EmbDev.net
Forum: ARM programming with GCC/GNU tools MCB2300 SD card problem
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Baltasar R. (breig)
Rate this post
useful
not useful
Hi all,
I have been trying the demo "ChaN's FAT-Module and LPC23xx/24xx MCI" on
my MCB2300 board (with LPC2388 controller), using a Sandisk 512 MB SD
card:
http://gandalf.arubi.uni-kl.de/avr_projects/arm_projects/efsl_arm/index.html
My problem is the demo always gets stuck when initializing the disk,
that is, in the function MCI_CardInit(). The output debug information
is:
MCI_INIT ok
timeout CMD8-> SD-Card<Version 2.0 or MMC
MCI_Send_ACMD failed-> MMC, invalid power-range or no card
unknown card
I have tried some solutions proposed in this and another forums, like
disabling the MAM and/or reducing the clock speed. However the problem
is the same every time.
The demo is tested with a LPC2368 controller. Is there some important
change that I should take into account between the LPC2368 and the
LPC2388? I have not found it in the user's guide, but maybe I just
missed it.
If anyone has some kind of experience with this demo, any help would be
really appreciated.
Thanks in advance!
PD: I will try a different SD card too, even though the one I have works
fine under Windows...
von Martin T. (mthomas) (Moderator)
Rate this post
useful
not useful
Baltasar Reig wrote:
> Hi all,
> card:
> is:
> MCI_INIT ok
> unknown card
> missed it.
> really appreciated.
> Thanks in advance!
The example-project from my page is rather experimental. It's basically
a combination of NXP's MCI-driver and ChaN's fat-code. ChaN's new
example-package now includes a LPC MCI driver too so give it a try. You
may also try the MCI example from NXP's example-package for LPC23xx/24xx
first to verify that the hardware works correctly. The NXP-code is
prepared for RealView but the Keil MDK-ARM evaluation-version should do
for tests.
von Gregory S. (Company: SKF) (gsmith)
Rate this post
useful
not useful
I had the same situation described by Baltasar Reig except I'm using a
Kiel MCB2387 (Version 4.0) development card.
The solution was to change the definition of "MCB2300_VERSION_0" mci.h
from zero to one as shown:
/* For the earliest MCB2300 board, set below bit to 1, for the newer
one, set it to zero. */
#define MCB2300_VERSION_0  1
(Thank you to Martin Thomas for the excellent example software).
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
