EmbDev.net
Forum: Analog Circuits op amp driving capacitive load
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Thomas (Guest)
Rate this post
useful
not useful
Hi guys,
I read that when an op amp is driving a capacitive load, its transfer
function is disturbed, a new pole is added into it which reduces the
phase margin. This leads to instability at the output voltage of the op
amp.
Now I'm wondering if this problem occurs only when the input voltage of
the op amp is AC, or also for DC?
I have an op amp (Voltage follower), which has a cap of 10uF in fornt of
it.
Do you think this cap will influence its stability even if the input
voltage is DC, and I need to use a compensation method?
Thx
von Cubus (Guest)
Rate this post
useful
not useful
If you have a stability problem, you will see oscillations at the
output. The type of input voltage doesn't matter. Or your settling
behaviour is bad when applying a step at the input. In the datasheet
there should be a value for maximum capacitive load. The op amp can
handle a greater load than written in the datasheet when putting a
resitor in series to the capacitance. But then the maximum output
current and slew rate are reduced.
You will find opamps whitch can drive unlimited capacitive load, but
then there could be worse values for offset voltage, 1/f-noise etc. You
should compare.
von Ina (Guest)
Rate this post
useful
not useful
Yes, of course. There's always enough noise within the circuit to make
the OPamp finally run into wild oscillations. And do not forget the
voltage step when turning on the supply voltage.
Remember, there are some OPamps which can directly drive such high loads
though.
von Thomas (Guest)
Rate this post
useful
not useful
Thank you for your answer.
I read a lot of technical papers in the net, explaining what happens
when an op amp is driving a cap load. But I'm not sure if this problem
occcurs only when the input is AC, or regardless of the input... So when
we talk about bause diagramm for phase and amplitude, and phase margin
etc... which frequency are we talking about, isn'it the freq of the
inout signal to the op amp?
Thx
von Thomas (Guest)
Rate this post
useful
not useful
I'm using TLV4110 op amp.
I'm using it as voltage follower.
In the data sheet I found the following graph. Could you help me
interpret it?
As far as I know, the bigger the phase margin, the more stable is the
output of the op amp.
On the other side, according to this graph, the stability depends on the
output resistive load too...
von Cubus (Guest)
Rate this post
useful
not useful
In your circuit is always noise and noise is broadband (as Ina said). So
you will never have only a dc input voltage. And  even your supply isn't
clean and constant. It includes noise and ripples from ac input or even
peaks from switching power supply.
von Ina (Guest)
Rate this post
useful
not useful
>interpret it?
It just states, that you shall insert a series resistor of at least 20R,
if you intend to drive large capacitive loads.
Tell us in more detail what you plan to do...
von Cubus (Guest)
Rate this post
useful
not useful
You can read from the diagramm:
Load resistance has a small influence on phase margin too. But the load
capacitance is dominant. For higher values you have to put a resistor in
series (RNull). Have you had a look at the application information at
page 12? There's even given a value. You can try.
von Thomas (Guest)
Rate this post
useful
not useful
Guys,
thank you very much for all your answers.
What I'm intending to do is, to measure the current consumption of a
uprocessor. So I have to take care abbout the voltage regulation of it
too.
So now I assume that my uP (Load) is my resistor R2.
The current consumed by R2 s the same one flowing through R1 (shunt).
Later I will amplify the voltage drop across R1 to know how much current
is flowing.
So The caps C1 and C2 are decoupling caps, needed by the uP.
In my testing board, I used a battery at Vg1. So its voltage is pretty
much stable.
At the output of the op amp, the voltage is also pretty much stable, BUT
the voltage drop across R1 is not stable!!!
Unfortunately I can't use a series resistor of 20 Ohm, as stated in the
data sheet, because imagine when my uP is consuming 100mA, I will have a
voltage drop of 2V across that resistor, and that is too much!
von Thomas (Guest)
Rate this post
useful
not useful
In
http://www.analog.com/library/analogdialogue/archives/38-06/capacitive_loading.html
some compensation methods are proposed.
Let's concentrate about Snubber Network which seems to be a very well
known method, It is said that the values of Cs and Rs are determined.
based on the freq of the signal.
I attached the sweep of the voltage across the shunt resistor in the
feedback loop. The signal is periodic, and has a period of 133kHz.
von Ina (Guest)
Rate this post
useful
not useful
>too.
The approach you follow is highly unsuited. There are way simpler
circuits to accomplish that. Measure the voltage drop across the shunt
resistor by using a "high side current monitor", for instance. Google
for that.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
