EmbDev.net
Forum: Analog Circuits voltage regulation circuit
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Thomas (Guest)
Rate this post
useful
not useful
Hi guys,
I'm truying to understand the circuit attached, used as voltage
regulation for microprocessor. the uP supply is attached in front of the
cap 122.
I think LP3982ILD-ADJ is the LDO which suervises the voltage at the
input of the uP and through its feedback loop is regulates it when it
falls down (correct me if I'm not right).
R121 is used as a shunt to measure the current flowing to the uP.
R123 with the potentiometer AD5245-100K form a voltage divider.
So what is the role of the op amp MCP6001T? I see this kind of config
for the first time. is it a voltage follower? if so why is its + input
connected to its output? How about the cap C287?
Thanks!
von minifloat (Guest)
Rate this post
useful
not useful
R352 and R353 are the only resistors marked with "NM".
I think, that stands for "Never Mind" :D I think they are not assembled.
Now, seriously, the circuit designer put them in to make late
modifications of the circuit possible. Now even a comparator rather than
a opamp can be used and trip level and hysteresis can be defined.
regards, mf
von Thomas (Guest)
Rate this post
useful
not useful
Hi minifloat,
I think it really makes sense that R352 and R353 are not assembled, and
hence the op amp is in voltage follower stage.
Thanks
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
