EmbDev.net
Forum: Analog Circuits How about a low pass filter followed by LTC6085 and then to the ADC KW40Z sound?
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Elijah C. (meideolian)
Rate this post
useful
not useful
Hello,
I'm designing my first ever circuit for a hobby project. I've a sensor
that outputs in mV and a controller with ADC. The ADC is 16 bits, VDDA =
3.0 V, Temp =25°C, fADCK = 1.0 MHz. Since the sensor voltage that is fed
is to the controller is low I'm in a predicament! Should I use a low
pass filter or a band pass filter in this application? Do you have a
circuit that I can relate to?
(The attached)
The sensor is a screen printed piezoelectric sensor. Since it is printed
on textile, textiles present a very low dielectric constant that reduces
the surface wave losses and increases the impedance bandwidth.
(http://www.kynix.com/uploadfiles/pdf9675/LTC6085CDHC23PBF_778665.pdf)
(https://www.nxp.com/docs/en/data-sheet/MKW40Z160.pdf) sound?
Any advice is appreciated. Thanks.
von ths (Guest)
Rate this post
useful
not useful
Rate this post
useful
not useful
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
