EmbDev.net
Forum: µC & Digital Electronics Pump for a water-bearing stove
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Rolf (Guest)
Rate this post
useful
not useful
I have written a program for the Raspberry Pi to control a pump for a
water-bearing stove. The program works fine - but I still need a
computer independent safety device. If the Raspberry fails - then it
must be ensured that the pump runs in continuous operation to avoid
overheating of the boiler. My first approach was - to evaluate a clock
signal to be output from the Raspberry. As long as the clock signal
comes from the Raspberry - as long as a retriggerable monostable toggle
stage is reset again and again. If the clock signal is missing - the
pump goes into continuous operation. But if the clock signal remains
HIGH - then this idea does not work. One must also evaluate the falling
edge of the clock signal and connect it with logic. At the moment I am
on the hose - can someone help me?
von minifloat (Guest)
Rate this post
useful
not useful
I suggest to address the problems from the root, in following
priorities:
1 put an overpressure blowoff valve at the output of the boiler. This
acts against the fault effect and prevents severe injuries, as the
boiler tank cannot explode anymore.
2 put an overtemperature switch in series to the heater element.
Consider also using a non-resettable type. This acts against the root
cause and also prevents fire.
3 now it is time to think about the additional safety device you're
planning. Simple solution is make the toggling signal AC by adding a
capacitor in series and a resistor after the cap to GND. Then feed this
into the input of a retriggerable monoflop. A simple form of this is the
attached circuit. (from
https://cpldcpu.wordpress.com/2021/02/27/the-transistorpixel/ )
Higher capacitor values have to be used, and a resistor in series to
Q7:collector of a few hundred Ω is advisable.
br, mf
Rate this post
useful
not useful
PS.
A pressure switch of NC type in series with the heater element could
also serve as another safety mechanism. But pressure switches could  be
rather bulky and maybe also expensive...
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
