EmbDev.net
Forum: FPGA, VHDL & Verilog modify vdhl code to use t flip flops to blink 4 led's
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Nick D. (ufcking18)
Rate this post
useful
not useful
I have this code, but I need help to modify it in order to use the t
flip flops to simulate 4 leds that light up on each clock like this:
0 = led on
x = led off
clk 1: 0000
clk 2: 000x
clk 3: 00xx
clk 4: 0xxx
clk 5: xxxx
clk 6: xxx0
clk 7: xx00
clk 8: x000
(then it loops back to how it was in the first clock on the 9th clock.)
Thanks for the help
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
So first will be to add the fourth flipflop.
And then implement the transition terms for the 8 transitions. It will
be less typewriting when you reduce the logic terms by using state of
the art tools like Karnaugh maps in advance.
> I have this code
And what does it do?
Examine it and think about what to add to get your job done.
> Thanks for the help
Its not the intention of this forum to do your homework. So start with
something and when you have a particular problem, then ask.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
