EmbDev.net
Forum: µC & Digital Electronics APA107 white digital led strip, can replace dotstar apa102?
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Miguel T. (miguel_tena)
Rate this post
useful
not useful
i got some pieces apa107 white color digital led strips, can I use it to
replace dotstar apa102 white?
von yesitsme (Guest)
Rate this post
useful
not useful
APA107 has 4 pins, APA102 has 6.
APA107 only has a data-pin, APA102 has pins for data and clock.
Its not a drop-in replacement.
Rate this post
useful
not useful
hey,
Had you seen the APA107 before? if not, please shut up.....
check the picture, open your fu...cking big eyes, it is 4pins?
if you are not blind, I think you can see 6pins....
von Watschn (Guest)
Rate this post
useful
not useful
Miguel T. wrote:
> please shut up.....
In the same rough tone: RTFM!
Rate this post
useful
not useful
Please look on the attached image. Its from the datasheet.
I guess you are on your own now.
von Marcel P. (Company: pixel) (marcel_paul)
Rate this post
useful
not useful
see my photograph...i bought 1 meter white APA107 sample from
china....it is 6pin...
you are absolutely their competitor...perhaps your APA102 is very good
selling...you looks very scared
von Jessy J. (jessy_jela)
Rate this post
useful
not useful
Why did you make that datasheet???? I am very curious.
This is the real datasheet...
von void (Guest)
Rate this post
useful
not useful
No. This is a jpeg image - not a datasheet.
And no. Yesitsme did not made the datasheet. Like you he randomly
selected a document from the internet. Actually the vendor wrote two
datasheet documents with the same name "SPC/APA107".
 1) https://datasheetspdf.com/pdf-file/1273359/NEWSTAR/APA107/1
 2) https://cdn.hackaday.io/files/21293910999712/APA107%20RGB.pdf
The later one with revision number 01 seems to be the current valid one,
as it is the version available on the homepage of newstar.
  http://www.newstar-ledstrip.com/productshow817.html
  -> http://www.newstar-ledstrip.com/product/20180820112602493.pdf
Miguel T. wrote:
> can I use it to replace dotstar apa102 white?
It seems to be what newstar has in mind when writing:
"APA107 will be upgraded again, the PWM can be 26-28kHz, faster and
cheaper than APA102."
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
