EmbDev.net
Forum: FPGA, VHDL & Verilog VHDL Debouncer 4 clocks
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Alexander S. (Company: Home) (alex_isr)
Rate this post
useful
not useful
Attached ModelSim VHDL design of Debouncer 4 clocks.
Regards Alex.
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
Alexander S. wrote:
> design of Debouncer
Thats that very coding style why people say VHDL is extremly chatty:
process (ClockIn ,nResetIn,DebounceClockIn,DataTmp,DataIn)
variable DebounceStatus : std_logic_vector(1 downto 0);
begin
DebounceStatus(0) := DataTmp(0);
DebounceStatus(1) := DataTmp(3);
 if(nResetIn = '0') then
  DataTmp <= (others => '0');         -- Pipe Line
 elsif (ClockIn'event and ClockIn = '1') then
  case DebounceClockIn is
   when '1' =>
    DataTmp(0) <= DataIn;
    case DebounceStatus is
     when "00" =>
      DataTmp(2 downto 1) <= (others => '0');
     when "11" =>
      DataTmp(2 downto 1) <= (others => '1');
     when others =>
      DataTmp(3 downto 1) <= DataTmp(2 downto 0);
    end case;
   when others =>
    DataTmp <= DataTmp;
  end case;
23
 end if;
24
end process  PipeLine_Process;
BTW: there are way to much singals in the sensitivity list of that
process. ClockIn and nResetIn would be enough, because the process must
be recalculated by the simulator only when one of those two changes.
I prefer debouncing (and edge detection) with a shift register:
http://www.lothar-miller.de/s9y/archives/3-Tastenentprellung-mit-Schieberegister.html
(use Google translator, its German)
That way I find it much more easy to understand because its less chatty
and straight forward.
Other ways to debounce are those:
http://www.lothar-miller.de/s9y/categories/5-Entprellung
Rate this post
useful
not useful
You're right .
 It's my old design.
Currently it's preferred to use synchronous Reset.
 Only in the old Quartus version was needed all inputs signals in the
sensitive list.
 Regards Alex.
: Edited by User
Rate this post
useful
not useful
> [vhdl]
 But you can control synthesis process for max. speed.
 High level language have optimization by developments system and you
don't know result.
 Regards alex.
: Edited by User
Rate this post
useful
not useful
 It's nice, but you use only one clock. If general gesign clock is some
(1 - 50) MHz you can't design debounce for slow signals such as from
mechanical switches.
 Regards Alex.
Rate this post
useful
not useful
Alexander S. wrote:
> If general gesign clock is some (1 - 50) MHz you can't design debounce
> for slow signals such as from mechanical switches.
Have a second look on the code in the link. It includes a prescaler to
reduce sampling speed.
Rate this post
useful
not useful
 Yes , you use additional 14 Bits counter and check it status by high
system clock for reduce sampling speed.
 For my opinion : It's not good practice for high speed design.
Regards Alex.
Rate this post
useful
not useful
Of course.
To get down from 50MHz to mechanical speed it simply needs 14 bits. Your
design must do some similar dividing in real life. Such kind of
"prescaler" won't work there:
DebounceClock   <= not DebounceClock after 101 nS;
Personal opinions doesn't matter in hardware. Synthesize the both
designs and let the toolchain speak.
And one thing is for sure: counters are the fastest things you can build
on FPGAs. There is special hardware for that job on the die (look at the
carry chain).
: Edited by Moderator
Rate this post
useful
not useful
Lothar M. wrote:
 Your
 DebounceClock
Debouncer_Tb.vhd
It's clock for simulation only.
 In the real design you can generate DebounceClock from slow clock which
usualy present in the your design or generate it from slow clock
generated by PLL.
 In this case you do not need tuning you Debounce components for each
design and always use big counter.
 Regards Alex.
: Edited by User
Rate this post
useful
not useful
Lothar M. wrote:
 You are right : I did not write it's rule of good practice design for
high speed design.
> on FPGAs.
 But it's present rules for design high speed counters and checking it
states .
 Only if you use hardware components from manufactory library or use
high speed design rules for design you will have :
fastest things you can build on FPGAs.
 Regards Alex.
: Edited by User
von Klakx (Guest)
Rate this post
useful
not useful
> Regards Alex.
What is your intention with such posts?
For online storage github would be more suitable.
Rate this post
useful
not useful
 I receive remarks and repair my design.
 What's : github ?
Rate this post
useful
not useful
Alexander S. wrote:
> What's : github ?
https://www.google.com/search?q=github
Its a place you can get your designs into public. If I would paste three
of the designs on my harddisk a day, then we would have much fun till at
least next spring. But I don't. Why do you?
A forum is a place for discussing particular questions and problems. But
you post your designs without any questions to discuss about nor at
least a description what the designs should be good for.
Rate this post
useful
not useful
 My main question : are my designs according to good practice design and
VHDL rules ?
nor at
 Design good if design work and make it application.
Description of design is the name of design.
If you need additional description you can ask me.
von ktorkkelson (Guest)
Rate this post
useful
not useful
@Alexander S. you are just a damn chat bot. Stop wasting people's time.
Cheers ;)
Rate this post
useful
not useful
> Cheers ;)
  Save your time: you and others (such as you) not required to read my
posts .
 If Moderator think as you, he can stop my participation in this forum.
Regards Alex.
: Edited by User
Rate this post
useful
not useful
> VHDL rules ?
There are no general "VHDL rules".
Or better: the most relevant "VHDL rules" are those in the synthesizers
user guide.
See https://embdev.net/topic/498013?goto=6303958#6303958 also.
Rate this post
useful
not useful
 Thanx. I've repaired my design.
 Regards Alex.
Rate this post
useful
not useful
Lothar M. wrote:
> Alexander S. wrote:
>> What's : github ?
 If I've understood right, it's for software only : not for hardware
VHDL place.
 Regards Alex.
Rate this post
useful
not useful
Alexander S. wrote:
> If I've understood right, it's for software only : not for hardware VHDL
> place.
Of course you can place hardware projects also:
https://github.com/topics/fpga
Or you can try to host your projects at https://opencores.org/projects
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
