EmbDev.net
Forum: FPGA, VHDL & Verilog square root and cubic root for integer and FPGA implementation
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Detlef _. (detlef_a)
Rate this post
useful
not useful
This post refers to:
Beitrag "Kubikwurzel bilden"
The attached C-code implements square root and cubic root calculations
for integers. The code uses mere Add/Shift operations and is thus well
suited for hardware implementation.
It was assembled and adapted from different sources.
There are more details given in the attached file.
Cheers
Detlef
: Moved by Admin
von Mohan (Guest)
Rate this post
useful
not useful
Do you have any material guidance on how to implement cubic root using
FPGA - with matlab SIMULINK?
Any help is greatly appreciated .
Thank you
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
