EmbDev.net
Forum: FPGA, VHDL & Verilog New to VHDL Need help with this assignment
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von James Y. (Company: Student) (eejyang)
Rate this post
useful
not useful
Hey guys!
I'm a new university freshman and new to VHDL.
So recently I've given this sort of assignment,
in class,and some clue codes from professor,but nothing really helps.
The picture in the attachment is the subject I been trying to code.
Here's some partial clue codes provided by professor,of course with some
errors need to correct...
Thanks guys for any thoughts and guide me through this.
edit : errors are :
signal ck1hz : STD_LOGIC_VECTOR (24); <-The expression can not be
converted to type STD_LOGIC_VECTOR.
Q <= Q + '1'; <- + can not have such operands in this context.
ck1hz <= Q(24) => Y when DIR = '1' else DIR = '0'; <- Undefined symbol
'ck1hz'. & parse error, unexpected ROW, expecting SEMICOLON
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity demoW2 is
    Port ( CLK : in  STD_LOGIC;
           RST : in  STD_LOGIC;
           DIR : in  STD_LOGIC;
           C : out  STD_LOGIC_VECTOR (6 downto 0));
end demoW2;
architecture Behavioral of demoW2 is
signal Q : STD_LOGIC_VECTOR (24 downto 0);
signal Y : STD_LOGIC_VECTOR (3 downto 0);
begin
process (CLK,Q)
begin
if CLK' event and CLK = '1'
  then
      Q <= Q + '1';
  end if;
23
end process;
24
25
with Y select
26
  C <= "1000000" when "0000",
27
      "1111001" when "0001",
28
      "0100100" when "0010",
29
      "0110000" when "0011",
30
      "0011001" when "0100",
31
      "0010010" when "0101",
32
      "0000010" when "0110",
33
      "1111000" when "0111",
34
      "0000000" when "1000",
35
      "0011000" when "1001",
36
      "0001000" when "1010",
37
      "0000011" when "1011",
38
      "1000110" when "1100",
39
      "0100001" when "1101",
40
      "0000110" when "1110",
41
      "0001110" when others;
42
43
end Behavioral;
: Edited by User
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
What are your suggestions? What error messages does the toolchain
report?  What's wrong in the erronous lines?
It's your homework, when you give some reasonable suggestions then maybe
someone will help you further on.
Rate this post
useful
not useful
> signal ck1hz : STD_LOGIC_VECTOR (24); <-The expression can not be converted to
I know I supposed to work out my own homework,but I'm honestly out of
ideas,and the clues aren't helping...I can't see the points where I need
to do.
Rate this post
useful
not useful
James Y. wrote:
> I can't see the points where I need to do.
You have a sketch of a hardware you have to describe with VHDL.
So
1. describe the prescaler for the 1.5 Hz and
2. the 4 bit counter, connect
3. them together and
4. to the 7 segment decoder.
: Edited by Moderator
von C. A. Rotwang (Guest)
Rate this post
useful
not useful
Check with the internet how to code an incrementing counter in VHDL.
It's important to use the approbiate types und libraries and not to be
confused with the differences beetwenn 1 and '1'.
library IEEE;
      Q <= Q + '1';
Compare the quoted lines with the lines there:
http://www.asic-world.com/examples/vhdl/simple_counter.html
Rate this post
useful
not useful
Looks like this should be an alias of Q(24)
> process (CLK,Q)
There are too much sichals in the sensitivity list here.
clk is enough.
> Undefined symbol 'ck1hz'.
Define it in a proper way. And define its name in a way that it matches
the real world: you do not want a 1 Hz clock, you want 1.5 Hz.
BTW: are 1.562 Hz close enough to the 1.5 Hz you want? Then maybe you
can head on with your "2^24 prescaler clock divider", although you
should not use such a "clock-divider-prescaler" design strategy in
modern FPGAs.
Do you have to use as much as you can from that very old fashioned
example? Or can you write code thats more up to date? Code with clock
enables and so on?
All in all my attempt would look like this:
use IEEE.NUMERIC_STD.ALL;
signal prescaler : integer range 0 to 33333332 := 0; -- 1.5Hz = 50000000/1.5
signal index     : integer range 0 to 15 := 0;
signal clockenable1hz5: STD_LOGIC;
begin
-- prescaler
process begin
   wait until rising_edge(clk);  -- only 1 clock throughout the whole design!
   if prescaler < 33333332 then
      clockenable1hz5 <= '0';
      prescaler       <= prescaler+1;
   else
      clockenable1hz5 <= '1';     -- generate a clock enable with 1.5 Hz
      prescaler       <= 0;
   end if;
end process;
-- index counter
23
process begin
24
25
   if clockenable1hz5 = '1' then
26
      if index < 15 then  index <= index+1;
27
      else                index <= 0;
28
      end if;
29
   end if;
30
end process;
31
32
-- the decoder
33
with index select
34
   C <= "1000000" when 0,
35
        "1111001" when 1,
36
        "0100100" when 2,
37
        "0110000" when 3,
38
        "0011001" when 4,
39
        "0010010" when 5,
40
41
        "0000110" when 14,
42
        "0001110" when 15;
All in all that coding style is far more read- and understandable for
humans. And thats the style I'm teaching my students...
Rate this post
useful
not useful
> enables and so on?
I can't be sure,but I don't think there is any limitation.
: Edited by User
Rate this post
useful
not useful
Ok,I'll try to google more information about it as possible.
Rate this post
useful
not useful
And may I ask,can you recommend a book for me to study VHDL?(I'm using
Xilinx ISE)
: Edited by User
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
