EmbDev.net
Forum: ARM programming with GCC/GNU tools LPC2148 Pulse width demultiplexer using CAP0.0
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Noel Le Moult (Guest)
Rate this post
useful
not useful
Hello,
I have an Logomatic-v23 board from Sparkfun electronics. I want to use
an ADXL213AE accelerometer.
The ADXL send his PWM output value and i want to capture it using the
CAP0.0 input of the LPC2148. Unfortunately I have tried the following
code and it don't want to acquire the value.
Initialization :
//Enable Interrupts
VPBDIV=1;    // Set PCLK equal to the System Clock
VICIntSelect = ~(UART1_INT | RTC_INT | TIMER0_INT);
VICVectCntl0 = 0x20 | 7;      //Set up the UART1 interrupt
VICVectAddr0 = (unsigned int)ISR_RxData1;
VICVectCntl1 = 0x20 | 13;      //Set up the RTC interrupt
VICVectAddr1 = (unsigned int)ISR_RTC;
VICVectCntl2 = 0x20 | 4;      //Timer 0 Interrupt
VICVectAddr2 = (unsigned int)ISR_Timer0;
//TIMER0 setup
T0TCR = 0x02;       // TIMER0 Disable; reset T0TC & T0PC
T0PR = 0x00000000;  // Reset T0PR
T0CTCR = 0x00;      // Timer Mode: every rising PCLK edge
T0CCR = 0x06;       // Capture on CAPn.0 falling edge and Interrupt on CAPn.0 event
static void ISR_Timer0(void)
    //Interrupt Code Here
    YPacc = T0CR0;     //Get accelerometer captured value
    T0IR = 0xFF;       //Clear the timer interrupt
    T0TCR = 0x01;      // TIMER0 Enable
    VICVectAddr =0;    //Update the VIC priorities
Main code :
rprintf_devopen(putc_serial0); //Init rprintf
rprintf("ADXL2148 Accelerometer Yp raw data :\n\r");
VICIntEnable |= TIMER0_INT;  //Enable Timer0 Interrupts
while( 1 )
    rprintf("T0CR0:%i\n\r",T0TC);
Output on Hyperterminal :
T0CR0:369396
T0CR0:139755
T0CR0:271646
T0CR0:539757
T0CR0:311754
And the value is never the same...
Does anybody could help me to find my problem?
Rate this post
useful
not useful
I have made a mistake in my previous post :
Main code should be :
while( 1 )
    rprintf("T0CR0:%i\n\r",YPacc);
And the result output is now :
T0CR0:4326756
T0CR0:4325926
T0CR0:4324216
T0CR0:4324036
T0CR0:4326626
T0CR0:4324236
It seems working now.
Thanks
Rate this post
useful
not useful
Ok, now it detect falling edge of pwm signal but it always capture the
total period and not the duty cycle of my signal.
I need to capture the duty cycle to have a correct value of my ADXL.
Rate this post
useful
not useful
I have solved my problem. Here is my personal solution to get the duty
cycle of the original pwm incoming signal:
Main code :
while( 1 )
    VICIntEnable |= TIMER0_INT; // Enable Timer0 Interrupts
    delay_ms(20);               // Do some acquisition
    T0TCR = 0x00;               // TIMER0 Disable
    VICIntEnClr |= TIMER0_INT;  // Stop Timer0 Interrupts
    result = T1/((T1+T2)/100);  // Duty cycle calculation in percent
    if( (result > (oldresult+1)) || (result < (oldresult-1)) ) // If detect movement
        i=100;
        rprintf("%d ", result );
Interrupt section :
    if(state)
        T1 = T0CR0;
        state = 0;
    else
        T2 = T0CR0;
        T0CCR = 0x05;   // Capture on CAPn.0 rising edge and Interrupt on CAPn.0 event
        state = 1;
24
It should be working, but adjust the "delay_ms(20);" in the main code
section according to the period of your pwm signal.
von parth k. (er_parth92)
Rate this post
useful
not useful
hello sir,
i am also try to access capture mode in timer0,but can't get the
output..i am try to calculate frequency using this mode.. plz send ur
code so i can get some idea..
thank you....
von Nik (Guest)
Rate this post
useful
not useful
I can print anything with
rprintf("T0CR0:%i\n\r",T0TC); !!!
rprintf is not possible for uVision 4 ?
Can you tell me how I can use this software for rotary encoder
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
