Projektseminar, in dem es darum ging, die USB-Schnittstelle des TUSB3210 zu aktivieren und die Daten eines ADC an den PC zu senden. USB-Implementierung für µC und PC.
  • Steuern und Messen mit USB - FT232, 245 und 2232 Das aktuelle Buch zu den USB-Controllern von FTDI. Viele Beispielprogramme in C, zwei Projektbeschreibungen: I²C-Bus mit LM75A und ein Web-Projekt. Bauteilesatz und USB-Modul mit dem FT2232 zum schnellen Einstieg in die Thematik. Buch / Teilesatz über Segor oder dieser Seite erhältlich.
  • USB to Ehternet Connector - Share your USB devices via LAN/Internet
  • Viele kleine USB Projekte Rund um die Bibliothek usbn2mc http://usbn2mc.berlios.de. Dies ist eine einfache Bibliothek für den USBN9604/03 von National Semiconductor
  • Mega8D12 - Schritt für Schritt zum virtuellen COM-Port. Ein Einsteiger-Tutorial zur CDC-Klasse mit Schaltung und Firmware (ATmega8 und PDIUSBD12).
  • http://www.maares.de/tools USB_ISO: Isolierter Schnittstellenwandler USB auf RS232 (TTL) mit FT232RL und ADUM1402. Galvanische Trennung für das Zielsystem.
  • USB HID Host Treiber - USB HID Treiber DLL für Windows (Demo Projekte für Visual Studio 2010 C++, C# und VB).
DMX512
  • Konverter RS232 zum DMX512 Steuerung DMX-fähigen Geräten mit einem PC. Es gibt Low cost Variante zum selber basteln.
  • Hennes Sites Bauanleitungen für DMX-Dimmerpacks, DMX-Switchpacks, PWM-Controller, ... Tutorial für Senden und Empfangen von DMX-Daten mit AVRs.
  • DMX Lichtanlage im Selbstbau Projekt für den Selbstbau einer kompletten Lichtanlage zur Steuerung über DMX. Projekt beinhaltet alles was man für den Betrieb einer eigenen Lichtanlage benötigt (Mischpult, Steuersoftware, Dimmer, Scanner mit Iris, Shutter-Dimmer, 2 rotierenden Goborädern, 2 Farbrädern, CMY-Farbmischeinheit, Prisma, Fokus ...).
  • Digital Enlightenment Verschiedene DMX-Selbstbauprojekte
PS2
LANC
MMC/SD-Card
LC-Displays
Text (character-mode) HD44870
Grafik T6963C etc.
Siemens S55/C60
Siemens S65/M65/CX65
  • S65-Display vom Siemens S65/M65/CX65, 132x176 Pixel, 65536 Farben, günstig als Ersatzteil zu bekommen.
Nokia 3210/3310
Nokia 6100 LCD
KS0108
GPS
8051 / MCS51
MSP430
MSP430 Launchpad
EZ430 Chronos
ARM
Herstellerseiten
  • ARM - Entwickler des ARM-Prozessorkerns (kein Hersteller von ICs)
  • ARM Infocenter Sammlung Technischer Informationen
  • Anglia Idealist IDE und Anglia Toolchain GNU toolchain für Win32-hosts inkl. Beispielen für STR7, STR9 und STM32. IDE kostenlos aber registrierungspflichtig
  • attolic TrueSTUDIO
  • Codesourcery GNU Toolchains für ARM (Hosts: Linux, MS Windows, Solaris; Targets: "bare-metal", arm-linux, SybianOS)
  • devkitPro/devkitARM GNU-Toolchain für MS-Windows "Hosts". Vor allem auf GBA abgestimmt aber auch für andere ARM-Controller geeignet
  • Green Hills Software
  • Hitex IDE für diverse Compiler, Debugger
  • IAR Embedded Workbench, kommerzielle IDE/Compiler, codegrößenbeschränkte Evaluierungsversion verfügbar
  • iSYSTEM Integrated Development Environment, USB/JTAG interface, OnChip Emulation and Trace
  • Keil/ARM MDK-ARM kommerzielle IDE/Compiler, unterstützt zwei Compiler (ARM RealView, GNU/gcc), codegrößenbeschränkte Evaluierungsversion verfügbar (IDE/Compiler unbeschränkt für GNU), guter Debugger, sehr guter Simulator, Simulator und Debugger in der Evaluierungsversion auch bei Nutzung der GNU-Toolchain mit Größenbeschränkung
  • MCT Demoversion C-Compiler für ARM und 68k ARM C-Compiler basiert auf GCC laut Herstellerinformation jedoch mit Codegrößenbeschränkung
  • www.mpeforth.com - A free Forth system with 125 page manual for all Philips LPC2xxx CPUs with at least 64k Flash and 16k RAM and cystal frequency of 10, 12, or 14.7456 MHz.
  • Raisonance Ride, RKit-ARM
  • Rowley Kommerzielle IDE für GNU-Compiler, eigene libc (nicht newlib), Debugger (inkl. gutem Support für Wiggler)
  • Tantos gcc for ARM Targets eine weitere ARM-GNU-Toolchain für MS-Windows "Hosts"
  • Yagarto GNU arm-eabi-Toolchain, Eclipse, OpenOCD für Win32 inkl. Setup
  • WinARM eine an WinAVR angelehnte Sammlung von Entwicklungswerkzeugen (binutils, arm-elf-gcc, newlib, newlib-lpc, Programmers Notepad, Beispiel-Makefiles und Beispielcode) für alle ARM-Controller. Beispiele für Philips LPC2000 und Atmel AT91SAM7S (ARM7TDMI) u.a.
  • Dissy is a disassembler for Linux and UNIX which supports multiple architectures and allows easy navigation through the code. Dissy is implemented in Python and uses objdump for disassembling files.
  • sinelaboreRT - generiert leicht lesbaren C-Code aus einer Zustandsmaschine. Die Generierung berücksichtig speziell die Bedürfnisse eingebetteter Echtzeitsysteme.
  • http://arm.hsz-t.ch Entwicklungsumgebung für ARM7 Mikrocontroller basierend auf der Knoppix CD. Keine Harddisk installation nötig für uClinux.
  • OpenOCD Open On-Chip Debugger: Schnittstelle ("gdb-Server") zwischen verschiedenen JTAG-Interfaces (u.a. auf FTDI2232-Basis, "Wiggler"-ParPort und andere) und GNU-debugger (gdb/Insight-gdb) Flash-Programmierfunktion für LPC2k, AT91SAM7S, LM3S, STM32 und viele andere interne und externe Flashspeicher (Open Source, GPL, unter anderem auf MS Windows und Linux lauffähig)
  • OCDLibRemote Schnittstelle zwischen WIGGLER-kompatibler JTAG Hardware und dem GNU-Debugger (gdb)
  • GDB-JTAG-ARM GDB JTAG Tools
  • JTAG-Pack GDB JTAG Tools
  • H-JTAG RDI-Interface für Wiggler, Flash-Funktionen für diverse interne und externe Speicher
  • lpc21isp Flashutility für LPC21xx, ISP via "Bootloader" ("multiplattform")
  • Abatron BDI1000 & BDI2000, On-Chip Debuggers für ARM, 68k, Coldfire uvm.
  • Amontec JTAGkey, JTAGkey2(P): JTAG-Adapter auf Basis des FTDI2232(H)
  • H-JTAG USB Emulator
  • Keil/ARM ULINK/ULINK2/ULINK-ME JTAG-Adapter, USB-Anschluss, wird von Keil uVision unterstützt, ULINK2 teilw. auch von Codesourcery G++ (lt. Hestellerangaben)
  • Kristech USB-Scarab, JTAG Adapter, kommt mit eigener Debugger-UI, kompatibel zu Olimex
  • Lauterbach TRACE32 JTAG-Adapter, USB und Ethernet-Anschluss, eigene Software
  • Olimex JTAG-Adapter: Wiggler-Nachbau (ParPort) und Adapter auf Basis des FTDI2232 (USB)
  • Ronetix Peedi
  • Segger J-Link JTAG-Adapter, USB-Anschluss, unterstützt z. B. von IAR, Keil uVision (via RDI) (OEM: IAR J-Link, SAM-ICE)
  • Signalyzer Signalyzer Tool, u.a. JTAG-Adapter auf Basis des FTDI2232
  • Simon Qians Versaloon
  • Procyon ARMlib-LPC2100 - Treiber, Beispiele (Lizenz: GPL, kaum weiterentwickelt)
  • NXP BlueStreak Code für LH7xxxx (ehemals Sharp)
  • M. Thomas' ARM Projekte "Projectvorlagen" für AT91SAM7 und LPC2000 mit GNU-Toolchain Einsteiger-Projekte für AT91SAM7, LPC2000, ADuC7000 u.a. (u.a. Blinky, UART, Interrupt, C++, GLCD mit KS0108, DS18x20, DCF77, Anpassungen von FAT16/32-Libraries)
  • STMicro Treiber und Beispiel für STR7, STR9 und STM32
  • LPCUSB - Open-source USB stack for the built-in USB controller in LPC214x microcontrollers von Bertrik Sikken. Sample code
  • Olimex Einige Beispiele auf den "Produktseiten" der ARM Boards.
  • ARM MP3/AAC Player
  • J.C. Wrens Beispielprojekt für LPC214x
  • Beispiele von Keil abgestimmt auf deren Boards und Realview-Toolchain, Portierung auf andere Boards und Compiler relativ einfach, Lizenz beachten.
  • Luminary Micro Driverlib für Stellaris Cortex-M3
  • GPS-Tracker mit Navigation auf LPC2103-Basis (Complier: GCC)
  • elua Lua für ARM-controller
  • FreeMODBUS "A Modbus ASCII/RTU and TCP implementation" (für STR71x, AT91SAM7, LPC214x, auch: AVR, MSP430 u.a.)
  • BettyHacks Freie Firmware für die "interaktive TV-Fernbedienung" betty-tv (ARM7tdmi, 2MB Flash, 160 x 128 Pixel 2 bit LCD, CC1100, IR, Lautsprecher,..)
Betriebssysteme
  • Agnix
  • ChibiOS/RT
  • Circle-OS for STM32 Kostenloses OS, sehr klein mit Basisfunktionen fuer STM32
  • CoOS
  • eCos - "Real-Time-Operating-System" o.a. auch für ARM7
  • FreeRTOS (.org!) - "Real-Time-Kernel" unter anderem für ARM7 (LPC2xxx) auch AVR, MSP430, '51er
  • FunkOS
  • L4Ka
  • Linux 2.4.29 für Toradex Colibri basierend auf Intel XScale PXA270
  • Linux4SAM Informationen, Anleitungen und Code zur Anwendung von Linux auf AT91SAM9xxx
  • NicheTask (URL ist www.freertos.com aber hat nichts mit FreeRTOS(.org) zu tun)
  • Nut/OS Echtzeitbetriebssystem für Mikrocontroller (ARM, AVR, AVR32, Cortex M3 u.A). Multitasking und vollständiger TCP/IP Stack inklusive. Leicht zu erlernen und viele Beispiele
  • NuttX RTOS (ARM7TDMI port for TI TMS320C5471 also called a C5471 or TMS320DM180).
  • Phoenix-RTOS
  • PicoOS
  • Prex is a portable real-time operating system for embedded systems. The small, reliable, and low power kernel is written in the C language based on microkernel design. The file system, Unix process, and networking features are provided by user mode tasks. (ARM, i386, geplant: MIPS, PowerPC, Hitachi-SH und Win32)
  • RTEMS
  • rt-thread
  • scmRTOS
  • TNKernel - "Real-Time-Kernel" TNKernel ist ein kompakter und sehr schneller Echtzeitkernel unter anderem für ARM7 (Philips LPC2106/LPC21XX/LPC22xx, Samsung S3C44B0X, Atmel AT91SAM7S128, STMicroelectronics STR711FR2)
  • uC/OS-II RTOS
  • KNIF-elektronik Preisgünstige Industriemodule und Bausätze z.B GPS, W-Lan, Kamera,Bluetooth uvm. -->
  • Embest Philips, Samsung und Atmel ARM Boards und Module, JTAG-Hard- und Software
  • Embedded-Waveplayer mit ARM7-Prozessor EP7309 (MIDI- und RS232-Steuerung)
  • Embedded Artists bietet verschiedene preisgünstige Platinen (ab 25 Euro für LPC213x Familie)
  • Embedded-IT eNet-sam7X: Ethernut kompatible Embedded Ethernet Mikrocontroller Boards für Industrie und Hobby auf ARM mit Nut/OS Betriebssystem sowie USB Module auf AVR Basis
  • Hiteg SAMSUNG und Intel XScale basierende boards. (Deutsches Unternehmen in China)
  • Hitex Starter-Kits für Philips LPC2000, ST STR7, Atmel AT91M
  • IAR Starter-Kits für Atmel, Oki, Philips, ST und TI
  • ic-board.de Kommunikationsplattform auf Basis des AT91SAM7X256 mit Ethernet, USB, CAN und Funk Schnittstellen
  • Keil Philips LPC2000 und ST STR7/9 Boards und Starter-Kits
  • LPCTools bietet verschiedene Starter Kits für die LPC2000-Familie
  • MakingThings Make Controller Kit (AT91SAM7X256)
  • MCT Paul und Scherer Starterkits für ARM7 (NXP LPC2000, ADI ADUC7000)
  • Mikrocontroller.net Shop Platinen mit AT91SAM7, LPC2xxx, JTAG
  • Microcontroller-Starterkits Starter-Kits für verschiedene Microcontroller (D) preisgünstige Platinen (ab 12,95 Euro für LPC2129 und 2194) sowie Entwicklungsboard komplett bestückt
  • Micro-Research Development- und Header-Boards für LPC2000 und ADuC7000
  • Olimex Bulgarischer Anbieter günstiger ARM Prototypen- und Header-Boards (LPC2000, STR7, AT91SAM, ADI, TI, OKI u.a.)
  • Propox
  • Primer2 from Raisonance Focus auf STM32 mit sehr grossem Forum im STM32circle
  • Revely Evaluations- und Demo-Boards mit Sharp ARM Controllern. Teilweise mit SVGA-Anschluss.
  • SKPang electronics Entwicklungsboards für diverse ARM7/9 (UK)
  • SSV Embedded Systems bietet verschiedene Starter Kits für die verschiedenen DIL/NetPC u.a. (A)DNP/9200 SBC mit AT91RM9200
  • taskit Development- und Header-Boards für AT91SAM7S/X, AT91RM9200, AT91SAM9
  • Toradex Colibri: Intel XScale PXA270 DevKit (Schweiz)
PIC
Herstellerseiten
  • www.osterer.co.at Entwicklungs-Board mit integrierten Programmer/Debugger für PIC18F4550.
  • www.martins-elektronikwelt.tk ICD1-Debugger-Nachbau im Kleinstformat u. SMD Technik (so groß wie eine halbe Scheckkarte).
  • PIC-Microchip-Controller (www.sprut.de) Diese Seite soll dem Anfänger die ersten Schritte in die Welt der Microcontroller der Firma Microchip erleichtern. Betrachtet werden die 14-Bit-Controller der Serien PIC16Fxxx bzw PIC12Fxxx.
  • PIC-Projekte.de Sehr gut geschriebene Tutorials und Projekte mit erklärten Codesnipseln. Besonders geeignet für Anfänger!
  • PIC: Programmierung in CCS (www.fernando-heitor.de) Dies ist eine weitere Seite die dem Anfänger, der sich mit PICs beschäftigt, auf die Beine hilft. Sie befasst sich hauptsächlich mit dem CCS-Compiler und hat dazu ein sehr gutes Tutorial. Ausserdem bietet die Seite ein Forum speziell für PIC Mikrocontroller.
  • CC5X Programmierkurs für PIC-Mikrocontroller in C (CC5X Compiler)] Programmierkurs mit Beispielen und Schaltplänen, fertige Hardware- und Softwarelösungen. In diesem Kurs sind auch einige Unterprogramme detailliert erklärt.
  • MicrochipC.com Programmieren von PIC-Microcontrollern mit C. (Enthält auch Links und Bootloader für diverse PICs.)
  • Internetworking with Microchip Microcontrollers - PIC18F4620+ENC28J60
  • Wiki about Microchip USB PIC (PIC18F2550, PIC18F4550...)
  • PICPgm - A free and simple PIC Development Programmer Software for Windows and Linux Einfacher PIC Programmer für Windows und Linux. Unterstützt eine Vielzahl von PIC-Chips und wird ständig erweitert. Derzeit können PIC10F, PIC12F, PIC16F, PIC18F, PIC24H sowie dsPIC30F und dsPIC33F programmiert werden.
  • InCircuit-Programmer und -Debugger (www.stolz.de.be) Einfacher Nachbau des Microchip ICD2s. Zum Programmieren und Debuggen.
  • WinPicProg Programmer und Tutorials für Anfänger von Nigel Goodwin (Englisch)
  • usbpicprog, an open source Microchip PIC programmer for the USB port. A wxWidgets based (cross platform) application to communicate with the usbpicprog hardware / firmware. This application is known to function well on Linux, Windows (XP or later) and Macosx.
  • EasyPIC3, EasyPIC4, Easy8051A, EasyAVR, Easy-was-weiss-ich (www.tigal.com) - Distributor für Produkte von mikroelektronika und weiteren Herstellern
  • Pro Zukunft Evaluation-Board für PIC16F84A, hands-on-training und Print-Lehrgang. Für Schulen, Ausbildungsbetriebe & Hobbyelektroniker.
  • www.wselektronik.at Bausatz für "Full Speed ICD2" (USB2.0, Debugger, Programmer) oder Fertiggerät erhältlich.
  • How to setup for PIC microcontroller development on Linux von Steven Moughan
  • gpsim is a full-featured software simulator for Microchip PIC microcontrollers distributed under the GNU General Public License.
  • YaPIDE aims to be a fully featured Microchip PIC simulator for Linux (and probably other UNIXes). YaPIDE is a GUI only application. If you need a commandline based PIC simulator there is the excellent gpsim. The simulator kernel currently supports the PIC 16F628.
  • Piklab is an integrated development environment for applications based on Microchip PIC and dsPIC microcontrollers similar to the MPLAB environment. It integrates with several compiler and assembler toolchains (like gputils, sdcc, c18) and with the simulator gpsim. It supports the most common programmers (serial, parallel, ICD2, Pickit2, PicStart+) and debuggers (ICD2).
  • vPICdisasm is a Microchip PIC Mid-Range family firmware disassembler. This single-pass disassembler can read Intel HEX and Motorola S-Record formatted files containing valid PIC firmware. (GPL)
  • PiKdev is a simple graphic IDE for the development of PIC-based applications. It currently supports assembly language. C language is also supported for PIC 18 devices. PiKdev is developed in C++ under Linux and is based on the KDE environment.
  • Yenka PICs lets you write routines using simple flowcharts, and test them on-screen, before using them to program real PIC or PICAXE chips. To help spread the news about Yenka, we're offering free copies of Yenka PICs for use at home or school.
  • Das deutsche PIC Forum Diskutieren Sie mit anderen über PIC und stellen Sie Fragen zu Ihren Problemen. Das deutschsprachige PIC-Forum
  • Open Programmer - An open source USB programmer for PIC micros, I2C-SPI-MicroWire EEPROMs, some ATMEL AVR micros, generic I2C/SPI devices and (soon) other devices. Can work as ICD debugger.
  • www.martins-elektronikwelt.tk Viele Projekte mit den PIC Mikrocontrollern, u.a. SMS-Schaltzentrale, SD/MMC-FAT32-MP3-Player, Lichtschranken, Funk-Wetterempfänger, PS/2 am PIC usw.
  • Firmware-On-Demand Umfangreiche Firmware-Bibliothek.
  • www.rentron.com Anfänger-taugliche Projekte für PIC und 8051 von Reynolds Electronics (Englisch)
  • Microchip 16-Bit Embedded Control 2007 Design Contest bei Circuit cellar
  • Mondo Technologiy Grosse Ansammlung von PIC-Projekten, u.a. SuperProbe: Logic Probe,(Auf der linken Seite ganz oben) Logic pulser, Frequency Counter, Event Counter, Voltmeter, Diode Junction Voltage, Capacitance Measurement, Inductance Measurement, Signal Generator, Video Patern, Serial Ascii, Midi Note, R/C Servo, Square Wave, Pseudo Random Number, ir38, PWM in einem... (PIC16F870)
  • uGNU/RTOS is a microcontroller-targeted serial real time operating system. It has been ported to USART capable Microchip PIC16 devices. It supports I/O operations and some internal registry operations. The user can interact with the chip through the RS-232 serial cable and a shell. The user can type a small list of commands and see the results on the chip's outputs. (LGPL)
  • www.PIC-Projekte.de Hier finden sich einige interessante Projekte mit PIC Mikrocontrollern (z.B. Anleitung zum Ansteuern eines HD44780 komp. LCD von eA, Ansteuern eines KS0107/8 Controllers in ASM mit PIC) sowie Erklärungen zu den dazugehörigen Programmabschnitten. Außerdem gibt es eine Anleitung zum Herrstellen von Platinen. Besuchen Sie das PIC-Forum und diskutieren Sie mit bei spannenden Themen. Wenn Sie Fragen zu PIC µC der Firma Micochip haben, dann sind Sie hier richtig aufgehoben!
  • Experiments with PIC16F628A - PIC Programming in C
  • Stevy's Homepage http://stevy.bplaced.com Pic Projekte die in C geschriebn wurden z.B 3D Engine, Grafik Display Ansteuerungen, Oszilloskip usw
  • RGB Stripe mit 16bit Bus, realisiert mit PIC12F629
  • Spiel PONG auf einer 16x16 LED Matrix mit Ton, realisiert auf einem AVR.
  • Pinguino Webpage und Pinguino Wiki ist ein Arduino-ähnliches Open Source und Open Hardware Projekt für 8-Bit (PIC18F2550, PIC18F4550) Mikrocontroller.
Z8
DSP
Wettbewerbe (Contests)
Verschiedene Hersteller veranstalten zur Promotion ihrer Produkte Designwettbewerbe, aus denen teilweise komplette Projektunterlagen hervorgehen (Schaltung, Source).
2011
2010
2009
2008
2007
2006
2005
2004
2003
2002
2001
Interfaces & Protokolle
Siehe auch Linksammlung#Schnittstellen
Infrarot (IR)
Parallelport
iPod
RFID
http://www.message_bocracco.com/
13,56 MHz RFID
  • OpenPCD - a free 13.56MHz RFID reader design for Proximity Coupling Devices (PCD) based on 13,56MHz communication. This device is able to screen informations from Proximity Integrated Circuit Cards (PICC) conforming to vendor-independent standards such as ISO 14443, ISO 15693 as well as proprietary protocols such as Mifare Classic. (AT91SAM7S128 ARM Projekt)
  • RFDump is a backend GPL tool to directly interoperate with any RFID ISO-Reader to make the contents stored on RFID tags accessible. (Linux)
2,4 GHz RFID
  • OpenBeacon - a free active 2.4GHz beacon design. (Reader: USB oder Ethernet; Tags: RF_Chip: NRF24L01, PIC16F684)
DMX512
Verschiedenes
Leiterplattenhersteller
siehe Platinenhersteller
Schulungen (Online)
Skripte
Messequipment
  • Filmetrics Inc. (Filmetrics manufactures affordable thin-film measurement instruments capable of measuring thin films from 3nm to 0.5mm in thickness.)
  • PCE Instruments (Entwicklung und Produktion für Prüfgeräte und Waagen.)
Logikanalyse
  • Intronix LogicPort, Günstiger, aber sehr leistungsfähiger Logikanalysator mit USB-Anschluß an PC (34Ch, 500MHz Timing, 34 x 2kSa mit Kompression, ca. 295 Euro hier)
  • Zeroplus LAP-Cxxxx (Familie von LA's mit unterschiedlichen Daten, 32kBit...2MBit, 16ch oder 32ch, 100MHz..200MHz, Preise von 90,-...1100,- Euro, zu kaufen hier)
  • TechTools DigiView, Günstiger Logikanalysator mit USB-Anschluß an PC (18Ch, 100MHz Timing, 128kSa mit Kompression, ca. 430Euro)
  • Tribalmicro, PC hosted LA (32ch, 40MHz Timing, 128kSa, ca. 1700$)
  • NCI GoLogic, Logikanalysator mit USB-Anschluß an PC (34 oder 72Ch, 500MHz Timing, 1 oder 2MSa, ca. 3000..5500$)
  • Tektronix, Verschiedene Geräte, standalone oder modular (ab 34ch, 2GHz Timing, ab 512kSa, gut und teuer)
  • Agilent, Verschiedene Geräte, standalone, modular oder PC-hosted (ab 34ch, ab 800MHz timing, ab 256kSa, gut und teuer)
  • Sumps LA, günstiges Projekt für einen LA basierend auf einem Digilent Spartan Board (32ch, 100MHz Timing, 256kSa, Kosten Digilent Board ca. 100$ + Versand/Zoll)
  • Meilhaus Electronic - MEphisto Scope UM203 Robustes, mobiles 16 bit Kombi-Instrument 7 Mess-Geräte in einem! (ab 348€)
  • TravelLogic TL2x36, Logikanalysator zum Anschluß an PC über USB, (36ch, 4GHz timing, 200MHz state, Speicher bis 72MBit, Preis ab ca. 500,- netto)
  • Bus und Logic Analyzer 100MHz Samplerate und integrierten SPI, I²C, CAN Interpreter, erweiterbar als Oszilloskop
  • logic - Logik-Analyzer mit 8 Kanälen, mit Software zur Analyse von SPI, I2C, UART, etc... (ca 150$ + Versand/Zoll)
  • DEDITEC USB-LOGI-500, kostengünstiges Einsteigermodell mit USB-Anschluß und dazugehöriger Software Logi+ (36Ch, Abtastrate 500MHz, 4096 Samples Speichertiefe/Kanal, ca. 236 Euro)
  • TimingAnalyzer can be used to easily draw timing diagrams and perform timing analysis to find faults in digital logic systems. Written in Java, it runs on any platform that supports the Java Run-time Environment, JRE1.6.0 or Java Development Kit JDK1.6.0 or newer.
Oszilloskope
Generatoren
Vermischtes
Foren
Videocasts und Podcasts
  • EEVblog Electronics Engineering Video Blog von David L. Jones (englisch). Anm.: David ist Australier und das hört man. An die Sprechweise kann man sich aber gewöhnen. Und nicht erschrecken, wenn öfter mal ein drastisches Fourletterword auftaucht!
  • The Amp Hour Podcast mit Chris Gammell und David Jones (englisch)
Projektsammlungen
Meist in Englisch.
Online-Bücher
  • BAMA Archiv
  • Big-List.com - This is a directory of over 600 dealers in used high technology equipment. Most deal in used electronic test equipment or semiconductor production equipment. Included are dealers in related high technology items, rental companies, equipment auction sites, test equipment manual dealers, foreign (non-U.S.) used equipment dealers, cal labs, and repair services.
