EmbDev.net
Forum: PCB Design & Technology Bed of Nails Tester
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von PCB P. (Company: ALLPCB) (pcbassembly)
Rate this post
useful
not useful
A bed of nails checker may be a ancient electronic check fixture that
has various pins inserted into holes in AN epoxy phenolic resin glass
fabric laminated sheet (G-10) that square measure aligned victimisation
tooling pins to form contact with test points on a computer circuit
board and also are connected to a unit of measurement by wires. Named by
analogy with a real-world bed of nails, these devices contain AN array
of tiny, elastic device pogo pins; every pogo pin makes contact with one
node within the electronic equipment of the DUT (device beneath test).
By pressing the DUT down against the bed of nails, reliable contact may
be quickly and at the same time created with a whole bunch or perhaps
thousands of individual check points at intervals the electronic
equipment of the DUT. The restriction force is also provided manually or
by suggests that of a vacuum or a mechanical presser, so propulsion the
DUT downward onto the nails.
Bed-of-Nails check itself because of the limitation of principle and
technique, featured with severe technological challenges. however as I
delineated on top of, there still has benefits different strategies
don’t have. With the utilization of recent and improved technology and
fixture technology, it'll even have robust vitality within the field of
electrical testing.
https://www.allpcb.com/bed_of_nails_test.html?code=P9
: Moved by Moderator
Rate this post
useful
not useful
The thickness of a printed circuit board (PCB) can influence the
performance and practicality of the board. counting on what your needs
area unit for your PCB, can verify what thickness utmost suits you.
But not all PCB’s area unit identical. several variables inherit play
once building a PCB. The thickness of the board is one in every of those
essential variables. once electing the amount of thickness you would
like, you want to take into account not simply the perform of the PCB,
however the profile, weight, assembly parts and specifications of the
parts additionally. All of those factors contribute to the performance
of the PCB additionally because the thickness level.
The maximum thickness of a finished computer circuit board may be
determined by measurement it from copper to copper. most thickness of a
PCB plays a very important role within the fabrication of a printed
circuit. the utmost finished PCB thickness determines the stack heights
for the aim of drilling and identification, the ratio, additionally
because the permanent limits of producing instrumentality for process.
Thickness of solder mask ought to be thought of, whereas shrewd the
whole thickness. the whole thickness of a PCB is between zero.5 mm
(0.020 inches) to six.85 mm (0.270 inches). we offer PCBs with finished
thickness zero.008″ - 0.275″ (0.2mm- 7mm).
https://www.allpcb.com/pcb_board_thickness.html?code=P9
Rate this post
useful
not useful
This is a comparison of printed circuit board design software. Our
criteria for as well as a PCB CAD program are:
There ought to be a version accessible at no cost (no money).
The free version shouldn't be time restricted, i.e. you ought to be
ready to use the package indefinitely without having to purchase it.
The free version ought to offer schematic and board style and will
generate some type of output that may be accustomed manufacture boards.
The package ought to be actively developed and supported.
https://www.allpcb.com/software/P9
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
PCB P. wrote:
> we offer PCBs with finished thickness zero.008″ - 0.275″ (0.2mm- 7mm).
For advertising pls contact the webmaster.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
