EmbDev.net
Forum: FPGA, VHDL & Verilog Error loading design (Modelsim student version)
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Keltuzad (Guest)
Rate this post
useful
not useful
Hi @ all,
Im working with the student version of Modelsim, I have dowloaded the
latest version (6.5b) and the licence and copied it to the root
folder(C:\dev\Modeltech_pe_edu_6.5b).
Now to the problem:
Im using "vsim -voptargs=+acc work.tdm_bert_tb" as my run command.
My only error report is:
#Error loading design
Due to the limited content of the error msg I have difficulties finding
a solution.
What have I already done:
I have reinstalled Modelsim + licence with Administrator rights, tried
running it with different -commands e.g. vsim -optargs work.tdm_bert_tb,
vsim work.tdm_bert_tb (none).
I only recieve the above mentoinened error.
Any suggestions are welcome.
Thanks in advance.
Kel.
: Moved by Admin
von guest (Guest)
Rate this post
useful
not useful
did you compile your designfiles/tb into the work lib using vlib and
vcom?
von Kel (Guest)
Rate this post
useful
not useful
hi,
yes all files including the testbench are compiled.
von Christian R. (supachris)
Rate this post
useful
not useful
In the most cases the error is shown many lines obove the "Error loading
design" Message. Search the blue lines for "Fatal : ..." or so.
von Kel (Guest)
Rate this post
useful
not useful
Hi supachris,
thx for the hint but the only error line I recieve is the "#Error
loading design" line and no other output. This is the fact that keeps me
from investigating further.
von Anand Singh (Guest)
Rate this post
useful
not useful
I am getting the error "Error Load Design"(Modelsim student version).
I have three modules and all are compiling without errors.
However,the order for one of them (test bench) stays '0' in the left
window.
Now,while trying to run the three modules,I was getting the error which
I have specified above.
von Ottmar (Guest)
Rate this post
useful
not useful
If the topmodule isn't loadable, try the submodules one by one.
von Sentinel (Guest)
Rate this post
useful
not useful
Make sure that your PDF student license is contained in the
C:\Modeltech_pe_edu_10.0c' directory folder only( i.e. is not contained
in any subfolders, the 'win32pe_edu' folder in particular!). I tried
this before and it cured the #Error loading system# for me when it
appeared!
I hope this will cure some headaches aswell!
Regards,
Sentinel.
von Victoria (Guest)
Rate this post
useful
not useful
I just had the same error message myself
and this is how I fixed it
- Check your license is not in a sub folder especially 'win32pe_edu' in
the  ModelSim directory
- and then check your "tb" design to see if your "module" and "uut" name
are one and the same for example mine was
         module tb_ex1_gate();
and
         ex1 uut
This led to the error "#Error loading design" because ModelSim could not
find it in the libraries, it should have been
and
         ex1_gate uut
also when the this error appears you can find more detail when you
scroll up on the Transcript section
I hope all this helps I am using ModelSim PE Student Edition 10.0c
von BVP (Guest)
Rate this post
useful
not useful
Thanks, Christian. Your input has helped me! Cheers..
von Anuj K. (anuj_k)
Rate this post
useful
not useful
Guys I solved my problem!
But first lets describe the problem
I was building a half subtractor using structural modelling. One of the
components used a not gate and I named the component "NOTGATE", which
was okay since it compiled peacefully.
But when i simulated the entity, an error occurred that said "Error
loading Design".
I ran a google search and stumbled here. The guy named Christian on this
post pointed out to check the lines above the error "FATAL...". Thanks
christian!
I checked mine out and it said that the "entity" NOTGATE was causing
problem which was in the same folder as the entity of half subtractor. I
checked the folder and I remembered "Oh yeah! I had once made that
entity (practicing you know!)." So i went back to my program and renamed
the component NOTGATE as NOTG. Simulated it and it executed without a
problem!
<Conclusion:
1. Read the whole error message not just the error line!
2. Always try to use unique identifiers in you program :/
von karim (Guest)
Rate this post
useful
not useful
hi I have same Error which is error loading design
there is no any problem in my code also the licen. file was downloaded
in my computer but i dont know the problem that make my modelsim doesnot
run the code is there any one has the solve thanks
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
You seem to be very confident about that. What gives you that certitude?
>> The guy named Christian on this post pointed out to check the lines
What error messages do you get previous to the fatal error?
von akaryas (Guest)
Rate this post
useful
not useful
This do not solve my problem...
# Compile of TB_Add1b.vhd was successful.
# Compile of Add1b.vhd was successful.
# Compile of config_Add1b.vhd was successful.
# 3 compiles, 0 failed with no errors.
ModelSim > vsim -voptargs=+acc -t ns work.cfg_test
# vsim -voptargs=+acc -t ns work.cfg_test
# Error loading design
von Cheroot (Guest)
Rate this post
useful
not useful
Kel wrote:
> hi,
von Cheroot (Guest)
Rate this post
useful
not useful
Loding...
von maryam (Guest)
Rate this post
useful
not useful
module Alsu8bit (a,b,cin,s3,s2,s1,s0,z);
     input [7:0]a,b;
     input cin,s3,s2,s1,s0;
output [7:0]z;
wire cout;
 wire [7:0] au,lu,shr,shl;
au8bit   au0 (a[7:0],b[7:0],cin,s1,s0,cout,au[7:0]);
lu8bit   lu0(a[7:0],b[7:0],s1,s0,lu[7:0]);
shru8bit shr0 (a[7:0],1'b1,s1,s0,shr[7:0]);
shlu8bit shl0 (a[7:0],1'b1,s1,s0,shl[7:0]);
mux8bit  alsu (au[7:0],lu[7:0],shr[7:0],shl[7:0],s3,s2,z[7:0]);
endmodule
von mukul (Guest)
Rate this post
useful
not useful
hi,
i got the same error and i saved the license file in
C:\Modeltech_pe_edu_10.4a . it would be very helpful if anybody let me
know wht should i do to remove this error
von Sharan (Guest)
Rate this post
useful
not useful
Hello. This is my code of full subtractor using 2 half subtractors. No
error in compiling. but there is this error will simulating the program:
Port w and d are not found in the connection module.
module hs(diff,borrow,a,b);
  output diff,borrow;
  input a,b;
  assign diff= a^b;
  assign borrow= ~a&b;
endmodule
module fs(diff,borrow,a,b,cin);
  output diff,borrow;
  input a,b,cin;
  wire [1:0]w,d;
  hs a1(.w(w[0]),.a(a),.d(d[0]),.b(b));
  hs a2(.a(d[0]),.d(d[1]),.b(cin),.w(w[1]));
  assign diff=d[1];
  assign borrow= w[0] | w[1];
endmodule
I will be obliged if you could help.
von Joseph (Guest)
Rate this post
useful
not useful
Here's another thought....
I had this problem after moving a simulation folder containing all my
verilog and project files.  After opening the project file (*.mpf) in a
text editor, I found all verilog files were described with absolut path
names, NOT relative path names. A simple find & replace to correct the
path would fix it!
von Alex Cole (Guest)
Rate this post
useful
not useful
> path would fix it!
This is the correct fix for most of these errors. It's another one of
ModelSim's wonderful "quirks", of which there seem to be an infinite
amount!
von Saad (Guest)
Rate this post
useful
not useful
* Error: (vsim-3053) C:/Users/Uzma/Desktop/fedup/fsm_tb.v(9): Illegal
output or inout port connection for "port 'out'".
Plz help as i dont understand the meaning of this error.. output port
has been clearly identified but still its not loading the file...
von Saad (Guest)
Rate this post
useful
not useful
// My FSM TB Code
module fsm_tb;
reg clk,rst;
reg din;
reg out;
fsm MUT(din,rst,clk,.out(out));
initial
clk<=1;
always
#5 clk <=  ~(clk);
//Set occurance of sequence
initial
begin
@(posedge clk);     din <= 1'b1 ;
@(posedge clk);     din <= 1'b0 ;
end
endmodule
von Duke Scarring (Guest)
Rate this post
useful
not useful
$ vlog fsm_tb.v
Model Technology ModelSim SE-64 vlog 10.3d Compiler 2014.10 Oct  7 2014
Start time: 12:00:36 on Nov 21,2016
vlog fsm_tb.v
-- Compiling module fsm_tb
** Error: fsm_tb.v(10): near ".": syntax error, unexpected '.', expecting ')'
End time: 12:00:36 on Nov 21,2016, Elapsed time: 0:00:00
Errors: 1, Warnings: 0
After changing ".out(out)" to "my_out(out)", I got the following output:
$ vlog fsm_tb.v
Start time: 12:01:41 on Nov 21,2016
vlog fsm_tb.v
Top level modules:
        fsm_tb
End time: 12:01:41 on Nov 21,2016, Elapsed time: 0:00:00
Errors: 0, Warnings: 0
Duke
von Avani (Guest)
Rate this post
useful
not useful
It worked for me
von Eduardo Hernandez (Guest)
Rate this post
useful
not useful
Author: Sentinel (Guest)
Posted on: 2011-10-06 17:15
appeared!
Regards,
Sentinel.
Sentinel
YOU ARE A GENIUS !
COOL!
von y.parhizkar (Guest)
Rate this post
useful
not useful
thanks, it was very helpful!
von Unanimous (Guest)
Rate this post
useful
not useful
Maybe somebody already mentioned it but just to be sure, after you've
saved the license file in the right directory as described in previous
posts, close ModelSim and then try again to simulate because otherwise
the error won't disappear
von SUMIT (Guest)
Rate this post
useful
not useful
please help don't know what to do
von SUMIT (Guest)
Rate this post
useful
not useful
von rafi (Guest)
Rate this post
useful
not useful
Thanks ,it works
von rafi (Guest)
Rate this post
useful
not useful
this method works..
von Rajesh (Guest)
Rate this post
useful
not useful
i am keep on getting error loading design error after when i click on
simulate
i have tried some things
but i was not able to correct
could someone explain it briefly how can i solve this problem
von Seimen (Guest)
Rate this post
useful
not useful
My code has been compiled successfully but on simulating the following
error is shown. Please help in rectifying the error.
vsim -gui work.half_adder
# vsim
# Start time: 21:24:16 on Oct 13,2018
Rate this post
useful
not useful
Here are the basic steps for using modelsim from command line:
1. Create library (working directory for modelsim):
$ vlib work
2. Compile design:
$ vcom design.vhd
Start time: 11:18:20 on Oct 16,2018
vcom design.vhd
Model Technology ModelSim SE-64 vcom 10.6c Compiler 2017.07 Jul 26 2017
-- Loading package STANDARD
-- Loading package TEXTIO
-- Loading package std_logic_1164
-- Compiling entity design
-- Compiling architecture rtl of design
End time: 11:18:20 on Oct 16,2018, Elapsed time: 0:00:00
3. Compile testbench:
$ vcom testbench.vhd
Start time: 11:19:23 on Oct 16,2018
vcom testbench.vhd
23
24
25
-- Compiling entity testbench
26
-- Compiling architecture testbench of testbench
27
End time: 11:19:23 on Oct 16,2018, Elapsed time: 0:00:00
28
29
30
4. Start simulator:
31
$ vsim -gui testbench
32
33
5. Add some signals to view:
34
VSIM 1> add wave *
35
36
6. Run simulator for a specified time:
37
VSIM 2> run 1 ms
38
39
7. Zoom the wave window:
40
VSIM 3> wave zoom full
41
# {0 ps} {1050 us}
Duke
von Fezzeni Nejla (Guest)
Rate this post
useful
not useful
plz any aide
Rate this post
useful
not useful
any aide
Rate this post
useful
not useful
help with the error massage: error loading design
von hyannistoolman (Guest)
Rate this post
useful
not useful
Thanks guys, matching these names and then redefining in the simulation
file settings solved this problem for me.
von Ram (Guest)
Rate this post
useful
not useful
Checks: 1.student license must be in the same folder of ModelSim
        2.If not cut and paste it.
        3.run the simulation
If you have done above things but still getting same.Then
        Uninstall ModelSim and again reinstall it.
von cyberwalker (Guest)
Rate this post
useful
not useful
You were SOOOO right about the license path! Thank you so much!
von Arslan (Guest)
Rate this post
useful
not useful
My work library will not work proper.when i will compile it will add
another work library in compile and show the work library empty.Anyone
can tell me the problem.
von Shubham Agra (Guest)
Rate this post
useful
not useful
I had the same problem for almost 2 months now. This is how i solved it:
For those trying gate level simulation and using a sdf file along with
it, you must also compile the sdf file. But it not like compiling any
other file. You must use the command sdfcom. Also when using this
command, you must also specify the sdo file name as input, and a new
file name that will be used as output file. So the syntax goes like:
sdfcom [ options ] source-file output-file
This might help some people.
I am using Modelsim FPGA Starter version 10.5b
Thanx
von Supriya (Guest)
Rate this post
useful
not useful
hi,
i am even getting same erroe and in the blue line it's written
( Error: (vsim-3173) Entity
'C:/Modeltech_pe_edu_10.4a/CourseraFPGA/Course2/AAC2M1P1/work.comparator
2'  has no architecture)
Please suggest what should i do.
von Supriya B. (Company: Lovely Professional University) (supriya_18)
Rate this post
useful
not useful
I am getting error due to loading design and the reason given is
"comparator 2 has no architecture".Please help me out.I had attached the
file also'
von Andi (Guest)
Rate this post
useful
not useful
# vsim
# Start time: 11:53:42 on Oct 20,2020
this is the error that keeps showing when i try to simulate my codes
module bufif_notif_gates (output c,d, input a, b);
bufif1 (c, a, b);
notif1 (d, a, b);
endmodule
module bufif_notif_gates_tb;
  reg tb_a, tb_b;
  wire tb_c, tb_d;
  bufif_notif_gates_tb Instance0 (tb_c, tb_d, tb_a, tb_b);
  initial begin
    tb_a = 0; tb_b = 0;
 #1 tb_a = 0; tb_b = 1;
 #1 tb_a = 1; tb_b = 0;
 #1 tb_a = 1; tb_b = 1;
  end
  initial begin
    $monitor ("T=%t| a=%b |b=%b| c(bufif)=%b |d(notif)=%b", $time, tb_a,
tb_b, tb_c, tb_d);
  end
endmodule
this is my code. i don't know how to fix this :(
Rate this post
useful
not useful
You need three steps to simulate in modelsim:
1. create library:
vlib work
2. compile all design files (and the testbench!) into the library (work
is the default):
vlog my_design.v
vlog my_testbench.v
3. start simulation:
vsim -gui my_testbench
That's it.
Duke
von anusha (Guest)
Rate this post
useful
not useful
how to fix this prblm?
# vsim -gui
# Start time: 00:25:07 on Dec 06,2020
# Loading work.tb_1101moore_74
# ** Error: (vsim-3033) C:/Modeltech_pe_edu_10.4a/examples/TB_310.v(13):
Instantiation of 'moore1101' failed. The design unit was not found.
#    Time: 0 ns  Iteration: 0  Instance: /tb_1101moore_74 File:
#         Searched libraries:
#             C:/Modeltech_pe_edu_10.4a/examples/work
vlog -reportprogress 300 -work work
# Model Technology ModelSim PE Student Edition vlog 10.4a Compiler
2015.03 Apr  7 2015
# Start time: 00:27:50 on Dec 06,2020
# vlog -reportprogress 300 -work work
# -- Compiling module tb_1101moore_74
# Top level modules:
#   tb_1101moore_74
# End time: 00:27:50 on Dec 06,2020, Elapsed time: 0:00:00
# Errors: 0, Warnings: 0
Rate this post
useful
not useful
How does line 13 of TB_310.v look like?
von anusha (Guest)
Rate this post
useful
not useful
this is my test bench
Rate this post
useful
not useful
I'm sorry, I won't open a doc file.
Pls. simply attach VHDL files as *.VHDL files.
: Edited by Moderator
von anusha (Guest)
Rate this post
useful
not useful
when i complile it was like this
vlog -work work -L mtiAvm -L mtiRnm -L mtiOvm -L mtiUvm -L mtiUPF -L
infact -O0 C:/Modeltech_pe_edu_10.4a/examples/TB_310.v
2015.03 Apr  7 2015
# Start time: 14:53:12 on Dec 07,2020
# vlog -reportprogress 300 -work work -L mtiAvm -L mtiRnm -L mtiOvm -L
mtiUvm -L mtiUPF -L infact -O0
# -- Compiling module tb_moore1101_74
#   tb_moore1101_74
# End time: 14:53:12 on Dec 07,2020, Elapsed time: 0:00:00
Rate this post
useful
not useful
Did you have compile moore1101.v also?
Duke
von Paulpraveen P. (paulpraveen23)
Rate this post
useful
not useful
Damm even I am having a similar kind of issue, I have searched all over
the internet and even have posted on number of threads on different
forum, no solution seems to work. I am really frustrated, can anyone of
you here help me resolve this issue, I am very much tired now.
Rate this post
useful
not useful
New Problem -> new question.
And without specific and detailed error description only people with a
working crystal ball can help.
Duke
von Lerninstructor (Guest)
Rate this post
useful
not useful
As pointed out in this old posting:
https://embdev.net/topic/error-loading-design-modelsim-student-version#6511390
the cause of the error is "Not all required source files are compiled" .
Rate this post
useful
not useful
Also check, if all working libraries are created and active (see command
'vlib' and 'vmap').
von Rahul P. (Company: Webcorewin) (rahulp411)
Rate this post
useful
not useful
window.
Rate this post
useful
not useful
Again, check library references ('use'-clause, instance-component
references) as described above.
Rate this post
useful
not useful
> Duke
Should I start a new thread or post it here anyway? cz I'm unable to
find a suitable thread for it.
Rate this post
useful
not useful
Do so.
And write more than "I have problems".
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
