EmbDev.net
Forum: FPGA, VHDL & Verilog VHDL project
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Paul (Guest)
Rate this post
useful
not useful
Our professor asked us to write a program in VHDL to read a bmp image
and to
replace the red color in the image  with blue color .
Any ideas how to do it please ?
Thanks in advance
: Moved by Moderator
von Tobias B. (Company: www.elpra.de) (ttobsen)
Rate this post
useful
not useful
Get the specification of the Bitmap File format and start coding.
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
Only for simulation? Or must it be implemented in real hardware?
If the first, then check out that discussion:
https://groups.google.com/forum/m/#!topic/comp.lang.vhdl/libdwhFbtNY
If the second: where is your bmp image stored?
: Edited by Moderator
von Paul (Guest)
Rate this post
useful
not useful
Only for the simulation .
von FPGAzumSpass (Guest)
Rate this post
useful
not useful
I don't get why somebody gives such a task. The real quest here is to
find out how to read and write a file in binary with VHDL. It doesn't
teach much about VHDL in general and nothing about logic or how to
describe hardware.
So here is a testbench i have written years ago to read a bmp, modify
and write back.
You still need to understand it and implement the logic you need instead
of my modify function.
Rate this post
useful
not useful
von Paul (Guest)
Rate this post
useful
not useful
Thank you
von wbila (Guest)
Rate this post
useful
not useful
Bogomolni ?
von Guest (Guest)
Rate this post
useful
not useful
Paul wrote:
> Unser Professor hat uns gebeten, ein Programm in VHDL zu
> schreiben, um ein bmp-Image zu lesen
> und zu
> Ersetzen Sie die rote Farbe im Bild durch blaue Farbe.
> Irgendwelche Ideen, wie es bitte geht?
> Danke im Voraus
Hello Paul, I got the same assignment. Did you solve it
If so, would you help me?
thanks
von Duke Scarring (Guest)
Rate this post
useful
not useful
Please open a new topic for a new question!
(Of course you can give a link to the old question.)
That is a weird assignment, because in hardware there exist no bpm file.
In hardware there are only voltages on signal lines. And VHDL is for
hardware.
Another point is simulation: In simulation testbenches exists files, but
mainly as input and output for signals. Nobody with common sense will
make a file converter in VHDL language.
I've done some VHDL code which take a VGA signal as input and write
every video frame to a bpm file to see if the graphical output of my
design is valid.
> Did you solve it
What have you done so far?
Where is your sore point?
What specific help did you expect?
If you ask squishy questions, you will get much squishier answers.
Duke
von Andreas S. (Company: Schweigstill IT) (schweigstill)
Rate this post
useful
not useful
> hardware.
VHDL also doesn't "know" anything about voltages.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
